[postgis-users] Help, What am I missing gist_geometry_ops column???
Mark Cave-Ayland m.cave-ayland at webbased.co.uk
Tue Jul 19 08:34:58 PDT 2005
> -----Original Message-----
> From: postgis-users-bounces at postgis.refractions.net
> [mailto:postgis-users-bounces at postgis.refractions.net] On
> Behalf Of Stephen Woodbridge
> Sent: 19 July 2005 16:31
> To: PostGIS Users Discussion
> Subject: [postgis-users] Help, What am I missing
> Hi all,
> I'm try to create a postGIS table in a schema and it is
> mostly working,
> but I am having trouble building an index.
> 1. loaded the postGIS extensions and spatial references into schema
> "public" like normal
> 2. created tables and loaded the data in my own schema like:
> ### Drop the table if it exists
> echo "DROP TABLE swoodbridge.rgeo;" | psql -U pgsql -h localhost dev
> ### Define the table so we can load data into it
> FILE=`ls e*/*.shp | head -1`
> shp2pgsql -p -s 4326 -g the_geom $FILE swoodbridge.rgeo |
> psql -U pgsql
> -h localhost dev
> ### Append each of the files to the table
> for FILE in e*/*.shp ; do
>      shp2pgsql -a -s 4326 -g the_geom $FILE swoodbridge.rgeo
> | psql -U
> done
> The above all works and looks ok.
> 3. tried to create an index:
> dev=# create index rgeo_gidx on swoodbridge.rgeo using gist
> (the_geom,
> gist_geometry_ops);
> ERROR:  column "gist_geometry_ops" does not exist
> I seem to have missed a critical step, but not sure what.
> Any help would be appreciated.
> -Steve
Hi Steve,
I don't think there should be a comma after the column name - try just
simply:
create index rgeo_gidx on swoodbridge.rgeo using gist (the_geom
gist_geometry_ops);
Kind regards,
Mark.
WebBased Ltd
17 Research Way
Tamar Science Park
Plymouth
PL6 8BT
T: +44 (0)1752 797131
F: +44 (0)1752 791023
W: http://www.webbased.co.uk
