Fw: [postgis-users] Gentoo Emerge (from Gerald FENOY)
Gérald Fenoy
gfenoy at gmail.com
Wed Jul 27 07:13:25 PDT 2005
I'm not shure to understand your request ... but one thing is shure
you don't need to downgrade your postgis installation (indeed we begin
the postgis ebuild only for the 1.0.0 release).
/-- Maybe this could help :
Could you add this line to your /etc/portage/package.keywords :
dev-db/postgis ~x86 ? (if some problems come from the postgresql
version please add this line to your /etc/portage/package.unmask :
>=dev-db/postgresql-8.0.0 - or an upper version if you prefer ... )
-- Maybe not .../
You could probably use your allready installed postgresql version
without problem (the tests I've made use the 8.0.1-r2 version).
Thanks in advance to keep us informed.
Cordially.
2005/7/27, Christo Du Preez <christo at mecola.com>:
> Hi Gérald
> emerge -p postgis
> These are the packages that I would merge, in order:
> Calculating dependencies ...done!
> [ebuild UD] dev-db/postgresql-7.3.6-r2 [8.0.2-r1]
> [ebuild UD] dev-db/postgis-0.7.5-r2 [1.0.0_p20050512]
> Now it busy downgrading? Is this correct?
> I't is busy as we speak, I'll send you the
> emerge-postgis-1.0.0_p20050524.ebuild.log once it's done.
> Gérald Fenoy wrote:
> >Hi,
> >please could you log the whole compilation process with something like
> >this : emerge -v postgis >& emerge-postgis-1.0.0_p20050524.ebuild.log
> >This could help me more to see if there is a problem with an old
> >installation. Indeed I just try with the version 1.1.0CVS (2005-07-27
> >6:00) and I have a problem with the old ebuild so I made a new one for
> >the cvs version which is now called postgis-1.0.1_p20050727.ebuild and
> >you could get it from the web page gentoo.01map.net (or
> >http://www.01map.net/gentoo if the first one don't work). Indeed with
> >the postgis-cvs.tar.gz downloaded this morning from
> >postgis.refractions.net I have problem for the /usr/libexec directory
> >creation ...
> >So there are two solutions, first you choose to debug the first ebuild
> >then you send me the complete log requested before, second, you use
> >the fresh ebuild then you tell me if you have any problem with it (and
> >you could also inform me if it works like a charme ;) )
> >Waiting for a response.
> >Cordially.
> >ps: sorry for redondency.
> >----- Original Message -----
> >From: Christo Du Preez
> >To: Jean David TECHER
> >Sent: Wednesday, July 27, 2005 12:21 PM
> >Subject: Re: [postgis-users] Gentoo Emerge (from Gerald FENOY)
> >Hi there,
> >I have attached the complete emerge.log, I thought having all the info
> >might come in handy.
> >ebuild: postgis-1.0.0_p20050512.ebuild
> >Thanx in advance.
> >Jean David TECHER wrote:
> >>Hi,
> >>could you give me which is the version of the ebuild youve used to
> >>make this test ?
> >>Could you give me the emerge logs of this emerge ? (Indeed I would
> >>like to see if you don't have some trace of an old installation on
> >>your system, cause in that case portage will not remove the old
> >>one...)
> >>Cordially.
> >>PS: Sandro could U add gfenoy at gmail.com <mailto:gfenoy at gmail.com> as a
> >>sender for this mailling list, indeed he experiences a tecnical
> >>problem on his djayux.net mail server :/
> >> *From:* Christo Du Preez <mailto:christo at mecola.com>
> >> *To:* postgis-users at postgis.refractions.net
> >> <mailto:postgis-users at postgis.refractions.net>
> >> *Sent:* Tuesday, July 26, 2005 11:54 PM
> >> *Subject:* [postgis-users] Gentoo Emerge
> >> I Installed Postgis on Gentoo using:
> >> USE="geos proj doc" ACCEPT_KEYWORDS="~x86" emerge postgis
> >> select postgis_version() = 1.1 USE_GEOS=0 USE_PROJ=1 USE_STATS=1
> >> Does this mean it's still not using GEOS? If so what should I do
> >> to make it use GEOS?
> Kind Regards,
> Christo Du Preez
> Senior Software Engineer
> Mecola IT
> http://www.mecola.com
> +27 [0]82 4255 895
Gérald FENOY
01map.net
