AW: [postgis-users] UPDATE_GEOMETRY_STATS() usage ??
Düster Horst
Horst.Duester at bd.so.ch
Tue Jan 25 07:19:57 PST 2005
correct usage is
select update_geometry_stats('xxdrain','the_geom');
Dr. Horst Düster
GIS-Koordinator /Amtschef Stv.
Kanton Solothurn
Amt für Geoinformation
Abteilung SO!GIS Koordination
Werkhofstr. 65
CH-4509 Solothurn
Tel.: ++41 (0)32 627 25 32
Fax: ++41 (0)32 627 22 14
horst.duester at bd.so.ch
www.sogis.so.ch
-----Ursprüngliche Nachricht-----
Von: David.Jacques at CCRS.NRCan.gc.ca
[mailto:David.Jacques at CCRS.NRCan.gc.ca]
Gesendet am: Dienstag, 25. Januar 2005 16:18
An: postgis-users at postgis.refractions.net
Betreff: [postgis-users] UPDATE_GEOMETRY_STATS() usage ??
As per section 3.4 of the FAQ for speeding up queries &
Display of large spatial tables I have created indexes on them using
CREATE INDEX [indexname] ON [tablename] USING GIS ( [geometrycolumn]);
However running this: SELECT UPDATE_GEOMETRY_STATS(xxdrain,the_geom); gives
an error telling me that column "xxdrain" doesn't exist.
I've looked in the function list and this function is overloaded,
1 form with 2 varchar params and one with only 1 (column name expected).
However running what this other form expects also gives an error.
Any examples of a successful run of this to ensure my spatial indexes and
Statistics are up to date would be great.
postgis-users mailing list
http://postgis.refractions.net/mailman/listinfo/postgis-users
