[postgis-users] Intersection problems with complex polygons
Andreas Neumann neumann at karto.baug.ethz.ch
Thu Jan 6 03:47:26 PST 2005
I regularly run into intersection problems when using intersection
between a rectangle (defined as a POLYGON) and a very complex polygon
(MULTIPOLYGON).
After intersection I expect to get back a MULTIPOLYGON, however, it
results in a GEOMETRYCOLLECTION not only containing POLYGON or
MULTIPOLYGON elements, but also LINESTRINGs.
I can't understand why? is there a limit in complexity or a bug in the
GEOS library?
To reproduce my problem I have a SQL query online, containing the two
geometries: http://www.carto.net/neumann/temp/intersection_test.sql.gz -
the first geometry is fairly complex, but a realworld example from the
Yosemite National Park.
I am using the latest GEOS library (2.1.1) and the latest postgis
version (0.9.1).
Any hints would be welcome.
Thanks,
Andreas
