[postgis-users] Postgis Simplify
Christo Du Preez
christo at mecola.com
Tue Jul 26 12:27:44 PDT 2005
I used another installation, this time Linux and did the same test.
This time the result was different on rows 3, 6 and 9. More what I was
expecting in the first place.
1: 25290 : 39
2: 23978 : 43
3: 25999 : 41
4: 4996 : 19
5: 24679 : 31
6: 50819 : 25
7: 31899 : 71
8: 63292 : 45
9: 84990 : 59
10: 12878 : 15
11: 1047 : 8
In previous posts I also mentioned the exponential format that my result
was, doing a Simplify(). I have also noticed that the exponential format
was only on rows 3, 6 and 9. The rest of the results was lat/long wgs84,
as expected.
Can someone please shed some light on this?
strk at refractions.net wrote:
>Christo, nothing weird about it, not every shape contains redundand
>informations.
>Consider a straight line defined by millions of intermediate points.
>A simplify(geom, 0) would make it a 2 point line.
>If you google for Douglas-Peuker you'll get
>lots of informations about the algorithm.
>--strk;
>On Mon, Jul 25, 2005 at 10:20:23PM +0200, Christo Du Preez wrote:
>>This is really weird.
>>select npoints(the_geom), npoints(Simplify(the_geom, .1))
>>from province
>>results to:
>>1: 25290, 39
>>2: 23978, 43
>>3: 25999, 22046
>>4: 4996, 19
>>5: 24679, 31
>>6: 50819, 43120
>>7: 31899, 71
>>8: 63292, 45
>>9: 84990, 70460
>>10: 12878, 15
>>11: 1047, 8
>>The data is lat/long wgs84, what could cause rows 3,6 and 9 not to
>>simplify as much as the others?
>>_______________________________________________
>>postgis-users mailing list
>>postgis-users at postgis.refractions.net
>>http://postgis.refractions.net/mailman/listinfo/postgis-users
Kind Regards,
Christo Du Preez
Senior Software Engineer
Mecola IT
http://www.mecola.com
+27 [0]82 4255 895
