[postgis-users] Gentoo Emerge
Christo Du Preez christo at mecola.com
Tue Jul 26 14:54:15 PDT 2005
I Installed Postgis on Gentoo using:
USE="geos proj doc" ACCEPT_KEYWORDS="~x86" emerge postgis
select postgis_version() = 1.1 USE_GEOS=0 USE_PROJ=1 USE_STATS=1
Does this mean it's still not using GEOS? If so what should I do to make
it use GEOS?
