[postgis-users] Differences between postgis on Windows and Unix?
strk at refractions.net strk at refractions.net
Sun Jan 30 01:28:17 PST 2005
On Fri, Jan 28, 2005 at 07:48:33PM +0100, Benjamin Thelen wrote:
> strk at refractions.net wrote:
> >The missing columns in geometry_columns are due to postgresql 8.0
> >making them unneeded (it supports used-defined statistical analisys).
> Hi,
> Ok, not surprising that this hasn't happend accidently. :-) So this is
> not a Windows/Unix thing, I'll maybe face the same while upgrading my
> Unix machines to pg-8. :-(.
> >You should first install postgres, then postgis, then restore the
> >dump (and this last step whould give you the warnings/errors).
> Well, I'm not sure what's going on. After removing the last three
> values (instead of adding the missing columns) of the INSERTs from
> geometry_columns within the "Unix/PG7-dump", the dump went through, of
> course complaining about existing functions, etc. and I was able to
> see data from WinPG-8 for the first time! Cool, although I further
> prefer Unix.
> But what would be your migration guide line to the user? Editing the
> dump? Adding the missing columns?
> The first could be problematic in case of a dump of a big size, e.g. 3
> GByte! Probably the second way should do it, too, then without the
> need of opening a huge dump.
I think adding the missing columns is a good idea.
Another way is using the utils/postgis_restore.pl script, but
would be slower as it will open and edit the dump.
--strk;
> I succeeded by using Win-postgis 0.9.1, not the 0.8.x dilivered with
> WinPG-8. Don't know if that's a matter.
> Thanks,
> Ben
> >--strk;
> >On Thu, Jan 27, 2005 at 10:19:31PM +0100, Benjamin Thelen wrote:
> >>Hi,
> >>I installed postgresql-8.0-release on Windows, selected postgis, too and
> >>tried to import (first COPY, then INSERT) data, which I had dumped from
> >>postgresql-7.3.8/postgis-0.8.1. Usually, importing data caused messages
> >>like "function already existing", but nevertheless it worked. Not so with
> >>the windows postgres/postgis. Nothing was imported, even no table created.
> >>I found out, that three columns are missing in "geometry_columns":
> >>attrelid oid
> >>varattnum int4
> >>stats histogram2d
> >>I added the missing columns manually, manipulated the dump manually, but
> >>without success importing the data cleanly. I wouldn't really mind, but I
> >>can't display the postgis-data with mapserver.
> >>I then downloaded Windows postgis 0.9.1, reinstalled postgres without
> >>postgis, but it the same.
> >>I searched google and the list, but I don't get an idea.
> >>Can somebody help, give me a hint?
> >>Thanks,
> >>Benjamin
> >>_______________________________________________
> >>postgis-users mailing list
> >>postgis-users at postgis.refractions.net
> >>http://postgis.refractions.net/mailman/listinfo/postgis-users
