[postgis-users] number format weirdness from dbfopen.c?
Stephen Woodbridge
woodbri at swoodbridge.com
Sun Jul 3 09:54:33 PDT 2005
gold wrote:
> are there any open issues or common experience with some number values
> being read incorrectly from a .dbf file? i noticed this in using
> shp2pgsql, and i'm still trying to track it down.
> basically, shp2pgsql was generating insert statements inserting values
> like '1234.' (notice the trailing '.'). i've put extra debugging in my
> local copy of dbfopen and shp2pgsql, and indeed this is the ascii data
> coming from the .dbf file itself (after the whitespace trimming). the
> fields in question are marked as type 'N', as returned by
> DBFGetNativeFieldType.
> i'm gonna write a separate low level version (bypassing dbfopen) to just
> extract this field and at least get some degree of confirmation as to
> whether this is really how the data is, or whether there's something
> amiss in dbfopen (unlikely, but i should check).
> i'm also going to get in touch with the data providers to see if this is
> something they're aware of. is it possible that in the .dbf world
> '1234.' is valid numeric syntax?
Jon,
The shapelib API document says DBF type code 'N' (Numeric, with or
without decimal).
-Steve W.
