[postgis-users] PostGIS schemas
Gustavo Henrique Sberze Ribas
gribas at cpqd.com.br
Tue Jul 12 04:10:48 PDT 2005
Hello,
> a. Why is it that after logging on as a particular user/schema owner, I
> can list ALL of the tables, regardless of the schema they belong to? (I
> suspect that since both products work the same that it is a PostGIS /
> PostGreSQL anomaly, not problems with uDig or Quantum GIS?)
Because both programs list all the entries in the geometry_columns table.
Since geometry_columns is in the Public schema, any user has access to
it (usually).
The geometry_columns table acts as a reference to all spatial tables
in your database. An entry is automatically created when you invoke
addGeometryColumn(...) on a table.
Gustavo
> I can only answer your second question:
> > b. How I can create multiple PostGIS connections, each from a
> > different schema/?/
> You can set the search_path to whatever schema(s) you want in the
> connection string:
> CONNECTION "dbname=mydb options='-c search_path=myschema,public'"
> The "public" schema has to be in the search_path, else PostGIS won't
> find its geometry_columns and spatial_ref_sys tables.
