AW: [postgis-users] MapServer and PostGIS 1 RC1 and RC2
Düster Horst Horst.Duester at bd.so.ch
Thu Jan 27 05:11:58 PST 2005
> What OS ? What postgresql version ?
RedHat 7.2 i586
Postgresql 8.0.0
gcc version 2.96 20000731 (Red Hat Linux 7.2 2.96-124.7.2)
> Any warning at build time ?
No warnings except of defined but unused variables during build of postgis.
I dropped the whole postgresql/ postgis installation and DB-Clusetr
inclusive all sources.
Then I rebuild postgres with the following ./configure options:
LDFLAGS=-lstdc++ ./configure \
  --prefix=/usr/local/pgsql/current \
  --enable-multibyte
OK. Postgresql was build and installed without any problems and works.
Next step build postgis with the use of GEOS and without GEOS.
In both cases postgresql crashes. I'm stumped!
Dr. Horst Düster
GIS-Koordinator /Amtschef Stv.
Kanton Solothurn
Amt für Geoinformation
Abteilung SO!GIS Koordination
Werkhofstr. 65
CH-4509 Solothurn
Tel.: ++41 (0)32 627 25 32
Fax: ++41 (0)32 627 22 14
horst.duester at bd.so.ch
www.sogis.so.ch
-----Ursprüngliche Nachricht-----
Von: strk at refractions.net [mailto:strk at refractions.net]
Gesendet am: Donnerstag, 27. Januar 2005 12:18
An: Düster Horst
Cc: 'postgis-users at postgis.refractions.net'
Betreff: Re: [postgis-users] MapServer and PostGIS 1 RC1 and RC2
I don't get the same result:
  [lo:asbinary_crash]$ cat test.sql
  select postgis_full_version();
  create table test_pnt (id serial);
  select addgeometrycolumn('public','test_pnt','wkb_geometry',-1,'POINT',2);
  insert into test_pnt (wkb_geometry) values (Geometryfromtext('POINT(610000
230000)',-1));
  SELECT asbinary(force_collection(force_2d(wkb_geometry)),'NDR') FROM
test_pnt;
  SELECT summary(wkb_geometry) from test_pnt;
  [lo:asbinary_crash]$ psql -etf test.sql test
   POSTGIS="1.0.0RC2" GEOS="2.1.1" PROJ="Rel. 4.4.8, 3 May 2004" USE_STATS
DBPROC="0.1.0" RELPROC="0.1.0"
  psql:test.sql:2: NOTICE:  CREATE TABLE will create implicit sequence
"test_pnt_id_seq" for serial column "test_pnt.id"
  CREATE TABLE
   public.test_pnt.wkb_geometry SRID:-1 TYPE:POINT DIMS:2
   geometry_column fixed:0
230000)',-1));
  INSERT 11512442 1
test_pnt;
\001\007\000\000\000\001\000\000\000\001\001\000\000\000\000\000\000\000\240
\235"A\000\000\000\000\200\023\014A
  Point[]
--strk;
On Thu, Jan 27, 2005 at 12:02:18PM +0100, Düster Horst wrote:
> > You mean 'geometry', right ?
> Of course I meant type of geometry.
> > Also, did you dump/reload or manually upgrade postgis ?
> I created a new blank PostgreSQL-8.0.0 DB with:
> # createdb test
> # createlang plpgsql test
> # psql -d test -f lwpostgis.sql
> > Can you reproduce the bug on a single POINT geometry ?
> Here the steps that produces a single POINT geometry and leads to the
server
> crash:
> # create table test_pnt (id serial);
> CREATE TABLE
> # select
>                                 addgeometrycolumn
> (1 row)
> # insert into test_pnt (wkb_geometry) values
> 230000)',-1));
> INSERT 16691569 1
> # SELECT asbinary(force_collection(force_2d(wkb_geometry)),'NDR') FROM
> test_pnt;
> server closed the connection unexpectedly
>       This probably means the server terminated abnormally
>       before or while processing the request.
> > If you can show me summary(that_point)
> # select summary(wkb_geometry) from test_pnt;
>   summary
> Point[]
> (1 row)
> Dr. Horst Düster
> Kanton Solothurn
> Werkhofstr. 65
> CH-4509 Solothurn
> www.sogis.so.ch
> Gesendet am: Donnerstag, 27. Januar 2005 09:44
> An: Düster Horst
> On Thu, Jan 27, 2005 at 09:39:03AM +0100, Düster Horst wrote:
> > strk
> > > What type is  wkb_geometry ?
> > wkb_geometry is type of POINT
> > > Did you try manually issuing the query ?
> > >    FROM avt_asit_unfall;
> > PostgreSQL responsed with
> If you can show me summary(that_point).
> --strk;
> > Dr. Horst Düster
> > Kanton Solothurn
> > Werkhofstr. 65
> > CH-4509 Solothurn
> > www.sogis.so.ch
> > Gesendet am: Donnerstag, 27. Januar 2005 09:29
> > An: Düster Horst
> > On Thu, Jan 27, 2005 at 09:03:18AM +0100, Düster Horst wrote:
> > > Now my third attempt to get an answer of my posted question.
> > > Since a time I'm playing with MapServer 4.4.1 and PostGIS 1RC1 and RC2
> > since
> > > today with semi
> > > success. I'm able to create maps with polygon and line layers from
> > PostGIS,
> > > but PostGIS/Postgres crashes with the error message (see below) when I
> > > use a point layer. This crash appears exclusively with all my point
> layers
> > > which work fine with MS 4.4.1 and Postgis 0.8. Do there exist any
> > > restrictions of using PostGIS 1 with MapServer 4.4.1??
> > > I would be appreciate about any hint.
> > > With best regards
> > > Horst
> > > Mapfile snippet:
> > > LAYER
> > >   CONNECTIONTYPE POSTGIS
> > >   CONNECTION 'dbname=xx host=xx user=xx port=5432'
> > >   DATA "wkb_geometry from asit2 USING UNIQUE ogc_fid USING SRID=-1"
> > >   TYPE POINT
> > --strk;
> > > Error message:
> > > > msDrawMap(): Image handling error. Failed to draw layer named
'asit2'.
> > > > msPOSTGISLayerWhichShapes(): Query error. Error executing POSTGIS
SQL
> > > > statement (in FETCH ALL): DECLARE mycursor BINARY CURSOR FOR SELECT
ANZ_TOT::text,asbinary(force_collection(force_2d(wkb_geometry)),'NDR'),ogc_f
> > > > id::text from avt_asit_unfall WHERE wkb_geometry &&
> > > setSRID('BOX3D(588837.5
> > > > 213700,648462.5 261400)'::BOX3D, -1 ) -server closed the connection
> > > > unexpectedly This probably means the server terminated abnormally
> before
> > > or
> > > > while processing the request. Error with POSTGIS data variable. You
> > > > specified ''.
> > > > Standard ways of specifiying are :
> > > > (1) 'geometry_column from geometry_table'
> > > > (2) 'geometry_column from (<sub query>) as foo using unique <column
> > name>
> > > > using SRID=<srid#>'
> > > > Make sure you put in the 'using unique <column name>' and 'using
> SRID=#'
> > > > clauses in.
> > > > For more help, please see
> > http://postgis.refractions.net/documentation.php
> > > > Mappostgis.c - version of Jan 23/2004.
> > > Dr. Horst Düster
> > > Kanton Solothurn
> > > Werkhofstr. 65
> > > CH-4509 Solothurn
> > > www.sogis.so.ch
> > > _______________________________________________
> > > postgis-users mailing list
> > > http://postgis.refractions.net/mailman/listinfo/postgis-users
