[postgis-users] Postgis Simplify
strk at refractions.net
Tue Jul 26 18:08:18 PDT 2005
Christo, please be specific about your problem.
Do you have a test case showing unexpected behaviour for
the simplify() function ?
Would you include postgis version information in the
file ?
--strk;
On Tue, Jul 26, 2005 at 09:27:44PM +0200, Christo Du Preez wrote:
> I used another installation, this time Linux and did the same test.
> This time the result was different on rows 3, 6 and 9. More what I was
> expecting in the first place.
> 1: 25290 : 39
> 2: 23978 : 43
> 3: 25999 : 41
> 4: 4996 : 19
> 5: 24679 : 31
> 6: 50819 : 25
> 7: 31899 : 71
> 8: 63292 : 45
> 9: 84990 : 59
> 10: 12878 : 15
> 11: 1047 : 8
> In previous posts I also mentioned the exponential format that my result
> was, doing a Simplify(). I have also noticed that the exponential format
> was only on rows 3, 6 and 9. The rest of the results was lat/long wgs84,
> as expected.
> Can someone please shed some light on this?
> strk at refractions.net wrote:
> >Christo, nothing weird about it, not every shape contains redundand
> >informations.
> >Consider a straight line defined by millions of intermediate points.
> >A simplify(geom, 0) would make it a 2 point line.
> >If you google for Douglas-Peuker you'll get
> >lots of informations about the algorithm.
> >--strk;
> >On Mon, Jul 25, 2005 at 10:20:23PM +0200, Christo Du Preez wrote:
> >>This is really weird.
> >>select npoints(the_geom), npoints(Simplify(the_geom, .1))
> >>from province
> >>results to:
> >>1: 25290, 39
> >>2: 23978, 43
> >>3: 25999, 22046
> >>4: 4996, 19
> >>5: 24679, 31
> >>6: 50819, 43120
> >>7: 31899, 71
> >>8: 63292, 45
> >>9: 84990, 70460
> >>10: 12878, 15
> >>11: 1047, 8
> >>The data is lat/long wgs84, what could cause rows 3,6 and 9 not to
> >>simplify as much as the others?
> >>_______________________________________________
> >>postgis-users mailing list
> >>postgis-users at postgis.refractions.net
> >>http://postgis.refractions.net/mailman/listinfo/postgis-users
> Kind Regards,
> Christo Du Preez
> Senior Software Engineer
> Mecola IT
> http://www.mecola.com
> +27 [0]82 4255 895
