[postgis-users] Buffer Question
    Gustavo Henrique Sberze Ribas
    gribas at cpqd.com.br
    Wed Jul 27 05:48:42 PDT 2005
 Use setSRID():
  Select *
   from city
   where setSRID(
		buffer(
              transform(GeomFromText('POINT(-98.20194 32.22056)',4269),2163),
              100000
         2163)
   transform(city.the_geom, 2163)
Gustavo
> I am using PostgreSQL 8.0.3 on WindowsXP Professional and PostGIS
> version 0.9.
> I want to return a list of cities within a certain distance
> of a point.
> Note my city table is in srid=4269 which has units in
> degrees, so I must
> transform it to srid=2163 to get to units in meters.
> Select *
> from city
> where buffer(transform(GeomFromText('POINT(-98.20194
> 32.22056)',4269),2163), 100000) &&
> However when I run the buffer function I get
> ERROR: Operation on two GEOMETRIES with different SRIDs
> I started dissecting the query and found the following:
> Using SELECT transform(GeomFromText('POINT(-98.20194
> 32.22056)',4269),2163) I return:
> 	"SRID=2163;POINT(170540.337643801 -1435432.98097678)"
> All is well; my srid = 2163 just as I would expect.
> However, if I buffer the point with:
> SELECT buffer(transform(GeomFromText('POINT(-98.20194
> 32.22056)',4269),2163), 10000)
> My result returns srid = -1
> How do I return a buffer result in srid=2163?
> If I read the documentation correctly, the result should be
> in the same
> spatial ref sys as the geometry passed in (in this case 2163).
> Any help would be greatly appreciated.
> Jeff
> postgis-users mailing list
