[postgis-users] problem with AddGeometryCoumns
Kaustav Ghoshal
kghoshal at tamu.edu
Sat Feb 26 22:47:32 PST 2005
I have installed postgis patch on my postgres server.I'm now facing this
problem when I'm trying to use the AddGeometryColumns function.
#create table test_table (grid integer);
CREATE
#select AddGeometryColumn('new_test','test_table','mygeom',33,0,3);
ERROR;function
addgeometrycolumn("unknown","unknown","unknown",integer,integer,integer)
does not exist
HINT: No function matches the given name and argument types.You may need
explicit type casts.
In statement:
Any clues as to why I''m getting this problem?
Greetings,
Kaustav Ghoshal
Graduate Assistant Research
Telecommunications Academy
Texas A&M University
www.kaustav.org
_____________________________________________________________________________________________
"UNIX is basically a simple operating system, but you have to be a genius to understand the simplicity. -Dennis Ritchie"
