[postgis-users] Reasonable Way to Convert MULTIPOINT to POINT?
Martin Davis
mbdavis at VividSolutions.com
Thu Feb 24 11:37:02 PST 2005
Thanks, Dave.
Not sure why you didn't find getGeometryN and getNumGeometries on
Geometry - this was done in JTS 1.6
Of the others, some of them deal with structure specific to a given
Geometry type. I can an argument for having isRing and isClosed at the
top level.
Martin Davis, Senior Technical Architect
Vivid Solutions Inc. www.vividsolutions.com
Suite #1A-2328 Government Street Victoria, B.C. V8T 5G5
Phone: (250) 385 6040 - Local 308 Fax: (250) 385 6046
> -----Original Message-----
> From: dblasby at openplans.org [mailto:dblasby at openplans.org]
> Sent: February 24, 2005 11:16 AM
> To: postgis-devel at postgis.refractions.net
> Cc: postgis-users at postgis.refractions.net
> Subject: Re: [postgis-users] Reasonable Way to Convert
> Martin Davis wrote:
> >Generally, a clear pattern that has emerged from using the
> SFS API is
> >that methods should be supported by ALL Geometry types if at all
> >possible, using reasonable default return values if necessary.
> >PostGIS/GEOS might want to consider providing similar methods.
> Martin,
> When I autogenerated the StaticGeometry class for Spatial DB
> in a Box, these are the functions that it found that are not
> at the "top level":
> static public int getNumGeometries(Geometry arg0)
> GeometryCollection _this = (GeometryCollection) arg0;
> return _this.getNumGeometries();
> static public Geometry getGeometryN(Geometry arg0,int arg1)
> return _this.getGeometryN(arg1);
> static public double getX(Geometry arg0)
> Point _this = (Point) arg0;
> return _this.getX();
> static public double getY(Geometry arg0)
> return _this.getY();
> static public boolean isClosed(Geometry arg0)
> LineString _this = (LineString) arg0;
> return _this.isClosed();
> static public Geometry getPointN(Geometry arg0,int arg1)
> return _this.getPointN(arg1);
> static public Geometry getStartPoint(Geometry arg0)
> return _this.getStartPoint();
> static public Geometry getEndPoint(Geometry arg0)
> return _this.getEndPoint();
> static public boolean isRing(Geometry arg0)
> return _this.isRing();
> static public Geometry getExteriorRing(Geometry arg0)
> Polygon _this = (Polygon) arg0;
> return _this.getExteriorRing();
> static public int getNumInteriorRing(Geometry arg0)
> return _this.getNumInteriorRing();
> static public Geometry getInteriorRingN(Geometry arg0,int arg1)
> return _this.getInteriorRingN(arg1);
> dave
> This mail sent through IMP: https://webmail.limegroup.com/
> postgis-users mailing list postgis-users at postgis.refractions.net
