[postgis-users] problem with AddGeometryCoumns
strk at refractions.net
Mon Feb 28 00:32:31 PST 2005
On Sun, Feb 27, 2005 at 12:47:32AM -0600, Kaustav Ghoshal wrote:
> I have installed postgis patch on my postgres server.I'm now facing this
> problem when I'm trying to use the AddGeometryColumns function.
> #create table test_table (grid integer);
> CREATE
> #select AddGeometryColumn('new_test','test_table','mygeom',33,0,3);
> ERROR;function
> addgeometrycolumn("unknown","unknown","unknown",integer,integer,integer)
> does not exist
> HINT: No function matches the given name and argument types.You may need
> explicit type casts.
> In statement:
> Any clues as to why I''m getting this problem?
Wrong syntax. See manual:
http://postgis.refractions.net/docs/ch06.html#id2916494
--strk;
> Greetings,
> Kaustav Ghoshal
> Graduate Assistant Research
> Telecommunications Academy
> Texas A&M University
> www.kaustav.org
> _____________________________________________________________________________________________
> "UNIX is basically a simple operating system, but you have to be a genius
> to understand the simplicity. -Dennis Ritchie"
> postgis-users mailing list
