[postgis-users] number format weirdness from dbfopen.c?
gold
dev at samizdatdigital.org
Sun Jul 3 09:49:30 PDT 2005
are there any open issues or common experience with some number values
being read incorrectly from a .dbf file? i noticed this in using
shp2pgsql, and i'm still trying to track it down.
basically, shp2pgsql was generating insert statements inserting values
like '1234.' (notice the trailing '.'). i've put extra debugging in my
local copy of dbfopen and shp2pgsql, and indeed this is the ascii data
coming from the .dbf file itself (after the whitespace trimming). the
fields in question are marked as type 'N', as returned by
DBFGetNativeFieldType.
i'm gonna write a separate low level version (bypassing dbfopen) to just
extract this field and at least get some degree of confirmation as to
whether this is really how the data is, or whether there's something
amiss in dbfopen (unlikely, but i should check).
i'm also going to get in touch with the data providers to see if this is
something they're aware of. is it possible that in the .dbf world
'1234.' is valid numeric syntax?
jon
