[postgis-users] Crash when creating index on ( int, geom )
Robin Chauhan
robin.chauhan at gmail.com
Sat Jan 29 14:07:09 PST 2005
Hello Mark,
I'm attempting to generate a backtrace as you suggested. I was able
to attach gdb to the postmaster process, but I dont know how to make
gdb break when the failure occurs -- I dont know where I would set a
breakpoint or watchpoint to be able to catch this event. When I Can
you give me a hint or pointer? I think no core file is being
generated from the crash, because the postmaster and psql processes
both continue to run.
Should I be debugging the psql process and not the postmaster process?
I tried causing this crashing both while attached to psql and
postmaster but again I dont know how to cause gdb to stop at a useful
place to see the backtrace of the crash, and not just of the normal
running of postmaster. This is noob territory for me, so please
excuse the ignorant questions.
Many thanks,
-Robin
On Fri, 21 Jan 2005 17:35:16 -0000, Mark Cave-Ayland
<m.cave-ayland at webbased.co.uk> wrote:
> Hi Robin,
> If you're ok working with source code then I would also compile and use the
> latest 7.3 release which is currently 7.3.8 with --enable-debug. Create a
> fresh database cluster with initdb, load your data, and try again. If it
> still fails then it's fairly certain to be a bug, perhaps something subtle
> in the PostGIS indexing code or with btree_gist. The backtrace should give
> us more information on this.
> Kind regards,
> Mark.
> WebBased Ltd
> South West Technology Centre
> Tamar Science Park
> Plymouth
> PL6 8BT
> T: +44 (0)1752 791021
> F: +44 (0)1752 791023
> W: http://www.webbased.co.uk
> > -----Original Message-----
> > From: postgis-users-bounces at postgis.refractions.net
> > [mailto:postgis-users-bounces at postgis.refractions.net] On
> > Behalf Of Robin Chauhan
> > Sent: 21 January 2005 17:23
> > To: Mark Cave-Ayland; PostGIS Users Discussion
> > Subject: Re: [postgis-users] Crash when creating index on (
> > int, geom )
> > Mark,
> > I tried duplicating the table and got the same reuslt with
> > the new table. Thanks for your instructions on getting a
> > backtrace using gdb.
> > Before I tried that, I also attempted to install a more
> > updated version of btree_gist from here:
> > http://www.sai.msu.su/~megera/postgres/gist/btree_gist/btree_g
> > ist-7.4.tar.gz
> > ...which in the README says it can work on postgres 7.3 and
> > up (I have 7.3.2). Unfortunately I was not able compile it:
> > btree_common.c: In function `gbtreekey_in':
> > btree_common.c:18: warning: implicit declaration of function `ereport'
> > btree_common.c:19: warning: implicit declaration of function `errcode'
> > btree_common.c:19: `ERRCODE_FEATURE_NOT_SUPPORTED' undeclared
> > (first use in this function)
> > btree_common.c:19: (Each undeclared identifier is reported only once
> > btree_common.c:19: for each function it appears in.)
> > btree_common.c:20: warning: implicit declaration of function `errmsg'
> > btree_common.c: In function `gbtreekey_out':
> > btree_common.c:29: `ERRCODE_FEATURE_NOT_SUPPORTED' undeclared
> > make: *** [btree_common.o] Error 1
> > For now I am using the separate indexes as suggested by
> > Markus which is working very well, but I will try to track
> > this down further.
> > -Robin
