[postgis-users] Can't build GIST index on table with > 5, 000, 000 rows
Chip Masters chip_masters at yahoo.com
Wed Jul 27 20:02:23 PDT 2005
I downloaded the NGA Geographical Names dataset (from
http://earth-info.nga.mil/gns/html/cntry_files.html)
and built a spatial database using the attached
script, nga.sql. The resulting table has over 5.5
million rows. Everything went fine until it reached
the step in my script that builds the GIST index on
the_geom column:
> create index gns_the_geom_gist on gns using gist
> (the_geom);
I let this run for around 24 hours before I realized
that postgres had died without producing any error
message. Unfortunately, I don't have any further
debugging information to provide.
I was wondering if there is a known limitation on the
size of a GIST index, or if there is another method I
could use to build the index incrementally.
I'm running PostgreSQL 8.0.3. Here's my postgis
version info:
nationalatlas=# select postgis_full_version();
 POSTGIS="1.0.1" GEOS="2.1.2" PROJ="Rel. 4.4.9, 29 Oct
2004" USE_STATS DBPROC="0.3.0" RELPROC="0.3.0"
(1 row)
Thanks in advance,
Chip Masters
____________________________________________________
Start your day with Yahoo! - make it your home page
http://www.yahoo.com/r/hs
Type: application/octet-stream
Desc: 1532888283-nga.sql
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20050727/41bf1a97/attachment.obj>
