[postgis-users] update_geometry_stats() on PostGIS 0.8.1
strk at refractions.net
Fri Jan 28 09:25:06 PST 2005
On Fri, Jan 28, 2005 at 06:09:31PM +0100, Markus Schaber wrote:
> Hello,
> On some of our PostGIS 0.8.1 databases, update_geometry_stats() fails:
> logigis=# select update_geometry_stats();
> ERROR: more than one row returned by a subquery used as an expression
> CONTEXT: PL/pgSQL function "update_geometry_stats" line 2 at execute
> statement
> I think this could be caused by some problems wr/t schemas (we have
> several equally named tables in different schemas).
> I did not yet look at the code, but do you think it is possible to fix
> this function (or replace it with a fixed function from a never PostGIS)?
> I would like to avoid updating the whole PostGIS.
It is surely updatable.
Get the one you have in 1.0.0.
Of course you'll have to build lwpostgis.sql with USE_VERSION=<your_pg_ver>.
Pre 800 stats computation and use is not changed.
--strk;
> Thanks,
> Markus
> markus schaber | dipl. informatiker
> logi-track ag | rennweg 14-16 | ch 8001 zürich
> phone +41-43-888 62 52 | fax +41-43-888 62 53
> mailto:schabios at logi-track.com | www.logi-track.com
> postgis-users mailing list
