[postgis-users] Latitude and longitude distances
Mark Fenbers
Mark.Fenbers at noaa.gov
Thu Jul 28 04:32:01 PDT 2005
Actually, I do this sort of thing all the time, and PostGIS is perfect
for the job! First, you want to convert your lat/lon coordinate into a
POINT geometry. Sometimes I do this by duplicating the original
location table with 'SELECT INTO TEMP ..." and adding a geometry column
(see AddGeometryColumn() function) for my many locations. You will also
need to convert your given lat/lon to a POINT geometry (see MakePoint()
function). Next you will want to use the buffer() function to create a
polygon that is a certain radius from your given location, and finally
test which locations are in the polygon (contains() function).
So let's say your many locations were in a table called location.lat and
location.lon, and your reference location was (80.5W, 40.5N). Then to
retrieve all rows in a 3-degree radius of you reference, you could so
something like the following (although it is probably not the most
efficient method):
Begin;
SELECT INTO TEMP gislocation * from location;
SELECT addGeometryColumn(
'public','gislocation','the_geom',4269,'POINT',2 ); -- 4269 might
differ if your lat,lon is not referenced to NAD83.
UPDATE gislocation set the_geom = makePoint( lon,lat );
SELECT * from gislocation where contains( buffer( makePoint( 80.5,40.5
), 3 ), the_geom );
I haven't tested any of this, nor looked up the function syntax, so
there probably are errors, but this will get you in the ballpark. Also,
if you want to compute a 3km radius instead of a 3-degree raduis with
buffer(), then you have to first convert all your geometries into an
equal-area projection using the transform() function, such as SRID = 2792.
Hope this helps!
Mark
Vacuum Joe wrote:
>Hello,
>I'm new to PostGIS. I have what I hope is a basic
>question. I have a database with many locations in
>it. These locations are all specified by latitude and
>longitude. I need to be able to do things like select
>all the rows that are within a certain radius of a
>given latitude/longitude. The results don't have to
>be precise, and the radius will never be more than a
>few miles.
>I assume this type of use is perfectly within what
>PostGIS can do, but I can't figure out how to store
>lon/lat data and do searches on it.
>If there are any docs or examples you could point me
>to, I would greatly appreciate it.
>Thanks
>__________________________________________________
>Do You Yahoo!?
>Tired of spam? Yahoo! Mail has the best spam protection around
>http://mail.yahoo.com
>postgis-users mailing list
>postgis-users at postgis.refractions.net
>http://postgis.refractions.net/mailman/listinfo/postgis-users
Type: text/x-vcard
Desc: not available
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20050728/47a17929/attachment.vcf>
