[geos-devel] Re: [postgis-users] Error compiling PostGIS + GEOS
Chip Masters
chip_masters at yahoo.com
Wed Jul 6 12:31:21 PDT 2005
GEOS and PostGIS users,
Since I last posted on this thread about my
installation problems, we upgraded our OS to SuSE 9.2
with the 2.6.8-24.16-default kernel. Also, for the
record, we are using gcc version 3.3.4.
Now after installing PostgreSQL 8.0.3, PostGIS 1.0.1
with the flags set in Makefile.config to include PROJ
and GEOS:
> USE_PROJ ?= 1
> PROJ_DIR ?= /usr/local
> USE_GEOS ?= 1
> GEOS_DIR ?= /usr/local
I try to do
> psql -f lwpostgis.sql -d test
from within the postgis-1.0.1 install directory, and I
get this error:
> psql:lwpostgis.sql:36: ERROR: could not load
library > "/scratch/pgsql/lib/liblwgeom.so.1.0":
libgeos.so.2: > cannot open shared object file: No
such file or
> directory
I notice that the liblwgeom.so.1.0 library doesn't
link to the geos or proj libraries:
> postgres at cyc11:~/lib> ldd liblwgeom.so.1.0
> linux-gate.so.1 => (0xffffe000)
> libstdc++.so.5 => /usr/lib/libstdc++.so.5
> (0x40067000)
> libgeos.so.2 => not found
> libproj.so.0 => not found
> libgcc_s.so.1 => /lib/libgcc_s.so.1
> (0x40125000)
> libc.so.6 => /lib/tls/libc.so.6 (0x4012d000)
> libm.so.6 => /lib/tls/libm.so.6 (0x40243000)
> /lib/ld-linux.so.2 => /lib/ld-linux.so.2
> (0x80000000)
even though both libgeos.so.2 and libproj.so.0 are
present in /usr/local/lib.
Can anyone help here? Should the PROJ_DIR and GEOS_DIR
variables in the Makefile.config point to
/usr/local/lib instead of /usr/local?
Thanks,
Chip Masters
--- strk at refractions.net wrote:
> On Tue, Jun 21, 2005 at 03:45:51PM -0700, Chip
> Masters wrote:
> > We did compile GEOS (PostgreSQL and PostGIS as
> well)
> > with GCC 3.4.3.
> Are you sure you don't have old c++ headers around ?
> Can you seek that __builtin_new symbol in system
> headers ?
> --strk;
> postgis-users mailing list
http://postgis.refractions.net/mailman/listinfo/postgis-users
____________________________________________________
Sell on Yahoo! Auctions no fees. Bid on great items.
http://auctions.yahoo.com/
