[postgis-users] 'server closed the connection unexpectedly' problem
Ralph Mason ralph.mason at telogis.com
Fri Jan 28 03:27:08 PST 2005
I have a single table with 'only' 3,000,000 rows in it ( all
linestrings) it about 20gb.  No problems at all :-)
Ralph
>On Thu, Jan 27, 2005 at 12:48:37PM -0800, Ionut Iordache wrote:
>>Hello,
>>I recently loaded large quantities of point data (close to half a
>>billion records) into postgresql-7.4.6 with postgis-cvs version 1.0.0
>>(as of 2005/01/13) and although the geometry creation and table
>>loading went smoothly, I can't use any of the postgis functions on the
>>POINT geometry columns!
>>For example, when I try to run something like SELECT X(point_geom)
>>FROM raw_data LIMIT 10; , I get the following error message:
>>        This probably means the server terminated abnormally
>>        before or while processing the request.
>>The connection to the server was lost. Attempting reset: Failed.
>>The same thing happens when I try to execute the Distance function for
>>example. But if I do a SELECT AsText(point_geom), the records show up
>>just fine...
>>The log is not showing anything suspicious, except reporting that the
>>child process was terminated by signal 10.
>>I compiled postgres with LDFLAGS = -lstdc++ -lgcc and enabled geos and
>>proj4 in postgis.
>>Thanks for you assistance!
>MM.. this is the second weird bug report related to points, but I
>can't reproduce this as well (PGGIS-1.0.0RC2 / PGSQL-7.4.3).
>Can you try RC2, creating a *new* db ?
>Can reproduce the bug on a single record ?
>What OS are you using ? Which compiler used to build postgis ?
>--strk;
>>Best regards,
>>Dorel Ionut Iordache - <ionut at eps.berkeley.edu>
>>UC Berkeley - Earth & Planetary Science Dept.
>>_______________________________________________
>>postgis-users mailing list
>>postgis-users at postgis.refractions.net
>>http://postgis.refractions.net/mailman/listinfo/postgis-users
