[postgis-users] Crash when creating index on ( int, geom )
Mark Cave-Ayland
m.cave-ayland at webbased.co.uk
Sun Jan 30 23:36:23 PST 2005
Hi Robin,
It sounds as if you've got quite close :) As you rightly point out, you need
to attach gdb to the forked process on the server as opposed to the PID of
the postmaster. This is the procedure I use when debugging crashes:
Client
psql -d mydb
mydb=# select pg_backend_pid();
(This will give you the PID of the backend)
Server
gdb
(gdb) attach <pid of backend>
(gdb) cont
Client
mydb=# select my_crashing_function();
Server
(gdb) bt
Note that even compiling without --enable-debug should still be enough to
give you the symbols of the functions. Another option may be to try manually
loading the symbols from the postgres executable using the symbol-file
command. This should be done just before the attach command, e.g.
(gdb) symbol-file /path/to/postgres
Kind regards,
Mark.
WebBased Ltd
South West Technology Centre
Tamar Science Park
Plymouth
PL6 8BT
T: +44 (0)1752 791021
F: +44 (0)1752 791023
W: http://www.webbased.co.uk
> -----Original Message-----
> From: postgis-users-bounces at postgis.refractions.net
> [mailto:postgis-users-bounces at postgis.refractions.net] On
> Behalf Of Robin Chauhan
> Sent: 30 January 2005 18:13
> To: Mark Cave-Ayland
> Cc: PostGIS Users Discussion
> Subject: Re: [postgis-users] Crash when creating index on (
> int, geom )
> I eventually discovered that I was meant to attach gdb to the
> particular postgres instance, not the postmaster. However
> I'm not sure the bt output is very useful. Would I need to
> rebuild postgres with debug enabled to get anything more meaningful?
> (gdb) attach 30603
> Attaching to Pid 30603
> 0x2ac26b22 in ?? ()
> (gdb)
> (gdb) cont
> Continuing.
> Program received signal SIGSEGV, Segmentation fault.
> 0x8082f0f in ?? ()
> (gdb) bt
> #0 0x8082f0f in ?? ()
> #1 0x815fe3f in ?? ()
> #2 0x2ae553af in ?? ()
> #3 0x81604b5 in ?? ()
> #4 0x8071b7c in ?? ()
> #5 0x807112f in ?? ()
> #6 0x806e574 in ?? ()
> #7 0x806e4c6 in ?? ()
> #8 0x806e3d6 in ?? ()
> #9 0x8160d7c in ?? ()
> #10 0x807b4d1 in ?? ()
> #11 0x80cfe5d in ?? ()
> #12 0x80cc6fc in ?? ()
> #13 0x80cc2c3 in ?? ()
> #14 0x80cb82d in ?? ()
> #15 0x81175b2 in ?? ()
> #16 0x8115c67 in ?? ()
> #17 0x8116c09 in ?? ()
> #18 0x80ff013 in ?? ()
> #19 0x80fe8b3 in ?? ()
> #20 0x80fdb7d in ?? ()
> #21 0x80fd750 in ?? ()
> #22 0x80dd93e in ?? ()
> #23 0x2ab8c9cb in ?? ()
> (gdb)
> On Sat, 29 Jan 2005 17:07:09 -0500, Robin Chauhan
> <robin.chauhan at gmail.com> wrote:
> > Hello Mark,
> > I'm attempting to generate a backtrace as you suggested. I
> was able
> > to attach gdb to the postmaster process, but I dont know
> how to make
> > gdb break when the failure occurs -- I dont know where I
> would set a
> > breakpoint or watchpoint to be able to catch this event.
> When I Can
> > you give me a hint or pointer? I think no core file is being
> > generated from the crash, because the postmaster and psql processes
> > both continue to run.
> > Should I be debugging the psql process and not the
> postmaster process?
> > I tried causing this crashing both while attached to psql and
> > postmaster but again I dont know how to cause gdb to stop
> at a useful
> > place to see the backtrace of the crash, and not just of the normal
> > running of postmaster. This is noob territory for me, so please
> > excuse the ignorant questions.
> > Many thanks,
> > -Robin
