[postgis-users] Intersection problems with complex polygons
TECHER Jean David
davidtecher at yahoo.fr
Fri Jan 7 03:41:06 PST 2005
Hi Andreas
I'm a friend of Bernd :-)
I tried your SQL file in two postgis tables...= One for the mulitpolygon
that I called anmp and the polygon (rectangle) ansp
I viewed the tables with QGIS ...It seems normal that you have a
geoemtrycollection
instead of a polygon as an expected intersection...
For the intersection I do
create table "aninter" (gid serial);
SELECT
AddGeometryColumn('','aninter','the_geom','26911','MULTILINESTRING',2);
INSERT INTO "aninter" (gid,"the_geom") VALUES ('0',
GeometryFromText(
AsText(
Intersection(Boundary(anmp.the_geom),
ansp.the_geom
,26911);
If you make a zoom in the intersection area you have two disjoint polygons
in this intersection ...just see the attached images...
TECHER Jean David
Responsable Informatique 01MAP
e-mail: davidtecher at yahoo.fr
Bureau: 04 67 45 60 27
Portable: 06 85 37 36 75
site perso : http://techer.pascal.free.fr/postgis/
site pro: http://www.01map.com/download/
K-S:"The greatest trick the devil pulled off was convincing people he didn't
exist"
----- Original Message -----
From: "Andreas Neumann" <neumann at karto.baug.ethz.ch>
To: <postgis-users at postgis.refractions.net>
Sent: Thursday, January 06, 2005 12:47 PM
Subject: [postgis-users] Intersection problems with complex polygons
> Hi,
> I regularly run into intersection problems when using intersection
> between a rectangle (defined as a POLYGON) and a very complex polygon
> (MULTIPOLYGON).
> After intersection I expect to get back a MULTIPOLYGON, however, it
> results in a GEOMETRYCOLLECTION not only containing POLYGON or
> MULTIPOLYGON elements, but also LINESTRINGs.
> I can't understand why? is there a limit in complexity or a bug in the
> GEOS library?
> To reproduce my problem I have a SQL query online, containing the two
> geometries: http://www.carto.net/neumann/temp/intersection_test.sql.gz -
> the first geometry is fairly complex, but a realworld example from the
> Yosemite National Park.
> I am using the latest GEOS library (2.1.1) and the latest postgis
> version (0.9.1).
> Any hints would be welcome.
> Thanks,
> Andreas
> postgis-users mailing list
Type: application/octet-stream
Desc: not available
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20050107/19400895/attachment.obj>
