[postgis-users] Error while importing data
Aditya aditya at grot.org
Thu Jun 2 14:03:20 PDT 2005
I'm getting an error similar to what was described in this thread from March
2005. I searched for
 postgis "ERROR:  Invalid type in wbk"
and found this thread, but with a fix that seems not to apply to the
shapefiles I'm trying to import. I would appreciate it greatly if someone else
could try and reproduce this error (and thereby implicate the shapefile :-)
The shapefile was produced from:
  http://www.esri.com/data/download/basemap/index.html
and trying to import it using shp2pgsql on fresh installs of:
  postgis 1.0.1
  postgresql 8.0.3
shapefile and resulting .sql file appended. The transcript of my sessions are
below.
Thanks,
Adi
some[ttyp0]:aditya/usr/local/src/gis/sa> /usr/local/pgsql/bin/shp2pgsql -d -D
Country\ Boundaries\ 2.shp geoserver.country > country.sql
Shapefile type: Polygon
Postgis type: MULTIPOLYGON[2]
some[ttyp0]:aditya/usr/local/src/gis/sa> psql -d grot -U geoserver -f country.sql
psql:country.sql:1: ERROR:  column not found in geometry_columns
table
CONTEXT:  SQL statement "SELECT  DropGeometryColumn('', $1 , $2 , $3 )"
PL/pgSQL function "dropgeometrycolumn" line 4 at select into variables
psql:country.sql:2: ERROR:  table "country" does not exist
BEGIN
psql:country.sql:4: NOTICE:  CREATE TABLE will create implicit sequence
"country_gid_seq" for serial column "country.gid"
psql:country.sql:4: NOTICE:  CREATE TABLE / PRIMARY KEY will create implicit
index "country_pkey" for table "country"
CREATE TABLE
                                  addgeometrycolumn
 geoserver.country.the_geom SRID:-1 TYPE:MULTIPOLYGON DIMS:2
 geometry_column fixed:0
(1 row)
psql:country.sql:6: ERROR:  Invalid type in wbk
CONTEXT:  COPY country, line 1, column the_geom:
"00000000060000000100000000030000000100000070404E25B23571D1D4404259FF2E48E8A84050296B3354C122404259FF..."
ROLLBACK
country.sql                                    BEGIN
psql:country.sql:2: NOTICE:  CREATE TABLE will create implicit sequence
psql:country.sql:2: NOTICE:  CREATE TABLE / PRIMARY KEY will create implicit
CREATE TABLE
                                  addgeometrycolumn
(1 row)
psql:country.sql:4: ERROR:  Invalid type in wbk
psql:country.sql:5: ERROR:  current transaction is aborted, commands ignored
until end of transaction block
psql:country.sql:6: ERROR:  current transaction is aborted, commands ignored
psql:country.sql:7: ERROR:  current transaction is aborted, commands ignored
psql:country.sql:8: ERROR:  current transaction is aborted, commands ignored
psql:country.sql:9: ERROR:  current transaction is aborted, commands ignored
psql:country.sql:10: ERROR:  current transaction is aborted, commands ignored
psql:country.sql:11: ERROR:  current transaction is aborted, commands ignored
psql:country.sql:12: ERROR:  current transaction is aborted, commands ignored
psql:country.sql:13: ERROR:  current transaction is aborted, commands ignored
psql:country.sql:14: ERROR:  current transaction is aborted, commands ignored
psql:country.sql:15: ERROR:  current transaction is aborted, commands ignored
psql:country.sql:16: ERROR:  current transaction is aborted, commands ignored
psql:country.sql:17: ERROR:  current transaction is aborted, commands ignored
psql:country.sql:18: ERROR:  current transaction is aborted, commands ignored
psql:country.sql:19: ERROR:  current transaction is aborted, commands ignored
psql:country.sql:20: ERROR:  current transaction is aborted, commands ignored
psql:country.sql:21: ERROR:  current transaction is aborted, commands ignored
psql:country.sql:22: ERROR:  current transaction is aborted, commands ignored
psql:country.sql:23: ERROR:  current transaction is aborted, commands ignored
psql:country.sql:24: ERROR:  current transaction is aborted, commands ignored
psql:country.sql:25: ERROR:  current transaction is aborted, commands ignored
psql:country.sql:26: ERROR:  current transaction is aborted, commands ignored
ROLLBACK
Thanks,
Adi
On Thu, Mar 10, 2005 at 05:20:16PM +0100, strk at refractions.net wrote:
> On Thu, Mar 10, 2005 at 06:00:20AM +0000, Nigel Kukard wrote:
> > Hi Guys,
> > I'm new to postgis. I got shape files from our local government,
> > containing all data for South Afica.
> > I installed postgresql 8.0.0, postgis 1.0.0-rc3, proj 4.4.9, gdal 1.2.5,
> > php-5.0.3 & mapserver 4.4.1
> > The first thing i did is pipe lwpostgis.sql & spatial_ref_sys.sql into
> > pgsql.
> > I continued to run shp2pgsql on one of the shape files to insert it into
> > my database with
> > shp2pgsql -d drainagexxxxx.shp drainage > /tmp/postgis.sql
> > I then tried to pipe the /tmp/postgis.sql into postgresql,  but got the
> > following error...
> > BEGIN
> > NOTICE:  CREATE TABLE will create implicit sequence "drainage_gid_seq"
> > for serial column "drainage.gid"
> > CREATE TABLE
> >                                   addgeometrycolumn
> > public.drainage.the_geom SRID:-1 TYPE:MULTILINESTRING DIMS:4
> > (1 row)
> Nigel, we have fixed a (Multi)LineString-related bug in shp2pgsql.
> If you can test a CVS snapshot that would help us release RC4.
> --strk;
> > ERROR:  current transaction is aborted, commands ignored until end of
> > transaction block
> > transaction block
> > transaction block
> > ROLLBACK
> > most of the shape files import fine, there are a couple of types which
> > give me the above error.
> > any help would greatly be appreciated, if need be I can attach the
> > actual sql file or any other info needed.
> > Regards
> > Nigel Kukard
> > postgis-users mailing list
> > postgis-users at postgis.refractions.net
> > http://postgis.refractions.net/mailman/listinfo/postgis-users
                     w??     ???0?K@?q??????d?Y@??H.?YB@                                     ?   ??q5?%N@?????A@"?T3k)P@??H.?YB@   p       ??q5?%N@??H.?YB@"?T3k)P@??H.?YB@?`?(P at 8>Z?1XB at zT??(P@(????TB@&???{'P@|]??tQB@????'P@?a???LB@|??!U'P@<??HB@f`X(P@?u?!DB@?f??(P at x???A>B@:?]?(P at 8?]?:B@?Ws?`'P@???86B@`X?|&P at T4???2B@??|?5%P@(???I/B@?????!P@?#??S&B@?N??: P@?z2??#B@????P@<?8b- B@??t!VP at P^d~B@????P@????B at f?ba?
P@??aB@??(@P at Lp??B@?x?'?O@|??BB@?: ???O at T:X??B@??????O at d?VAB@??;???O@???j?A@???j?O@? ?bG?A@??{?Y?O@??\?C?A@?z2???O@?d?<
?A@?E~??O@$D???A@?_?|x?O at P????A@??q???O@??!??A@???j?O at P^d~?A@<?? ??O@??E}??A at P????O@???@??A@|fI???O@???A@|?????O@|??B?A@?????O@(h??'?A at P?D??O@|i? ??A@????*?O@?"??J?A@ ?? ??O@?C p?A at 8?}?k?O@?.??|?A@??\?C?O@?t????A at T
????O@???8?A@???B??O@<tz???A@$???{?O@??\?A@?????O@??~7?A@?IEc??O@???A at P<???O@??}?A at 8??!?O@??m?R?A@??0Bx?O@$A?
?A@?x#??O@?t"??A@???8~O@????9?A@??(@vO@???@,?A at P?`??sO@$8????A@|$%=qO@???C??A@??i? kO@ ?=~?A@????]O at h?>??A at Lg'??PO@?[<???A at PU??XFO@?"??J?A@??E}?CO at PF\ ?A@<?U??AO@$A?
?A@?%r?<O@?????A@?)??6O@?<?|??A@?D??4O@??X??A@???B?1O at P%@?A@???8.O@????k?A@iT?d+O@???C??A@?????'O@?????A@|$%=#O@?\???A@?p!?"O@?a????A@$;6?O at P????A@??C??O@,?}?A@?8?ZO@??M??A@?#?G	O@???C??A@??VBwO at P??|z?A@??e???N@??????A@?????N@??????A@ ?????N@?h????A@$J{?/?N@m??A@??\?C?N@??h??A@?t????N at P?????A at T
????N@??t ??A@????l?N at x??C5?A@???0?N@?????A@?]????N at t?r??A at d?&??N@????k?A@?????N@?>??s?A@<??@f?N@<P?<??A at T||Bv?N at x~Q???A at xu???N@<? ??A at 4??#??N at d?????A at T8???N@??????A at PU??X?N@|'f??A@?[<???N@?M?=??A@(????N@|!????A at P<???N@?!<?B@??I~??N@?b??
B at t?V?N@??B?B@????C?N at xx???B@??#???N at P
?=?$B@<? ??N@??p?5B at 8?a?A?N at d?b?HB@???>U?N@ ?A?PB@$????N@?~??@SB@???~P?N@$?6?DSB@??#??wN@?K ?)SB@??[?eN@???SB@???A^UN@(?.??RB@??
?RN@(5??RB@,*?Z at N@|l???RB@?)??.N@$W@?RB at T?t<f*N at L.??:TB@??q5?%N@??H.?YB@      h   0?q??Q@????UB@(yu??Q@??H.?YB@
       0?q??Q@??H.?YB@(yu??Q@??H.?YB at P@???Q@?C???XB@<?(A?Q@??l?WB@??
??Q@T???VB@f????Q@?C?bVB@???~?Q@????UB@|6?>W?Q at l??~?VB@?G?`?Q@<???RYB at 0?q??Q@??H.?YB@
?   ?????@N@??M?g=@????DR@??H.?YB@   ?      <??@f?N@<P?<??A@?????N@?>??s?A at d?&??N@????k?A@?]????N at t?r??A@???0?N@?????A@????l?N at x??C5?A at T
????N@??t ??A@?t????N at P?????A@??\?C?N@??h??A@$J{?/?N@m??A@ ?????N@?h????A@?????N@??????A@??e???N@??????A@??VBwO at P??|z?A@?#?G	O@???C??A@?8?ZO@??M??A@??C??O@,?}?A@$;6?O at P????A@?p!?"O@?a????A@|$%=#O@?\???A@?????'O@?????A@iT?d+O@???C??A@???8.O@????k?A@???B?1O at P%@?A@?D??4O@??X??A@?)??6O@?<?|??A@?%r?<O@?????A@<?U??AO@$A?
?A@??E}?CO at PF\ ?A at PU??XFO@?"??J?A at Lg'??PO@?[<???A@????]O at h?>??A@??i? kO@ ?=~?A@|$%=qO@???C??A at P?`??sO@$8????A@??(@vO@???@,?A@???8~O@????9?A@?x#??O@?t"??A@??0Bx?O@$A?
?A at 8??!?O@??m?R?A at P<???O@??}?A@?IEc??O@???A@?????O@??~7?A@$???{?O@??\?A@???B??O@<tz???A at T
????O@???8?A@??\?C?O@?t????A at 8?}?k?O@?.??|?A@ ?? ??O@?C p?A@????*?O@?"??J?A at P?D??O@|i? ??A@?????O@(h??'?A@|?????O@|??B?A@|fI???O@???A at P????O@???@??A@<?? ??O@??E}??A@???j?O at P^d~?A@??q???O@??!??A@?_?|x?O at P????A@?E~??O@$D???A@?z2???O@?d?<
?A@??{?Y?O@??\?C?A@???j?O@? ?bG?A@??;???O@???j?A@??????O at d?VAB@?: ???O at T:X??B@?x?'?O@|??BB@??(@P at Lp??B at f?ba?
P@??aB@????P@????B@??t!VP at P^d~B@????P@<?8b- B@?N??: P@?z2??#B@?????!P@?#??S&B@??|?5%P@(???I/B@`X?|&P at T4???2B@?Ws?`'P@???86B@:?]?(P at 8?]?:B@?f??(P at x???A>B@f`X(P@?u?!DB@|??!U'P@<??HB@????'P@?a???LB@&???{'P@|]??tQB at zT??(P@(????TB@?`?(P at 8>Z?1XB@"?T3k)P@??H.?YB at 0?q??Q@??H.?YB@?G?`?Q@<???RYB@|6?>W?Q at l??~?VB@???~?Q@????UB@f????Q@?C?bVB@??
??Q@T???VB@<?(A?Q@??l?WB at P@???Q@?C???XB@(yu??Q@??H.?YB@???3.R@??H.?YB@????DR@??D?XB at 8? U	R@?8d?RB@|3j?J?Q@$???]EB at XLl>??Q@??V|C5B@?[?~l?Q@?????7B at 0/?>:?Q@??G??;B@??????Q@????9B@?s????Q@?O@?1B at H?@1?Q@?v?>X,B@???A??Q@?5???"B at 8?~???Q@?????B@??p $?Q@?i???B@!Y??Q@ A?B@N??;?Q@????B@?E?>?Q@?T?~O?A@???~?Q@|?????A@????U?Q@??C???A@??	???Q at d?J!??A@(2s???Q at Ls+???A@???_?Q@??i? ?A@|l????Q at T???r?A@???~?Q@?????A@<?????Q@?9"???A@?z2???Q@?b???A at h???Q@?)???A@??Y?r?Q@??^?A@??~7?Q@?????A@?.???Q@??VBw?A@??\?C?Q at h??\??A@ 2?Q@????}A at D?u???Q@<?,B?{A at 8w?^??Q@?4~??zA@????s?Q@????yA at P<???Q@??w?'uA@?k?}??Q@(?N>=jA at xx????Q@??d ?\A@??$???Q@??E}?UA@??l??Q at d???jRA@$W@??Q@|?<?NA@<??A??Q@(?o|?GA at .>?x?Q@??0~GA@<?Y???Q@??"?DA@?????Q@|??BAA@?z2???Q@???;A@?l???Q@????2A@?????Q at P}>?0A@<?? ??Q at 8????-A@<???Q at d??]?A@?v?1?Q@???0A at R.?_x?Q@?b*???@@"[A??Q@$>w???@@o???Q at P?>??@@??????Q@?@????@@zi? ??Q@ ?A|`?@@r????Q@$A?
?@@o???Q@|???A at d?????Q@?????A@?;??Q@??C?A at T:X??|Q@???@?A@??M?{Q@???>UA@B@??{Q@?Q??BA@?
)??yQ@?,???A at Nu?wQ@$???@@?k?}?zQ@???@@??,Q at h??`o?@@?l ]?Q at x?|?@@?1=a??Q at P@???@@xE????Q@??
??@@&?B??Q@?????@@"????Q@|]??t?@@???~?Q@?b???@@NF?a??Q@??????@@(????Q at P%@?@@f??E?Q@?6?^??@@&?R?o?Q@?t????@@?Tka?Q@??i? ?@@??F!??Q@?#??@@?4~???Q@??>$?@@i??Q@?T?~O?@@zu???Q@(??b?@@?L??yQ@??-?@@??@?wQ@????r?@@<??~hQ@?????@@???@,eQ@??i? ?@@P???cQ@|-??1?@@?-?s`Q@<???@@?ng_y_Q@&??@@RC?
`Q at x~Q??x@@????z`Q@??w?'u@@?t???`Q at R
???o@@?t???]Q@??i? k@@&c`ZQ@???@,e@@???aNYQ at z?m?(b@@?
j??ZQ@&5??^@@??6 \Q@|c ?[@@(?
?0]Q@??:MV@@???ZQ@??C??N@@~<???YQ at zo?K@@???@-XQ@(/2?H@@?w?~?VQ@?A?<?G@@>}??TQ@???8F@@:????SQ@(h??'E@@???RQ at R??B?B@@???~PQQ@? ?	@@@???jPQ@???C6<@@???~?OQ@??`?u8@@&"?PQ at Ng'??4@@?.??PQ@$G:#1@@?1 ?QQ at R???-@@:w?^?RQ at z??C5)@@|fI??RQ@(?
?0%@@h??RQ@"???@@?t???QQ@???~P@@>?e?YQQ@?d#?@@?]??yQQ at j?{??@@P:?`?RQ at f???8@@????UQ@?M?????@:????RQ at Lg'????@?^?MQ@???????@??k~?LQ@?qo~???@??(@JQ at T:X????@??\?CHQ@???????@<????FQ at t<f?2??@???8AQ at h|_\???@h?>?4Q@??????@?+?`p3Q@??hU??@<???.Q@?L?:???@????.Q at t?y????@i?)Q@?d??@(??$Q@EH????@????#Q@??:???@TH?9!Q at 81$'??@??Q@?????@b?J!?Q@ R?8???@??x>!Q@,?????@<??"$Q@<?????@??Y?r#Q at x?u????@&?`6"Q at 8?]???@???A^Q@|?????@????Q@,?	????@??AQ@?0|D??@n-??x
Q@<e5]O??@???>U	Q@??K??@zQ?_Q@?C4????@????Q@?X?;???@f????P@(u?8F??@??i?P@?
?D??@?n.???P@???????@??i? ?P@?!<???@??????P@???????@??????P at X??????@|-??1?P@??????@???>U?P at x???A??@??|@??P@??9???@??B??P@?r????@??|?5?P@???~??@????N?P@?q?&n?@$#gaO?P@ ??F?f?@?Y?>??P@|?!8.g?@??a??P@?M?#~i?@?<c_??P@??n?!j?@?r???P at 87?',i?@$?????P@ \?zb?@??_??P at lH?c?W?@:???;?P@????gE?@~??@??P@?? 7?@??|@??P@??R%?6?@??@j?P@??9?8?@??????P@$???7?@(?_?P@??p?=?@?<c_??P at X??x?C?@|-??1?P@?M?#~M?@?e??S?P@?????Q?@?f???P@??}R?@&2s???P@??c?Q?@???A_?P@?5??J?@??????P@???A?G?@?b.?P@???75?@?9[@h?P@????l ?@??@??P@$z?r?@?r???P@?4~???>@f?????P at h?"???>@<??@f?P@??v?>@????s?P at T?{/?>@R}>??P at Ljh??>@>}???P@???g??>@P7P???P@??l??>@f???P at T=???>@??U?@?P@?I????>@R^+???P@??f?~>@?f???P@??1ZGq>@c?~??P@`$??\:>@<??A??P@$???/>@]~p?P@ ? ?S&>@N
?g?P at d?fb?>@<????P@??J#f
>@h?>??P@???>@??,?P@?0Bx??=@?6?[?P@$?^F??=@?Z? m?P@|'f??=@|-??1?P@|????=@**?Z?P@?1??8?=@RL? 3wP@,?	???=@???nP at P??}??=@>???4fP at Lp???=@????QPP@?.m8,?=@<?I/BP@?????=@?Y?>?7P@?^???=@4P?>1P@`L?{)?=@?6?[/P@(?
?0?=@"?{?,P@??C?=@??,AF*P@?_?|x?=@?7??$P at P??C?=@?*?)#P@$?^F??=@z0)>>P@??z??=@??:MP@???@??=@(?
?0P@?h????=@?????
P@????=@???P@???i{=@d???j
P@|$%=u=@d????P@|'f?j=@???P at T?{/n=@$>w???O@???B|=@??G?)?O@,?	???=@?a?? ?O@????l?=@???~?O@<.?EDy=@(??|?O@$???x=@?A?<?GO@???}?i=@????>O@??M?g=@???;O at L??ui=@L.??:4O@?:q9^m=@T?t<f.O@?!<?p=@$???{+O@?F?r=@ ??>?O@|0)>>y=@?Q??B
O@|?e???=@???B?O@??7?a?=@|$%=?N at x???s?=@??X??N@??$A??=@x???A~N@?+,??=@?:???nN@?|~?=@?2d?oN@ ?????=@xE???tN at PO???=@???A^?N at P?c*>@??N@?N@??E}?/>@?,????N at H/?9>@??q???N@|??A?H>@T
????N@?^??a>@?E~??N at P?&?O?>@<? ??N@??d?@???A??N@?:q9^-?@T:X???N@?*?w?7?@?8+?&?N@,?MF?A?@|l????N at P^d~Q?@?v|??N at x???sZ?@???W?N@ ???!b?@?)???N@?@-k?@x?$?N@??I~?s?@???>U?N at La???v?@?9"??lN@?a?? ?@?X?;?gN@ ?bG???@ ?=~iN at x???A??@?*?]giN@?U?????@(???IgN@|*?=%??@PO??hN@??}@@x???kN@|c ?@@?I?pmN at z9??c@@|????mN at d	kc?@@????mN@:?}?k!@@Ty=?jN at z??C5)@@(????\N@?X?;?O@@P[#?qTN@?/?h@@??\?CLN@??W??@@(n?@KN@?b???@@P??B?JN@??`?u?@@?T?~OJN@|6?>W?@@P??C?JN@|*?=%?@@?????PN at P??B??@@??d ?\N@? ????@@????`N@|?m?(?@@$[A?fN@??
??@@|*?=%mN@????@@?#??SpN@????@@h o?wN@???;??@@??-xN@?\?].?@@???0uN@?`"?@@(?R?orN@|*?=%?@@T8??mN@? ????@@?????dN@?Hg`??@@\p?ZN@??????@@????BUN@ ?????@@P[#?qLN at P??|z?@@????IN@???8?@@?b??EN at P"???@@?j?#?CN@??B??@@??BN at hv?[??@@P????AN@$P??H?@@p?r?AN at P=????@@(?
?0EN at T???r?@@????FN@?p $?@@?%?"?FN@?;l"3?@@?,???CN@????@@?????BN at T?3?YA@????,AN at 0s??A@?????@N@?,???A@?ek}?@N at T
???A@,kgAN at d??a?A@|6?>WCN@ ? >?A@?b??EN@$G:#A at d???jVN@|-??1(A@$W@?^N@?l??(A@?`"bN@?E?>)A at d?ckN at PR`L)A@??>pN@?|?|?(A at PF\ qN@???|y-A@???@-fN at 8??"N;A@<??bFbN@?b.=A@??d ?\N@<????CA@????^N@???@?EA@?,???cN at L+?@.GA@????jN at d????GA@??\5mN@??!?HA@????}N at PR`LSA at La????N@|$%=eA@??B??N@??B?pA at P}>??N@????*?A@?!<??N at P????A@???i?N@?[<???A at xx????N@?L????A@??????N@|fI???A at d??Q?N@? ?=?A at T8???N@??X??A@?A?<??N@??????A at PX?e?N@?!?A?A@?!<??N@???}?A@<??@f?N@<P?<??A@     h   ?:???nN@???#?7 at xN?@?tS@??H.?YB@   ?      ???~?O@<.?EDy=@?a?? ?O@????l?=@??G?)?O@,?	???=@$>w???O@???B|=@???P at T?{/n=@d????P@|'f?j=@d???j
P@|$%=u=@???P@???i{=@?????
P@????=@(?
?0P@?h????=@??:MP@???@??=@z0)>>P@??z??=@?*?)#P@$?^F??=@?7??$P at P??C?=@??,AF*P@?_?|x?=@"?{?,P@??C?=@?6?[/P@(?
?0?=@4P?>1P@`L?{)?=@?Y?>?7P@?^???=@<?I/BP@?????=@????QPP@?.m8,?=@>???4fP at Lp???=@???nP at P??}??=@RL? 3wP@,?	???=@**?Z?P@?1??8?=@|-??1?P@|????=@?Z? m?P@|'f??=@?6?[?P@$?^F??=@??,?P@?0Bx??=@h?>??P@???>@<????P@??J#f
>@N
?g?P at d?fb?>@]~p?P@ ? ?S&>@<??A??P@$???/>@c?~??P@`$??\:>@?f???P@??1ZGq>@R^+???P@??f?~>@??U?@?P@?I????>@f???P at T=???>@P7P???P@??l??>@>}???P@???g??>@R}>??P at Ljh??>@????s?P at T?{/?>@<??@f?P@??v?>@f?????P at h?"???>@?r???P@?4~???>@??@??P@$z?r?@?9[@h?P@????l ?@?b.?P@???75?@??????P@???A?G?@???A_?P@?5??J?@&2s???P@??c?Q?@?f???P@??}R?@?e??S?P@?????Q?@|-??1?P@?M?#~M?@?<c_??P at X??x?C?@(?_?P@??p?=?@??????P@$???7?@??@j?P@??9?8?@??|@??P@??R%?6?@~??@??P@?? 7?@:???;?P@????gE?@??_??P at lH?c?W?@$?????P@ \?zb?@?r???P at 87?',i?@?<c_??P@??n?!j?@??a??P@?M?#~i?@?Y?>??P@|?!8.g?@$#gaO?P@ ??F?f?@????N?P@?q?&n?@??|?5?P@???~??@??B??P@?r????@??|@??P@??9???@???>U?P at x???A??@|-??1?P@??????@??????P at X??????@??????P@???????@??i? ?P@?!<???@?n.???P@???????@??i?P@?
?D??@f????P@(u?8F??@????Q@?X?;???@zQ?_Q@?C4????@???>U	Q@??K??@n-??x
Q@<e5]O??@??AQ@?0|D??@????Q@,?	????@???A^Q@|?????@&?`6"Q at 8?]???@??Y?r#Q at x?u????@<??"$Q@<?????@??x>!Q@,?????@b?J!?Q@ R?8???@??Q@?????@TH?9!Q at 81$'??@????#Q@??:???@(??$Q@EH????@i?)Q@?d??@????.Q at t?y????@<???.Q@?L?:???@?+?`p3Q@??hU??@h?>?4Q@??????@???8AQ at h|_\???@<????FQ at t<f?2??@??\?CHQ@???????@??(@JQ at T:X????@??k~?LQ@?qo~???@?^?MQ@???????@:????RQ at Lg'????@????UQ@?M?????@P:?`?RQ at f???8@@?]??yQQ at j?{??@@>?e?YQQ@?d#?@@?t???QQ@???~P@@h??RQ@"???@@|fI??RQ@(?
?0%@@:w?^?RQ at z??C5)@@?1 ?QQ at R???-@@?.??PQ@$G:#1@@&"?PQ at Ng'??4@@???~?OQ@??`?u8@@???jPQ@???C6<@@???~PQQ@? ?	@@@???RQ at R??B?B@@:????SQ@(h??'E@@>}??TQ@???8F@@?w?~?VQ@?A?<?G@@???@-XQ@(/2?H@@~<???YQ at zo?K@@???ZQ@??C??N@@(?
?0]Q@??:MV@@??6 \Q@|c ?[@@?
j??ZQ@&5??^@@???aNYQ at z?m?(b@@&c`ZQ@???@,e@@?t???]Q@??i? k@@?t???`Q at R
???o@@????z`Q@??w?'u@@RC?
`Q at x~Q??x@@?ng_y_Q@&??@@?-?s`Q@<???@@P???cQ@|-??1?@@???@,eQ@??i? ?@@<??~hQ@?????@@??@?wQ@????r?@@?L??yQ@??-?@@zu???Q@(??b?@@i??Q@?T?~O?@@?4~???Q@??>$?@@??F!??Q@?#??@@?Tka?Q@??i? ?@@&?R?o?Q@?t????@@f??E?Q@?6?^??@@(????Q at P%@?@@NF?a??Q@??????@@???~?Q@?b???@@"????Q@|]??t?@@&?B??Q@?????@@xE????Q@??
??@@?1=a??Q at P@???@@?l ]?Q at x?|?@@??,Q at h??`o?@@?k?}?zQ@???@@Nu?wQ@$???@@?
)??yQ@?,???A@B@??{Q@?Q??BA@??M?{Q@???>UA at T:X??|Q@???@?A@?;??Q@??C?A at d?????Q@?????A@o???Q@|???A@r????Q@$A?
?@@zi? ??Q@ ?A|`?@@??????Q@?@????@@o???Q at P?>??@@"[A??Q@$>w???@@R.?_x?Q@?b*???@@?v?1?Q@???0A@<???Q at d??]?A@<?? ??Q at 8????-A@?????Q at P}>?0A@?l???Q@????2A@?z2???Q@???;A@?????Q@|??BAA@<?Y???Q@??"?DA at .>?x?Q@??0~GA@<??A??Q@(?o|?GA@$W@??Q@|?<?NA@??l??Q at d???jRA@??$???Q@??E}?UA at xx????Q@??d ?\A@?k?}??Q@(?N>=jA at P<???Q@??w?'uA@????s?Q@????yA at 8w?^??Q@?4~??zA at D?u???Q@<?,B?{A@ 2?Q@????}A@??\?C?Q at h??\??A@?.???Q@??VBw?A@??~7?Q@?????A@??Y?r?Q@??^?A at h???Q@?)???A@?z2???Q@?b???A@<?????Q@?9"???A@???~?Q@?????A@|l????Q at T???r?A@???_?Q@??i? ?A@(2s???Q at Ls+???A@??	???Q at d?J!??A@????U?Q@??C???A@???~?Q@|?????A@?E?>?Q@?T?~O?A@N??;?Q@????B@!Y??Q@ A?B@??p $?Q@?i???B at 8?~???Q@?????B@???A??Q@?5???"B at H?@1?Q@?v?>X,B@?s????Q@?O@?1B@??????Q@????9B at 0/?>:?Q@??G??;B@?[?~l?Q@?????7B at XLl>??Q@??V|C5B@|3j?J?Q@$???]EB at 8? U	R@?8d?RB@????DR@??D?XB@???3.R@??H.?YB at ht?3?R@??H.?YB@<?U???R@??a?VB@??Y??R@?,C?TB@??a??R@(}!??OB@???! S@????r;B at T[? ? S at l?6?8B@?k?}?S@\???fB at P+L?k?R@@?mB at x` ?C?R@??B?B at 8??_??R@??H?B@??Y?r?R@??7?	B at T@?? ?R at d^G?B@N^??R@??t ?B@<??"?R@?@??? B@<?(A S@???C6 B@|????S@????H B@????S@<?? B@????uS@?o?>; B@~? ?S@|?<??A@??p $S@??`?u?A@(__?	S@????A@u??	S@|*?=%?A@????
S@????\?A@?p!?S@??\?C?A@l\??S@??6 ?A at T@?? S@?#?G?A@????S@?M?=??A@|-??1S@?????A at PX?e#S@?d?<
?A@@???$S@?x?'?A@??u??$S at h?>??A@?#?&S@?|?|??A@??M?'S@(?o|??A at T(__,S@??B??A@?#?.S@?g]???A at d??A%/S@?g@??A@@?m0S@???@??A@|]??t1S@|-??1?A at PR`L9S at T?t<f?A@??? GS at L+?@.?A@?d??PS at T??;M?A@?5_%YS@?7?a??A at P???ZS at d?	???A@?;??\S@ ?{??A@?}s?^S@?????A at l?J>v`S@?????A@??,AFbS at P@???A@{???cS@?????A@??#??gS at xE????A@????kS@?b.?A@??!?mS at P???T?A at T^-pS@??J#f?A@?5_%rS@??+?z?A at xN?@?tS@?H?+?A@,*?ZtS at T
????A@ ? >?qS@??????A at L.??:dS at L+?@.?A@?]??yYS at T??;M?A@?;??TS@?n.???A at 8???OS@??? 4?A@?*?)CS at PR`L?A@????BS at P
?=??A@??|?5CS@|6?>W?A@?'?>DS@(??{??A@??? DS@?k?}??A@??\?CBS@?}s?~A@?r??=S@?6?^?mA@??? ?<S at x??C5eA@?P?:S at x???AVA@$???7S@(??>VTA@?=?5S at d??QTA@<??4S@(????TA@????\2S@????rWA@(??0S@??C??ZA@$??/S@?J???^A at d??@?,S at d*??_A@?|A*S at PX?e_A@???j S@???>UaA@<n??tS@???#bA@?7??S@??? 4bA at PX?eS@?E~?aA at xW=`S@????YA@????S@|!???WA@?1=a?S@|i? ?QA@?i???S at x???ANA at P4`?
S@??\KA@????S@$???KA@(???IS@???A^MA at h????S@$A?
OA@<?$@MS@$8???OA@????sS at Lg'??PA@@?]?? S@?????PA at P:?`??R at d*??OA@?
)???R@?h???MA@?9?}??R@(?N>=JA at d????R@$A?
GA@?l???R at T?t<fBA@??i? ?R@?!<?@A@?T2 T?R@(eRC@A@r????R@,*?Z at A@?????R@|*?=%GA@????Q?R@?m???HA@3?`??R@??>$PA at P@???R@|o?OA@??????R at P"??PA@?d?R@?8?ZPA@??6 ?R@?#?GQA@????U?R@?/?XA@??? ?R@??{?YYA@r????R@?>??sZA@o???R@???|y]A@?/???R@?a?^A@??????R@<?u?aA@??`?u?R@??}bA at T(__?R@<?8b-dA@?w?~??R at T??;MdA at PF\ ?R@?z2??cA@???>?R@(?.??bA at P????R@|fI??`A@???A^?R@???@-^A@??l??R@|i? ?YA@????Z?R@??h?XA at PO???R@???C6XA@?Ws?`R@?_?|xVA@??B ?}R@?m???TA@?K???{R at d?cQA@u??yR at T:X??DA@?!S>xR@?????AA@|-??1sR@??`?2A at h?2?}sR@!???-A@?7??tR@(5??*A@?.??|vR@|fI??(A@???~xR@?n.??'A@<?E~?yR at Lp??'A@??`?
|R@|!???'A@?.??|~R at PI??&&A@|???a?R at xu??A@???j?R@?
???A@<???;R@??d ?A at h????}R at PX?eA@??p?{R at P^d~A@?? ?zR@<???RA@??6 zR@??E}?A at d??~?zR@???@-A@????{R@?Q??BA@??`?|R@|*?=%A@???R@|]??tA@??bg?R at h?{??A@????N?R@|?<?A at h?2?}?R@??q??A@<?????R@?>??sA@<????R at h?:? A@$????R@??????@@???@??R@<?????@@????z?R@|6?>W?@@???~?R@???@,?@@h???b?R@?????@@??i?R at PF\ ?@@?x?'?R at h????@@d?????R@????r?@@?I+?R@$???{?@@|3j?J?R at d??E?@@d??@??R@??
??@@?=??R at P"???@@?T?~O?R@??e???@@ ?!pR@???i?@@??e??~R@??B??@@(??)R at d?c?@@?c> ??R at h???@@<??"?R@|W?[?@@h?2?}?R at PR`L?@@xB????R@$M?<?@@??$>w?R@??+?z?@@|fI???R@???j?@@8? U?R@?u?!?@@?i????R@?l???@@PX?e?R@??C?@@|??A??R@??m?R?@@d?????R at d?c?@@P4`??R@??????@@PX?e?R@,?	???@@???~?R@$;6??@@?.???R@??C?@@?z???R@?/????@@?Q??B?R@??E}??@@d??Q?R@???~P?@@?????R@?M?#~?@@??	???R@???B?@@x` ??R@(????@@?d?R@?????@@??B??R@|l????@@(????R@|?????@@|~!<?R at T??;M?@@N^??R@?p $~@@d??E?R at f?%??o@@?}s??R@?}s?l@@?&l??R@??`h@@ ??>??R@????e@@P0?A?R at 8? "5c@@??
??R@? ?	`@@??`??R@>
??pa@@??a?R at d?? wc@@$[A??R@??? 4Z@@<?Y???R@?w?~?J@@?Hg`??R@??%??@@@$???{?R@??l?=@@??U?@?R@?n.??;@@?~NA~?R@??a??:@@|fI???R at z0)>>=@@??? ??R@?????<@@|E?^??R@QL? 3@@??p $?R@&;6?,@@?=~o?R@?H?},@@??????R@$,*?t&@@(??s?R@??9#J#@@?`?>?R@Q???!@@??`?
?R@?*O ?@@???g?R at .;??l@@??????R@????#@@@?? k?R@???!?@@ ?q?j?R@?mm?y	@@??#???R at x?0DN@@`?_???R at .2?@@?NA~6?R@?D???@@???!??R at L????@@??o?R@?s}@@@?Q?y?R@? ????@?????R@?8'0??@??????R at 0??w??@P??Z?R@(S????@?bc^G?R@?K???@d?s~??R@ B\9{??@`??9?R at P?0????@?Y???R@????_??@?F???R@?/????@p ???R at 0?Lv?@Tg???R@(???^k?@`?[>??R@??}j?@<??H?R@,???e?@?;???R@?9D?`?@?|~?R@?\7??Z?@??I`s?R at d73??,?@ ?"?~?R at x?'e?@?k?}??R@\?Fx?@o???R@?S??Y?@T1?~??R@?Z?!?@(__??R at H?`???@B????R at x?W??@$??}8?R at d*???@??Ma??R at H??? ?@p?_!?R@?
ND?
?@? \??R@??U???>@(??>V?R at x?u???>@$????R@??P?>@B@???R@??|@??>@d?????R@?????>@??????R@????>@??i? ?R@(??b?>@|o?R@ ??{G?>@h????wR@-y<-c>@?;?wR at l????\>@?P?zR@,l? W>@LI???{R@?_x%?O>@?????|R@??_>I>@??>?}R at L?*??>>@h????}R@c??K5>@@????{R@?0??">@??i? sR@|???>@l\??nR@??&??
>@L+?@.kR@??t
?0eR@3???>@(5??ZR@ ?!???=@]~pYR@??{?Y?=@???=#UR@ ?????=@c?~?QR@??????=@?????PR@$???=@?????ER at Ly???>=@PL? 3CR@????B5=@(???I?R@(??>V$=@<? ?<R@(?N>=
=@??bg5R@`$??\?<@????.R@?D???<@h?R@?(R@?*?w??<@<?I/&R@$???<@B@??#R@??????<@<}??R@?}s??<@?????R@`?_??<@?NA~6R at PR`L?<@ ? >?
R at P[#?ql<@????9
R at T?T?	g<@?7??R@?4?8ES<@|]??tR at L??uI<@??A??Q@????@7<@<? ??Q at L?*??<@|?????Q@?????<@,kg?Q at x???A?;@x9??c?Q@?Z
H??;@??x>?Q at P^d~?;@|6?>W?Q at P??{H?;@|ZEh?Q@?
?7?;@<?i???Q at t?????;@?? ??Q@ ??F??;@?!S>?Q@ ??F??;@??>??Q@?B]?;@?????Q at PR`L?;@ 2?Q@ ?????;@????s?Q@$????;@?????Q@??v???;@T=???Q@?=??j?;@?d?Q@??&???;@h?2?}?Q at T4????;@8????Q at T?T?	?;@?B??Q@?X?;??;@PR`L?Q@?L?:??;@B@???Q@?g@??;@?E?>?Q@|???S?;@?w?~??Q@??3???;@?E?~?Q at Ls+???;@?cw???Q@????B?;@h?
???Q@$[A??;@P1????Q at P?|a?;@f?s~??Q at Ly????;@:?!?Q@?@?9w?;@???A_?Q@??????;@?z???Q@,i?7?;@|fI???Q@???B?;@?6?^??Q@?	??b?;@???A??Q@<? ? <@&???{?Q@?H?F?<@~Q??B?Q at X?x?	<@N@a??Q@?L?:?<@<n??t?Q@??w??<@??4?Q@|!????;@??
??Q@ ????;@{????Q@@
??;@?E&???Q@??????;@??|?5?Q at P?|a?;@?qo~??Q@????B?;@N"???Q@?C4???;@????r?Q@?D???;@??????Q@<]???;@<?E~??Q@ ?={.?;@B@??wQ@???w?h;@???_pQ@|*?=%O;@$W@?nQ@????(L;@?G?lQ@ ?~?:H;@????XeQ@?W??-;@*???`Q@?????:@??/?_Q@??	?Y?:@8?? n_Q@?K????:@&8???_Q@?b???:@???@?`Q at d?%???:@zl???bQ@???B?:@|fI??dQ at P?????:@|????eQ@??M??:@f???hQ@??I~??:@???~lQ@???@??:@????AnQ@??
DO?:@??B?oQ@??Dg??:@<?i??qQ@ ??z?:@:?? ?rQ@<? ??:@????QuQ@?/?
?:@P7P??yQ@??????:@?D??|Q@?@?9w?:@`X?|?Q at X?????:@?#????Q@???w??:@??B??Q at T??y??:@??~7?Q@?I????:@?a??Q@???<?:@zo??Q@$w?Df?:@P????Q@??d?:@??M??Q@|-??1d:@"????Q at PI??&^:@??w?'?Q@???[?:@R}>??Q@????t9:@zu???Q at P?\?m/:@?:????Q@?}s?(:@8????Q@(u?8F":@??;???Q@ ?A|`:@:?]??Q@,i?7:@P:?`??Q at t?8F??9@???~??Q at T???"?9@?_"?:?Q@??????9@(??>V?Q@|??8G?9@`X?|?Q@ ??F??9 at PO???Q at 8?!?9@??????Q@??f??9 at z???a?Q at P?\?m?9@(????Q at P??|z?9@????0?Q@?h;???9@l\???Q at hp[[x?9@:???;?Q@ ?%??9 at z0)>>?Q@??C?9@<n??t?Q@???7?9@:? U?Q@????9@?$???Q@N^??9@??? ?Q@,??<??9@?????Q@?n??q9@???A_?Q@]P?2g9 at h???Q@?5_%G9@?Q*?	?Q@uX??;9@(#. ??Q@??C??69@??B??Q@??gx?29@& &?B?Q at hy??-9@??+?z?Q at T?{/&9@~??A??Q@|*?=%9@???~P?Q@?????9@ ? >??Q at PI??&9@?????Q@?]K?	9@???A??Q@?
?D?8@??:M?Q at x?4E??8@?????Q@?
?D?8@?????Q@(??=$?8 at 8????Q@(????8@?"?~??Q at P??|z?8 at T=???Q@?+??2?8@?$???Q@?n???8 at zi? ??Q at d??a??8@|?5^??Q@??v???8@$?`6?Q at d?g^w8@??i?Q@<5?u8 at h???Q@?@???p8@?????Q@|6?>Wk8 at T%??R?Q at d?fb?\8@??l??Q@?b???\8@?-?s?Q@(x
?R_8 at h?????Q@???Y._8 at PX?e?Q@?#?\8@$&??[?Q@???e?M8@???f?Q@??j??E8@W???Q@????=8@?qo~??Q@({K9_<8@??3?I?Q@?.??|>8@&??b?Q@|?i??G8 at h??Q@??|@?S8@&?B??Q@$???c8@(??>V?Q@$???h8@??????Q at PR`Lm8 at P????Q@???[?o8 at f?s~??Q@??C??f8 at RF\ ?Q at t????^8@*?^??Q@?>U?V8@?
)???Q@????lP8@??????Q@|!???O8@`???~?Q@?????M8@<?i???Q@????;8@?5?!?Q at h????18 at PR`L?Q at t?8F?+8@     ?Q@????r+8@~T?~OnQ@????+8@?Ws?`lQ@??9y?18@<??"iQ@????>8@~T?~OfQ@ ?z?H8 at R}>?bQ@?????H8@(??>VXQ@?}s?H8@??;?(PQ@?	???G8@??@?DQ@$???{K8@?|AAQ@???<C8@:tz??>Q at h?!?{C8 at h???b=Q@$z?rK8 at P:?`?<Q@???A?O8@??A?;Q@??z?S8@?Z? m4Q@?2Q??U8@????z2Q@??@fgU8@???>?/Q@????\Q8@?
)??/Q@?BF?K8 at zo?/Q@?5??
8@?????/Q@      8@???A?/Q@?P??Q?7 at z9??c,Q at x9??c?7 at f??}q(Q@?P??Q?7@??+?zQ@???[?7 at f???8Q@??v?7@????
Q@???[?7@???W
Q@?t????7@??T??Q at pU?wE?7@?: ??
Q@$M?<?7@&??)Q@????/?7@&???Q at h?ba??7@??^
Q@?P??Q?7@?E?~	Q@?????7 at zi? ?	Q@???#?7@<????Q@|?<??7@????ZQ@???&?7@?
)??Q at Lp???7@|fI??Q@?5???7@???iQ@?n???7@     Q@@J?i?7@&c`Q@?q?&?7@?F??Q@?_x%??7@?E?>Q at P???6?7 at d??~??P@ ??F??7@?d?P@???>U?7@?H.?!?P@???B?7@$?@??P@?w?~??7@&8????P at P??{H?7 at h???P@?1??8?7@???@??P at l^?Y-?7@???A^?P@?>+?7@(???I?P@|?<??7@&???{?P@??@fg?7@??m?R?P@???w??7@<??~?P@ ??F??7@?_"?:?P at lW??e?7@?5_%?P at P?GT?7@&?R?o?P@?0?{??7@??`?
?P@????Z?7 at d??A%?P@?BF?8@? l@??P at L???8@????;?P at 4=((E8@|Bv???P@$}ZE8@???M?P@??:?8@?6?[?P@???7-8@|fI???P@?????78@??
??P at T??y?G8@???j?P at P^d~Q8@??????P@????m8@{????P at P??|zt8@???@??P@??:??8@>?U???P at T?????8@|`???P@??o?8 at xx????P@?A??8@????@?P@??P?8@???L?P@?n???8@?$???P@|?????8@?`6??P@?i? ??8 at f?s~??P@??}?8 at R}>??P@EH???8 at RL? 3?P at L???h?8 at f?????P@?I?p?8@???>?P at PL? 3?8@??? ??P@?u?!?8 at d?w??P@??????8@?F???P@?
?D?8@??????P@??B??8@??? 4?P@?X?;??8@?:????P at PR`L
9@???@??P@??:?#9@???~P?P at h|_\?*9 at xx????P@?F?29@?u?!?P at d	kc?89@?:????P@|3j?J>9@?? l?P@(??bI9@??????P@|?e??S9@|-??1?P at x?q?Z`9@??~7?P@?????s9@?D???P@??7?a?9 at N"???P at T??y??9@??? ?P@ ??z?9@?z2???P@|??A??9@?`6??P at T??y??9@????U?P at L???h?9@??u???P@?\??k?9@??]?9?P@?$????9@?t_??P@????9@??Q?(?P@,???9@?|A?P@?5???9@??_>?P@?????9@????P@??>$|9@QL? ?P@???Z`g9@?????P@?-$`h9@ ?? ??P@???'l9@??????P at H???$q9@?^??P@`!sePq9@^?"???P at x??[Yn9 at PX?e{P at P????i9@&c`rP at T???"a9@???@gjP@H?]?W9@?i???eP at P?|aZ9@????bP@??&??]9 at J?L??]P at 0?!??a9@&??UP@????b9@~<???OP at d*??_9@<??? MP@?]K?Y9@??:MLP@??_>Q9@???!?JP@<????K9@????HP at d{-??I9@??m?RGP@@J?iK9 at 8?? nCP@?8???O9 at b?? ?;P@,l? S9@<??@f2P@??:?R9@?4E??0P at 8?]?R9 at f??.P@?~??@O9@?B?_?+P@?!<?H9@??/??*P at lU?A9 at PU??X*P@?pz;9@$??*P@?S^59@???!?,P at 8???(09 at P1???)P at x??E?)9@$???'P@(???+9 at z9??c(P@?h;??69 at d????'P@?;?<9@??+?z&P@$???@9@???q"P@??@fgE9@&??b P at du???C9@?????P@??9DD9@?????P at T??zT9@?5_%P@?N$?jj9 at P:?`?P@???fn9@?:???P@|-??1l9@<? ?	P@`??*r9@?/??P@??? t9@???P@?Fu:?q9@&??bP at Lp??o9@?????O at 8??!k9@??+?? P@??:?c9@|{??/P at d ???i9 at x?n?|P@???A?g9@?????P@??w?']9@?(z?cP@?5??V9@?C? P@?H?F?U9@??e???O@$????U9@??B??O@$???W9@$????O@?????\9@ ??>??O@?
?7_9@ ?A|`?O at h|_\?b9 at T
????O@????b9@???B?O@??y?`9@??C???O@ ??F?^9@?#?G?O@|?m?(\9@?&?|??O@`??>?X9@ ? ?S?O@?dT9@?p>??O at l^?Y-H9@?????O@$????9@??e???O at T?T?	79@EH???O@<2V??79@?j?#??O at P^d~99 at h???b?O@????;9@|i? ??O@$??=9@??#???O@$}ZE@9@??????O at hm?kA9@|`???O@??w??@9@??}?O@`'?ei;9@?B?_??O@???Y.79@ ? ?S~O@?@?9w79@|'f?zO at t?y??89 at T?3?YqO at T??z<9 at x???kO at t????>9@?9"??fO@?ek}?@9@??m?R_O@?=??jB9@?????LO@?4?8EC9@(???IGO@-@?jB9 at T???rCO@?\??kA9 at P???T=O@?? ?9@??M?/O@ ??F?.9@ ????(O@?????+9@????\&O at t??F?19@?{F"4"O@?: ??69@(???IO@`?_?89 at Lp??O@(?O:?89@???|yO at PX?e79@$G:#O@ ??59 at T8??
O@(??>V49 at PU??X
O@??E}?/9@?x?'	O@|'f?*9@?t???O@|????9 at 8?????N@?????9@??d ??N@?????9@?P???N@ ????9@?cw???N at 8:??89@??>$?N@6\?	9 at h???b?N at P???69@<?? ??N@?>+
9@??????N at PI??&9@???~P?N@@	]9@?T?~O?N@???9@??|?5?N@?Z(?,9@??6 ?N@???39 at x??C5?N at d????39@???C6?N@'i??29@??7?a?N@?Yg|_L9@(????N at PF\ Y9@????r?N@?z2??c9 at P[#?q?N@?&M???9 at x?U?0?N@ ?={.?9@???B?N@????(?9@?z2???N at 8+?&??9@??l??N at xrM???9 at P????N@ ?z??9@$D???N@?????9@|i? ??N at P???T?9@?ek}??N@????:@Ty=??N@ ????-:@?d?<
?N at T?{/6:@8?}?k?N at d?c;:@$???{?N@(??9x>:@Lp??O@?NG?O:@??7?a
O@????lP:@PR`L
O@$}ZEP:@???O@<\r?)a:@PX?eO at T@?? _:@??hUO@?v?1\:@|{??/#O@??9#J[:@$;6?$O@?n??a:@P?>?"O@????k:@?'??Z(O at P?&?O?:@T?^
8O@?]K??:@PF\ AO@????:@????EO@|?e???:@T:X??LO at X?????:@|'f?ZO@?>+?:@h??}q_O@(?R?o?:@??bO@,i?7?:@?`"jO@?)???:@?????|O@?2Q???:@??
??O@?qo~??:@?????O@??gx??:@$;6??O@(~??k?:@?M?=??O@?????:@??ZC??O@$??E??:@??^?O@?????:@?d?O@(h??'
;@h?^`V?O@?????;@PX?e?O@?w?~?;@$D???O at h??\? ;@<??bF?O@??C&;@?? v?O@???%?8;@xu???O@3???D;@|??B?O at t??F?=;@???A?O@|?<?:;@?B?_?wO@?????6;@???"MhO at 8???(<;@d*??cO@$qVDMD;@?_?|xfO@?=??jb;@|'f?jO at x?n?|r;@$???{kO@????ty;@(??biO@?S^?;@x??C5iO@??r???;@x9??chO at L??u?;@????fO@?Ry;??;@(?.??bO at T?z??;@?<?|?aO at H/??;@???@,aO@ ??F??;@?>??sbO@$???{<@TpxADdO@???B,<@?????dO@???f6<@h??dO@?b*??C<@(?o|?WO@??@<@8?!QO@???=<@P???KO@?6?x?;<@x{?CO@?b*??K<@|fI??>O at T?T?	[<@?b.3O@???Z`k<@$???(O at 8???Zp<@|l???O@(????u<@P%@?N@(??=$?<@T?t<f?N@@
??<@?z2???N@,i?7?<@x??C5?N at P??{H?<@ ?A|`?N@?]K??<@???B??N@(?R?o?<@Ty=??N@??????<@?????N at p?Z|
?<@??????N@(k?C4=@P}>??N@<#?&=@?H?}?N at TC?
D=@??_>?N at d??a?J=@PO???N at P???Te=@|?m?(?N@|*?=%o=@?+?P?N@??C???=@?:???nN@?|~?=@x???A~N@?+,??=@??X??N@??$A??=@|$%=?N at x???s?=@???B?O@??7?a?=@?Q??B
O@|?e???=@ ??>?O@|0)>>y=@$???{+O@?F?r=@T?t<f.O@?!<?p=@L.??:4O@?:q9^m=@???;O at L??ui=@????>O@??M?g=@?A?<?GO@???}?i=@(??|?O@$???x=@???~?O@<.?EDy=@     ?   |6?>WT@eM^:@L
4?sV@$?@?l>@   r      ??????T@?/?
?;@?u?!?T@??w?'?;@??A??T@?=??j?;@??,AF?T@?O8???;@,*?Z?T at P?\?m?;@?????T@|?b?:?;@??e???T@?Y?;@$???{?T@?+?`p?;@<?E~??T@?!<??;@?]??y?T at PU??X?;@?t????T@ ?={.?;@??????T@(r??9?;@,_????T@????;@??????T@??G?)?;@?????T at T??z?;@d?VA~T@ ?????;@??M?{T at PL? 3?;@?{e??yT@?w?~??;@?=?qT@?G,?;@?`6?nT@$?^F??;@x` ?fT@?QG??<@??W?^T@??Dg?<@??M?WT@????*<@?dST@?^}<?)<@(?N>=NT@,l? S<@x9??cLT@<?Y??]<@<??~LT at L?*??^<@l\??JT@??`<@T:X??HT@??B?a<@?#?FT@$?^F?d<@????BT@|?!8.g<@xB???;T@???r<@PF\ -T@?+,??<@]~p%T@(x
?R?<@????"T at P?\?m?<@??~7!T at d*???<@(G?` T@??????<@P
?=? T at T@?? ?<@???8T at T?T?	?<@?7??T@|!????<@??\?CT@?	??b?<@(?_T@???[?<@|i? ?	T at P?c*?<@{???T@@?v?<@|6?>WT at d????<@d?6??T@??????<@l?J>vT@????<@|fI??T@?!<? =@x{?T@?T?G?)=@???jT@?????4=@??m?RT@?V&?RG=@?? ?T at 81$'O=@<??HT@??9?Q=@????;T at P??{Hl=@??;??T@?L?:?{=@P"??T@????=@PI??&T@@?Q?y?=@??A$T@N^??=@?
)??T@ ?!???=@(G?`T at 87?',?=@f???T@???f?=@@??! T at P^d~?=@????T@??d#?=@???A_T@?i? ??=@$???T at x?q?Z?=@(??b"T@????:?=@(/2?$T@?}s??=@8??!&T at 8??!?=@P"??(T@??f??=@??? 4*T@?I????=@????r+T at x9??c?=@P7P??/T@|??B>@x{?7T at T??z$>@????Z<T@?B].>@???AT@??kzP4>@(5??BT@???7->@?.??DT@????? >@PI??&FT@?H?F?>@<????GT at x0H?>@???MJT@?NG?>@P}>?LT at X????>@?w?~?NT@(b?>@?NA~6PT at L?g\>@P???OT@(?R?o>@u??QT at x??C5>@???>ST@?Z
H?>@T(__XT@|?m?(,>@<??"YT@?Z
H?C>@?@I?YT@?O8??P>@PI??&ZT@??>$`>@?bc^G[T@@
?b>@|fI??\T@?ek}?`>@?x@?]T@???B\>@??B ?_T@???nW>@|K9_?bT at 8?!U>@<???;cT@?,???[>@$???cT@?N$?jb>@??t!VhT@$?@?l>@??B?iT at x?0DNk>@<??A?nT at P??|zd>@o??sT@???]>@<??A?vT@????l`>@?9?}?|T@??w?']>@xW=`?T@?h???U>@|<????T at d?b?>@x]?`7?T@???@?>@PX?e?T at PL? 3>@??e???T@??r??>@?T?~O?T at L???h?=@??h??T@?I????=@h?????T@$????=@PCT???T at Lm????=@??i? ?T@???x??=@?z2???T at hs????=@@?a?'?T@$????=@P????T@??E}??=@?^??T@?~??@?=@h??>??T@|????=@L.??:?T@@ ????=@????z?T@????z?=@l\???T@$??}=@??\?C?T@(x
?Rw=@8???(?T@ ?%?p=@????Z?T@$??E?j=@?`6??T at h????]=@("??T@?(z?c0=@??P???T@?>+*=@L.??:?T at x???s*=@??????T@|?%9`+=@?#??T@?t???)=@?"1A
?T@?A?/=@x?n?|?T at Ls+??4=@?'?>?T@????:=@TC?
?T@?j?=&>=@<??@f?T@?>+J=@P.?_x?T@?dL=@<n??tU at T4???B=@$??U at Ljh?5=@?????U@?h;??.=@??4
U@??6 (=@T(__
U@ ??{G!=@?6?[U at X?y?
=@xx???U at Lvl??<@?*?)U at T?X?;?<@<????U@?T?G??<@????U@???Y.?<@?????U at 8?!?<@T=??U@(??b?<@c?~?U@|!????<@(??bU@?D/?X?<@xW=`U at d?????<@?"?~?$U@???f?<@?.??(U@?z2???<@?%9`W-U@ ??F??<@d???,U@$z?r?<@P
?=?4U at PR`L?<@<?I/6U@ ?A|`?<@?f??<U@??????<@??
?BU@$??E??<@f`XCU@`$??\?<@???@?DU@|-??1?<@(5??FU@ ??G??<@o??}LU at x?0DN?<@<????KU@?????<@?9"??HU at 8??!w<@??RAEGU at P???Te<@????FU at l????P<@W??GU at L?*??N<@?}s?HU@?BF?K<@?*?)OU@?V&?RG<@?I+RU@?H?F?E<@??6 XU@???|C<@?? lYU@ 2D<@`X?|ZU@?	???G<@??M?[U@?b???L<@???A^]U@(r??9M<@<?e?YeU@?70?QH<@?I+nU@?@?9wG<@P1???oU@??C><@?=?qU@$?S;?4<@?f??tU at P?\?m/<@???8vU at P[#?q,<@??]??wU at hX???*<@|??A?xU@?/?
&<@T:X??|U@???W<@?.??|~U@??{???;@PU??X?U@?5???;@l?J>v?U@|6?>W?;@8???U@T?^
?;@??'???U@????r?;@{????U@?pz?;@?????U@,????<@8???(?U@?{F"4<@|i? ??U@??v(<@T^+???U at h??\?<@8w?^??U@????s<@T"?^F?U@|?(B?<@$????U@??B??;@P?>??U@??/???;@<??"?U@?O8???;@???j?U at Ljh??;@$W@??U@??3?/<@???q?U@?^??<@<?U???U at T????<@<?(A?U@?4~??<@$W@??U@ ????<@?d?U@??^<@?d?U@ ? ?S<@?????U@?c?<@u???U@?p>??;@??u???U@$??E??;@??a?U@?????;@c?~??U@??????;@?NA~6?U at 8???(?;@?r???U@???;@????U?U@??gx??;@d?????U@,?	???;@h??U@??}?;@?I+?U@???A??;@PU??X?U@|?,C?;@(2s???U@???w??;@8en??U@????H?;@??,AF?U@|-??1?;@?'?>?U@,i?7?;@?d???U@(??=$?;@?<*???U at PL? 3?;@h?2?}?U@?????;@|??A??U at t?????;@??t!V?U at T???"?;@xu???U@?U????;@?`6??U@ ?!???;@ 2 V@??????;@?1 ?V@$???{?;@$???{V@????;@|????V at L???h?;@X??#	V@??????;@????	V@(r??9?;@?"1A
V at x??Dg?;@?N?`?V@????Z?;@?????	V at PI??&?;@??p?V@@???;@~? ?V at P?&?O?;@<????V@??????;@????V@????;@???8V@???w?H;@???? V@|0)>>9;@???? V@?0Bx?1;@P
?=? V at D?H??&;@$????U@????;@????AV@<??;@<?U??V at 8(a??;@d????V@???B?:@??w?'V@@?v?:@L
4?sV@?Z{???:@??FV@??*???:@??A?V at P?\?m?:@???V@?N$?j?:@??I~?V@??????:@?`6?V at l?R]??:@|H???V@?H?"}:@h???V@??ky?n:@?"??JV@eM^:@x?a??U at T?T?	g:@|6?>W?U@({K9_l:@?'?>?U@(u?8Fr:@TH?9?U@???#x:@?????U@???|yu:@??@??U@?????l:@i??U@ ? ?Sf:@?x?'?U@?[zd:@8?? n?U at T??y?g:@?<*???U@?pzk:@??/??U at 8??!o:@??i? ?U@QL? o:@|c ??U@???k:@?6?^??U@ ??F?f:@?Q??B?U@??`:@x` ??U@$w?Dff:@???@g?U@?\???|:@????H?U@|??A??:@L?#~??U@?I????:@8?????U@wJ??:@<?????U@?u?!?:@8?]??U at lu9% z:@d?s~??U@????o:@P@???U@???[?k:@(?N>=?U@?[<??t:@(?R?o?U@?????:@(??b?U at Ld???:@?u?!?U@(?R?o?:@???`??U@?L?:??:@h?R@??U@??}?:@<????U@?B]?:@???@??U at 8?]??:@<??~?U@???i?:@?u?!?U at d ????:@?t???}U@<,????:@P???|U@$?^F??:@?C?wU@??????:@h???8pU at x?u???:@?9"??nU at P[#?q?:@<??@fnU at P??|z?:@?`6?nU@?6?x??:@o??nU@?M?#~?:@?]??ymU@??????:@???A^hU@?Y?$??:@?(z?cdU@????Z?:@??;??bU at L???h?:@?f??`U at x?q?Z?:@?;??\U at L??u?:@??B ?UU@?-???:@?;??TU at P[#?q?:@$???SU@?sD?K?:@??? 4NU@???W?:@|H???LU@?=??j?:@$???KU@$qVDM?:@P@??=U@??E}??:@????6U@$??;??:@|6?>W3U@?z2??;@<?E~?1U@|?(B?;@???80U at pLOX?;@?Q?G-U@????g;@????)U@ ? ?S
;@$&??[)U@?n.??;@????A*U@?u?!;@????+U@?\7??";@xu??+U@???x?4;@?1=a?+U@????r;;@h???)U at d??a?J;@?????(U at du???O;@PR`L&U at T?T?	W;@??M?U at T?X?;[;@?Q?GU@,i?7^;@PF\ U@?O8??`;@???U@???ic;@?? l	U@|?(B??;@??3?IU@??M?s;@????9U@(~??kq;@d?: ??T@?.??|r;@|r
?T@@74e?s;@??I~??T@?O8??p;@???A??T@$W@?b;@d?{???T@?? Z+Z;@??????T at T@?? _;@????N?T@|???b;@?????T@|$%=e;@$????T@???w?h;@?#????T at Ljh?u;@xx????T@??6 x;@<??A??T@?g@?y;@??????T at H/?y;@??~7?T@?W?Bi;@??6 ?T@??`;@????T@??G?)[;@?i? ??T@$???W;@??a???T@,i?7V;@?0_^??T at PO??X;@??????T at T?T?	_;@(c`?T@ ?!??c;@???M?T@??or;@????Z?T@???s;@$????T@?????r;@?L???T@????s;@T=???T@?/?
v;@?r???T@??)X??;@?? ??T at P?&?O?;@$?????T at T:X???;@x` ??T at t?8F??;@?:????T at t?y???;@??????T@?/?
?;@     8   ????0V@?D???:@$#gaOW at PL? 3S<@   ?       ??~7W@????y?:@h??W@??#??:@d???W@|'f??:@?ng_y?V@?F??:@?9"???V@??{???:@?????V@?e?%??:@(2s???V@??^?:@P<???V at PI??&?:@?E?~?V@??v???:@t???V@?c!:?:@(????V at T?T?	?:@?i????V@?.m8,?:@(????V@?=??j?:@P"???V@|?????:@N^??V@@??P?:@?i????V@ ?={.?:@?N??:?V@$????:@??????V at hs????:@xrM???V@$w?Df?:@?
)???V@|*?=%?:@?Ko.?V at T=???:@`?????V at L?????:@?Q?G?V@|??A??:@??M??V@|?y??:@?????V@|?y??:@i??V@?????:@<?e?Y?V at T1?~??:@xT???V@????:@d?VA?V@?70?Q?:@??6 ?V@??d?:@??|?5?V@,l? ?:@????A?V@$????:@|l????V@?;??:@Pg?!??V@??I?:@????9?V@@	]?:@??$???V@?t????:@?D???V@$?????:@??p??V@$qVDM?:@??,AF?V@??d?:@c?~??V at h???b?:@?z2???V at x?4E??:@?E?>?V@(r??9?:@?	/??vV@	Q???:@?cw??sV@|$%=?:@P@a?rV@?m???:@??RAEqV@?D???:@@?a?'iV@?? ?:@LF?a?gV@?7?a??:@??|?5iV@5????:@???!iV@???<?:@|<???eV at T?P???:@???dV@?I?p?:@|<???aV@?_x%??:@?????^V@<? ??:@??A?WV@???B?:@???~WV@|?m?(?:@]P?2SV@?t????:@?????QV@??????:@?H.?!NV@?ek}??:@?7??LV at x?q?Z?:@??>?IV@?&M???:@8en?HV at T?P???:@h???FV at T???"?:@?=?EV@?,????:@???iEV@?????:@h??}qBV at 8???(?:@??d ?<V@,oG8-?:@??|?59V@ ?????:@??]??7V@??_>;@Z_&7V@|!???;@?????4V at T@?? ;@????2V at P[#?q$;@PL? 30V@??
??%;@????0V@?/?
&;@r???0V@?
?7/;@P?>?3V at x??C5A;@????5V at P???D;@?@I?9V@?????F;@????Q:V at 4=((EK;@`???:V at pN%@Q;@l\??:V@ ???!R;@???>;V@??vX;@$???;V@|3j?J^;@xE???<V@$W@?b;@PL? 3=V@|3j?Jn;@(__?=V@iT?dw;@<???	?V@??w?'};@?????@V@@????;@d?6??CV@(?J=?;@?????EV@?t????;@????FV at T?????;@L.??:HV at PU??X?;@|-??1HV@??E}??;@d??~?JV@???x??;@h?2?}KV@????a?;@|??A?LV at t?}???;@???MV@???7?;@xZ~?*OV at X?L???;@????9QV@ ?!???;@<???	WV@|*?=%?;@?qo~?XV@??
DO?;@?]??yYV@?w?~??;@??? 4ZV at PL? 3?;@XU/??\V@????%<@(?
?0]V at L???h<@P@??]V at X????<@PL? 3_V@ ??F?<@??G??eV@?
?D$<@d???hV@<? ?(<@??t!VlV at P[#?q,<@??;?(nV@@??,<@??I~?oV at T????,<@$???rV@??*??1<@<?i??uV@????l@<@<???;wV@???|yE<@@??`?V@??z?R<@T%??R?V at PL? 3S<@8?? n?V at T????L<@(?R?o?V at P?&?OJ<@{????V@|?y?H<@(??>V?V at L?*??F<@h??}q?V@<?\?C<@???@-?V@????aB<@\y????V@|'f?><@????N?V@|6?>W3<@??,AF?V@???i+<@<???r?V at La???&<@$[A??V@??B?!<@?????V at x??C5<@$?	??V at lj?Z_<@?x@??V at PU??X<@,????V@??M(D<@??(@?V@?????<@??????V@???<<@?u?!?V at x?0DN<@i??V at 84e?<@?Z? m?V@?ek}?<@?1 ??V@$qVDM<@?????V@??`?<@??????V@?i? ?<@?9?}??V@?70?Q<@P@???V at T:X??<@$???V@?/?
?;@????N?V@<8???;@??>??V@?P??Q?;@????0?V@??????;@?k&?l?V@<&R???;@?+?P?V@$??? <@h??>??V@?)??<@?????V@,l? <@(???I?V@?qo~?<@??????V@(??=$<@(5???V@?K???
<@(5???V@,????<@?7???V@?t{I?;@????V@????B?;@?Sb?V@????P?;@???~P?V at t??F??;@(5???V@,oG8-?;@Pg?!??V@???0?;@???j?V@??B??;@8? U?V@<?Y???;@???!?V@?e?%??;@?????V@??????;@(2s???V@(?J=?;@?#??V@|?,C?;@d????V@|?e???;@?I+?V@????i?;@<?I/?V@?c???;@??$???V@?Qew?;@PF\ ?V at x???s?;@(????V@??r?S?;@|??!U?V@?;??;@d???j?V@$?????;@B@???V@??E}??;@?9[@h?V@??P?;@??U?@?V@???$?|;@???>U?V at L?*??n;@$W@??V at Lp??o;@|??!U?V@?CVt;@?? ??V at 8?~??y;@?;??W@?B]^;@h????W at L??uY;@$#gaOW@??z?K;@|E?^?W@???C60;@????? W@??z?+;@???? W at T?z?;@|x? #W@???"M;@?n??W at P?"?;@P4`?W@?M?#~	;@<?i??W@<????;@????sW@$??:??:@|0)>>W@Z_&?:@<??A?W@????B?:@?Hg`?W@<)???:@??~7W@????y?:@     @   ???0?K@??n?!?6@?!<?0L@???|y:@   ?       ???0?K at X??j?6@???0?K@?,?Yf?8 at HR????K@ u??8@????*?K at T+~??8 at T?t<f?K@?<?E~9 at T?<?K@???@?9@|fI???K@?b??9@??????K@?????#9@??????K@?@?9w'9@?T?~O?K@?BF?+9@|?e???K@(??=$09@???>U?K at L???h49@?s????K@???9]>9@()? ??K@?Mc{-H9@??????K at 4?Ry;N9 at PU??X?K at T7?O9@?V&?R?K@?9??q\9 at P?|a?K@?i??d9@?n.???K@??9?i9@@? ??K@(????u9@??????K@?E?>y9 at 8t??P?K at t???	?9@?b*???K@(?N>=?9@???cw?K@?`????9@???I?K@?+-#??9@??????K at T???N?9@?z?I?K@`?2???9@???_??K@?b????9@i????K@?HV?9 at 4?z???K at p!??F?9@$??;??K@(?[Z
?9 at T||Bv?K@??P???9@??l??K@??`?>?9@?oB!?K@@?m?9@???@,L@????9@??1?L@???@??9@?\??k	L at X?L??:@N??;
L@\??y?:@??#??L@???|y:@?^?"?L@|?e??:@??]?9L@??v?9@?t???L@??Q??9@??
?L at t?5=(?9 at h$B#?L@@????9@??!YL@??????9@???cwL@`=?[??9@?
? xL@????H?9@?? @?"L@?????9@(_?B*L@<]???9@?I??h,L@(??=$?9@?;l"3/L at x0H??9 at P?D?.L@(n?@w9@?H?}.L@????k9@?????.L@,?F<?a9@(eRC0L@? ???W9@?!<?0L@ ???!R9@?n.??/L@ ?9z?B9 at T1?~?-L@?%??9@?h???-L at T:X??9@?G?C?-L@?^??9@????/L@?J\???8 at h??-L at T?z??8@?y??d+L@?Mc{-?8@?????*L@!<?8?8 at Ty;?i+L@ ??z?8@? ???+L@??????8@??%??*L@?x?'?8@?v|?&L@??c??8@(/2?$L@??;??8@?????#L at l?J>v?8@??}"L@???|y?8@$;6?L@????g?8@`L?{)L at PL? 3?8 at T@?? L@(eRC?8 at T?t<fL@??b??8@???>U
L@?????8@,?F<?	L at T?????8 at PO??L@@????8@f????K at P?c*?8@?L???K@?i? ??8@<?\?L at X?x??8@|`??L@???@??8@ ???qL@?S?{F?8@|?(B?L@(n?@?8@?d L@ ???!?8@? ?> ?K@??c?8@?m????K@?b*???8@(?J=?K@??????8 at T1?~??K@?????8@,?????K at x??C5?8@??;?K@?BF??8@ 2?K@??????8@??`??K at l^?Y-?8@|???-?K at T4????8@(\????K@??|@??8@??????K@ ? ?S?8@|!????K@???w??8@?d?K at X?????8@?H?}?K@ ? z8@(\????K@?k?}?j8 at l?Z_$?K@??d#Q8 at P?????K@<?<c_>8@??^f?K@???W?68@??3?/?K@?1??8:8@??1??K@<?$?<8@?\??k?K@<Y??;8@????L@?A?"L8 at T:X?? L@6\?8@? ?	?K@(\???8@??;???K@???8 at h???K@|?i??8@?X"??K@?5_%8 at Ts??P?K@?]K??7@??`??K@?????7@~??7?K@?-]??7@?oB!?K at X?????7@??3?/?K@??9D?7@(_?B?K@,?F<??7 at x???A?K@???|S7@?B=}?K@(??=$H7@?\??k?K at h??`o>7@??[??K@?????37@(?N>=?K@?d(7@?a??K@?
???7@???i?K@?St$?7@?K ?)?K@(????6@,?~N?K at T:X???6@?????K@?%???6@??????K@|????6@?yT???K@??`??6@ ?=~?K@,l? ?6@???!?K@??n?!?6@???0?K at X??j?6@     L   ????V@ h???4@????*W at L???J?:@         4   O   i   ?   ?   ?  ????V@$?@??5@(2s???V@??x!?5@??l??V@?+,?6 at 8????V@???#6@{????V@??M?'6@????Z?V@?C4??,6@?n.???V@?H?"96@<??@f?V at P[#?q<6@?@I??V@?E?>A6@(???I?V@|$%=E6@o???V at PX?eW6@???A??V at P??|zd6@????N?V@???r6@<??A??V@?ek}??6@????\?V@?4?8E?6@]~p?V at x?0DN?6@<??"?V@$???6@@?????V@  _B?6@????N?V at x?q?Z?6@<??@f?V@??B??6@<?????V@|?<??6@????N?V at Lg'???6@????@?V@??I~??6 at PX?e?V@|0)>>?6@?cw???V at x<-?p?6@r????V@????H?6 at Ts??P?V@(??>V?6@?t????V at lXSY?6 at h?????V@?5_%?6@?;???V@ ?z??6@??f?V at dl?f?6@<???	?V@?u?!?6@$???V@?oB!?6@$?w~Q?V@$???6 at xE????V@?>+?6@??????V at PU??X?6 at d?VA?V@|*?=%?6@<??"?V@??????6 at P7P???V@??ky??6@$[A??V at X?y??6 at PR`L?V@$?^F??6 at 8?!?V@     ?6 at P7P???V@???x?|6@??Q?(?V@|$%=u6@?p>??V at Lp??o6@??i?V@?????Q6@??=x?V@?a?? ?6@(?N>=?V@??G?);6@<}???V at PO??(6@<?(A?V@?????"6@$ &?B?V@??j??6@????V@$?@??5 at P<???V@???|y6@????N?V@???B,6 at 8?? n?V@|*?=%/6@`?? ??V at X????H6 at P"???V@|$%=U6 at d????V@??vX6@<??~?V at t?8F?c6@??????V at P????6@???=??V@(?
?0?6 at P<???V at PI??&?6@????s?V@ ?9z??6@????9?V at t?y??h6@??i? ?V@(k?C4R6@B@???V@??7?aJ6@$???{?V@|?e??C6 at PX?e?V at x?4E??6 at L+?@.?V@??M?76 at d??@??V at H|??36@`X?|?V@?X?;?/6@??(@?V@??&??-6 at h??V@??P)6@f????V@?*?w?'6@?Q?G?V@?I?p6@?.???V@????6@????V@?	???6@??K?A?V@?b??6 at P<???V@???|y6@??????V@??vX6@<?E~??V@?????X6@???>?V at x???sZ6@???j?V@$?@?\6 at xE????V at PX?eg6@??A??V@?w?~?n6@?H.?!?V@ ?bG?x6 at P@???V at Ld??{6@?1 ??V at x?4E?6@?1 ??V at T?P???6 at P@???V@(?J=?6 at 8}=_??V@???i?6@?f???V@?w?~??6@]~p?V@??z??6@?&???V@-@?j?6@^?V at T@?? 6@??#???V@??B?q6 at P????V at P?\?mo6@<??~?V@?L?:?k6@???_?V at T?T?	g6@?l ]?V@?\7??b6@??M??V@?????^6@$???{?V@?C4??\6@??e???V@??z?[6 at h?????V@?]K?Y6@??????V@??vX6@?qo~??V@?G,y5@??Q?(?V@??
DOz5@<?????V@$???{5 at PL? 3?V at P????}5@x` ??V@????H?5@l\???V@???W?5@?????V@?/??5@??p $?V@`2?C?5@(5???V@?5???5@????@?V@?B]?5@??#???V@$}ZE?5@??????V@ ??{G?5@{????V@??????5@\????V@?Y????5@?????V at x?u???5@??????V@???w??5@?w?~??V@?#??5@l\???V@??v???5@??8a??V@?v?1?5 at PR`L?V@?&M???5@?7???V@     ?5@]~p?V@?>U?z5@?qo~??V@?G,y5@?F???V at t?}???5 at l?? ??V@(r??9?5 at h o??V@?X?;??5@<?????V at T?z?6@l\???V@??5?	6@???? ?V@?,???6 at d?????V@??C6 at x{??V at PL? 3#6@?Q??B?V@?I???&6@u???V@??M?'6@?Tka?V@?	??b)6@??`?
?V@@?v6@??#???V at P??C6 at xrM???V@???? 6 at h?????V at P?????5@?F???V at t?}???5@??h??V at 0??8*7@?4E???V@??C???6@?????V@\??AA?6@?^)?V@,?6+?6@(?
?0?V@?X?;??6@?B??V@$???6@???A^?V@???
?6@????V@?@???x6@$?*???V at 4\???n6@$???{?V at T@?? _6@?????V@?70?QX6@]P?2?V@?Z??M6@?????V at x???AF6@|Nz???V@?D??46@??I~??V@?B?y?/6@??????V@???,6@??@j?V@S???$6@$????V@??gx?6@??????V@?Y?$?6@?=??V@$[A?&6@?????V@|$%=56 at T=???V@(???;6@ ? >??V@,????B6@?w?~??V@??
DO66@???A^?V@?>U?*6@????V@$z?r6 at h????V at 84e?6@<?$@M?V@?ek}? 6@?<c_??V@?[?t?5 at d??a??V at d?b??5@?P??V@??J#f?5@?Q?G?V@<? ??5@?}s??V@?Fu:??5@??e???V@?Yg|_?5 at h?????V@(r??9?5 at PX?e?V@?8????5 at h?2?}?V@|$%=?5@<?? ??V@(?????5 at P@???V@?]K?	6 at d?????V@?!<?6@??f?V@?????6 at P%@?V@|-??16@????V@<#?6@?0??B?V@?U???.6@? \??V at 8:??86 at d????V@?NG?6@?:????V@$}ZE6@???=#?V@???a??5 at 0&???V@@74e??5@?I+?V@?`<??5@$???{V at x?n?|6@|fI???V@??/?? 6@??e???V@?fh$6@??????V@??/??(6 at P4`??V@??>$$6@<??A?~V@???C?6 at L%<??~V@?9d??5@?6?[}V@?D???5@??I~?{V at t?????5@????zV@?????	6@????NzV at PO??6@??;??zV at T=??6@????zV@?5??"6@<?e?YyV at PL? 336@(/2?xV@,oG8-86 at d?g^xV@? ?=>6 at x{?wV@??v??F6 at d???jzV@???"M\6 at d????{V at t?8F?c6@???~|V at PX?eg6 at 4??<~V at d??
n6@??
?V@?#?Gs6@     ?V at Dh?{6@?4E??~V@?;?x6@???@?~V at d???v6@????Z|V@?a?? o6@??? 4zV@?z2??c6@<???	wV@?ek}?P6@????AvV@(??bI6@????uV@EH??B6 at P
?=?vV@?C?b?56@????@wV at 8?a?A.6@<tz??wV@?n.??'6@o??wV@|'f?6 at h??}qwV@|$%=6 at PL? 3vV@|6?>W?5@??!?vV@?5???5 at P=???wV@$?@??5@?p!?xV@?n???5@????\tV@?Ry;??5@<??rV@?L?:??5@$?@?lV@??????5@(?
?0eV at P?`???5@{???cV@$???5@<? ?bV@???i?5@(??baV@??????5@?????aV@|?m?(?5@(???cV@??p??5@?l ]dV@?????5@??,AFfV at T:X??6@????fV@,?F<?A6 at d?F ^gV@?t???Q6@<}??dV@?????C6 at PL? 3cV@?2Q??56@???cV@({K9_06@|Nz??cV@ ????)6 at d??@?dV@????:$6@@?a?'eV@9D??6@??`?$cV@???)?5@?z??aV at hy???5 at 0,?-bV at X32?]6@(&o??aV@(?[Z
6@?8~?`V at X S$6 at L+?@._V@?=??j26@c??K_V@`??*:6@?^?_V@???W?B6@|???a^V at 8.??J6@?cw??]V@?ZH86@B@??_V@$??!6@?9??*`V@???/6@??a??`V@??)??6@??|?5aV@$}ZE6 at H
m 6_V@??QcB6@?E?>aV@?d?<
?5 at h?aV@?]K??5 at P7P??]V@?QG???5@??I~?ZV at Lm????5 at h??YV@?/?
?5 at LF?a?WV@?t?? ?5@<???;WV at x0H??5 at L+?@.WV@?B]?5@?q???WV@???i?5@????kXV@|$%=?5@<??XV@?C4???5@???^?WV at T?T?	?5@????VV at 8??"N?5@??e??RV@|?(B??5@(?B?RV@ ?A|`?5@$???OV at hv?[??5 at p!??FMV at x?????5 at h????MV@?[?t?5@|????MV@|0)>>?5@??Q?(LV at X?x??5@?E&??IV at PF\ ?5@??l?FV at PL? 3?5 at d?VAEV@$?????5@??W?EV@???d??5@?^?EV@??[<?6@??V`?CV at t?<G?6@$???CV at d???6@??ADV at p???6@???@-DV@???6@?@I?FV@???$?$6@?*???DV at 4???416 at h????CV at T??f?46@ 	??%AV@,?F<?A6 at l?J>v at V@??;?F6@?cw???V@???S6@??{???V@|E?f6@?]??y;V@??????6@??? =7V@$????6@<???;7V@|*?=%?6@?N?`?7V@@N??7@??bg9V at d*??7@????:V@??E}?7@??1!?>V@`]??47@?????4V@???!>7@????3V@??C:7@?1=a?.V@????@?7@?f??-V@?^??E7@(&o??-V@?	???O7@????N/V@???}?Y7@?T2 T2V@???is7 at p$?`S2V@`??*~7@]~p0V@??Q?(x7@<???r%V at d??a??7@???8$V@??
???7 at h????$V@ ?~?:?7@ ????&V@???!??7 at xZ~?*(V@?$y??7@????+V@?{?E{?7@?@I?/V@??p=
?7 at 4SZK0V@|?"n
8@????s.V@??x?n8@?w?~?,V at PF\ 8@$?6?D-V@??(8@?4E??,V@????&8 at h???-V@|'f?.8@?F? \/V@x` ?/8@???>0V at p?0'h78@?~NA~/V@ u?=8 at xx???.V at T?P??B8@<?I/.V@???A?G8@?;???,V@????aN8 at xrM??*V@???[O8 at P<??)V at x?0DNK8@?? v V at L??uQ8@??A?V@?4?8EW8 at PX?eV at L??ui8@??? 4V@???is8@??? V@?1=a?w8 at PU??XV@??????8@??|?5V at do)???8@????V@???i?8@(/2?V@??B??8@??/??
V at 87?',?8@?(z?c
V@<?????8@????	V at 8w?^??8@?E?~V at L
4?s?8@????V@@ ????8@???@?V@|6?>W?8@|c ?V@?NG??8@??? ?V@??J#f?8@?? lV at hv?[??8 at P"??V@?b??9@?????V@(???9@?%9`WV@?t?? '9@?C?V@????:09@<?? ?V@?t?? 39@?B?'V@??gx?29@(??b)V@?F?29@?F??-V at T?z?19@?9?}?8V@????-9@?n.??;V@|'f?*9@??M~?<V@???i+9@|c ?@V at P?&?OJ9@??$>w?V@???X?N9 at P@a?;V@?????N9 at P@??7V at T???"U9@??l?5V@?K?^]9@?3???4V@?1=a?g9 at P4`?5V at 8? "5m9@??8a?5V@????v9@(???I5V@?t?? {9@?Ko.3V@,?????9 at h?1V at X?????9@?B?_?-V@???7}9 at h????)V@?sD?K}9 at 8???#V at x??C5?9@??^V@?????9@?f??V@??Hh??9@<????V@?/??9 at P1???V@??J#f?9@??K?AV@??s???9@<??@fV@??????9 at PF\
V@?????9@<n??t
V at X??x??9@~??7	V@??d#?9@?dV@?b???9@?'?>V@??
DO?9 at d???
V@?}s?:@?????V at La???&:@?T?~OV@|???!2:@????NV at 8???Z8:@PCT??V@?X?;??:@u??V@?70?QH:@???A^V@?4?8ES:@?T?~OV@$z?r[:@?mm?y!V@?T[^:@?:??? V@ ?%?h:@?D???V@??E?u:@ ?{?V@?}s?x:@??P??V@??:M|:@???A?V at 8???Zt:@?}?AzV@????{:@d???V@??????:@D?X?oV at L???J?:@$???V@(?N>=?:@d?s~?V@?b???:@h?N??$V@????w:@(5??&V at h?ba?x:@?cw??+V@uX??k:@L:??l,V@?CVd:@????
-V@??PU:@?d??/V@??x#K:@T7?6V@?mm?y=:@?T?~OAV@ ?4<:@?????BV at lQf?LF:@Xa3?>V@`?D?V:@??a;V@???d?[:@ ??^E:V@??(&od:@4??a0;V@?????l:@??<??<V at dv?Sq:@?????DV@?;??b:@????EV@?Y?XL:@?^?GV@<?U??-:@x?a?HV@?yY':@???a1PV@?u???:@?ng_yTV@??EB[:@?<*??UV@??$\:@?bc^G`V@???q:@E? cV@???d :@|c ?fV at p??\?:@d???fV@?P?l:@p???dV at x?q?Z :@?~?~?cV@??a':@?/??fV at 4?Ry;::@??<??hV@???::@?R?!?iV@???0:@$???kV at d??]?(:@|Nz??nV@???B(:@xu??qV@??;?:@?F??uV at Lp???9@(??>VvV at D??~??9@@?a?'uV@?X?;??9@,*?ZtV@(?N>=?9 at P=???sV@?P3???9 at PI??&vV at T???"?9@<???;wV@??&???9@????@wV@?5???9@<???	wV@??|@??9@`X?|vV@??D???9@?l??tV@?B]n9@|0)>>tV at D? ?]9 at Ts??PuV at L?*??N9@(?R?ovV@??9?I9@????xV@?5_%K9 at d?F ^zV at 81$'O9@u??}V@?BF?K9@|`???V@?????B9@$[A??V@?)??69@?"?~??V@?@?9w'9@<??@f?V@??C&9 at d??~??V@??o&9 at h?????V@|0)>>)9@?Hg`??V@?4~??,9@?t????V@$??E?*9@u???V@????&9@$????V at La???&9 at h?????V@??P)9@??????V@|?b?:,9@<??@f?V@?a?? /9@?9"???V@(??b19 at h?????V@(u?8F29@????V at d??
29 at h?????V at t?y??49@{????V@ ??F?.9@???~??V@????#9 at h?>??V@?U???&9@??M??V@?U???*9@?n.???V@?W???.9@`X?|W@<2V??/9@<?E~?W at x<-?p-9@?Ws?`W@?,???+9@????ZW@ ?!??#9@?Q?GW@(??>V9@?I+W@?P3??9@<??@fW@???|9 at d??QW@?B]?8 at l???W@??8?~?8@?f??W@(?????8@??_>W@?i????8@????vW@???~??8 at 8?M?aW at l?? ??8@?L?^?W@<?zj?8 at T=??W@?`S?Q?8@??B?W@??B??8@$?`6W@ ?%??8 at xx???W at 8?!?8@??$??W@?>U??8@?????W at Ld???8 at T4???W@B]??8@?Z? mW at P?"??8@?z2??W at H?p?8@?"1A
W@?Z
H??8@??i? W@?????8@??x>	W at d?b??8@?????W@$?^F??8@(??>VW at hy??}8@?7??W@?8???o8@<?(AW@ ?bG?h8@??A?W@ ?!??c8 at P@a??V@????Q8 at xE????V at L??uY8 at 0M???V@??_Z?S8 at 8w?^??V@?p>?H8@?????V@?sD?K-8@  |?V at 8??_?&8@????V@? ???'8@?q ??V at X????8@??U?Z?V@|?,C8@?S??V at x???A8@ 3??O?V@?I???8 at Xya??V@?~??@8@`?"???V@???B8@`?o`r?V@<?? ?8@?Ko.?V@?????7 at h?B,?V@?h;???7@?%9`W?V@?/??7@|uU??V@??g?7@|?5^??V@@????7@f`X?V@?u?!?7@$W@??V@??????7 at h???V@$???7@????\?V@<?U???7@?(z?c?V@?K????7@<?$@M?V at P?`??s7@?????V@??E}?_7 at PL? 3?V at T??zL7 at P"???V at xE???<7 at L.??:?V@?Ry;?57 at l?J>v?V@?O8??07@?+?P?V@?X?7@?P??V at T???"7@?E&???V@?b???7@????V@??d#7@??>??V@<?Y??7@(__??V@,oG8-7@??????V at T?z?!7 at x9??c?V@?B].7@???I?V@???#87@??????V@??I'D7@$?6?D?V@(b?C7@?f???V@?
?7?7@???A_?V@?(z?c87 at xB????V at x??E?)7@?d?V@,oG8- 7@N^??V@`2?C?6@<??"?V at h?"???6@<??@f?V at t?????6@u???V at L??u	7@????\?V@|?,C7@??A??V@?????(7 at xx????V@??B?17 at h?????V@??v??:7@(??)?V at la?9A7@(???I?V@0?[wG7 at PI??&?V@|!???O7@?????V@????/V7@??(@?V@?]K?i7@?p!??V@??Io7@|Q?_?V@???0q7@(5???V@?P?l?7@i??V@???7@?Q??B?V@0?[w?7@???A_?V at L???h?7 at d?g^?V at T?{/?7@????Y?V@??
DO?7@??????V@??????7@W??W@?:q9^?7@???MW@??f??7@?@I?W@?!<??7@(?
?0W@?	K<??7@?;??W@?[<???7@(?
?0W@,oG8-?7@(2s??W at d????7@?`6?W@??{?Y?7@??3?/W@,J	???7 at P
?=?W@$?S;?t7@??B?W at t??<^7@?B?W@??C??V7 at 4bf??W@?f?"I7@??iW@??E}??7@?(z?cW@??N$?:7@?????W@???-7 at P"??W at x?q?Z?6@??l?W at xB????6 at h?N?? W@ ???6 at h?>?!W@K????6 at h????!W@?:q9^?6@?d$W at Ld??[6@??x>%W@??}R6@@???4&W at T????,6 at d???&W at T?P??"6@]~p%W@?????6@????s&W@????r?5 at P}>?&W at T?T?	?5@?Ws?`'W@?????5@`?
??'W@?z??9?5@???~'W@?B]?5 at PU??X&W@?b*???5@(??>V&W@??>$?5@???j&W at PU??X?5@|c ?'W@?P??Qx5@???A_(W@(?N>=j5 at d?VA)W at P?\?m_5@?]??y)W@?????Y5 at 8???(*W@????Q5@????*W@,?)L5@$W@?*W@(???K5@u??&W@?#?@5@?????%W@?
?7C5@<??@f"W@?/?`5@?Z? mW@<)??x5 at d?VAW@ ?A?x5 at P
?=?W@|'f?j5@???8W@?L?:?[5@?F??
W at T????L5@???@,
W@ ?%?85@??h?
W@QL? #5@????W@@???5@?qo~?W@???B?
5@?dW@<????5@?I??hW at x??E??4 at P
?=?W@(???I?4@?@I?W@@ ????4@$W@?W@?1??8?4@???A?W@?qo~??4@???=#W@??3?/?4 at t?^?W@ h???4@<???;W at d??a??4@(?N>=W@??ky??4@?Q?G
W@?w?~??4@$???W at T???"5@`X?|W@?]K?!5 at h??W@? ?=*5@<?? ?W@????/5@??i? W@????:5@?6?[W@?????@5 at h??W@?l??H5@???@?W@|-??1T5@???? W@?B]^5 at d???j?V@?_x%?g5@<??"?V@|6?>Ws5@??,AF?V at PX?ew5@<?$@M W@?a?? 5@?T2 TW@$W@??5@?`6?W@?]K??5@?#???W@?D???5@??7?? W@?D???5 at P?>??V@?I????5@ ?????V at pEb??5@E?>??V@?s????5 at l???V@`???|?5@T????V@??G??5@ ? >??V at x???A?5@??;???V@??????5 at P<???V@|?b?:?5@<??@f?V@?d6@$#gaO?V@???6 at h??`o?V@???0%6@{????V@?Fu:?16@??t!V?V@iT?d;6@??bg?V@(?N>=B6 at T.T???V@??B?Q6@?#????V at x???sZ6@@???4?V@$???`6@$???{?V@?*?w?g6@?E?~?V@  _B{6@(5???V@??????6@?H.?!?V@|?????6@????Q?V@?#??6@$[A??V@ ?!???6@???@,?V@(?N>=?6@?? l?V at La????6 at PR`L?V@???[??6@?U????V at x?q?Z?6 at P@a??V@??d?6@??A??V@ ?!???6@l\???V@(x
?R?6@????V at d6\?6 at P:?`??V@??f??6@|Bv???V@|'f??6 at d?s~??V@?????6@~??7?V@???C6?6@?*?)?V@????r?6 at T7??V at 8% &??6@?2??
?V@???9??6@$?????V@???@??6@`?_??V@?????6@?Q??B?V@?????6@??A??V@???~??6@r????V at h???b	7@|Nz???V@?
1^?7@<???	?V@?5??27@?????V@?)??R7@??????V at d?%??_7@?D???V@?Y?ww7 at P????V@??v|7@??=x?V@??oz7@|E?^??V@ ?????7@???j?V@?????7@??L?D?V@??;?(?7@??{?V at T??y??7@?9"???V@??7??7@ ??c?V@,?F<??7@???i?V at Lvl?}7@f????V@??????7@<}???V@K????7@?`?>?V@'?;?7@?Y?>??V at T?{/?7@?T?~O?V@???i?7@????0?V at PX?e?7@?.??|?V@??^?7 at h?>??V at h???b?7 at Tal!??V@??1ZGq7 at h???V@????ab7@???~?V at x??Dge7@]~p?V@?t???i7 at x{??V at x?0DNk7@?? l?V@???~?m7@?Y?>??V@??E}?o7@??I~??V@|'f?j7 at PR`L?V at PL? 3S7@?I+?V@(?R?oN7@?z2???V@????zL7@?
j???V at P????K7@??\?C?V at x???AJ7 at h?????V@?JY?8>7@??_>?V@?X?77@|6?>W?V@??>07@?"??J?V@????/7@?????V at T?T?	7@??I~??V@<?? ?7@??Z`??V at TL??p7@??????V@(5??7@??h??V at 0??8*7@?E?>?V@??E}??6@$???V@|3j?J?6@??x>?V at L??u?6@|?????V@@????6@(??)?V at TC?
?6 at h???V at 8.???6@<???;?V@??B??6@?&???V@??*???6 at h??V@ ??F??6@|3j?J?V@?I?p?6@|o??V@$??E??6@$?w~Q?V at 8(a???6@<??H?V@??^?6@???f?V at d?b??6@?????V@?????6@???>U?V@?5???6@<??~?V@ ?????6@???0?V at D?????6 at 4;????V@d?w?6@?f??V@???XP?6@?@I??V@,oG8-?6@?E?>?V@??E}??6@   	  L   ???0?K@?R]?? 1@@?m?M@,???c^:@   f        C  ???0?K@?R]?? 1@???0?K@?|$%4@??v?
?K@?{?E{D5@?Q??B?K@|????5@ ?=~?K@,l? ?6@?yT???K@??`??6@??????K@|????6@?????K@?%???6@,?~N?K at T:X???6@?K ?)?K@(????6@???i?K@?St$?7@?a??K@?
???7@(?N>=?K@?d(7@??[??K@?????37@?\??k?K at h??`o>7@?B=}?K@(??=$H7 at x???A?K@???|S7@(_?B?K@,?F<??7@??3?/?K@??9D?7@?oB!?K at X?????7@~??7?K@?-]??7@??`??K@?????7 at Ts??P?K@?]K??7@?X"??K@?5_%8 at h???K@|?i??8@??;???K@???8@? ?	?K@(\???8 at T:X?? L@6\?8@????L@?A?"L8@?\??k?K@<Y??;8@??1??K@<?$?<8@??3?/?K@?1??8:8@??^f?K@???W?68 at P?????K@<?<c_>8 at l?Z_$?K@??d#Q8@(\????K@?k?}?j8@?H?}?K@ ? z8@?d?K at X?????8@|!????K@???w??8@??????K@ ? ?S?8@(\????K@??|@??8@|???-?K at T4????8@??`??K at l^?Y-?8@ 2?K@??????8@??;?K@?BF??8@,?????K at x??C5?8 at T1?~??K@?????8@(?J=?K@??????8@?m????K@?b*???8@? ?> ?K@??c?8@?d L@ ???!?8@|?(B?L@(n?@?8@ ???qL@?S?{F?8@|`??L@???@??8@<?\?L at X?x??8@?L???K@?i? ??8@f????K at P?c*?8 at PO??L@@????8@,?F<?	L at T?????8@???>U
L@?????8 at T?t<fL@??b??8 at T@?? L@(eRC?8@`L?{)L at PL? 3?8@$;6?L@????g?8@??}"L@???|y?8@?????#L at l?J>v?8@(/2?$L@??;??8@?v|?&L@??c??8@??%??*L@?x?'?8@? ???+L@??????8 at Ty;?i+L@ ??z?8@?????*L@!<?8?8@?y??d+L@?Mc{-?8 at h??-L at T?z??8@????/L@?J\???8@(eRC0L@,?????8@?????4L@??K?8@,??<??L@???W??8@,?~NCL@?\??k?8@?b??EL@??????8@?Q??BML@????l?8@??hUOL@??}?Az8@<?\?SL at T?P??r8@?v|?VL at L?*??n8@???|[L@?)??f8@(?J=fL@?(?7O8@ 2hL@?E?>I8@<_?\6jL@???>8 at T@?? oL@@?v08@|?m?(tL@?Z
H?#8@?)??~L@ ???!8@??VBw?L@?z2??8@?_?|x?L@?E?>?7 at h?????L@?
?7?7@??????L@(b??7@??????L at T?????7@ 	??%?L at L??u?7@?-?s?L@<?????7@??N@?L@$w?Df?7@(/2??L@?_?|x?7@?w?~??L@? :v?7@(5??M at L??u?7@|???
M@?d?7@?????M@?	????7@?K ?)M@?+,??7@??3?/M@(k?C4?7@??}M@v5y??7 at d^G?M at h??!?7@??"M@|?(B??7@??$??%M at du????7@(,???+M@?H?F??7@@?0`?3M at X?y??7 at PO??8M at L?*???7 at h?!?{=M@B]??7@?Gp#e?M@v5y??7@??$??IM@????7@$>w??MM at T?z??7@?I?peM@??U?Py7@ 	??%oM@?;?\7@?[Y??vM@?H?F?Q7@????M@?
?737@???@,?M@?S?)7@?!?A?M@?Yg|_$7@ 2?M@???9]7 at P?????M@??:?
7@~??7?M@ ?~?:7@??a??M@???&??6@|!????M@??t?6@??????M@?h8e?6@?r???M@?Z{???6@?+?P?M@????g?6@ ??>??M@|?,C?6@|?(B??M@?1??8?6@?!<??M@|?e???6 at x???A?M at P????6@(??>V?M@??????6@ ?=~?M@?Fu:??6@??t><?M at x??C5?6@<???M@?I?p?6 at P??B??M@(h??'}6@@?m?M at lXSYn6@(??s?M@|???O6@|????M@?k?}?J6@<?????M@?.m8,96@?v|??M@?????*6 at T7??M@??5?6@<???R?M@?f???5@(5???M@,?	???5@(?
?0?M@(???I?5@??$???M at X?????5@|?i???M@?J??q?5@??}?M@??????5@??????M at X?L???5@??_??M@??d#?5@??X??M@(h??'q5@$A?
?M@????k5@??i? ?M@?]K?i5@(k?C4?M@???[`5@??D?M@ ?~?:\5@??t><?M at P???L5@@?M?GuM@???#5@|?:mM@????75@?K ?)kM@ ?
5@??e??fM@(_?B?4@?????ZM@|?y??4@??%??\M at PF\ ?4@??d#]M at d??a??4 at t????ZM@?7?{??4@?????SM@????i?4@|fI??LM@<?????4@?_?|xJM@???&??4 at T||BvHM at PI??&?4@?9"??BM at PX?ek4 at h?R@?9M@?NG?[4@?I?p5M@|?<?Z4@|]??t#M at X?L??^4@?)??&M@?^??a4@????Q"M@?}s?`4 at h??M@?H?F?e4@?b*??M@ ?={.k4@??x?nM at do)??u4 at P???M@????|4@ ? "M@?S?{F?4@???@?!M@??6??4@?????M@??M(D?4@|W?[M@?O???4@??VBwM@??9D?4@?O??
M@??r???4@?????M@?NG?4@(?J=M at P?_?v4 at T=???L@?????b4@?+?P?L@????A4@?oB!?L at L?g\74@@?M?G?L@?%??24@???A^?L at dx?g?,4@<?????L@??`?$4 at h?!?{?L at P???64@? ?	?L@??d#?3@??e???L@???eN?3@(_?B?L@,?B;??3@?-?s?L@ ???!?3@?d?L@???>U?3@ ?????L@(???I?3@ ??<e?L@?]K?y3@?T?~O?L@?+,?l3@(b??L@?Z
H?c3 at d??a??L@?#?\3@?+?P?L@?O??T3@(????L@?Gp#eK3 at PO???L at P???6 at 3@X(????L at T7?3 at h?!?{?L@???<3@<??? ?L@?T????2 at 8?}?k?L@??)X??2 at T:X???L@(??=$?2@???@??L@?<?E~?2@|?,C?L@yv???2@?v|??L@?4?8E?2@???|?L@,i?7?2 at P????L@?9??q?2@(?
?0?L@(?
?0?2@?s????L@??????2@(?
?0?L@?,????2@?????vL@|!????2@@???`sL@?;??2@$??]?gL@?E{???2 at T1?~?eL@(????2@|????]L@ ?A|`?2@??r??ZL at x0H??2@,??<?SL@?V????2@???jRL@??M(D?2@?&M??QL@<????2 at x??C5QL@|???o2@??(@NL@????gU2@?g]??JL@??:?C2@?????GL@(??b92@???_?FL@??Dg?12@$8???GL@?`U??"2@??RAEGL@??_>!2@??DBL@(?J=2@,??<?=L@?b*??2 at h??`o:L@(???2@?????3L@,l? 2 at T:X??,L@??3?/?1@??%?-L at T?????1@?g]??&L@??)X??1@????*"L@??r???1 at T1?~?L@???|?1@?#?L@?+,??1 at Ty;?iL@|!????1@???A^?K@,????1@(?
?0?K@(n?@?1 at T?t<f?K@,??;??1@???j?K@?+,??1 at h$B#??K at x0H??1@??????K@? :v?1@?t????K at h?!?{?1 at h?????K@?;??1@?????K@?z2???1@(/2??K at P?"??1@?`??K@?Gp#e?1@??????K@?t????1@(??>V?K@@}??.?1@|????K@????1 at P????K@??w???1@?`??K@?k?}?~1@??K?K@?Z
H?w1@??}?K at h?!?{s1@????/?K@?i? ?k1@???
?K@????/f1 at Tv?A]?K@????/^1@??X??K@(??>VD1@?K ?)?K@?\??k11 at l?????K@<???1@(&o???K at T?P??
1@??#??K@<????1@???0?K@?R]?? 1@?? @?"L@?????9@?
? xL@????H?9@???cwL@`=?[??9@??!YL@??????9 at h$B#?L@@????9@??
?L at t?5=(?9@?t???L@??Q??9@??]?9L@??v?9@?^?"?L@|?e??:@??#??L@???|y:@N??;
L@\??y?:@?5_%L@?_?|x:@(?J=L@????? :@h-??L@???X?::@?????L@?????B:@(_?BL@???A?7:@,????&L@???|3:@(2s??)L at T?P??2:@????-L@?>?'I7:@?Gp#e3L@??M(D8:@<?y?91L@??@fg=:@T4???,L@??^=:@????*L@??d#9:@?n??'L@|??B9:@(/2?(L@?QG??D:@,kg-L@?S?{FR:@?g@?3L@,???c^:@T???r3L@(\???H:@?k?}?:L at L?g\?:@????=L@???u=:@h?^`V<L@?d$:@??'?H0L@??#?,:@??'?H0L@9D??2:@??^)L@?K???*:@9D??*L@?????:@?yT??/L@?70?Q:@?	??.7L@???
:@x???A6L@?4?8E?9 at Ty;?i3L at T:X???9@(k?C42L@?n.???9@ ?]??.L@?=??j?9@?????)L at d ????9@?????&L@?/K;5?9@<??? #L@?NG??9 at h?{??!L@|??A??9@?? @?"L@?????9@????SM@(???+4 at h???RM@????+4@?E?>QM@|?m?(<4@???@,QM@?w?~?>4@?E~?QM@??3?/F4 at P????QM@|?,CW4@|???RM at X?x?Y4@(??bSM at d?b?^4@?t???YM at T???l4@??}[M at T@?? o4@??%??\M@?????m4@?O??^M@$????m4@?????`M@v5y?n4 at T=??aM@,?	??p4@???_?dM@??s??x4@??$??iM@??}?4@?E~?qM@???9]?4@???_?rM@??_>?4@?<c_?uM@?k?}??4@?????yM at T?P???4 at T?<xM@??P??4@$;6?tM@?? @?z4@|?<?rM@?70?Qx4@????oM@??9?u4@ ? ?SnM@?qo~?t4@<?8b-lM at L??uq4@ ?=~iM@?c> ?i4@?	??.gM@?W???^4@?)??fM@?C4??\4 at T8??eM@?+,?T4@@?mdM@???)K4 at T?<dM@??P??G4@<?<c_\M@???54@od?UM at T????,4@????SM@(???+4@
  ?   ht?3?R@?
j??#5@?d?Y@??H.?YB@   ?      ht?3?R@??H.?YB@?d?Y@??H.?YB@?d?Y@?g#??6 at LLb??Y@|*?=%?6@???A^?Y@yv???6@?????Y at h?????6@?l ]?Y@??Dg??6 at 8?]??Y@?}s??6@$?6?D?Y@???C6?6@,)w???Y@??????6@$ &?B?Y@???~?}6@?????Y@({K9_l6@?????Y@????re6@????Y?Y@????n6@??????Y@l?`qt6@??~7{Y@<????o6 at PL? 3sY@?sD?K}6@<q9^?qY@?Z
H?6@<n??toY at P?\?m6@?p>?lY@ ?bG?x6@?K???jY at P^d~q6@????\jY@??	?Yi6@?_"?:kY at P?\?mc6@???hY at T7?G6@?qo~?dY@????56@?W??"hY@????l?5@???kY@?W????5 at h?>?pY@?h????5 at PI??&pY@`'?ei?5@??
?rY@??I?5@?F??qY@|*?=%5@??/??pY@?d?<
t5@?t?_?oY@?St$?[5@????koY@????ZP5@|-??1qY@???X?J5 at P7P??sY at PF\ I5@???MvY@ ?bG?@5@@???^vY@?66;R=5 at d???vY@(x
?R75@???MrY@??y?$5@??$??nY@?
j??#5@??x>mY@???x?,5 at 8? UkY@(u?8F25@???fY at T??z<5@?f??dY@??I?5@(#. ?`Y@|?!8.?5@?????XY@?H?"95@??]??UY@?P??Q05@l\??RY@??1ZG-5@?N??:PY@???~?55@?!S>OY@?C4??@5@???A?OY@???>UU5 at d??@?PY@?X?;?_5@???A?KY@?(?7?5 at x?n?|IY@$??E??5@?E&??JY at La????5@??? ?JY@?????5@,MJA?GY at T???@?5@??t!VFY@?O???5@???~5Y@??
???5@o??3Y@?L?:??5@?-W?63Y@?P3???5@??;?(.Y@?????5@<}??(Y@|'f?z5@?f??$Y@<&R??s5@?????Y@??
DOv5@??|?5Y@?????~5@?sD?KY@<Y???5 at d?: ?Y@??5??5@???>Y@?D/?X?5 at d???Y@|'f?z5@(??)
Y@??A_zo5@????
Y@?/?
v5@?<c_?Y@?n.???5@???!?Y@??Hh??5 at d?VA	Y at PU??X?5@(??bY@$????5 at h?????X@??G?)?5@?#????X@?????5@??:M?X@(?N>=?5 at d?s~??X at x?0DN?5@(??b?X@(??>V?5 at 8?M?a?X@?U????5@????b?X@?F???5@??F?X@,????6 at PF\ ?X@??P??6 at d?????X at 8% &?6@(??b?X@?>+
6@$????X at x?0DN6@?_"?:?X@@	]6@i??X@????6@(2s???X@?????"6@???A??X@?A?6@$?`6?X at T?X?;6@?ng_y?X at 8(a??6@???n?X@??w??6@??W??X at T?h?'6@??I~??X@$???g6@???@,?X@?X?;?o6@?sD?K?X@W?}Wt6 at PL? 3?X@??6 x6@<??~?X@???$?|6@??u???X@??5??6@?n.???X@?????6 at TC?
?X@?c???6@$?w~Q?X@?????6@|K9_??X@?7?a??6@??3?I?X@</??6@Z_&?X@??I~??6@??p??X@??!? 7@??+???X@?B]"7@?OU???X@??d7@????X@???L7 at T:X???X@???}?7 at P:?`??X@??N$?7@?6?[?X@????l07 at d??@??X at X????H7 at L+?@.?X@|?e??S7@$???X at x??E?i7@|?????X@(~??kq7@(2s???X@?g@?y7 at P??5?X@({K9_|7@?a??X@?a?? {7@?????X@?)???7@??;???X@?4?8E?7@??4L?X@??????7 at d????X@,?	???7 at d?	???X@?T????7@??????X@({K9_?7@?T?~O?X@??}?7@@?} R?X at 8b->8@ ?> ??X@??8 at x<-?p?X@????8@{????X@????
 8@`???X at x0H?(8@? ?}??X@?8?@d%8@??r???X@?8?@d!8@?r???X@??"h8 at d?&??X@?im?8 at h?????X@??G??!8@?% ???X@$f?y?"8 at 0)>>!?X at x
? 8@??~??X@??sF?8@`?? ?X at T4???8@3m???X@$?`68@<??@fzX@$[A?8 at PX?eyX@???i8@?Ws?`wX@  _B?7@<}??pX@|?b?:?7@<??HlX@(u?8F?7@??A?iX at T??E	?7@???~PiX at L?*???7 at P4`?hX@???n?7@??|?5eX@?????7 at d?VAcX@?q?&?7@|???abX at t?????7@????9iX@$??
8@??`?ulX at 8(a??8 at 8???(nX at PR`L8@??i? oX@$W@?"8@$???oX@ ??{G)8@??_?pX@??gx?B8@?&??mX@??`8 at P4`?jX at 8? "5q8 at h????bX@?>U?z8 at 8???cX at L??u?8@N^?cX@??????8 at Tv?A]dX at h|_\??8 at LF?a?cX@???:T?8@????\cX@????k?8@????eX@(b??8@???jX@$W@??8@???lX@?h????8 at d??A%oX at T?X?;?8@????AnX at T?X?;?8@????snX@?ek}?9 at TO?}pX@?Gp#e9@?`6?rX at PL? 3#9 at d????sX at Ld??+9@????#tX@???|y59@?
1^?tX@????:@9 at d?s~?vX@(??>VD9@|<???xX@??I?9 at h?B,zX@??? 469 at 8???z|X@|6?>W79@$?`6?X@? ???O9@`?? ??X@ ?!??c9@??????X@?]K?i9 at h?????X@??????9@??????X@?{F"4?9 at L.??:?X@????9 at d?s~??X@???A??9 at 0kb???X at x??Dg?9@??i? ?X@??5??9@?f???X@? ????9 at 8en??X@ ?A??9@f????X@?
b??9@??$???X@|?i???9 at D????X at L???J?9@|??!U?X at 8% &??9@?_"?:?X@??&???9 at d?? w?X@,l? ?9@?n.???X@??+?z?9 at P@???X@|-??1?9@??????X@|0)>>?9@|??A??X@???>U:@?{
?q?X at d.? :@u???X at PL? 3#:@?f???X@??*??%:@??x?n?X@?????:@<}???X@?&M??:@|]??t?X at T?X?;:@<?e?Y?X@??c?!:@P}>??X@(???I/:@("??X at PX?e?:@|`???X@?????\:@o???X@???7m:@i??X@(????:@???A??X@?=Ab??:@?1 ??X@?k?}??:@??????X@?[<???:@$?6?D?X@?\??k;@h?2?}?X at T?z?!;@??? =?X@????B5;@8?M?a?X@??v??:;@h?????X@<? ?@;@<??~?X@??r?SR;@?'???X at L?E?\;@?}s??X@|0)>>a;@?Hg`??X@??>$x;@??#???X@@N???;@<?e?Y?X@|?<??;@?H.?!?X@?I????;@???A^?X@|?m?(?;@$?6?D?X at T?z??;@??w?'?X@?~??@?;@d?VA?X@??;???;@(c`?X@@?v?;@?N??:?X at L?g\?;@?]??y?X at ldWZF?;@???@g?X@?????;@P
?=??X@??B??;@h?R@??X@?=??j?;@ ?a???X@???[?;@$????X at T?T?	?;@|W?[?X@ ???!<@d????X@QL? <@?Q?G?X@??d&<@`????X@???B(<@H?P??X at h@?57<@???M?X at T????D<@o??yX at 8?!a<@????vX@(x
?R_<@P4`?uX@???X?Z<@???sX@?C4??X<@8?Q??oX@@N??k<@d??A%oX at Ls+??t<@$?`6nX@?(z?c?<@(?
?0mX@?O???<@??I~?cX@?z2???<@??I~?_X at Lm???j<@xx???^X@$w?DfV<@?oB!^X@?e6L<@d?	??\X@???W?J<@????ZX at hs???K<@d?VAWX@?????><@?T2 TVX at H/?9<@??!?SX@??M?;<@$???OX@(??bI<@????9OX@|?,CO<@<?i??IX at x?4E?_<@??4HX at d ???a<@????QFX@??	?Ya<@$)?ahCX@?L?:?[<@?9?}?@X@???|yU<@?@I??X@???U<@????#4X@|????]<@?????1X@??v`<@????z0X@??M?g<@?
)??/X@?
?Dl<@??~7+X at P???Tu<@xu??)X@$???w<@d??Q&X@?IEc?w<@$???X@????j<@???@?X@?T?G?Y<@d??A%X at x?u??d<@?1 ?X@$w?Df?<@????NX@??l??<@?1=a?X@???7?<@	?c'X@??????<@?bc^G'X at X??x??<@@???&X@????Z?<@?I+"X@???|y?<@??? X at t?<G??<@o??X@?E?>	=@?H.?!X at L?*??=@??~7X@?C4??=@?dX@?d=@?@I?X@Z_&?<@????X at x??E??<@???@,X@(?????<@h o?X@?!<??<@|3j?JX@???B?<@$??}8X@<#??<@h????	X@???A??<@?????	X@(???I=@????X at Ljh?%=@h??>?X@??C*=@<??@fX@?U???*=@????QX@?,???+=@?T2 TX@(?R?o.=@?C?X@??j??A=@?K???X@ ??{GI=@|????X at P?"?F=@????X@?/?
>=@?`???X@???f>=@|K9_?X@??a?A=@|i? ?
X at P?_?F=@LLb?X@?u?!P=@??>?X at d???Y=@|]??t	X@????Be=@??g?RX@??ky?v=@????YX@,i?7v=@(__? X@$[A?n=@|?5^??W@??hUe=@??i?W@|-??1d=@d?s~??W@?????W=@`?? ??W@ ??{GA=@?????W@ ?A?0=@?&???W at T?P??"=@$????W@????
=@??6 ?W@$??E?
=@|??A??W@?]K?	=@??!??W@EH??
=@$?w~Q?W@,i?7=@?xZ~??W@???a?#=@???M?W@? %?,=@??????W@\?'??B=@?(A??W@G?&V=@?;3?p?W at 0?r?]U=@??M??W at 0n??E=@?|a2?W at X|E;=@ ?|?W@??"??6=@PCT???W@??{?7=@?h?^`?W@`?
?+7=@\?????W at t?5=($=@?????W@?????=@???^D?W@??<I=@???!??W@? @???<@? 3???W@ c?ZB?<@?"1A
?W@?N"???<@<?e?Y?W@????<@<??A??W@??K?<@???@W@?:?? ?<@?3???}W at Ts??P?<@?;?%yW@??B??<@8????vW@ ?a???<@(5??nW@??VBw?<@?W??"lW@?/?
?<@?{??miW@|o??<@l??fW at lg??R?<@????bW at lQf?L?<@h???aW@?x"???<@L(D?!`W@??=]??<@h???0\W@?X?;??<@?q ?XW@??????<@@???VW@e?f?<@?P?UW at Hw;S?<@???@?TW@x?=\?<@(?_RW at t<f?2~<@?B?_?MW@@C?k<@ ?? >OW at 0???/c<@??5OW@?
(?W<@???!6NW@????Q<@<??aHW at 8???Q<@?J???BW at h9?CmO<@????;W@?c???;<@?? !?8W at H$a?2<@?$??6W at 8 B\93<@???>5W@@?@?w6<@<?I/0W@??h>+<@???w-W@?U,~S$<@h?>?+W@????`<@8n1?7+W@,~SX?<@?<*??+W@ ?P?f<@??? !.W@\C???
<@TC?
.W at d??a??;@Q???,W@??????;@]P?2)W@?F??;@x` ?"W@@???;@LLb?W at 0??:??;@xu??W@????o?;@(?
?0W@$z?r?;@????#W@?n???;@?????W@??eO?;@P.?_xW@?????;@`??-W@     ?;@<?e?Y	W@?M?#~?;@?cw??W@     ?;@?qo~?W@??{b?;@L?'?W@ #???;@|K9_? W@??#??;@?????V@@????;@???@??V at P?c*?;@Q????V@@??"2?;@d????V@|?e???;@?#??V@|?,C?;@(2s???V@(?J=?;@?????V@??????;@???!?V@?e?%??;@8? U?V@<?Y???;@???j?V@??B??;@Pg?!??V@???0?;@(5???V@,oG8-?;@???~P?V at t??F??;@?Sb?V@????P?;@????V@????B?;@?7???V@?t{I?;@(5???V@,????<@(5???V@?K???
<@??????V@(??=$<@(???I?V@?qo~?<@?????V@,l? <@h??>??V@?)??<@?+?P?V@$??? <@?k&?l?V@<&R???;@????0?V@??????;@??>??V@?P??Q?;@????N?V@<8???;@$???V@?/?
?;@P@???V at T:X??<@?9?}??V@?70?Q<@??????V@?i? ?<@?????V@??`?<@?1 ??V@$qVDM<@?Z? m?V@?ek}?<@i??V at 84e?<@?u?!?V at x?0DN<@??????V@???<<@??(@?V@?????<@,????V@??M(D<@?x@??V at PU??X<@$?	??V at lj?Z_<@?????V at x??C5<@$[A??V@??B?!<@<???r?V at La???&<@??,AF?V@???i+<@????N?V@|6?>W3<@\y????V@|'f?><@???@-?V@????aB<@h??}q?V@<?\?C<@(??>V?V at L?*??F<@{????V@|?y?H<@(?R?o?V at P?&?OJ<@8?? n?V at T????L<@T%??R?V at PL? 3S<@@??`?V@??z?R<@<???;wV@???|yE<@<?i??uV@????l@<@$???rV@??*??1<@??I~?oV at T????,<@??;?(nV@@??,<@??t!VlV at P[#?q,<@d???hV@<? ?(<@??G??eV@?
?D$<@PL? 3_V@ ??F?<@P@??]V at X????<@(?
?0]V at L???h<@XU/??\V@????%<@??? 4ZV at PL? 3?;@?]??yYV@?w?~??;@?qo~?XV@??
DO?;@<???	WV@|*?=%?;@????9QV@ ?!???;@xZ~?*OV at X?L???;@???MV@???7?;@|??A?LV at t?}???;@h?2?}KV@????a?;@d??~?JV@???x??;@|-??1HV@??E}??;@L.??:HV at PU??X?;@????FV at T?????;@?????EV@?t????;@d?6??CV@(?J=?;@?????@V@@????;@<???	?V@??w?'};@(__?=V@iT?dw;@PL? 3=V@|3j?Jn;@xE???<V@$W@?b;@$???;V@|3j?J^;@???>;V@??vX;@l\??:V@ ???!R;@???>U9V@???>UU;@P
?=?4V@ ??G?b;@?Ko.3V@$??E?j;@?r??1V@?W??q;@????0V@?w?~??;@(???I3V@??&???;@?"1A
4V@??*???;@?x?'5V@??E}??;@<???6V@??	?Y?;@x9??c8V@?h;???;@????#8V@(??=$?;@$???7V@????B?;@`X?|5V@|???<@h?2?}1V@ ??z
<@PX?e/V@??*??<@LLb?'V@?b??<@P+L?k#V@?????<@f??? V@??7?a
<@??x>V@<&R???;@??|?5V@?U????;@?L??V@???	?;@PCT??V@|-??1?;@????sV@ ?bG??;@X??#	V@??????;@|????V at L???h?;@$???{V@????;@?1 ?V@$???{?;@ 2 V@??????;@?`6??U@ ?!???;@xu???U@?U????;@??t!V?U at T???"?;@|??A??U at t?????;@h?2?}?U@?????;@?<*???U at PL? 3?;@?d???U@(??=$?;@?'?>?U@,i?7?;@??,AF?U@|-??1?;@8en??U@????H?;@(2s???U@???w??;@PU??X?U@|?,C?;@?I+?U@???A??;@h??U@??}?;@d?????U@,?	???;@????U?U@??gx??;@?r???U@???;@?NA~6?U at 8???(?;@c?~??U@??????;@??a?U@?????;@??u???U@$??E??;@u???U@?p>??;@?????U@?c?<@?d?U@ ? ?S<@?d?U@??^<@$W@??U@ ????<@<?(A?U@?4~??<@<?U???U at T????<@???q?U@?^??<@$W@??U@??3?/<@???j?U at Ljh??;@<??"?U@?O8???;@P?>??U@??/???;@$????U@??B??;@T"?^F?U@|?(B?<@8w?^??U@????s<@T^+???U at h??\?<@|i? ??U@??v(<@8???(?U@?{F"4<@?????U@,????<@{????U@?pz?;@??'???U@????r?;@8???U@T?^
?;@l?J>v?U@|6?>W?;@PU??X?U@?5???;@?.??|~U@??{???;@T:X??|U@???W<@|??A?xU@?/?
&<@??]??wU at hX???*<@???8vU at P[#?q,<@?f??tU at P?\?m/<@?=?qU@$?S;?4<@P1???oU@??C><@?I+nU@?@?9wG<@<?e?YeU@?70?QH<@???A^]U@(r??9M<@??M?[U@?b???L<@`X?|ZU@?	???G<@?? lYU@ 2D<@??6 XU@???|C<@?I+RU@?H?F?E<@?*?)OU@?V&?RG<@?}s?HU@?BF?K<@W??GU at L?*??N<@????FU at l????P<@??RAEGU at P???Te<@?9"??HU at 8??!w<@<????KU@?????<@o??}LU at x?0DN?<@(5??FU@ ??G??<@???@?DU@|-??1?<@f`XCU@`$??\?<@??
?BU@$??E??<@?f??<U@??????<@<?I/6U@ ?A|`?<@P
?=?4U at PR`L?<@d???,U@$z?r?<@?%9`W-U@ ??F??<@?.??(U@?z2???<@?"?~?$U@???f?<@xW=`U at d?????<@(??bU@?D/?X?<@c?~?U@|!????<@T=??U@(??b?<@?????U at 8?!?<@????U@???Y.?<@<????U@?T?G??<@?*?)U at T?X?;?<@xx???U at Lvl??<@?6?[U at X?y?
=@T(__
U@ ??{G!=@??4
U@??6 (=@?????U@?h;??.=@$??U at Ljh?5=@<n??tU at T4???B=@P.?_x?T@?dL=@<??@f?T@?>+J=@TC?
?T@?j?=&>=@?'?>?T@????:=@x?n?|?T at Ls+??4=@?"1A
?T@?A?/=@?#??T@?t???)=@??????T@|?%9`+=@L.??:?T at x???s*=@??P???T@?>+*=@("??T@?(z?c0=@?`6??T at h????]=@????Z?T@$??E?j=@8???(?T@ ?%?p=@??\?C?T@(x
?Rw=@l\???T@$??}=@????z?T@????z?=@L.??:?T@@ ????=@h??>??T@|????=@?^??T@?~??@?=@P????T@??E}??=@@?a?'?T@$????=@?z2???T at hs????=@??i? ?T@???x??=@PCT???T at Lm????=@h?????T@$????=@??h??T@?I????=@?T?~O?T at L???h?=@??e???T@??r??>@PX?e?T at PL? 3>@x]?`7?T@???@?>@|<????T at d?b?>@xW=`?T@?h???U>@?9?}?|T@??w?']>@<??A?vT@????l`>@o??sT@???]>@<??A?nT at P??|zd>@??B?iT at x?0DNk>@??t!VhT@$?@?l>@$???cT@?N$?jb>@<???;cT@?,???[>@|K9_?bT at 8?!U>@??B ?_T@???nW>@?x@?]T@???B\>@|fI??\T@?ek}?`>@?bc^G[T@@
?b>@PI??&ZT@??>$`>@?@I?YT@?O8??P>@<??"YT@?Z
H?C>@T(__XT@|?m?(,>@???>ST@?Z
H?>@u??QT at x??C5>@P???OT@(?R?o>@?NA~6PT at L?g\>@?w?~?NT@(b?>@P}>?LT at X????>@???MJT@?NG?>@<????GT at x0H?>@PI??&FT@?H?F?>@?.??DT@????? >@(5??BT@???7->@???AT@??kzP4>@h????AT@?Z(??6>@?4~???T@<????C>@??!?<T@@	]F>@|?5^?9T@(?
?0I>@????3T@???X?R>@?f??2T@?"??JV>@?????1T@|?m?(\>@?3???0T@????b>@?x?''T@<)??x>@??$>w%T@??t ?y>@???A^!T@?>+z>@XR?>?T@?n???>@??? =T@??????>@?`6?T@??n?!?>@xx???T@ ?9z??>@PO??
T@ S>U?>@(??>VT@?]K??>@??RAET@??????>@xT??T@??????>@???~?S@?=??j?>@?????S@?d?z??>@??A??S at x?0DN?>@?]??y?S at x?0DN?>@h?????S@<;%?>@<???;?S@?~??@?>@?<c_??S@????B?>@T"?^F?S@|0)>>?>@??+?z?S@??3???>@?Q*?	?S@`?_??>@?]??y?S at 8?!?>@(5???S@?:q9^
?@?I+?S at p?????@P<???S@?w?~??@h???S at x???s"?@?]??y?S@???~?=?@??l??S@??^M?@xW=`?S@$z?rS?@|`???S@(?
?0e?@h?B,?S@?????o?@$[A??S at PR`Lm?@|{??/?S@?[<??h?@???+?S@??d ?J?@????Q?S@@ ???I?@?I+?S@????O?@?6?^??S@$?^F???@??4?S@?_?|x??@???n?S@???????@??B??S at hs?????@(__??S@???????@?t????S@N^???@f`X?S@?	?????@???>?S@??I~???@??F>??S at l??{
??@??-?S@$?????@(/2??S at Lg'????@?T2 T?S@|?????@|E?^??S@@?q?? @@d????S@(?o|?@@?|A?S at R
???@@(?N>=?S@???@@??N@?S at f?fb?@@h?????S@??'?H@@(?R?o?S@????r@@4}v?u?S@?? @@(??)?S@?{F"4 @@?_"?:?S at z6?>W7@@P:?`??S@?+?PA@@?`?>?S@??P?vB@@???i?S@????lD@@????S@?b.G@@??7???S@??;??J@@?T?~O?S at z??C5I@@<???S at f?ba?H@@??????S at T=??I@@?.??|?S@~?<?J@@d?6???S@??/??L@@?x?'?S at Na???P@@?????S@?B?_?Q@@???8?S@|'f?P@@??|@??S@?#?L@@@?]???S@~b??E@@??>??S@????>@@T"?^F?S at z9??c<@@?Ws?`?S@?^}<?9@@d?VA?S at zl???.@@PI??&?S at T:X??,@@?;???S@?????0@@W@??S@:w?^?:@@??e???S@:?}?k=@@d?VA?S at PX?e?@@<?e?Y?S@(/2?@@@??????S@?????A@@??? 4?S at d?VAB@@PU??X?S@?+?`p?@@h?>??S@??/??L@@`X?|?S@??E}?O@@PX?e?S@?&M??Q@@??;?(?S@??'??S@@??k~??S@?D/?XV@@?<*???S at v?U?0]@@?L???S@??]?`@@l\???S@???0q@@??;???S@?????t@@?]??y?S@????u@@??_??S@:????w@@???A??S@N^?{@@8?? n?S@???A??@@d?&??S at d?fb??@@$???S@?p>??@@<??~?S@??3???@@|3j?J?S@|????@@8en??S at P[#?q?@@??I~??S@?[<???@@??????S at PI??&?@@??=x?S@????l?@@P:?`??S at h|_\??@@??????S@<b??B?@@P@???S@???>9?@@c?~??S@??????@@l\???S@??????@@??>e?S@??p??@@?Tka?S@9D???@@$W@??S@??,AF?@@d?J!??S@?g]???@@???~??S@|-??1?@@??;?(?S@|????@@(??>V?S@|?i???@@????H?S@??????@@<?????S@|fI???@@?
)???S@??G?)?@@h?R@??S@|l????@@??F!??S@? ????@@xx????S@$;6?A@???~?S@(/2?A@??(@?S@T?^
A@?cw???S@(?J=A@??e???S@,????A at L.??:?S at PX?eA@??!??S@m?A@?]??y?S@?)??A@|??A??S@|`??A@??????S@?#?GA@??(@?S@?P??A@(????S@|??B!A at h?N???S@??^%A@??A$?S@|o?'A@???S at 0?=B?,A@?9?}??S@?P??0A@???n?S@?????BA at Pd????S@??c?EA at P"???S@$A?
GA at d?w??S@??#??GA@?Q?G?S@(?o|?GA@??~7?S@???@,IA@(?
?0?S@|]??tIA@?????S@?????JA at PX?e?S@T?^
LA@<?????S@<e5]ONA at d?? w?S@$A?
SA@?????S@???C?UA@u???S@?{)<h\A@$?@??S@??;??nA@(&o???S@?&M??qA@$????S@????rsA at d?????S@????uA@????S@????yA@??????S at P%@}A at d?????S@(?.???A@?????S@?z2???A@??i?S@??ZC??A@@?Q?y?S at h?????A@c?~??S@?/???A@??? 4?S@???|y?A@?????S@??>$?A@?]??y?S@?9"???A@??_??S@?yT???A@|i? ??S@<????A@???MS at x????A@?????|S@?)X?l?A@?! _zS at h?-??A at P.?_xxS@??/???A at h????vS@$A?
?A@?F??uS@?v|??A at xN?@?tS@?H?+?A@?5_%rS@??+?z?A at T^-pS@??J#f?A@??!?mS at P???T?A@????kS@?b.?A@??#??gS at xE????A@{???cS@?????A@??,AFbS at P@???A at l?J>v`S@?????A@?}s?^S@?????A@?;??\S@ ?{??A at P???ZS at d?	???A@?5_%YS@?7?a??A@?d??PS at T??;M?A@??? GS at L+?@.?A at PR`L9S at T?t<f?A@|]??t1S@|-??1?A@@?m0S@???@??A at d??A%/S@?g@??A@?#?.S@?g]???A at T(__,S@??B??A@??M?'S@(?o|??A@?#?&S@?|?|??A@??u??$S at h?>??A@@???$S@?x?'?A at PX?e#S@?d?<
?A@|-??1S@?????A@????S@?M?=??A at T@?? S@?#?G?A@l\??S@??6 ?A@?p!?S@??\?C?A@????
S@????\?A@u??	S@|*?=%?A@(__?	S@????A@??p $S@??`?u?A@~? ?S@|?<??A@????uS@?o?>; B@????S@<?? B@|????S@????H B@<?(A S@???C6 B@<??"?R@?@??? B@N^??R@??t ?B at T@?? ?R at d^G?B@??Y?r?R@??7?	B at 8??_??R@??H?B at x` ?C?R@??B?B at P+L?k?R@@?mB@?k?}?S@\???fB at T[? ? S at l?6?8B@???! S@????r;B@??a??R@(}!??OB@??Y??R@?,C?TB@<?U???R@??a?VB at ht?3?R@??H.?YB@      P   ???0?K@?|$%4@?Q??B?K@,l? ?6@          ???0?K@?|$%4@???0?K at X??j?6@???!?K@??n?!?6@ ?=~?K@,l? ?6@?Q??B?K@|????5@??v?
?K@?{?E{D5@???0?K@?|$%4@     8   xu??Y@?^}<?u1@?d?Y@?Z
H?6@   ?       $?`6?Y@?4~???5@?d?Y@????)?5@?d?Y@?1????1@??^a??Y@|????1@|o??Y@??B??1@??a?Y@QL? ?1@??~7?Y@??G?)?1@?i????Y at P?|a?1@$[A??Y at t?y???1@?~NA~?Y@?G,?1@(?N>=?Y@??v?1@?F???Y@???Z`?1 at d??A%?Y@?v?12@<?(A?Y@?_?|x2@|i? ??Y@???i#2@B@???Y@ ?bG?02@T?^
?Y@?ZH42 at 4k) ??Y@?%???52@\?????Y@,2: 	72@?"?~??Y at P???T52@????Y@????12@??M?Y at Lg'?? 2@<??HzY at hm?k	2@<????xY@ ?z?2 at L
4?svY at x?0DN2@?Z?a/rY@?
?D2@?`???pY@?c> ?	2@??$>woY at H/??1@??6 lY at T??y??1@?
j??hY@?,????1@<}??dY@,oG8-?1@???A?cY@W?}W?1@???0eY at 84e??1@(?^?_Y@|???S?1@?????VY at PO???1@???A?SY@?8????1 at 0b? ?NY@??
??1 at h???8JY@?^}<?u1@????DY@??M?1@??p $BY@@
??1@????9?Y@??6??1@i?=Y@?/??1@??_><Y@????x?1@!Y?;Y@??&???1 at d??Q:Y at L??u?1 at d??A%;Y at L?*???1@|Q?_=Y@ ? ?S?1@$ &?B?Y@`'?ei?1@? ?> ?Y@B??	?1@??^a?>Y@???W?1@|6?>W?Y@?B]?1@(5??AY@?e?%??1@???DY@|???!?1 at h????EY@??C?1@?Q?GGY at 8?!?1@ ?,^,IY at T1?~?2@??e??JY@ ? ?S2@????NKY@?????,2@$8???IY@?H??QX2@???!FY@?,???_2@???`?EY@?9}=c2@?!???CY@??G?)k2 at 8}=_?CY@<5?q2 at xu??FY@??w???2@?? lIY@??7?a?2@??l?KY@?Gp#e?2 at 8?? nOY at T?X?;?2 at PI??&QY@????@?2@?*?)OY at t??F??2@?????OY@(?R?o?2@??U?@PY@?????2@]P?2SY at h?"???2@?dTY@?A??2@?^?UY@?K???3@<??VY at L?g\3@?cw??SY@?????3@?????RY@??G?)3 at LLb?LY@$??E?Z3@(??LY at T??y?_3@?s???MY at x?$v3@(__?PY at x<-?py3 at PO??RY at P??C?3@?w?~?QY@?}s??3@<??A?PY@??j???3@?J?hNY@@v()?3@????EY@|?,C?3@?C?DY@|?<??3@???BY@??f??3@<?e?Y=Y@?A??3 at 8?M?a:Y at t?????3@?#???8Y@?.m8,?3@B@??7Y@ ?!???3 at d?s~?6Y at L?g\?3@?C?4Y at P??C?3@?????1Y at 8???Z|3@?%9`W0Y at 8.???3@?7??,Y@???w??3@?!S>)Y@?}s??3@????;'Y@??5??3@?,??o%Y at d?u~3@T?^
%Y@|???S~3@ A?!Y@?QG???3 at d???jY@<?U???3 at d?	??Y@?O8???3@?E?~Y@?C??3@(__?Y@??6??3@????QY at h?????3@?D??Y@?EC???3@???>Y@???B?3@<??@f Y@K????3@?0??B#Y@3???4@?????$Y@?@?9w4@?(?A&%Y@?Z?{c(4@?????$Y@?????)4 at PU??X!Y at P???T%4@???MY@?&04 at xrM??Y@?;?<4@????Y@????N4@??FY@?"??JV4 at P"??Y@ H?9?]4@?=?Y@??*??a4@?3???Y@????:d4@<??@fY at x?u??d4@?<c_?Y@????b4 at d?s~?Y at x?0DN[4@<??A?
Y@?\7??J4@????Y@?
?7O4 at xu??Y@|0)>>Y4 at P??5Y@,oG8-`4@??`?
Y@<???f4 at d?VA	Y@?sD?K}4@??>?	Y@$z?r?4@???Y@?????4@??bg
Y@(~??k?4 at h??>?Y@??????4@<??A?Y@$?????4 at P}>?Y@???f??4@??\?CY at P^d~?4@????Y@(??=$?4 at h???Y@??K?4@<?U??!Y@??9??4@|H???#Y@????Z?4@??'??&Y@???|y?4@??"?'Y@??K?'?4@?;??(Y@???w??4 at 0w-!)Y@?}8H??4@?d'Y@$???{?4@?????$Y@????l?4@?z??"Y@Z_&?4@?(z?c!Y@????l?4 at T%??R!Y@???g??4 at 8??`?"Y@<%?5@?`6?$Y at P???65@f???&Y@?T?G?	5@|Nz??'Y@????5@??? +Y@?/? 5@|Bv??,Y@<#?.5@??? -Y@? ?=:5@????.Y@<@???N5 at h??>?1Y@??^M5@????\4Y at dx?g?L5 at h????5Y@?b??M5@]P?27Y@?S?Q5@?Tka@Y at d???e5@?-?sFY@|*?=%w5@????#HY@??&??}5@?Ws?`JY@@??P?5 at x?n?|IY@$??E??5@???A?KY@?(?7?5 at d??@?PY@?X?;?_5@???A?OY@???>UU5@?!S>OY@?C4??@5@?N??:PY@???~?55@l\??RY@??1ZG-5@??]??UY@?P??Q05@?????XY@?H?"95@(#. ?`Y@|?!8.?5@?f??dY@??I?5@???fY at T??z<5 at 8? UkY@(u?8F25@??x>mY@???x?,5@??$??nY@?
j??#5@???MrY@??y?$5 at d???vY@(x
?R75@@???^vY@?66;R=5@???MvY@ ?bG?@5 at P7P??sY at PF\ I5@|-??1qY@???X?J5@????koY@????ZP5@?t?_?oY@?St$?[5@??/??pY@?d?<
t5@?F??qY@|*?=%5@??
?rY@??I?5 at PI??&pY@`'?ei?5 at h?>?pY@?h????5@???kY@?W????5@?W??"hY@????l?5@?qo~?dY@????56@???hY at T7?G6@?_"?:kY at P?\?mc6@????\jY@??	?Yi6@?K???jY at P^d~q6@?p>?lY@ ?bG?x6@<n??toY at P?\?m6@<q9^?qY@?Z
H?6 at PL? 3sY@?sD?K}6@??~7{Y@<????o6@??????Y@l?`qt6@????Y?Y@????n6@?????Y@????re6 at P????Y@?.??|b6 at 8???Y@$???{S6@??????Y@K???L6@????@?Y at H?p>6 at h?????Y@?M?E76@?????Y at t??F?56@????Y at hy??6 at 8?????Y at T???"6@?'?>?Y at 4??#??5@(????Y@$W@??5 at xB????Y@?/??5@?]??y?Y@?????5@?: ???Y@?Y?$??5@?? l?Y@????a?5 at PU??X?Y@?\??k?5@??,AF?Y@,?????5@???~??Y@?D???5@$?`6?Y@?4~???5@
  X?   ?N??:	Q@?=Ab??@????ZXX@<????A@         &   G   j   ?   ?   ?   ?   ?   ?   ?     	    #  +  0    ??M?7W@???1?(@?????6W@?c\qq?(@?d??5W@?2?,%?(@l?? ?3W@??\?(@?????2W at 8???n?(@\?[!?1W@75?|?(@?#???0W@????(?(@??/?/W@?^????(@T=??-W@??0???(@ ? >?-W at X?T?	?(@h????-W at x8?Jw?(@??I~?/W@????^)@?*?)/W at X??y??)@??i? /W@??;???)@$???{/W@??+?z?)@?"1A
4W@??T?G?)@T:X??4W@?????)@p
?-6W@??#?)@?<c_?6W@????)@?"1A
8W at HkE???)@?qo~?8W@ ?c???)@???~?9W@?n?KS?)@|?e??:W@?)Wx??)@8?? n;W@?f??}?)@???@g=W@???4??)@B@???W@?F??j)@??$>w?W@?????)@??i? ?W at p[?? )@$??;W@?B????(@|l???:W at x*?=%?(@?????9W@@????(@d??Q6W@???)?(@???6W@?s~???(@PX?e7W@ ?vi?(@8en?8W at pbHN&?(@?qo~?8W@?dp???(@????99W@ ?^F??(@??M?7W@???1?(@{???8W@????)@<?u?8W@@E??t?)@????6W@?p>??)@??A$6W@?j?	??)@H??>?4W@?{??/?)@???4W@??"M??)@?Y?>?3W at x8?Jw?)@??#??3W@?&M??*@ND??3W at 0T???*@??M?3W at x><K?!*@@???@5W@?z2??S*@h???5W@?????*@??? 7W@?????*@<????8W@?R?h?*@?g??9W@ ?&??*@?F??9W@(i?7?*@?9[@h<W@??N+@|ZEh at W@?<??$+@x` ?BW@?z2??#+@??I~?CW@?	???+@??|?5EW at x;????*@???DW@???4?y*@<???	CW@? ???'*@xx???BW at x><K?!*@????ABW@? :v*@??>?AW@?]?pX*@?????>W@?#?*@]~p=W@?T?2*@???A?=W at H???? *@?]??y=W@??Q?(*@??l?;W@?/? *@?'?>8W at H?????)@{???8W@????)@H??B0W@
fL?"(@T.T??0W@?????(@(5??2W at H?o	??'@??e??2W at X?y??'@l\??2W@??,?s?'@?????0W@??G?);'@d?s~?.W@?^??'@??a?-W@?G6W??&@?*?)+W@??e2'@????s*W@ ???'@d????'W at H??05'@?f??!W@?????'@<??H#W@?????'@|???a$W at P??z?'@<??@f&W@????b?'@`?? ?'W@ ??G??'@??x>)W@?	???(@??bg)W@??? <(@?F??)W@ (??B(@?????(W@?)r?H(@???@,)W at x)u?8N(@??p $+W@?;?l(@???n-W@????w(@0}?!8.W@?7?k?o(@<???;.W@????d(@?Y?>?-W@?'c|?](@???C.W at 8%?V(@P?>?/W@ m?Yg\(@????1W@?,???[(@?F??1W@?&M??Q(@?7??0W@????I(@<?(A0W@ ?jIGA(@??B?/W@?w?~?.(@?????/W at P?{/&(@H??B0W@
fL?"(@|c ?wW at P?`??@(??>VxW at P?*???@???jzW@?Z??K@??H?{W@?+?`p?@???{W@ ????@ ????yW@??,?s:@??	??tW@?=Ab??@ ????sW@?M?E@??d?<rW@???>UU@8? UqW at 0b??@?\??pW@??0???@h????mW at 0du???@P+L?kkW@????@?b.jW@`???@|]??tiW@`??jG!@PR`LiW@@(a??O@?Q??BiW@?Z??K]@(?
?0iW@?@?ty@<???	kW at pt?Oq?@x` ?rW@?A??@d????sW at P?o?@h?R@?tW@??{?Y?@????vW@?_?|x?@PL? 3wW@ ?)?:?@|c ?wW at P?`??@?????#W@@???%@?7??$W at H????l%@?:???$W@??0?f%@?9?}?$W@???N$`%@$#gaO"W@?"R?&%@h?R@? W@???OV%@????z W@
??%@?B?W@?E?n?	%@h????W@????%@|c ?W@(l? %@?????W at 8"???%@<?I/W@ ?vic%@@???4W@ ????m%@??;??W at X?y??%@(5??W at P???h?%@?Y?>?W@ w?*?%@??$??W@?)???%@|H???W at ha?9?%@??|@?!W@??>?%@T=??!W@???B?%@?????#W@@???%@x?E0W at P??H?$(@??0W@ ???0(@?i???0W at x????A(@(???I1W@??&7R(@d??^'1W@??Z(@ ??^E2W@???W?_(@?$??2W@?A	3mg(@??\??0W at H?!T??(@?"??J0W@???E?(@h?^`V0W@????A?(@??a1W at H?~??(@ ?"?~2W@?=b??(@0DN_?2W at p(CUL?(@l??32W@??f
??(@?;??2W at 0?-X?(@???3W@??&???(@????5W@?`R||?(@TUh ?6W@??@ ?(@<??~8W@ ??E??(@?p!?9W at P?k??(@h????9W@(eRC?(@???>7W@???S(@P7P??3W@??f?.(@x?E0W at P??H?$(@????]	V@??1??5@?% ??	V@?????5@?|A
V@???A??5 at d?s~?
V@?NG??5@$W@?
V at PO???5@?k?}?
V@|$%=?5@f???
V at Lvl??5 at P.?_xV@?w?~??5 at 8???(V at x??C5?5@$ &?BV@?5???5@?}s?V at P???T?5@x` ?V@?G,?5@????V@$????5 at PX?eV@$????5@??B?V@??5??5@<??@fV@????5@$???V@|?????5@??:MV@|!????5 at h?	V at T@?? ?5@????]	V@??1??5 at L+?@.bW@??=?j @?? laW at 0T???Z @PR`LaW@ ?%?8 @??>?aW@?T?23 @??(@bW@?r???% @PU??XbW@??w?' @????9bW at 8=((E @{???^W@ ??9x?@<??@f^W@?p=
? @xE???\W at 0Q?5?E @H???\W at p[?? S @?????^W at P?|aj @??e??^W@??0??n @o??_W@????r @?r??aW@??V?s @?L??aW@??B??p @L+?@.bW@??=?j @TC?
YW@?8??  @?9[@h\W@??(?A?@|??A?\W at p8?Jw?@???>U]W@?R??q?@|]??t]W at P?????@????]W@`?"??y@?????VW@d???@??p $VW@??/???@$??SW@??|@??@?cw??SW@??X??@8???SW@ ????@h???8TW@???N?@$[A?VW@??e2 @`?? ?WW@?t???	 @?k?}?XW@??:?? @TC?
YW@?8??  @??6 (W@?$%=?&@PX?e'W@(??9x?&@(??)&W at P?\?m?&@?"1A
(W@?5???&@$?w~Q(W at pP?L??&@?=?(W@???A'@|l???*W@?????&@??#??+W at H?2???&@????#,W at X?y??&@?9[@h,W@??Q??&@(???,W at P???h?&@?bc^G+W@?K?b?&@?f??(W at P???T?&@??6 (W@?$%=?&@?f??lW@?I(}!?@??Y?oW@??V?s@?????nW@????K@(/2?hW@?R??q?@(???gW@?]???@(???IgW@?<??
@?I+fW at 0]?6?9@????fW at p><K?a@??l?gW@?X?w@?? liW@?n???~@????vkW@@??>?@P
?glW@?A??@|fI??lW@?"1??@?f??lW@?I(}!?@?E?>ER@??G?)? @l\??DR@?;?? @?-W?6DR@?)??? @??i? CR at x><K?? @?a?AR at X?A??~ @???aNAR@@	]? @d?VAER@?w?~?? @?E?>ER@??G?)? @PU??X2W@ S?o*z"@?k?}?2W at X?T?	w"@??>?3W@????k"@?Y?>?3W@?>U?Z"@`?? ?3W@??|@?S"@?^?3W@?-s?L"@8?!3W@ ??CD"@????\2W@(?O:?@"@|??!U1W at pP?L??"@????.W@??Y5A"@?'?>.W at X????D"@T1?~?-W@???0?H"@?????-W at x)u?8N"@???A^-W@?????S"@???~P-W@ ??E?Z"@???A^-W at 0Z???d"@?&??-W at pD?K?k"@f???0W@?_?|x?"@?H.?!2W at xE???|"@PU??X2W@ S?o*z"@???@?1R@?7?_&@????Z1R@???
?b&@(2s??1R at P?{/v&@xl?u2R@?^????&@?t???1R at pG???`&@???@?1R@?7?_&@$?@?R@ w?*?%@ ?{?R@??? 4?%@B@??R@ (???%@d?{??
R@?????%@????@R@ %>w??%@|c ?R@??? 4?%@?????R at 0[?*??%@$?@?R@ w?*?%@(&o??)R@(u?8F"%@?`?(R@?l??%@6u(R@ w?*%@o??)R@?_??%%@(&o??)R@(u?8F"%@??T??Q at pU?wE?7@???W
Q@?t????7@????
Q@???[?7 at f???8Q@??v?7@??+?zQ@???[?7 at f??}q(Q@?P??Q?7 at z9??c,Q at x9??c?7@???A?/Q@?P??Q?7@?????/Q@      8 at zo?/Q@?5??
8@?
)??/Q@?BF?K8@???>?/Q@????\Q8@????z2Q@??@fgU8@?Z? m4Q@?2Q??U8@??A?;Q@??z?S8 at P:?`?<Q@???A?O8 at h???b=Q@$z?rK8@:tz??>Q at h?!?{C8@?|AAQ@???<C8@??@?DQ@$???{K8@??;?(PQ@?	???G8@(??>VXQ@?}s?H8 at R}>?bQ@?????H8@~T?~OfQ@ ?z?H8@<??"iQ@????>8@?Ws?`lQ@??9y?18@~T?~OnQ@????+8@     ?Q@????r+8 at PR`L?Q at t?8F?+8@?5?!?Q at h????18@<?i???Q@????;8@`???~?Q@?????M8@??????Q@|!???O8@?
)???Q@????lP8@*?^??Q@?>U?V8 at RF\ ?Q at t????^8 at f?s~??Q@??C??f8 at P????Q@???[?o8@??????Q at PR`Lm8@(??>V?Q@$???h8@&?B??Q@$???c8 at h??Q@??|@?S8@&??b?Q@|?i??G8@??3?I?Q@?.??|>8@?qo~??Q@({K9_<8@W???Q@????=8@???f?Q@??j??E8@$&??[?Q@???e?M8 at PX?e?Q@?#?\8 at h?????Q@???Y._8@?-?s?Q@(x
?R_8@??l??Q@?b???\8 at T%??R?Q at d?fb?\8@?????Q@|6?>Wk8 at h???Q@?@???p8@??i?Q@<5?u8@$?`6?Q at d?g^w8@|?5^??Q@??v???8 at zi? ??Q at d??a??8@?$???Q@?n???8 at T=???Q@?+??2?8@?"?~??Q at P??|z?8 at 8????Q@(????8@?????Q@(??=$?8@?????Q@?
?D?8@??:M?Q at x?4E??8@???A??Q@?
?D?8@?????Q@?]K?	9@ ? >??Q at PI??&9@???~P?Q@?????9@~??A??Q@|*?=%9@??+?z?Q at T?{/&9@& &?B?Q at hy??-9@??B??Q@??gx?29@(#. ??Q@??C??69@?Q*?	?Q@uX??;9 at h???Q@?5_%G9@???A_?Q@]P?2g9@?????Q@?n??q9@??? ?Q@,??<??9@?$???Q@N^??9@:? U?Q@????9@<n??t?Q@???7?9 at z0)>>?Q@??C?9@:???;?Q@ ?%??9@l\???Q at hp[[x?9@????0?Q@?h;???9@(????Q at P??|z?9 at z???a?Q at P?\?m?9@??????Q@??f??9 at PO???Q at 8?!?9@`X?|?Q@ ??F??9@(??>V?Q@|??8G?9@?_"?:?Q@??????9@???~??Q at T???"?9 at P:?`??Q at t?8F??9@:?]??Q@,i?7:@??;???Q@ ?A|`:@8????Q@(u?8F":@?:????Q@?}s?(:@zu???Q at P?\?m/:@R}>??Q@????t9:@??w?'?Q@???[?:@"????Q at PI??&^:@??M??Q@|-??1d:@P????Q@??d?:@zo??Q@$w?Df?:@?a??Q@???<?:@??~7?Q@?I????:@??B??Q at T??y??:@?#????Q@???w??:@`X?|?Q at X?????:@?D??|Q@?@?9w?:@P7P??yQ@??????:@????QuQ@?/?
?:@:?? ?rQ@<? ??:@<?i??qQ@ ??z?:@??B?oQ@??Dg??:@????AnQ@??
DO?:@???~lQ@???@??:@f???hQ@??I~??:@|????eQ@??M??:@|fI??dQ at P?????:@zl???bQ@???B?:@???@?`Q at d?%???:@&8???_Q@?b???:@8?? n_Q@?K????:@??/?_Q@??	?Y?:@*???`Q@?????:@????XeQ@?W??-;@?G?lQ@ ?~?:H;@$W@?nQ@????(L;@???_pQ@|*?=%O;@B@??wQ@???w?h;@<?E~??Q@ ?={.?;@??????Q@<]???;@????r?Q@?D???;@N"???Q@?C4???;@?qo~??Q@????B?;@??|?5?Q at P?|a?;@?E&???Q@??????;@{????Q@@
??Q@ ????;@??4?Q@|!????;@<n??t?Q@??w??<@N@a??Q@?L?:?<@~Q??B?Q at X?x?	<@&???{?Q@?H?F?<@???A??Q@<? ? <@?6?^??Q@?	??b?;@|fI???Q@???B?;@?z???Q@,i?7?;@???A_?Q@??????;@:?!?Q@?@?9w?;@f?s~??Q at Ly????;@P1????Q at P?|a?;@h?
???Q@$[A??;@?cw???Q@????B?;@?E?~?Q at Ls+???;@?w?~??Q@??3???;@?E?>?Q@|???S?;@B@???Q@?g@??;@PR`L?Q@?L?:??;@?B??Q@?X?;??;@8????Q at T?T?	?;@h?2?}?Q at T4????;@?d?Q@??&???;@T=???Q@?=??j?;@?????Q@??v???;@????s?Q@$????;@ 2?Q@ ?????;@?????Q at PR`L?;@??>??Q@?B]?;@?!S>?Q@ ??F??;@?? ??Q@ ??F??;@<?i???Q at t?????;@|ZEh?Q@?
?7?;@|6?>W?Q at P??{H?;@??x>?Q at P^d~?;@x9??c?Q@?Z
H??;@,kg?Q at x???A?;@|?????Q@?????<@<? ??Q at L?*??<@??A??Q@????@7<@|]??tR at L??uI<@?7??R@?4?8ES<@????9
R at T?T?	g<@ ? >?
R at P[#?ql<@?NA~6R at PR`L?<@?????R@`?_??<@<}??R@?}s??<@B@??#R@??????<@<?I/&R@$???<@h?R@?(R@?*?w??<@????.R@?D???<@??bg5R@`$??\?<@<? ?<R@(?N>=
=@(???I?R@(??>V$=@PL? 3CR@????B5=@?????ER at Ly???>=@?????PR@$???=@c?~?QR@??????=@???=#UR@ ?????=@]~pYR@??{?Y?=@(5??ZR@ ?!???=@(?
?0eR@3???>@L+?@.kR@??t
>@l\??nR@??&??
>@??i? sR@|???>@@????{R@?0??">@h????}R@c??K5>@??>?}R at L?*??>>@?????|R@??_>I>@LI???{R@?_x%?O>@?P?zR@,l? W>@?;?wR at l????\>@h????wR@-y<-c>@|o?R@ ??{G?>@??i? ?R@(??b?>@??????R@????>@d?????R@?????>@B@???R@??|@??>@$????R@??P?>@(??>V?R at x?u???>@? \??R@??U???>@p?_!?R@?
ND?
?@??Ma??R at H??? ?@$??}8?R at d*???@B????R at x?W??@(__??R at H?`???@T1?~??R@?Z?!?@o???R@?S??Y?@?k?}??R@\?Fx?@ ?"?~?R at x?'e?@??I`s?R at d73??,?@?|~?R@?\7??Z?@?;???R@?9D?`?@<??H?R@,???e?@`?[>??R@??}j?@Tg???R@(???^k?@p ???R at 0?Lv?@?F???R@?/????@?Y???R@????_??@`??9?R at P?0????@d?s~??R@ B\9{??@?bc^G?R@?K???@P??Z?R@(S????@??????R at 0??w??@?????R@?8'0??@@?Q?y?R@? ????@??o?R@?s}@@???!??R at L????@@?NA~6?R@?D???@@`?_???R at .2?@@??#???R at x?0DN@@ ?q?j?R@?mm?y	@@@?? k?R@???!?@@??????R@????#@@???g?R at .;??l@@??`?
?R@?*O ?@@?`?>?R@Q???!@@(??s?R@??9#J#@@??????R@$,*?t&@@?=~o?R@?H?},@@??p $?R@&;6?,@@|E?^??R@QL? 3@@??? ??R@?????<@@|fI???R at z0)>>=@@?~NA~?R@??a??:@@??U?@?R@?n.??;@@$???{?R@??l?=@@?Hg`??R@??%??@@@<?Y???R@?w?~?J@@$[A??R@??? 4Z@@??a?R at d?? wc@@??`??R@>
??pa@@??
??R@? ?	`@@P0?A?R at 8? "5c@@ ??>??R@????e@@?&l??R@??`h@@?}s??R@?}s?l@@d??E?R at f?%??o@@N^??R@?p $~@@|~!<?R at T??;M?@@(????R@|?????@@??B??R@|l????@@?d?R@?????@@x` ??R@(????@@??	???R@???B?@@?????R@?M?#~?@@d??Q?R@???~P?@@?Q??B?R@??E}??@@?z???R@?/????@@?.???R@??C?@@???~?R@$;6??@@PX?e?R@,?	???@@P4`??R@??????@@d?????R at d?c?@@|??A??R@??m?R?@@PX?e?R@??C?@@?i????R@?l???@@8? U?R@?u?!?@@|fI???R@???j?@@??$>w?R@??+?z?@@xB????R@$M?<?@@h?2?}?R at PR`L?@@<??"?R@|W?[?@@?c> ??R at h???@@(??)R at d?c?@@??e??~R@??B??@@ ?!pR@???i?@@?T?~O?R@??e???@@?=??R at P"???@@d??@??R@??
??@@|3j?J?R at d??E?@@?I+?R@$???{?@@d?????R@????r?@@?x?'?R at h????@@??i?R at PF\ ?@@h???b?R@?????@@???~?R@???@,?@@????z?R@|6?>W?@@???@??R@<?????@@$????R@??????@@<????R at h?:? A@<?????R@?>??sA at h?2?}?R@??q??A@????N?R@|?<?A@??bg?R at h?{??A@???R@|]??tA@??`?|R@|*?=%A@????{R@?Q??BA at d??~?zR@???@-A@??6 zR@??E}?A@?? ?zR@<???RA@??p?{R at P^d~A at h????}R at PX?eA@<???;R@??d ?A@???j?R@?
???A@|???a?R at xu??A@?.??|~R at PI??&&A@??`?
|R@|!???'A@<?E~?yR at Lp??'A@???~xR@?n.??'A@?.??|vR@|fI??(A@?7??tR@(5??*A at h?2?}sR@!???-A@|-??1sR@??`?2A@?!S>xR@?????AA@u??yR at T:X??DA@?K???{R at d?cQA@??B ?}R@?m???TA@?Ws?`R@?_?|xVA at PO???R@???C6XA@????Z?R@??h?XA@??l??R@|i? ?YA@???A^?R@???@-^A at P????R@|fI??`A@???>?R@(?.??bA at PF\ ?R@?z2??cA@?w?~??R at T??;MdA at T(__?R@<?8b-dA@??`?u?R@??}bA@??????R@<?u?aA@?/???R@?a?^A@o???R@???|y]A@r????R@?>??sZA@??? ?R@??{?YYA@????U?R@?/?XA@??6 ?R@?#?GQA@?d?R@?8?ZPA@??????R at P"??PA at P@???R@|o?OA@3?`??R@??>$PA@????Q?R@?m???HA@?????R@|*?=%GA@r????R@,*?Z at A@?T2 T?R@(eRC@A@??i? ?R@?!<?@A@?l???R at T?t<fBA at d????R@$A?
GA@?9?}??R@(?N>=JA@?
)???R@?h???MA at P:?`??R at d*??OA@@?]?? S@?????PA@????sS at Lg'??PA@<?$@MS@$8???OA at h????S@$A?
OA@(???IS@???A^MA@????S@$???KA at P4`?
S@??\KA@?i???S at x???ANA@?1=a?S@|i? ?QA@????S@|!???WA at xW=`S@????YA at PX?eS@?E~?aA@?7??S@??? 4bA@<n??tS@???#bA@???j S@???>UaA@?|A*S at PX?e_A at d??@?,S at d*??_A@$??/S@?J???^A@(??0S@??C??ZA@????\2S@????rWA@<??4S@(????TA@?=?5S at d??QTA@$???7S@(??>VTA@?P?:S at x???AVA@??? ?<S at x??C5eA@?r??=S@?6?^?mA@??\?CBS@?}s?~A@??? DS@?k?}??A@?'?>DS@(??{??A@??|?5CS@|6?>W?A@????BS at P
?=??A@?*?)CS at PR`L?A at 8???OS@??? 4?A@?;??TS@?n.???A@?]??yYS at T??;M?A at L.??:dS at L+?@.?A@ ? >?qS@??????A@,*?ZtS at T
????A at xN?@?tS@?H?+?A@?F??uS@?v|??A at h????vS@$A?
?A at P.?_xxS@??/???A@?! _zS at h?-??A@?????|S@?)X?l?A@???MS at x????A@|i? ??S@<????A@??_??S@?yT???A@?]??y?S@?9"???A@?????S@??>$?A@??? 4?S@???|y?A@c?~??S@?/???A@@?Q?y?S at h?????A@??i?S@??ZC??A@?????S@?z2???A at d?????S@(?.???A@??????S at P%@}A@????S@????yA at d?????S@????uA@$????S@????rsA@(&o???S@?&M??qA@$?@??S@??;??nA@u???S@?{)<h\A@?????S@???C?UA at d?? w?S@$A?
SA@<?????S@<e5]ONA at PX?e?S@T?^
LA@?????S@?????JA@(?
?0?S@|]??tIA@??~7?S@???@,IA@?Q?G?S@(?o|?GA at d?w??S@??#??GA at P"???S@$A?
GA at Pd????S@??c?EA@???n?S@?????BA@?9?}??S@?P??0A@???S at 0?=B?,A@??A$?S@|o?'A at h?N???S@??^%A@(????S@|??B!A@??(@?S@?P??A@??????S@?#?GA@|??A??S@|`??A@?]??y?S@?)??A@??!??S@m?A at L.??:?S at PX?eA@??e???S@,????A@?cw???S@(?J=A@??(@?S@T?^
A@???~?S@(/2?A at xx????S@$;6?A@??F!??S@? ????@@h?R@??S@|l????@@?
)???S@??G?)?@@<?????S@|fI???@@????H?S@??????@@(??>V?S@|?i???@@??;?(?S@|????@@???~??S@|-??1?@@d?J!??S@?g]???@@$W@??S@??,AF?@@?Tka?S@9D???@@??>e?S@??p??@@l\???S@??????@@c?~??S@??????@@P@???S@???>9?@@??????S@<b??B?@@P:?`??S at h|_\??@@??=x?S@????l?@@??????S at PI??&?@@??I~??S@?[<???@@8en??S at P[#?q?@@|3j?J?S@|????@@<??~?S@??3???@@$???S@?p>??@@d?&??S at d?fb??@@8?? n?S@???A??@@???A??S@N^?{@@??_??S@:????w@@?]??y?S@????u@@??;???S@?????t@@l\???S@???0q@@?L???S@??]?`@@?<*???S at v?U?0]@@??k~??S@?D/?XV@@??;?(?S@??'??S@@PX?e?S@?&M??Q@@`X?|?S@??E}?O@@h?>??S@??/??L@@PU??X?S@?+?`p?@@??? 4?S at d?VAB@@??????S@?????A@@<?e?Y?S@(/2?@@@d?VA?S at PX?e?@@??e???S@:?}?k=@@W@??S@:w?^?:@@?;???S@?????0@@PI??&?S at T:X??,@@d?VA?S at zl???.@@?Ws?`?S@?^}<?9@@T"?^F?S at z9??c<@@??>??S@????>@@@?]???S@~b??E@@??|@??S@?#?L@@???8?S@|'f?P@@?????S@?B?_?Q@@?x?'?S at Na???P@@d?6???S@??/??L@@?.??|?S@~?<?J@@??????S at T=??I@@<???S at f?ba?H@@?T?~O?S at z??C5I@@??7???S@??;??J@@????S@?b.G@@???i?S@????lD@@?`?>?S@??P?vB@@P:?`??S@?+?PA@@?_"?:?S at z6?>W7@@(??)?S@?{F"4 @@4}v?u?S@?? @@(?R?o?S@????r@@h?????S@??'?H@@??N@?S at f?fb?@@(?N>=?S@???@@?|A?S at R
???@@d????S@(?o|?@@|E?^??S@@?q?? @@?T2 T?S@|?????@(/2??S at Lg'????@??-?S@$?????@??F>??S at l??{
??@???>?S@??I~???@f`X?S@?	?????@?t????S@N^???@(__??S@???????@??B??S at hs?????@???n?S@???????@??4?S@?_?|x??@?6?^??S@$?^F???@?I+?S@????O?@????Q?S@@ ???I?@???+?S@??d ?J?@|{??/?S@?[<??h?@$[A??S at PR`Lm?@h?B,?S@?????o?@|`???S@(?
?0e?@xW=`?S@$z?rS?@??l??S@??^M?@?]??y?S@???~?=?@h???S at x???s"?@P<???S@?w?~??@?I+?S at p?????@(5???S@?:q9^
?@?]??y?S at 8?!?>@?Q*?	?S@`?_??>@??+?z?S@??3???>@T"?^F?S@|0)>>?>@?<c_??S@????B?>@<???;?S@?~??@?>@h?????S@<;%?>@?]??y?S at x?0DN?>@??A??S at x?0DN?>@?????S@?d?z??>@???~?S@?=??j?>@xT??T@??????>@??RAET@??????>@(??>VT@?]K??>@PO??
T@ S>U?>@xx???T@ ?9z??>@?`6?T@??n?!?>@??? =T@??????>@XR?>?T@?n???>@???A^!T@?>+z>@??$>w%T@??t ?y>@?x?''T@<)??x>@?3???0T@????b>@?????1T@|?m?(\>@?f??2T@?"??JV>@????3T@???X?R>@|?5^?9T@(?
?0I>@??!?<T@@	]F>@?4~???T@<????C>@h????AT@?Z(??6>@???AT@??kzP4>@????Z<T@?B].>@x{?7T at T??z$>@P7P??/T@|??B>@????r+T at x9??c?=@??? 4*T@?I????=@P"??(T@??f??=@8??!&T at 8??!?=@(/2?$T@?}s??=@(??b"T@????:?=@$???T at x?q?Z?=@???A_T@?i? ??=@????T@??d#?=@@??! T at P^d~?=@f???T@???f?=@(G?`T at 87?',?=@?
)??T@ ?!???=@??A$T@N^??=@PI??&T@@?Q?y?=@P"??T@????=@??;??T@?L?:?{=@????;T at P??{Hl=@<??HT@??9?Q=@?? ?T at 81$'O=@??m?RT@?V&?RG=@???jT@?????4=@x{?T@?T?G?)=@|fI??T@?!<? =@l?J>vT@????<@d?6??T@??????<@|6?>WT at d????<@{???T@@?v?<@|i? ?	T at P?c*?<@(?_T@???[?<@??\?CT@?	??b?<@?7??T@|!????<@???8T at T?T?	?<@P
?=? T at T@?? ?<@(G?` T@??????<@??~7!T at d*???<@????"T at P?\?m?<@]~p%T@(x
?R?<@PF\ -T@?+,??<@xB???;T@???r<@????BT@|?!8.g<@?#?FT@$?^F?d<@T:X??HT@??B?a<@l\??JT@??`<@<??~LT at L?*??^<@x9??cLT@<?Y??]<@(?N>=NT@,l? S<@?dST@?^}<?)<@??M?WT@????*<@??W?^T@??Dg?<@x` ?fT@?QG??<@?`6?nT@$?^F??;@?=?qT@?G,?;@?{e??yT@?w?~??;@??M?{T at PL? 3?;@d?VA~T@ ?????;@?????T at T??z?;@??????T@??G?)?;@,_????T@????;@??????T@(r??9?;@?t????T@ ?={.?;@?]??y?T at PU??X?;@<?E~??T@?!<??;@$???{?T@?+?`p?;@??e???T@?Y?;@?????T@|?b?:?;@,*?Z?T at P?\?m?;@??,AF?T@?O8???;@??A??T@?=??j?;@?u?!?T@??w?'?;@??????T@?/?
?;@?:????T at t?y???;@x` ??T at t?8F??;@$?????T at T:X???;@?? ??T at P?&?O?;@?r???T@??)X??;@T=???T@?/?
v;@?L???T@????s;@$????T@?????r;@????Z?T@???s;@???M?T@??or;@(c`?T@ ?!??c;@??????T at T?T?	_;@?0_^??T at PO??X;@??a???T@,i?7V;@?i? ??T@$???W;@????T@??G?)[;@??6 ?T@??`;@??~7?T@?W?Bi;@??????T at H/?y;@<??A??T@?g@?y;@xx????T@??6 x;@?#????T at Ljh?u;@$????T@???w?h;@?????T@|$%=e;@????N?T@|???b;@??????T at T@?? _;@d?{???T@?? Z+Z;@???A??T@$W@?b;@??I~??T@?O8??p;@|r
?T@@74e?s;@d?: ??T@?.??|r;@????9U@(~??kq;@??3?IU@??M?s;@?? l	U@|?(B??;@???U@???ic;@PF\ U@?O8??`;@?Q?GU@,i?7^;@??M?U at T?X?;[;@PR`L&U at T?T?	W;@?????(U at du???O;@h???)U at d??a?J;@?1=a?+U@????r;;@xu??+U@???x?4;@????+U@?\7??";@????A*U@?u?!;@$&??[)U@?n.??;@????)U@ ? ?S
;@?Q?G-U@????g;@???80U at pLOX?;@<?E~?1U@|?(B?;@|6?>W3U@?z2??;@????6U@$??;??:@P@??=U@??E}??:@$???KU@$qVDM?:@|H???LU@?=??j?:@??? 4NU@???W?:@$???SU@?sD?K?:@?;??TU at P[#?q?:@??B ?UU@?-???:@?;??\U at L??u?:@?f??`U at x?q?Z?:@??;??bU at L???h?:@?(z?cdU@????Z?:@???A^hU@?Y?$??:@?]??ymU@??????:@o??nU@?M?#~?:@?`6?nU@?6?x??:@<??@fnU at P??|z?:@?9"??nU at P[#?q?:@h???8pU at x?u???:@?C?wU@??????:@P???|U@$?^F??:@?t???}U@<,????:@?u?!?U at d ????:@<??~?U@???i?:@???@??U at 8?]??:@<????U@?B]?:@h?R@??U@??}?:@???`??U@?L?:??:@?u?!?U@(?R?o?:@(??b?U at Ld???:@(?R?o?U@?????:@(?N>=?U@?[<??t:@P@???U@???[?k:@d?s~??U@????o:@8?]??U at lu9% z:@<?????U@?u?!?:@8?????U@wJ??:@L?#~??U@?I????:@????H?U@|??A??:@???@g?U@?\???|:@x` ??U@$w?Dff:@?Q??B?U@??`:@?6?^??U@ ??F?f:@|c ??U@???k:@??i? ?U@QL? o:@??/??U at 8??!o:@?<*???U@?pzk:@8?? n?U at T??y?g:@?x?'?U@?[zd:@i??U@ ? ?Sf:@??@??U@?????l:@?????U@???|yu:@TH?9?U@???#x:@?'?>?U@(u?8Fr:@|6?>W?U@({K9_l:@x?a??U at T?T?	g:@?"??JV@eM^:@h???V@??ky?n:@|H???V@?H?"}:@?`6?V at l?R]??:@??I~?V@??????:@???V@?N$?j?:@??A?V at P?\?m?:@??FV@??*???:@L
4?sV@?Z{???:@??w?'V@@?v?:@d????V@???B?:@<?U??V at 8(a??;@????AV@<??;@$????U@????;@P
?=? V at D?H??&;@???? V@?0Bx?1;@???? V@|0)>>9;@???8V@???w?H;@????V@????;@<????V@??????;@~? ?V at P?&?O?;@??p?V@@???;@?????	V at PI??&?;@?N?`?V@????Z?;@?"1A
V at x??Dg?;@????	V@(r??9?;@X??#	V@??????;@????sV@ ?bG??;@PCT??V@|-??1?;@?L??V@???	?;@??|?5V@?U????;@??x>V@<&R???;@f??? V@??7?a
<@P+L?k#V@?????<@LLb?'V@?b??<@PX?e/V@??*??<@h?2?}1V@ ??z
<@`X?|5V@|???<@$???7V@????B?;@????#8V@(??=$?;@x9??c8V@?h;???;@<???6V@??	?Y?;@?x?'5V@??E}??;@?"1A
4V@??*???;@(???I3V@??&???;@????0V@?w?~??;@?r??1V@?W??q;@?Ko.3V@$??E?j;@P
?=?4V@ ??G?b;@???>U9V@???>UU;@l\??:V@ ???!R;@`???:V at pN%@Q;@????Q:V at 4=((EK;@?@I?9V@?????F;@????5V at P???D;@P?>?3V at x??C5A;@r???0V@?
?7/;@????0V@?/?
&;@PL? 30V@??
??%;@????2V at P[#?q$;@?????4V at T@?? ;@Z_&7V@|!???;@??]??7V@??_>;@??|?59V@ ?????:@??d ?<V@,oG8-?:@h??}qBV at 8???(?:@???iEV@?????:@?=?EV@?,????:@h???FV at T???"?:@8en?HV at T?P???:@??>?IV@?&M???:@?7??LV at x?q?Z?:@?H.?!NV@?ek}??:@?????QV@??????:@]P?2SV@?t????:@???~WV@|?m?(?:@??A?WV@???B?:@?????^V@<? ??:@|<???aV@?_x%??:@???dV@?I?p?:@|<???eV at T?P???:@???!iV@???<?:@??|?5iV@5????:@LF?a?gV@?7?a??:@@?a?'iV@?? ?:@??RAEqV@?D???:@P@a?rV@?m???:@?cw??sV@|$%=?:@?	/??vV@	Q???:@?E?>?V@(r??9?:@?z2???V at x?4E??:@c?~??V at h???b?:@??,AF?V@??d?:@??p??V@$qVDM?:@?D???V@$?????:@??$???V@?t????:@????9?V@@	]?:@Pg?!??V@??I?:@|l????V@?;??:@????A?V@$????:@??|?5?V@,l? ?:@??6 ?V@??d?:@d?VA?V@?70?Q?:@xT???V@????:@<?e?Y?V at T1?~??:@i??V@?????:@?????V@|?y??:@??M??V@|?y??:@?Q?G?V@|??A??:@`?????V at L?????:@?Ko.?V at T=???:@?
)???V@|*?=%?:@xrM???V@$w?Df?:@??????V at hs????:@?N??:?V@$????:@?i????V@ ?={.?:@N^??V@@??P?:@P"???V@|?????:@(????V@?=??j?:@?i????V@?.m8,?:@(????V at T?T?	?:@t???V@?c!:?:@?E?~?V@??v???:@P<???V at PI??&?:@(2s???V@??^?:@?????V@?e?%??:@?9"???V@??{???:@?ng_y?V@?F??:@d???W@|'f??:@h??W@??#??:@??~7W@????y?:@?Hg`?W@<)???:@<??A?W@????B?:@|0)>>W@Z_&?:@????sW@$??:??:@<?i??W@<????;@P4`?W@?M?#~	;@?n??W at P?"?;@|x? #W@???"M;@???? W at T?z?;@????? W@??z?+;@|E?^?W@???C60;@$#gaOW@??z?K;@h????W at L??uY;@?;??W@?B]^;@?? ??V at 8?~??y;@|??!U?V@?CVt;@$W@??V at Lp??o;@???>U?V at L?*??n;@??U?@?V@???$?|;@?9[@h?V@??P?;@B@???V@??E}??;@d???j?V@$?????;@|??!U?V@?;??;@(????V@??r?S?;@PF\ ?V at x???s?;@??$???V@?Qew?;@<?I/?V@?c???;@?I+?V@????i?;@d????V@|?e???;@Q????V@@??"2?;@???@??V at P?c*?;@?????V@@????;@|K9_? W@??#??;@L?'?W@ #???;@?qo~?W@??{b?;@?cw??W@     ?;@<?e?Y	W@?M?#~?;@`??-W@     ?;@P.?_xW@?????;@?????W@??eO?;@????#W@?n???;@(?
?0W@$z?r?;@xu??W@????o?;@LLb?W at 0??:??;@x` ?"W@@???;@]P?2)W@?F??;@Q???,W@??????;@TC?
.W at d??a??;@??? !.W@\C???
<@?<*??+W@ ?P?f<@8n1?7+W@,~SX?<@h?>?+W@????`<@???w-W@?U,~S$<@<?I/0W@??h>+<@???>5W@@?@?w6<@?$??6W at 8 B\93<@?? !?8W at H$a?2<@????;W@?c???;<@?J???BW at h9?CmO<@<??aHW at 8???Q<@???!6NW@????Q<@??5OW@?
(?W<@ ?? >OW at 0???/c<@?B?_?MW@@C?k<@(?_RW at t<f?2~<@???@?TW@x?=\?<@?P?UW at Hw;S?<@@???VW@e?f?<@?q ?XW@??????<@h???0\W@?X?;??<@L(D?!`W@??=]??<@h???aW@?x"???<@????bW at lQf?L?<@l??fW at lg??R?<@?{??miW@|o??<@?W??"lW@?/?
?<@(5??nW@??VBw?<@8????vW@ ?a???<@?;?%yW@??B??<@?3???}W at Ts??P?<@???@W@?:?? ?<@<??A??W@??K?<@<?e?Y?W@????<@?"1A
?W@?N"???<@? 3???W@ c?ZB?<@???!??W@? @???<@???^D?W@??<I=@?????W@?????=@\?????W at t?5=($=@?h?^`?W@`?
?+7=@PCT???W@??{?7=@ ?|?W@??"??6=@?|a2?W at X|E;=@??M??W at 0n??E=@?;3?p?W at 0?r?]U=@?(A??W@G?&V=@??????W@\?'??B=@???M?W@? %?,=@?xZ~??W@???a?#=@$?w~Q?W@,i?7=@??!??W@EH??
=@|??A??W@?]K?	=@??6 ?W@$??E?
=@$????W@????
=@?&???W at T?P??"=@?????W@ ?A?0=@`?? ??W@ ??{GA=@d?s~??W@?????W=@??i?W@|-??1d=@|?5^??W@??hUe=@(__? X@$[A?n=@????YX@,i?7v=@??g?RX@??ky?v=@|]??t	X@????Be=@??>?X at d???Y=@LLb?X@?u?!P=@|i? ?
X at P?_?F=@|K9_?X@??a?A=@?`???X@???f>=@????X@?/?
>=@|????X at P?"?F=@?K???X@ ??{GI=@?C?X@??j??A=@?T2 TX@(?R?o.=@????QX@?,???+=@<??@fX@?U???*=@h??>?X@??C*=@????X at Ljh?%=@?????	X@(???I=@h????	X@???A??<@$??}8X@<#??<@|3j?JX@???B?<@h o?X@?!<??<@???@,X@(?????<@????X at x??E??<@?@I?X@Z_&?<@?dX@?d=@??~7X@?C4??=@?H.?!X at L?*??=@o??X@?E?>	=@??? X at t?<G??<@?I+"X@???|y?<@@???&X@????Z?<@?bc^G'X at X??x??<@	?c'X@??????<@?1=a?X@???7?<@????NX@??l??<@?1 ?X@$w?Df?<@d??A%X at x?u??d<@???@?X@?T?G?Y<@$???X@????j<@d??Q&X@?IEc?w<@xu??)X@$???w<@??~7+X at P???Tu<@?
)??/X@?
?Dl<@????z0X@??M?g<@?????1X@??v`<@????#4X@|????]<@?@I??X@???U<@?9?}?@X@???|yU<@$)?ahCX@?L?:?[<@????QFX@??	?Ya<@??4HX at d ???a<@<?i??IX at x?4E?_<@????9OX@|?,CO<@$???OX@(??bI<@??!?SX@??M?;<@?T2 TVX at H/?9<@???@gUX@????*<@?bc^GTX@$w?Df<@<???	WX at P?c*<@????ZXX at t??F??;@???>WX@?!<??;@?B?GX@?K????;@P???BX@?8????;@PO??@X@??????;@?
)??;X at P?????;@?????8X@??????;@?.??8X@?Fu:??;@u??9X@?g@?u;@????>X@???@?];@?u?!@X at 84e?T;@<?E~?AX@?Z??M;@x` ?BX at L??uI;@???@-JX@?/? ;@?k?}?HX@??r?S;@l?j??CX at lv???;@$8????X@(u?8F";@?]??y=X at Ljh?%;@h????9X at T?X?;+;@????s8X@ ??F?.;@D??@J7X at P?|a6;@d?w?6X@?4?8EC;@??;??4X at P?&?OR;@<?I/2X@|??A?X;@l?? ?0X@(???[;@|]??t.X at hy??];@??'??'X@??&??];@d????X@?:q9^M;@L1AGX at T?z?M;@????X@?)??F;@??d?<X@ ??zE;@|????	X@?Fu:?A;@<??HX@???i;;@?Hg`?X@<2V??/;@?.?? X at 4=((E+;@d?????W@???X?";@?4E???W@ ?~?:;@??>??W at X????;@LI????W at la?9
;@8?M?a?W at T??y?;@??t ??W@???eN;@?@I??W@???;@d?????W@?K?? ;@d??@??W@??9??:@p????W@??????:@P????W@??????:@?X"??W@,l? ?:@????z?W@?u?!?:@d?????W@$??E??:@?D???W@???w??:@<q9^??W@`$??\?:@d??@??W at t?????:@h?R@??W@(???I?:@??????W@?B]?:@?N??:?W@ ?????:@|0)>>?W@`od?:@?bc^G?W@ ?????:@??~7?W at P????y:@??RAE?W@?_x%?O:@|x? #?W@?k|&?;:@????@?W@???i#:@???~4?W@?????:@?p!??W@?\??k	:@?????W@$}ZE :@xB????W@?,????9 at h?????W@<,????9@????N?W at 8:??8?9@T????W@?????9@??I~??W@????r?9 at h?N???W@?+,??9 at xrM???W@<????9@?Ko.?W@?C?b?}9@????\?W@$??:?~9@????W@?M?Ew9@(5???W@?F?r9 at PU??X?W@????m9@?_"?:?W@?5??f9@(A?G?W@N^?I9 at Pg?!??W@?6?x?;9@r???W@??
??59 at h???W@|*?=%/9@??$>w?W@?]i?+9@(?R?o?W@?^}<?)9@??????W@?????'9@?I+?W@ ?!??#9@~? ??W at x?4E?9@?"1A
?W@?v?19 at P}>??W at PI??&?8@?cw???W@??r???8@????A?W@???}??8 at P"???W@?=??j?8@???8?W at T:X???8 at P????W@|*?=%_8@<??~?W@?.m8,I8 at PR`L?W@ ????-8@B@???W@$?^F?8@??(@?W@????8@|]??t?W at T?z??7 at 8????W@??~??7@?P??W at 8% &??7@(?_?W@????r?7@??U?@zW@??/???7 at d??@?vW at x??C5?7@?9"??tW@iT?d?7@<???;sW@<?? ??7@?v?1rW@?>U??7@???qW@?? 8@????#lW at d????8@?8?:hW@|?b?:8@@???gW@?N$?j?7@?????eW at Lg'???7@|????aW@$[A??7@????`W@?B]?7@$#gaO^W at hv?[??7@?M?a?ZW@<X??08@,5{?ZW at Hh??8 at L?d??XW@???E8@????WW@\ ?K8@6???UW@???c8 at P???TW@???4	8@?C?UW@???	?7@??=xVW@?d?<
?7@f???XW at PF\ ?7 at d?s~?ZW@???Dh?7@???[W at x??E??7 at P??5[W@?{F"4?7@??>?YW@({K9_l7@??'??WW at Ld??[7@???A?XW@????@;7@(??>VVW@?{F"47@?D??SW@3???7 at h????QW at PF\ 7 at Pd???OW@??5?7@`X?|NW@<?$?7 at h??`oMW@????
7@????KW@?5_%7@??e??HW at TC?
7 at xT??HW@??|@?7@?l??HW@???B?6@?1=a?GW@?h;???6 at d?s~?FW@(r??9?6 at P@??EW@??ky??6@???8FW@??
DO?6@?7?a?GW@,??;??6 at h??IW@]P?2w6@?bc^GKW@????q6@???LW@?=??jb6@????ULW@$z?r[6@|fI??LW at T???"Q6@K??LW@<????C6 at p<??IW@??#?06@??,AFHW@????/6@?????FW at x?u??46 at P4`?DW at T?{/66 at d?&?CW at 8???Z46@????AW@?I?p6@??i?W at P[#?q6@?? l=W@ ? ?S6@?*?);W@ ??{G6@?9"??8W@???|6@?"1A
8W at T.T??6 at h?B,7W@???|y
6 at xW=`3W@?8???6@???~4-W@????'6@$???,W@??6 6@????A+W at h??`o6@?????&W@?,????5@????s&W@????r?5@]~p%W@?????6 at d???&W at T?P??"6@@???4&W at T????,6@??x>%W@??}R6@?d$W at Ld??[6 at h????!W@?:q9^?6 at h?>?!W@K????6 at h?N?? W@ ???6@??l?W at xB????6 at P"??W at x?q?Z?6@?????W@???-7@?(z?cW@??N$?:7@??iW@??E}??7 at 4bf??W@?f?"I7@?B?W@??C??V7@??B?W at t??<^7 at P
?=?W@$?S;?t7@??3?/W@,J	???7@?`6?W@??{?Y?7@(2s??W at d????7@(?
?0W@,oG8-?7@?;??W@?[<???7@(?
?0W@?	K<??7@?@I?W@?!<??7@???MW@??f??7@W??W@?:q9^?7@??????V@??????7@????Y?V@??
DO?7 at d?g^?V at T?{/?7@???A_?V at L???h?7@?Q??B?V@0?[w?7@i??V@???7@(5???V@?P?l?7@|Q?_?V@???0q7@?p!??V@??Io7@??(@?V@?]K?i7@?????V@????/V7 at PI??&?V@|!???O7@(???I?V@0?[wG7@(??)?V at la?9A7 at h?????V@??v??:7 at xx????V@??B?17@??A??V@?????(7@????\?V@|?,C7@u???V at L??u	7@<??@f?V at t?????6@<??"?V at h?"???6@N^??V@`2?C?6@?d?V@,oG8- 7 at xB????V at x??E?)7@???A_?V@?(z?c87@?f???V@?
?7?7@$?6?D?V@(b?C7@??????V@??I'D7@???I?V@???#87 at x9??c?V@?B].7@??????V at T?z?!7@(__??V@,oG8-7@??>??V@<?Y??7@????V@??d#7@?E&???V@?b???7@?P??V at T???"7@?+?P?V@?X?7 at l?J>v?V@?O8??07 at L.??:?V@?Ry;?57 at P"???V at xE???<7 at PL? 3?V at T??zL7@?????V@??E}?_7@<?$@M?V at P?`??s7@?(z?c?V@?K????7@????\?V@<?U???7 at h???V@$???7@$W@??V@??????7@f`X?V@?u?!?7@|?5^??V@@????7@|uU??V@??g?7@?%9`W?V@?/??7 at h?B,?V@?h;???7@?Ko.?V@?????7@`?o`r?V@<?? ?8@`?"???V@???B8 at Xya??V@?~??@8@ 3??O?V@?I???8@?S??V at x???A8@??U?Z?V@|?,C8@?q ??V at X????8@????V@? ???'8@  |?V at 8??_?&8@?????V@?sD?K-8 at 8w?^??V@?p>?H8 at 0M???V@??_Z?S8 at xE????V at L??uY8 at P@a??V@????Q8@??A?W@ ?!??c8@<?(AW@ ?bG?h8@?7??W@?8???o8@(??>VW at hy??}8@?????W@$?^F??8@??x>	W at d?b??8@??i? W@?????8@?"1A
W@?Z
H??8@?z2??W at H?p?8@?Z? mW at P?"??8 at T4???W@B]??8@?????W at Ld???8@??$??W@?>U??8 at xx???W at 8?!?8@$?`6W@ ?%??8@??B?W@??B??8 at T=??W@?`S?Q?8@?L?^?W@<?zj?8 at 8?M?aW at l?? ??8@????vW@???~??8@??_>W@?i????8@?f??W@(?????8 at l???W@??8?~?8 at d??QW@?B]?8@<??@fW@???|9@?I+W@?P3??9@?Q?GW@(??>V9@????ZW@ ?!??#9@?Ws?`W@?,???+9@<?E~?W at x<-?p-9@`X?|W@<2V??/9@?n.???V@?W???.9@??M??V@?U???*9 at h?>??V@?U???&9@???~??V@????#9@{????V@ ??F?.9 at h?????V at t?y??49@????V at d??
29 at h?????V@(u?8F29@?9"???V@(??b19@<??@f?V@?a?? /9@??????V@|?b?:,9 at h?????V@??P)9@$????V at La???&9@u???V@????&9@?t????V@$??E?*9@?Hg`??V@?4~??,9 at h?????V@|0)>>)9 at d??~??V@??o&9@<??@f?V@??C&9@?"?~??V@?@?9w'9@$[A??V@?)??69@|`???V@?????B9@u??}V@?BF?K9 at d?F ^zV at 81$'O9@????xV@?5_%K9@(?R?ovV@??9?I9 at Ts??PuV at L?*??N9@|0)>>tV at D? ?]9@?l??tV@?B]n9@`X?|vV@??D???9@<???	wV@??|@??9@????@wV@?5???9@<???;wV@??&???9 at PI??&vV at T???"?9 at P=???sV@?P3???9@,*?ZtV@(?N>=?9@@?a?'uV@?X?;??9@(??>VvV at D??~??9@?F??uV at Lp???9 at xu??qV@??;?:@|Nz??nV@???B(:@$???kV at d??]?(:@?R?!?iV@???0:@??<??hV@???::@?/??fV at 4?Ry;::@?~?~?cV@??a':@p???dV at x?q?Z :@d???fV@?P?l:@|c ?fV at p??\?:@E? cV@???d :@?bc^G`V@???q:@?<*??UV@??$\:@?ng_yTV@??EB[:@???a1PV@?u???:@x?a?HV@?yY':@?^?GV@<?U??-:@????EV@?Y?XL:@?????DV@?;??b:@??<??<V at dv?Sq:@4??a0;V@?????l:@ ??^E:V@??(&od:@??a;V@???d?[:@Xa3?>V@`?D?V:@?????BV at lQf?LF:@?T?~OAV@ ?4<:@T7?6V@?mm?y=:@?d??/V@??x#K:@????
-V@??PU:@L:??l,V@?CVd:@?cw??+V@uX??k:@(5??&V at h?ba?x:@h?N??$V@????w:@d?s~?V@?b???:@$???V@(?N>=?:@D?X?oV at L???J?:@d???V@??????:@?}?AzV@????{:@???A?V at 8???Zt:@??P??V@??:M|:@ ?{?V@?}s?x:@?D???V@??E?u:@?:??? V@ ?%?h:@?mm?y!V@?T[^:@?T?~OV@$z?r[:@???A^V@?4?8ES:@u??V@?70?QH:@PCT??V@?X?;??:@????NV at 8???Z8:@?T?~OV@|???!2:@?????V at La???&:@d???
V@?}s?:@?'?>V@??
DO?9@?dV@?b???9@~??7	V@??d#?9@<n??t
V at X??x??9 at PF\
V@?????9@<??@fV@??????9@??K?AV@??s???9 at P1???V@??J#f?9@<????V@?/??9@?f??V@??Hh??9@??^V@?????9 at 8???#V at x??C5?9 at h????)V@?sD?K}9@?B?_?-V@???7}9 at h?1V at X?????9@?Ko.3V@,?????9@(???I5V@?t?? {9@??8a?5V@????v9 at P4`?5V at 8? "5m9@?3???4V@?1=a?g9@??l?5V@?K?^]9 at P@??7V at T???"U9 at P@a?;V@?????N9@??$>w?V@???X?N9@|c ?@V at P?&?OJ9@??M~?<V@???i+9@?n.??;V@|'f?*9@?9?}?8V@????-9@?F??-V at T?z?19@(??b)V@?F?29@?B?'V@??gx?29@<?? ?V@?t?? 39@?C?V@????:09@?%9`WV@?t?? '9@?????V@(???9 at P"??V@?b??9@?? lV at hv?[??8@??? ?V@??J#f?8@|c ?V@?NG??8@???@?V@|6?>W?8@????V@@ ????8@?E?~V at L
4?s?8@????	V at 8w?^??8@?(z?c
V@<?????8@??/??
V at 87?',?8@(/2?V@??B??8@????V@???i?8@??|?5V at do)???8 at PU??XV@??????8@??? V@?1=a?w8@??? 4V@???is8 at PX?eV at L??ui8@??A?V@?4?8EW8@?? v V at L??uQ8 at P<??)V at x?0DNK8 at xrM??*V@???[O8@?;???,V@????aN8@<?I/.V@???A?G8 at xx???.V at T?P??B8@?~NA~/V@ u?=8@???>0V at p?0'h78@?F? \/V@x` ?/8 at h???-V@|'f?.8@?4E??,V@????&8@$?6?D-V@??(8@?w?~?,V at PF\ 8@????s.V@??x?n8 at 4SZK0V@|?"n
8@?@I?/V@??p=
?7@????+V@?{?E{?7 at xZ~?*(V@?$y??7@ ????&V@???!??7 at h????$V@ ?~?:?7@???8$V@??
???7@<???r%V at d??a??7@]~p0V@??Q?(x7 at p$?`S2V@`??*~7@?T2 T2V@???is7@????N/V@???}?Y7@(&o??-V@?	???O7@?f??-V@?^??E7@?1=a?.V@????@?7@????3V@??C:7@?????4V@???!>7@??1!?>V@`]??47@????:V@??E}?7@??bg9V at d*??7@?N?`?7V@@N??7@<???;7V@|*?=%?6@??? =7V@$????6@?]??y;V@??????6@??{???V@|E?f6@?cw???V@???S6 at l?J>v at V@??;?F6@ 	??%AV@,?F<?A6 at h????CV at T??f?46@?*???DV at 4???416@?@I?FV@???$?$6@???@-DV@???6@??ADV at p???6 at D??A|CV@??i? !6@|???aBV@<???6@?
j??BV@9D??6@???nCV@?!<?6@?dDV@??j??6@$?@?CV at t?????5@,*?Z at V@(x
?R?5@x'?AV at 8+?&??5@i?EV@<2V???5@<??@fEV@T?^
?5@<?Y??CV@<&R???5@<??@V at 8"????5@??e??:V@(u?8F?5@?p!?6V@??{???5@???A?1V@,i?7?5@?F??/V@?O???5@?#???-V@??:??5 at P<??+V@$????5 at xE???,V at T?????5@<i??-V@???c?5@????U.V@??????5@ ???/V@??8?5@?r??0V@?66;R6@?:?*0V@?)?D/6@i?-V at T7?6@?????.V@?b??6@????+V@?5???5@|<???(V@?D???5@??M?'V at T?{/?5@??;?(*V@?X6@`?sa?)V@@F@?#6@|??A?(V at X????6@?Q??B)V@?
?76@?!S>*V at hy??%6@o??}+V@??G?)+6 at xcAaP+V@(??9x26@?????(V@?G,)6@??_>'V at 87?',6@?B?_?'V at PF\ 6@?"1A
(V@?>+
6@?Ko.&V@??M??5@$W@?&V@?X?;??5@<?U??%V@???$??5 at Tal!?$V@?}s??5@?<c_?#V@6\??5@????5$V@??w???5@?;?_?&V@??1??5@$???1(V@?V????5@$???1(V@??y??5@|`??&V@??#??5@???@?$V at L?g\?5@????r"V@??z???5@?qo~? V@?h????5@$???V at P??C?5@<????V@??3?/?5@?:???V at X?y??5@?ng_yV@??????5@??h? V@???f??5@i?!V at T??y??5@?|A"V at T:X???5 at Tal!? V@?B]?5@(?_ V@??g??5@<?I/V@$???{?5@?=?V@? :v?5@c??KV at hv?[??5@ ? >?V@?4?8E?5@|E?^?V@?C4???5@|?e??V@?I?p?5@????V@<e5]O?5@??I~?V at x9??c?5@?B?V@?0Bx??5@$?6?DV@?A??5@?z2??V@EH???5@]???V@???5@f???V@??j???5@$??V@$?????5@|fI??V@ #???5@?o?^}V@(?
?0?5@????zV@??+?z?5@|H???V at T??z?5@<tz??V@?[?t?5@?????V@??
DO?5@????5
V@?K????5@?z2??V at x??Dg?5 at P
V@??????5@<?Y??	V@??/???5@(?
?0	V@???R?5@??m?RV@yv??6@ra?V at l^?Y-6 at h????
V@?2Q??
6 at d???
V@<?\?6@??n??V at P?>?&6@x` ?
V@?W???.6@???>U	V@?Fu:?16@???=#V at x??Dg56@<?E~?V@?H??Q86@????z V@|?b?:<6 at h?2?}?U@??/??@6@<?????U at T?P??J6 at d?s~??U@??ky?^6@???^??U@$[A?j6@<?E~??U@????k6@?9[@h?U@(eRCH6@|K9_??U@ ?A|`C6@(5???U@?g@?96 at PF\  V@l?`q46@?f??V@??06@???jV@(???I/6@`??_YV@\???-6@??	??
V at P^d~!6 at h?B,V@?J??q6 at h?N??
V@????6@?+?`pV@(?N>=
6@???iV at x0H?6 at PU??XV@???i?5@??i? ?U@?d?5 at P????U@@????5@?
)???U@?EC???5@?E?~?U@??6 ?5@????U@?????5@<n??t?U@??hU?5@(??b?U@,i?7?5@?1 ??U@?&???5@?F???U at 4=((E?5 at h??U@?NG??5@$ &?B?U@<???5 at 8? U?U@@????5 at d??Q?U@????z5@??????U@(????u5 at h??`o?U at P???Tm5@|i? ??U@$??a5 at d??Q?U@?_x%?G5@<?I/?U at H/?95@$???{?U at h?"??15@?;???U at T?T?	'5@?0_^??U@??eO5@??r???U@????4@?P???U@???w??4@??4`??U@?.m8,?4 at P1????U at lU??4 at d?VA?U@?=??j?4@$?	??U@?\7???4@?*?)?U@????4@?????U@?l???4@?C??U at x9??c?4@$???{?U@(k?C4?4@?????U at T=???4@(?R?o?U@?b???4@???_?U at t??F?}4 at h?????U@`?_?t4@{????U at x?u??d4@$???U@<???^4@???@g?U@?)??f4@(??>V?U@??G?)o4@$????U@?@?9wg4@????N?U at ldWZFb4@|??A??U@(?J=V4 at l?J>v?U@???UH4 at h?????U@(?R?o>4@$)?ah?U@?????<4@??K?U at Lvl?94@??? ??U at t?y??44 at h???8?U at P???T-4@??a?U@`od%4 at LLb??U@??>$?3 at L(D?!?U at d?c?3@?'???U@??Ia?4 at D????U@??c4@E?>??U at PL? 34@?B??U@??9?4@?@I??U@???=#4 at d?w??U@????@?3 at l?	?i?U at T???"?3@?'?>?U@?A??3@(?
?0?U@?QG???3 at h?}U@??*???3@??i{U@(??=$?3@??I~?wU@ ?~?:?3@????roU@??}?3@f???hU@??
DO?3@??	??^U@?.??|?3@?9?}?\U@?]K??3 at P7P??\U@?f?ba?3@???A?[U@?H?F??3@?a0?]U@?-v???3@?t"?T_U@{????3@$ &?BaU at h'????3@,Y?&cU@???f??3@ '"?cU@?#??S?3@(2s??cU@?|a2?3 at T????dU@?e?%??3@??3?/bU at d?? w?3@x?=\]U at P0?A?3@????[U@?A??3@?3??VU@??,AF?3@???=?TU@?????3 at X??IOU@?????3 at tJ_MU at L"? ??3 at h????JU@??~??3@?l??3IU@?h?^`?3@???!9HU@?lw?3 at 8?!HU@??=]??3@??FJU@|??8G?3 at 8b->LU at De????3@|?Y?HLU@` ?C??3@???~?NU@?????3@?????OU@????G?3@???!6RU@??#??3@?????SU at XL?Q?3 at l!?A	VU at H? \?3@?5??WXU@?:?*?3@??6 ZU@???M?3@????zXU@???x??3 at d??A%WU@?t????3@(?N>=UU@?????3@ ?a??RU@???<??3 at x??^SU@???f?3@\?&?UU@,?w?7?3@?D?A?RU@?4f?3@?M?tQU@? ?=?3 at 0h!?KU at h|_\?z3 at X?? JU@??tZ?u3@??7?aFU at P????i3@????Z8U at x???s:3 at d?VA5U@??G?)+3@??;??2U@??d3 at T@?? 1U@???x?3@?0_^?.U@?????3 at d??@?-U@????3@????/U@?%9`W3 at T=??0U at P??{H3@????0U@?n.??3 at T%??R-U@|-??1?2@(???I+U at T???"?2@?I+*U@(r??9?2 at P
?=?(U@f`X?2@<???;'U@??I~??2@<????U@|?b?:?2@????\U@?&M???2@??cU@
?2?2@f???U@?@?9wW2 at d???jU@??hUM2@?i? ?U at PO??D2@$W@??T@??
DO:2@f????T at x?q?Z02 at D?X?o?T@?ri??#2 at PL? 3?T@?z2??2@?F???T@?W????1@?.???T@ 2?1 at h?????T@??ky??1 at P????T@$????1@?x@??T@??????1@?T?~O?T@?fh?1 at h?N???T@$?@?|1@f????T@??vh1 at 8????T@??B?a1@?????T@(???I_1@|W?[?T@????J1@|E?^??T@|!????1@f????T@?>U?:1@???j?T@??I~?31 at h?B,?T at 87?',1@?"1A
?T@?L?:?1@??+???T@(h??'1 at xx????T@?[?t?0@???8?T@?T?G??0@?R?!??T@({K9_?0@$)?ah?T@$?^F??0 at 02??T@?P3???0 at 4?????T@?d?0@????U?T@|?y??0@??,?T@???Dh?0 at H? O?T at P??C?0 at xN?@??T at PU??X?0@?(?A&?T@?A?0@?D???T@??I~?s0@??JT@????g0 at 8n1?7|T@ ??G?b0@????UqT@???iS0@??M~?nT@??E}?O0@????mT at T???"Q0@????iT@???@?U0 at d????dT@$???W0@ ???_T@?U???Z0 at d???[T@?1??8^0@??'?bZT@$W@?b0@?V???UT@?_x%?_0@??M~?TT@??9?]0@`?? ?PT@|$%=U0@??Ia?OT@@?vP0@?H?}JT@?????0@?f??IT@?o`r??/@?????FT at P??{H?/@ ?!pBT at X?y??/@x0b? @T@?????/@?8?:@T@?5???/@ ?<?@T@????/@??_?9T@?>U??/@8?M?a:T@?Z??K?/@?'?>:T@??M??/@u??9T@|???0@?.??|8T@?r??0 at T:X??8T@??{?Y?/@??>e9T@??????/@?f?8T@????k?/@|??A?4T@??????/@Z_&4T@?5_%?/@?!S>4T at 0Z????/@$??3T@???n?/@o??1T at 0O?)??/@l\??.T@??Q??/@???A?+T@??????/@|i? ?#T at pw?}?/@?Q?GT@?1??/@??A?T@?Yg|_?/@(?
?0T@??V?I/@<????T@ ??Ct/@??$??T@ s??e/@|??A?T@?E?n?Y/@<?? ?T@???	7/@(??b
T at 0W?6?/@?.??T@?"????.@???>T@???OV?.@?oB!T@?7?a??.@?t?_?T@?g?8.@??p $T@?c\qq.@(&o??T@?"1??- at d??@?T@
6u?- at P+L?k	T@?????\-@??#??T@???OV4- at 8???zT@?#?-@$???1T@???
??,@?w?~?T@???1?, at 8en?T@?i?q?f,@<}??T at pJ@L?5,@ ? >?	T@?]?pX,@$???T@????b?+@$)?ahT@ ?????+@|c ?T@ ?!???+@?z2??T@???4??+@$8???T@?s~???+@?w?~?T@??
DOz+ at h??}qT@(x
?Rg+@????T@?~??@W+@???@,T@???B+@?I+T at x28J^
+ at P%@T@?/?
?*@d????T at P??{H?*@??
?T at X??x?+@?B??T@?r???%+@|6?>WT@?A?/+@????	T@ ???o+@?t???T@???#`+@?*?)T@??p?=+@|o?T at H????,+@???@gT at X????+@?b.T@??|@?+@???^?T at 8l???*@(??>VT@?i?q??*@?.??T@?JY?8?*@<??~T@(oG8-?*@?9[@hT@?[?tY?*@????QT at P?\?m?*@f???T at X????X*@xB???T at 0Z???D*@??7??T at H????*@(??T@???P??)@?.??T@?>U??)@?qo~?T@?i?q??)@|ZEhT at 8]???)@d?s~?T@?	???W)@????A
T@??? 4?(@T4???T@????(?(@d?s~?T at x><K??(@PI??&T at X?L???(@?4E???S@?'f?j(@T:X???S@?1?T(@|o??S@????F(@<??H?S@?5??(@XO????S at 8_%?(@PX?e?S at P?*??(@?q ??S@?.???'@?????S at x?n?|?'@l$	??S at h?????'@?}s??S@ ? ?'@L.??:?S@?~????'@???@-?S at H>?x??'@?/???S@ ???!?'@?/?^|?S at H\????'@?k&?l?S@?^????'@????N?S@????y?'@PU??X?S@ ??C?'@??
??S@?u?r?z'@???=??S@?r??O'@u??S@?d'@??A$?S@???)?&@|x? #?S@???	?&@?????S@ ??E?J&@|l????S@ :vP)&@$W@??S at X?z?&@??;???S@?O?c?%@u???S@(l? ?%@??$???S@?|A	?%@?_"?:?S at 8.???%@????@?S@??Za?%@?t????S@?????%@??B??S@??????%@?'?>?S@?b*???%@<??A??S@???3g%%@??~7?S@?/??$@??m?R?S@?yUg?$@??B??S@?]?pX?$@??`??S@ ?t?$@?Z? m?S at X?z??$@ ?k^??S@?????$@ '"??S@ a???$@??? ??S@??:M?$@?????S@?b????$@h???S@?7??$@,AF@??S at PqN?$@???@-?S@???.?$@xB????S@?Z??K?$@?v?1?S@@/??$@?????S at hg??R?$@??bg?S@?r???u$@$???{?S@???@?]$@P%@?S@?3Lm?K$@<n??t?S@?dp??*$@??_??S@?_??$@     ?S@???0?$@?|A?S at pS???#@$????S@?????#@??$>w?S at x3j?J?#@|?????S at X?L???#@f????S at H?????#@????A?S@??U}#@(5???S@?KTo
T#@???A_?S@?]?pX2#@???@-?S@??/??"@?k?}??S@?;??"@L.??:?S@?&M???"@??????S@ ?????"@f????S@?t????"@L
,?)?S@(5{??"@??u???S@??O?m?"@?h>??S at pJ@L??"@Tdt@?S@??$??"@?????S@H?`?"@???9?S@(n?@?"@??????S@?m3?Q"@<??@f?S@???TV"@??6 ?S@?D??d"@?`6??S@?/?p"@?Q??B?S@@#?v"@(5???S at x3j?J~"@??#0?S@?G??
?"@??3?I?S@Z_?"@P????S@?;??"@??l??S@??,??"@??Q?(?S@?ek}??"@?????S@??w?'}"@P????S at H??0u"@8?M?a?S@??,?sZ"@??????S@?5??:"@??$>w?S at P?{/6"@(?N>=?S@?&M??1"@h?>??S@?c??+"@P
?=??S@({K9_?!@<?i???S@??Po?!@$?w~Q?S at 0`???!@P??5?S@??eO?!@?}s??S@???B<!@?5_%?S@???P?(!@$#gaO?S@?i?q?? @|Nz???S@(???? @???@??S@????? @??;?(?S@???5?? @h???S@(r??9? @?????|S@?#?? @(?R?orS at P???hd @?&??iS at x ?HO @$[A?fS@?N??I @8?]?eS@?>U?B @????cS@@/?2 @?T?~ObS at 0Z???$ @???>_S@?????' @??3??\S@?,???+ @d??A%SS@?D??D @??;??NS@(qVDM\ @8w?^?JS at P???Tu @lFA?ES@?GW?? @??|?5ES at 0T???? @(?B?BS@ ?bG?? @?z2???S@?(?1? @???@?=S@???? @(??b=S@???25? @|??A?<S at P?{/? @|????5S@ ?t!@`?? ?3S@??K?[/!@?????*S@????Z?!@h?R@?$S at H?????!@???_$S at P???6?!@h??>?$S at H?o	??!@??I~?&S at hm?k?!@????(S@?????!@????A*S@?pt???!@??+?z*S@?E?n?"@|Bv??#S at pD?K??!@<?I/"S@(i?7?!@$?w~QS@????bI"@PR`LS at pY?? "@(??>VS@
???"@?t???S at P??C?"@|x? #S@
6u?"@?-W?6S at x28J^?"@?B?S@??Po?"@????rS@??7?a
#@<???;S@??;?#@?@I?S@(l? ##@$[A?S@ ???/#@????sS@???B\#@?t_?S@(M??y?#@ND??S@?v?
??#@??]??S@??>$?#@d???jS at x5y?j?#@???`?S@??e2?#@Tal!?S@?@????#@??g?RS@@|`??#@?9?}?S@?'f??#@(5??S at H????#@`?_?S@???*?G#@??~7S@?&M??1#@?4~??S@@???
#@?F??S@??
M?#@?.??|S@@#??"@{???S@?????#@??(@S@?5??#@?*?)S@`?5?!2#@????S@??w?']#@|W?[S@?B????#@f???S@ "??u?#@?????S@?????#@<?(AS at x,?IE?#@d?F ^S@?????8$@?3???
S at x??F?A$@d??a?
S at 0Xq??0$@?? ?S@@J?i#$@$?6?DS@?)??$@h?B,S@?X??#@??N@
S@???"$@E?>?S@(~??k!$@|o?S@({K9_,$@|`??
S@???N$`$@??|?5S at P???6?$@h?2?}S@??|@?%@d??A%?R at X?P???%@??(@?R@??i3N?%@?K ?)?R@@,????%@d??A%?R at H??
?%@P@???R@?(?1?&@?????R at x><K??&@(??b?R@`?1???&@?D???R@?????&@?F???R@`???'@??;?(?R@ ????-'@?? ??R@?c??C'@u???R@?i?q?f'@??Q?(?R at H?????'@ ?????R at 0cC7?(@LI????R at 84e?(@$)?ah?R@????0(@(???I?R@ (??"(@??Q?(?R@???
?j(@???A^?R@??}?(@???>?R@ :vP9)@?Z? m?R at X?y?m)@?*?)?R@????~)@d?w??R@ (???)@?&???R@???25?)@?bc^G?R@??0??)@(??b?R@?????*@ ?a???R@???0??*@??]?9?R@?u?!+ at xx????R@?c\qq<+ at 8????R@??O=?+@??;???R at X??o(?+@???@-?R@?!????+@?-@??R at H?o	?,@?????R@?M?EC, at h?R@??R@????~,@B@???R at 0`???,@???@??R@?G,?,@?!S>?R@ ?????,@(??>V?R@??Y5?,@????\?R at x8?Jw?,@?!S>?R@???>U-@|0)>>?R@?WXp? -@|]??t?R at 8% &?
-@???@g?R@??,?s
- at h???R at H??
6-@???W?R@???(\-@???A??R at H??	?q- at d???j?R@?[?ty-@$?6?D?R@?,???{- at d??E?R@???Y.?- at x?n?|?R@?????-@f????R@
???-@???>U}R@?^??!. at T:X??|R@?T?2S.@?=?yR at P?&?O?. at PX?ewR@????o?.@???!?sR@???s??. at P.?_xrR@??`?H?.@???9uR@?8????.@|l???zR@??Q??.@??:M|R at H?s
??.@?Z? m}R@?&S?.@<????|R@?:??
?.@<? ?zR@???,?.@????vR at X??x??.@(??stR@ ?^F??. at xrM??rR@???T?.@?;??pR@ ?????.@????kR@?v??i/@?f??lR@?i??q/@????jR@?f??}q/@??|?5iR@??C?z/@?6?^?iR@ s???/@<? ?hR@?b???/@???>gR@??
DO?/@|Bv??eR@?5???/@PL? 3cR@?Q?o&?/@<????aR@ s???/@??M?_R at P?`???/@?d_R@?l???/@d??~?\R at T@?? 0@?'?>ZR@???B<0@?#?VR@???~?m0@?????TR@({K9_|0@ ? >?UR@????i?0@?dWR@,l? ?0 at d???SR at T?X?;?0@?Q??BQR at x???s?0@ 2PR@$????0@?Ws?`QR@?????1@??>?QR@??E}?1@$??QR@?;?1@?#???PR@(?
?0%1@?-@?OR@?#?,1@l\??LR@?Ws?`^1@?Y?>?KR@?O8??p1 at 8?? nKR@???w?x1@?9[@hHR@(????1 at h?2?}GR@?Fu:??1@|o?FR at P?????1@(?B?GR@?R??1 at P???FR@|$%=?1@??=xFR@?k?}??1 at d????CR@ ??G??1@?.??@R@??&???1@?I+>R@?JY?8.2 at h????=R@(r??9M2@<????;R@??PY2@(?R?o:R@(??=$`2 at h???89R@?U???j2@??e??8R@|???!z2@?1 ?9R@?QG???2@????6R at PF\ ?2 at 4}v?u6R@?????2@??Y?7R@?????2 at 8? U;R at 8?]??2@???@->R@|!????2 at PL? 3?R@??
DO?2@|c ??R@??7?a?2@??`?u<R@?>+?2@????\:R@?5???2@(?R?o>R at PU??X?2@??*?wCR at 8? "53@????>R@|-??13@?
)??;R@$???3@?????8R@|*?=%?2@?????4R at x??E??2@?/?^|1R at h=|?(?2@?Z?a/3R at Ls+???2@ ?a??4R@??|@?3@??~74R at h4?+3@?"??J2R at hp[[x&3@??G?1R@`'?ei;3@??a?1R@???f?O3@??f6R@????Q3@<tz???R at lU?A3@<??~AR@????53@|?5^?BR@??S63 at h??BR@$}ZE@3@??Y?@R@6\?I3@?????=R at lg??RO3@<??H8R@?????R3@??m?R3R at T??zT3 at h??_=0R at P?\?m_3@(???I-R@|?,C?3@??x>-R@$W@??3@r???,R@???|?3@|6?>W+R at P?c*?3@?@I?+R@,?	???3@|`??*R@?W????3@$W@?*R@??G?)?3@????,R at d?g^?3@?T2 T.R@?????4@??j??.R@?L??!4@$W@?.R at x?u??$4@|6?>W/R@$???84@T?^
0R at PF\ I4@??
?2R@?????X4@(?N>=2R at x??:?Y4@??Y?r3R at h?!?{[4 at h?!?{4R@|$%=a4@???5R@?????p4@??;??6R@?I???v4@$???8R@(k?C4?4 at d????;R@?!<??4@??'??;R@ ? ?S?4 at d???:R@?
?D?4 at P
?=?8R@?
?7?4@(?N>=6R@?_x%??4@(2s??5R@?]K??4@|-??16R at P??	5@?????6R@?????5@??A?3R@,oG8- 5@???_0R@?????5@\???4.R@?]K?5 at d???(R@?b??5@?_"?:'R at lg??R5 at PI??&(R@ ??{G!5@?
)??+R@|'f?*5 at T^+??-R at Ld??35@?Q??B)R at PU??XB5@iT?d'R@<??@5 at PI??&&R@? ???G5 at PI??&$R@???B`5@?&??%R@?QG??d5@???&R@(??9xf5 at h??>?*R at P?|aj5@????/R@?0??v5@?1 ?-R at x??E?y5 at d?{??+R at t????v5@<?I/*R at P^d~q5 at P?>?%R at h4?k5@????9'R at 8? "5y5@?9[@h(R at P?}?~5@$W@?*R@???|y?5 at 8? U4R@f`X?5@?'?>6R@<?? ??5@<?I/8R@?????5@ ? >?9R@???x??5@B@??GR at 8>Z?1?5@?W??"HR@?oB!?5@??I~?CR at 8?$#g?5@(,???AR@$????5@(c`>R@??P?5 at x{?;R at L?*???5@|c ?1R at h????5@<?i??/R at P?\?m?5 at d?s~?'R@(x
?R?5@?b.%R@????:?5@??l?"R@?^}<??5@?????!R@?????5@|????!R@|-??1?5@????9#R@??C?5@?cw??#R@?T?G??5@ND??#R@?
?7?5 at PO??$R@?ek}??5@???'R@??w?'?5@?/??)R at x?u???5@???A_+R at T?{/?5@@?a?'-R@??????5 at PO??.R@|??9y?5@?-@?'R@?2Q???5 at P.?_x&R@? ?=?5@????$R@??>$?5 at h?2?}"R@??w?'?5@?u?! R@?????5@?Q?G!R@?oB!6 at PU??X"R@?4?8E#6@<??~$R@??I/6@(??)%R@?????26@???n'R at P???T56@?Q?G)R@?=Ab?36 at 8???z+R@??t ?-6@("?0R@??gx?*6@~??71R@???A?/6@`X?|2R@?? 76@<???	4R at P??|z<6 at d??Q6R@?Y<6 at h????8R@$W@?66@?
)??:R@|-??186@?????:R@??@fgE6@,*?Z4R@?H?F?E6 at PO??2R@@??PA6@$?6?D+R at L???hD6@???A^%R@?.m8,I6@??Y?r#R@????F6 at T"?^F R@???~?=6@|Nz??R at P?|a:6@??B?R at hv?[?@6@?"1A
R@?#?L6@?????R@ ?~?:L6 at h????
R@$z?rK6@??	??	R@|!???G6@?Q*?	R@???#@6@?????R@`??*:6@??? 4R@?j?=&:6@|fI??R@???x?,6@?4E??R@ ??F?&6@???A_R at d*??6@?????R@?+,?6@o??R@?/? 6@(???IR@`?_??5 at P"??R at H/??5@?o?^}R at x9??c?5 at 8?? nR at T?X?;?5@???i	R@??{?Y?5 at h??}q
R@?B]?5@?T2 TR at PO???5@??$>wR@?/??5@?Hg`??Q@$??E??5@?ng_y?Q@?????5@]~pR@??9??5@?????R at X?????5@?
R@?2Q???5@??8a?
R@??I~??5@|i? ?
R at P??|z?5@?d??R@????l?5@|`??R@({K9_?5@?z2??R@????z5@<???;R@????u5@?????R at d?ck5@?bc^GR at T?{/f5@$W@?R@9D??N5@??,AFR@$}ZE@5@??t ?R@`?_?45@??i? R@?G,)5@?NA~6 R@??}"5 at P}>??Q at T????5@,*?Z?Q at x??E??4@?.??|?Q at hv?[??4@??\?C?Q@?X?;??4@?!S>?Q@|?<??4@?T?~O?Q@?;??4@<?????Q@?????4@???@??Q@??:??4 at zi? ??Q@<&R???4@?z???Q@`??*?4@?=??Q@???B?4 at f?R@??Q@?%???4@|]??t?Q@????Z?4 at d?VA?Q@$???4@??>??Q@???A??4@????Z?Q@?????5@?Y?>??Q@?;?$5@?????Q@??v(5@??x>?Q@$???/5 at PR`LyQ@$???{S5 at R}>?vQ@?ek}?`5@?}s?tQ@????j5@??=xrQ at PX?ew5@?]??yiQ@?T?G??5@????gQ@??|@??5@?H.?!fQ@ ???!?5@??x>eQ@ ?!???5 at xB???cQ@???w??5@??M?[Q@$?????5@&??)UQ@??w?'?5@l\??NQ at x?n?|?5 at z9??cLQ@?,????5 at PX?eGQ@|!???6@<??"AQ at PR`L-6@&8????Q@,l? 36@?`6?>Q@?>+:6@?&??=Q at P?\?m?6 at f?s~?<Q@|???J6 at z9??c<Q at PL? 3S6 at zu??=Q at h|_\?b6@??i? ?Q@?pzk6@??7?a at Q@?7?a?q6@?#???DQ@?R?{6 at h????IQ@????@g6@c??KKQ@??|@?[6 at f????JQ@???B?O6 at d???NQ@ ???!F6@ A?QQ at T?T?	G6 at d??~?RQ@?u?!H6@&2s??]Q@???|yU6@?????lQ@???A?g6@o??wQ@|?!8.w6@?-W?6|Q@?S?{F?6 at P???~Q@??????6@????z?Q@?b*???6 at d?? w?Q@??}?6@>???4?Q@??????6 at TH?9?Q@,l? ?6@x` ??Q@|??B?6@&?????Q@??)X??6@~?????Q@?A??6@|fI???Q@? :v?6@B@???Q@$???{?6 at z9??c?Q@???A??6@?-W?6?Q@`??*?6@$W@??Q@?<Fy??6@?v?1?Q@`-wf??6@]~p?Q@|?e??7@??F!??Q@?????
7@~??@??Q at T???"7 at n?@??Q@?|$%= 7@?`6??Q@ ??F?7@(,????Q at T???"7@i??Q@?????
7 at f???Q@?C4??7@?????Q at P?????6@??|?5?Q@@???6@??? ??Q at 8??!?6@l\???Q@$W@??6 at f?s~??Q@????6@<?Y??uQ@???<?6@?*?)sQ at PI??&?6@?!S>pQ@??_>?6@|]??tmQ@?j?=&?6@o??kQ@?!<??6@??(@ZQ@|*?=%?6@?E?>QQ@?
?D?6@?t???MQ@|?,C?6@x'?IQ@?
?7?6@??RAEGQ@????6@????CQ at P??{H?6@&2s??=Q@?????6@????U<Q at t?}???6@?1 ?9Q at x??C57@??;?(0Q@??v??7@???@-*Q@N^?%7 at h????"Q at T:X??D7@?n.??Q@,i?7n7@<?Y??Q@???<?7 at d??A%Q@$????7@????&Q@??K?[?7@?H.?!.Q@??????7@????r/Q@??6 ?7@<???	'Q@??$A??7 at R}>?Q@?N$?j?7@?f??Q@????7@??RAEQ@?Z
H??7@?w?~?Q@ ?~?:?7@???Q@ ?????7@?l ]Q at lj?Z_?7@????kQ@(???I?7@?N??:	Q@?8????7@$?@?Q@@ ????7@??T??Q at pU?wE?7@(??biR@???`+$@PR`LiR@(l? #$@h????hR@?T?2$@(??>VhR at x,?IE#$@???!iR at x><K?1$@(??biR@???`+$@     ,?   ?F??
W@??????#@?E&??JY@?z2???<@   ?         0   I   a   z   ?   ?   ?   ?   ?   ?   ?
  ?  ?????wW at 0?ED1A3@(??byW at P??|z43 at d??~?|W@???W3@???W@?????2 at PI??&~W@?????2@??:M|W@???x??2@$[A?zW at PR`L?2@??!?vW@?h;???2@?????lW@|?e??3@?????jW@?.m8,3@?E?~iW at Lg'?? 3@?f??dW@??M?73@N^?_W@?P3??N3@??	??^W@???|yU3@??;??^W@|?m?(\3@??e??^W@????b3@{???_W@??Pi3@<?i??aW@$????m3@|Q?_cW@?Y?$?m3@W??gW@?I???f3@?t???hW at t????Z3@(5??hW at P^d~U3@?????jW@?,???K3@$???{oW@?X?;??3 at d?k_ at rW@ ???;3@|???atW@,l? ;3 at h????uW@$??=3@?????wW at 0?ED1A3 at T:X??}W@?????^3@?&??}W@$qVDM\3@()? ?zW@(???IO3@??$??yW at T????L3 at d??A%wW@|?,CG3@`X?|vW@??9?E3@??Y?sW@?}s?D3@??? 4rW@?@?9wG3@()? ?jW@????lp3@????AjW@?F?r3@?b.iW at H|??{3@(???iW at h?!?{?3@??A?kW@???
?3@$??}8lW@???A??3 at PL? 3oW@?#??3@]~pyW@?????w3@<?i??}W@???@?m3@?=?}W@?,???k3 at P.?_x~W@@???e3 at T:X??}W@?????^3@?q ??X@?C????(@P
?=??X@?)r??(@???@,?X@????(@???A^?X@????(?(@<?e?Y?X@??6 ?(@???_?X@?????(@??$>w?X at pVDM?))@|6?>W?X@?8???/)@<???;?X at H?s
?C)@|fI???X@?	???W)@h?2?}?X@?KTo
T)@?Q?G?X@??<?J)@|?5^??X@??
??5)@<?i???X at P??z,)@?L???X@?a/?%)@P@???X@      )@??a??X@??'???(@PR`L?X@? ??*?(@??>e?X@`???:?(@??Y??X@?2Q???(@??4?X@?????(@????z?X@ s???(@B@???X@?5???(@|o??X@(x
?R?(@?q ??X@?C????(@L=By?W at T?u8?>0@?
)???W@??r?S>0@??(@?W at Ld??;0 at h?????W at Ls+??40@??e???W@?
?7/0@`?_??W@????"0@ ? >??W at PR`L0@??x?n?W@?
1^?0@?????W@?c\qq?/@?f???W@???C6?/@d???j?W@ ?%??/@(??)?W@?O8?? 0@?T?~O?W@?4?8E0@????W at TC?
0@x` ??W@?????0 at T1?~??W@?????	0@QL? ?W@QL? 0@??;?(?W at x???A0 at T=???W@???C6 0@(#. ??W@???~?-0@?? v?W@iT?d70 at 8???z?W@$??=0@@?a?'?W@??E?>0 at L=By?W at T?u8?>0@??@?hW at P?}:?2@Z_&jW@?
?7?2 at d??@?jW@,i?7?2@???~PmW@????2@|?5^?nW@?)???2@<?Y??oW@??ky??2@????zpW@?j?=&?2@???_pW at x?0DN?2 at h o?pW@$????2@<???;oW@? ?=?2@??4nW@$???2@???@,mW at 4=((E?2@??l?kW@ ??G??2@l\??jW@?????2@(??biW@???@??2@,???hW@?~??@?2@????bW@????g?2@?H.?!bW@?70?Q?2@?
)??_W@?????2@??m?R_W@(?N>=?2 at d??Q_W@?????2@?d`W@???2@??|?5aW@???2@?W??"cW@?H??Q?2@??@?hW at P?}:?2@????s?X@??6?8'@??\?C?X at pJ@L?U'@d????X at 0T???Z'@$????X at pG???`'@?B??X@????G?'@?9[@h?X@????z?'@ ?{??X@ ??E??'@(2s???X@?5???'@P:?`??X@??Q??'@??i? ?X@??|@??'@?Ws?`?X@?O???'@????@?X@?}s?h'@??l??X@???C68'@h?????X at pVDM?)'@$8????X at H??	?!'@????Y?X@?A?'@????\?X at p\?M
4'@????s?X@??6?8'@<??A??X@??6 ?&@<??H?X@ d'@?6?[?X@?7?_'@h??I?X@??????'@h?????X@?}s??'@??????X@??6 ?'@????N?X@2t??'@????X at x5y?j?'@?d?X at x<-?p}'@???^?X at 0U0*?s'@?????X@?+??J'@<??@f?X at pG???@'@|3j?J?X@??
DO:'@?????X@?oB!'@?=??X at xA}???&@]~p?X@?????&@L:??l?X at X?P???&@????N?X at 0Z????&@l\???X@??C???&@<??A??X@??6 ?&@H?@1aX@????]?0@????fX@uX??{0@(???IgX@?^}<?y0@??$>wgX@?? w0@??A?gX at x?n?|r0@?????dX@`$??\>0@?Z? mdX@?6?x?;0@$???cX@?pz;0@????bX@|?%9`;0@???~PaX@???=0@??A$`X@?<?E~A0 at xB???_X at L???hD0@?t???]X at hm?kQ0@|l???\X@??B?q0@$???]X at Lg'??|0 at PO??`X@?!<??0@?;??`X@?Fu:??0 at H?@1aX@????]?0@?J?*?X@ ??Ws%@?????X@?t???i%@h???X@?&M??a%@|E?^??X@???25a%@??	???X at X?~l?w%@????N?X@?}s??%@????b?X@???f?%@h?????X@ ??E??%@h?????X@ d?%@(??)?X@??(?A?%@??'???X@?"????%@??????X@???OV?%@|c ??X at h????%@{????X@???A?%@?
1^??X@???{?%@???~?X at H??0?%@???@,?X at x0)>>?%@$???X at P??C?%@h?R@??X@({K9_?%@?F???X@?`?d?%@?Q?G?X@?^???%@?J?*?X@ ??Ws%@8n1?7?X@      (@$????X@??p??'@??????X@??G?)?'@<?(A?X at P?k??'@(?N>=?X@???@??'@(2s???X@`x?g??'@?k?}??X@???A?'@??B??X@(qVDM?'@?Tka?X@@J?i(@|??!U?X@?.??|2(@8en??X@(f??9(@???A??X@???"M,(@8n1?7?X@      (@$???ZW at lT?Y?3@???A?[W@?Fu:??3 at d??A%_W@?h????3@?cw??_W at t?8F??3@?z2??_W@(~??k?3@??-`W@?????3@|ZEh`W at T=???3 at PR`LaW@,?F<??3@????`W@?????3@???>U]W at T?T?	?3 at xE???\W@(??b?3@?!S>\W@?;??3@|o?[W@(???I?3@<?e?YYW@(r??9?3@?+?PYW@???g??3@$???ZW at lT?Y?3@?i??&?X at p
???$@$ &?B?X@ :vP?#@?=??X@?9???#@(????X@??????#@??t!V?X@??6 ?#@??i?X@?$%=?#@??6 ?X@?ek}??#@?????X@?\??k$@P??5?X@?`?d$@??Y?r?X at x;???$@l?J>v?X@?Z??K$@?`6??X@??Z?{$@????s?X@`????$@?i??&?X at p
???$@?????2W@????*p4@$?6?D3W@?8???o4 at xT??4W at d?b?n4@???7W@???iS4@$???6W at PO??P4 at P@??5W@?????L4@|??A?4W@ ?A|`K4 at x{?3W at T4???J4@<?I/2W@??7?aJ4@<?I/1W@??6 L4 at T.T??0W@ ??{GQ4@<?(A0W@,oG8-X4@(??0W@??g?n4@?????2W@????*p4@,g~5X@?je?/?(@???{X@??Po?(@L(D?!|X at xB????(@Q???|X@ (???(@<?e?Y}X at x0H??(@??????X at X??w??(@?:????X@????0?(@?????X@?d?(@????s?X@??Po?(@|?????X at H?????(@,*?Z?X@????Z?(@,g~5X@?je?/?(@@?@?w?X@?j???%@\F?=??X at 8?????%@??????X@@#?v%@??? =?X@?5??Z%@?&???X@`?9?S>%@8?!?X@?o`r?0%@h?????X@@?+
%@$?F??X@?????$@?Ws?`?X@ %>w??$@|fI???X@?n???$@{????X at x><K??$@xB????X at x?n?|?$@???>U?X@?????$@??A??X@ ??Cd$@<??@f?X@??Po$@J?X@c??K?#@<?U???X@?)??$@l?J>v?X@????ZP$@T[? ??X at x0)>>y$@h???X@??/??$@?.???X at H?2???$@|E?^??X at hv?[??$@TH?9?X@?????Y%@?.??|?X@??Su%@?@I??X at H?s
?s%@?<c_??X@ ?^F?d%@??6 ?X@???OVt%@??Q?(?X@???25?%@???@g?X@??S?%@<?E~??X@????t?%@(2s???X at x-??1?%@h?2?}?X@??:M?%@8w?^??X@????/F&@PU??X?X@???S&@????0?X@??E;\&@ ?????X@ E?>?&@??????X@????@?&@?x@??X at P??|z?&@?:????X@?!????&@$?`6?X@?Q?o&'@?????X@??l?Y'@???`?X@?dp??j'@??????X@?;?d'@T(__?X at X?T?	w'@(?N>=?X@??????'@?Q?G?X@?;?d'@8???(?X@????aZ'@?I+?X@@)??`'@??? ?X@??/?r'@???M?X@ ???'@??????X@?????'@(?R?o?X@????0?'@("??X@?r????'@?H.?!?X@??e2(@|??A??X@??N??(@8?A`??X at p???[V(@???w?X at h??uf(@`??-?X at x1??r(@?????X at h+???{(@?A|`??X at x1??r(@???8?X at x,?IEc(@8k??*?X at P#?3?j(@8???(?X@qN`?(@,*?Z?X at X?T?	?(@??????X at p,???(@`?_???X at h_@/??(@??Y??X at pEb??(@@?Q?y?X at h???t?(@?Q??B?X@ ?????(@L.??:?X@?????(@?
j???X@ ????(@|l????X@?8????(@$???X@??W?)@??????X@(x
?R7)@?cw???X@?^??a)@??!??X@(??9x?)@d?????X@?)???)@d????X at 0Z????)@?? l?X@?JY?8.*@???A^?X at 0`??N*@??A$?X@??i3N[*@<?????X@?v??y*@|c ??X at x,?IE?*@8?M?a?X@?n???*@???W?X@?`?d?*@?P???X@?/??*@B@???X@?s???*@?U?@??X@???
+ at T.T???X at X????D+ at PU??X?X at x3j?J^+@@? ??X at P?*???+ at x{??X@??u6??+ at P????X@?X??+@????X@??ajK
,@??B??X@???(,@???~?X@ ?L!
,@?!S>?X@???N$?+@?D???X@??O=?+ at 8?????X@??a1?R+@??t!V?X at X?z?+ at T@?? ?X at P?k?+@?Q?G?X at xm???+@??x>?X at x#???+@?I+?X at pG????+@$W@??X at 0W?6??+@<?e?Y?X at X????, at h?????X@??#?\,@?e??S?X@@?vh,@??,AF?X@????H?,@ ?a???X@??^?,@?w?~?~X at 8I,)w?,@????#xX at X????X-@?k?}?vX@??K?[o-@?;??tX@??????-@??>sX@(?????-@???>sX@?|A	?-@{???sX@(????5.@??t ?sX@?Q?o&N.@???sX@?7?_.@i?qX@ ????i. at xB???oX@???=#?.@???oX@????b?.@???>oX at H?o	??. at h????qX@??,?s?.@?:???pX@ ????/@??inX@?5???/@T(__nX@?f??}?/@???@gmX@
6u?/@????ZlX@(k?C4?/@d?VAiX@ ?^F??/@?|AfX@?ek}? 0@(/2?dX@?L?:?0@?? vdX@$?^F?0@N^?eX@$??`0@$&??[gX@ ??{G0@?????iX@?^??A0@i?iX@????F0@?????hX@?
?7O0@$????gX@?P3??V0@??p?gX@??+?z\0 at P???gX@?#?l0@()? ?hX@????}0@????kX@<?? ??0@??3?/oX at 0??:??0@??nX@??x@?0@???mX@?`R||?0@????jX@,????0@?w?~?dX@?????0@?"?~?`X@??P?0@???ZX at d ????0@|-??1XX@????~0 at xx???VX@??????0 at PF\ MX at PO???0@,MJA?MX@???8??0@?z2??KX@ ? ?S?0 at h??>?JX@??K1@?&??IX@?n.??1 at x{?CX@$}ZE@1 at P
?=?@X@|?<?J1@?#?>X@??B?Q1@??t!V:X@??@fg]1@?Q??B9X@??B?a1@|-??18X at PL? 3s1 at h????5X@$???g1@<??H8X@,oG8-X1 at PqN7X@?Ry;?=1@?P?6X@?D??01@???>7X@???|y%1@o??7X@?!<? 1@??`?u8X@?#?1@????9X@?I?p1@??f:X@(??b	1@?????7X@??>$?0@?&??5X at x?0DN?0@?????3X@?1=a??0@@??>4X@??? 5?0@<?$@M4X@??????0@??7??5X@QL? ?0@<?I/6X@?????0@??`?2X@|'f??0@?1 ?1X@|-??1?0@?f?0X@ ?%??0@$???+X at Ld???0@??]??'X at 8"????0@??;?(&X@??c??0@?d?? X@|????0@$????X@????H?0@??? 4X@??E}?0 at 8???(X@?EC???0@???X@??^?0@<}??X@?}s??0@????X@??????0@??~1X@??C???0 at p?_!X at LA??4?0 at h??}qX@??d#?0@??- ?X@???@??0@$???{X@??????0@$???X@ 2?0@Q???X@????t?0@?Q??B
X at t?????0 at 8w?^?X@??????0@E? X@???#b?0@(??>VX at p????0 at D?X?oX@?\?wbv0@???@,X@??I~?c0@?B?X@?}s?X0@?? lX@|'f?Z0@?=~o X@?$??b0 at P.?_xX at La???V0@??!?X@?????P0@???@gX@?<?E~A0@?r???W@????@70@'???W@???i70@?`??W at h??\?<0@?NA~6?W@?;?$0@W@??W at l???z0 at xZ~?*?W@?=??j
0@?"1A
?W@ ??{G0@???A??W@?%W???/@???>?W@({K9_?/@?qo~??W@?b???/@?B??W at X?????/@~??7?W@@?v?/@|c ??W@(r??9?/@Q????W@?0?|/@8?? n?W@(????u/@???@-?W at H????l/@P
?=??W@?????s/@(2s???W@??+?z?/@Pg?!??W at H?.???/@c??K?W@??F?0?/@<??@f?W@??K?[?/@<???	?W@
???/@(??b?W@?c???/@$???{?W@??z?0@????W@???C6$0@]~p?W at L?g\0@??+???W@?F?0@?u?!?W@(k?C40@??7?a?W@,??<?0@????Z?W@?????0@?C??W@??p??/@PF\ ?W@ ?????/@@?<?E?W@?E?~?/@?0_^??W at h?"???/@??,AF?W@`???l?/@? ?}??W@?<,???/@??l??W at 8(a???/@?d?W@?????/@d????W@??(?A?/@$8????W@?[?t?/@<n??t?W@?????/@?:????W@??N$??/@??6 ?W at pJ@L??/@d????W at hy???/@8?~???W@??(?A?/@????s?W at X? m??/@$????W at L?g\0 at LI????W@|?i??0 at PO???W at x???A0 at h??>??W@?????0@????b?W at d?fb?0@????Z?W@?.??|0@?1=a??W@</?"0@r????W@,l? #0@??????W@|$%=0@?T?~O?W@??&??
0 at l?J>v?W at P???6 0@r????W@???OV?/@?<c_??W@??????/@???V?W at x??C5?/@?6?^??W@??????/@<???r?W at X?x??/@|?Y?H?W@@?v?/@?n.???W@(i????/@???~?W@??F?0?/@ ??>??W@?`??0@??~m?W@???=^0@??h??W@|?m?(0@??i? ?W@(~??k!0@???~??W@?w?~?&0@|<????W@|?!8./0@????@?W at 8?]?20@u???W@c??K50 at x` ?C?W@??v<0 at T%??R?W@?4~??40@??,AF?W@<)??00@???>?W at x??E?)0@?5_%?W@?}s? 0@?=?>t?W@@e???0 at t0? ??W@???;j0@?1 ??W at xE????/@?3????W@ ?bG??/@?]??y?W@??B??/@d??~??W@??K?[?/@????r?W@??m4??/@TC?
?W@?????/@(?
?0?W@ ?????/@r????W at H????/@??????W@ ??G??/@?????W@ ?bG??/@<??H?W at x?n?|?/@?P??W at PO?? 0@??>??W@????0@?k?}??W@ C?&0@l\???W at d*??#0@?????W@???>U0 at d??@??W@??hU
0@|`???W at h?ba?0 at P????W at P??C?/@$????W at H????/@??(@?W at hv?[??/@??l??W@?????/@h??W@ 4????/@?k?}??W@ ??{G0@|o??W@?h???0@(/2??W@(?N>=
0@(&o???W at L?g\0@?????W@ ?z?0@$???W at h???0 at x{??W@$???00@|x? #?W at L?*??V0 at x<-?p?W@(?R?oV0 at 8????W@???>UE0@ ?0_^?W at l?F=DK0@?`??W@??:??H0 at t9% &?W@??_?@0@?:????W@(???30@????z?W@?/?
.0@?
)???W@?/?0@<}???W@ "??u?/@?????W@@/??/@?:????W at 81$'0@??+???W@?t???Y0@?L?^??W at l?????0@?F???W@?I?p?0 at d????W@??+?z?0@|~!<?W@<?????0@(?N>=?W@|$%=?0 at PF\ ?W@|?!8.?0@?&???W@({K9_,1@(/2??W@????@71@<???;?W at T???"Q1 at P"???W@(?N>=j1@$???]?W@?~NA~v1 at l?J>v?W@$}ZE?1@????0?W@??>$?1 at h?????W@????1@?Q?G?W@(u?8F?1 at P}>??W at P???T?1@??#???W@???>U?1@??$???W@?/? 2@??? 4?W@@???2@??m?R?W@??s??2@?"?~??W@?????\2@??B??W@$????e2@???>?W at x?T???2@$?6?D?W@??????2@??????W@(??>V?2@?B??W@$????2@|]??t?W@<)???2@?L???W@,i?7?2@?????W@?3????2@?B??W at PR`L
3@??Y?r?W at 8(a??3@???@??W@$?^F?$3@??5!??W at L?H??.3@?3??W@|i? ?33@??=^H?W at 0??{?83 at Xv????W@?2?}?=3@??A$?W@?Z(??63@|i? ??W at h?"??13@??h?W@ ? ?S&3@?C?~W at d?fb?$3@??/??|W@?h;??&3@??%PyW at d?*?363@?,'??wW at T???A3@<?e?YyW@?b??E3 at d?w?zW at P?c*K3@$?@?|W at PL? 3S3@????~W@?b???\3@?Ue?W at H/?u3@???8zW@|'f?z3@?"?~?tW at P[#?q?3@?z2??nW at hs????3@??'??kW@,oG8-?3@?Z? mfW@?
???3@???A_fW@?.m8,?3@????\jW@???#?3 at 8? UlW@]P?2?3@???~PnW@?Fu:??3@$???{oW@?k?}??3@$&??[nW@??gx??3 at xT??gW@?pz?3@$???eW@W???3@???`?cW at Xc'??3@?n??;bW@?ihw?3@?????`W@???c??3@???W_W@?q7???3@?,'??\W@??[??3 at h??}qZW@??P?3 at h?
??YW@(???4@|o?WW@?K???
4 at h??RW@ ?A|`4@?4E??PW at T4???
4@|`??JW@??j??
4 at H???HW@???Z?4@\p?JW@$B#???3 at 0/?>:KW@<,????3@?????MW@?@?9w?3@?D??OW at T?????3@????ANW at d*???3 at d??@?JW at T??z?3@?	/??IW at 8_????3@(5??HW@|8H???3 at h??`oFW at h?"???3@?+?`pFW@?1=a??3@?3???HW@@ ????3@|l???JW@?I?p?3 at d???HW@?w?~??3@?E&??>W@?r??4 at LF?a?>W@?3??4@|o?CW@ ??{G!4@?a?FW@ ?!??+4@$?w~QGW at 8GW74@????EW at x???s24@l\??BW@? ?=*4@??e??@W@K???$4@?????W@?JY?8&4@??m?R?W@$?S;?44 at d???BW@??}b4@?F??EW@?=??j?4@@???@EW@?P??4@????BW@,oG8-x4@|W?[AW@?????n4@(?
?0AW@(x
?Rg4@<?e?YAW@$t??Ya4@????YAW@??z?[4 at h??`o at W@X??x?K4@r??9W at hp[[x4@?G?7W@$??E?4@??\?C1W@(??|44@??A?2W at h???bA4@??$>w7W@(?
?0M4@?E?~9W@$W@?R4@?I+6W at T?T?	g4 at d??@?2W at x<-?p}4@?????-W@?t????4@????<)W@??E}??4@N^?+W@????:?4@?:?*-W@??S ??4@W??/W@?????o4 at L+?@./W@ ?A|`C4@|c ?-W@?????F4@????U,W at X?y?M4@H???+W@(r??9U4@?
)??'W@|$%=u4 at h?? W@??&???4@|]??tW@ ? ?S?4@?cw??W at d*???4@?I+W at PI??&?4@$&??[W@ ???4 at L+?@.W@(k?C4?4@?Y?>?W@?Z
H??4@????AW@,oG8-?4 at h????W@?\????4@?qo~?W@???B?
5@????W@@???5@??h?
W@QL? #5@???@,
W@ ?%?85@?F??
W at T????L5@???8W@?L?:?[5 at P
?=?W@|'f?j5 at d?VAW@ ?A?x5@?Z? mW@<)??x5@<??@f"W@?/?`5@?????%W@?
?7C5@u??&W@?#?@5@$W@?*W@(???K5@????*W@,?)L5 at 8???(*W@????Q5@?]??y)W@?????Y5 at d?VA)W at P?\?m_5@???A_(W@(?N>=j5@|c ?'W@?P??Qx5@???j&W at PU??X?5@(??>V&W@??>$?5 at PU??X&W@?b*???5@???~'W@?B]?5@`?
??'W@?z??9?5@?Ws?`'W@?????5 at P}>?&W at T?T?	?5@????s&W@????r?5@?????&W@?,????5@????A+W at h??`o6@$???,W@??6 6@???~4-W@????'6 at xW=`3W@?8???6 at h?B,7W@???|y
6@?"1A
8W at T.T??6@?9"??8W@???|6@?*?);W@ ??{G6@?? l=W@ ? ?S6@??i?W at P[#?q6@????AW@?I?p6 at d?&?CW at 8???Z46 at P4`?DW at T?{/66@?????FW at x?u??46@??,AFHW@????/6 at p<??IW@??#?06@K??LW@<????C6@|fI??LW at T???"Q6@????ULW@$z?r[6@???LW@?=??jb6@?bc^GKW@????q6 at h??IW@]P?2w6@?7?a?GW@,??;??6@???8FW@??
DO?6 at P@??EW@??ky??6 at d?s~?FW@(r??9?6@?1=a?GW@?h;???6@?l??HW@???B?6 at xT??HW@??|@?7@??e??HW at TC?
7@????KW@?5_%7 at h??`oMW@????
7@`X?|NW@<?$?7 at Pd???OW@??5?7 at h????QW at PF\ 7@?D??SW@3???7@(??>VVW@?{F"47@???A?XW@????@;7@??'??WW at Ld??[7@??>?YW@({K9_l7 at P??5[W@?{F"4?7@???[W at x??E??7 at d?s~?ZW@???Dh?7@f???XW at PF\ ?7@??=xVW@?d?<
?7@?C?UW@???	?7 at P???TW@???4	8@6???UW@???c8@????WW@\ ?K8 at L?d??XW@???E8@,5{?ZW at Hh??8@?M?a?ZW@<X??08@$#gaO^W at hv?[??7@????`W@?B]?7@|????aW@$[A??7@?????eW at Lg'???7@@???gW@?N$?j?7@?8?:hW@|?b?:8@????#lW at d????8@???qW@?? 8@?v?1rW@?>U??7@<???;sW@<?? ??7@?9"??tW@iT?d?7 at d??@?vW at x??C5?7@??U?@zW@??/???7@(?_?W@????r?7@?P??W at 8% &??7 at 8????W@??~??7@|]??t?W at T?z??7@??(@?W@????8@B@???W@$?^F?8 at PR`L?W@ ????-8@<??~?W@?.m8,I8 at P????W@|*?=%_8@???8?W at T:X???8 at P"???W@?=??j?8@????A?W@???}??8@?cw???W@??r???8 at P}>??W at PI??&?8@?"1A
?W@?v?19@~? ??W at x?4E?9@?I+?W@ ?!??#9@??????W@?????'9@(?R?o?W@?^}<?)9@??$>w?W@?]i?+9 at h???W@|*?=%/9@r???W@??
??59 at Pg?!??W@?6?x?;9@(A?G?W@N^?I9@?_"?:?W@?5??f9 at PU??X?W@????m9@(5???W@?F?r9@????W@?M?Ew9@????\?W@$??:?~9@?Ko.?W@?C?b?}9 at xrM???W@<????9 at h?N???W@?+,??9@??I~??W@????r?9@T????W@?????9@????N?W at 8:??8?9 at h?????W@<,????9 at xB????W@?,????9@?????W@$}ZE :@?p!??W@?\??k	:@???~4?W@?????:@????@?W@???i#:@|x? #?W@?k|&?;:@??RAE?W@?_x%?O:@??~7?W at P????y:@?bc^G?W@ ?????:@|0)>>?W@`od?:@?N??:?W@ ?????:@??????W@?B]?:@h?R@??W@(???I?:@d??@??W at t?????:@<q9^??W@`$??\?:@?D???W@???w??:@d?????W@$??E??:@????z?W@?u?!?:@?X"??W@,l? ?:@P????W@??????:@p????W@??????:@d??@??W@??9??:@d?????W@?K?? ;@?@I??W@???;@??t ??W@???eN;@8?M?a?W at T??y?;@LI????W at la?9
;@??>??W at X????;@?4E???W@ ?~?:;@d?????W@???X?";@?.?? X at 4=((E+;@?Hg`?X@<2V??/;@<??HX@???i;;@|????	X@?Fu:?A;@??d?<X@ ??zE;@????X@?)??F;@L1AGX at T?z?M;@d????X@?:q9^M;@??'??'X@??&??];@|]??t.X at hy??];@l?? ?0X@(???[;@<?I/2X@|??A?X;@??;??4X at P?&?OR;@d?w?6X@?4?8EC;@D??@J7X at P?|a6;@????s8X@ ??F?.;@h????9X at T?X?;+;@?]??y=X at Ljh?%;@$8????X@(u?8F";@l?j??CX at lv???;@?k?}?HX@??r?S;@???@-JX@?/? ;@x` ?BX at L??uI;@<?E~?AX@?Z??M;@?u?!@X at 84e?T;@????>X@???@?];@u??9X@?g@?u;@?.??8X@?Fu:??;@?????8X@??????;@?
)??;X at P?????;@PO??@X@??????;@P???BX@?8????;@?B?GX@?K????;@???>WX@?!<??;@????ZXX at t??F??;@<???	WX at P?c*<@?bc^GTX@$w?Df<@???@gUX@????*<@?T2 TVX at H/?9<@d?VAWX@?????><@????ZX at hs???K<@d?	??\X@???W?J<@?oB!^X@?e6L<@xx???^X@$w?DfV<@??I~?_X at Lm???j<@??I~?cX@?z2???<@(?
?0mX@?O???<@$?`6nX@?(z?c?<@d??A%oX at Ls+??t<@8?Q??oX@@N??k<@???sX@?C4??X<@P4`?uX@???X?Z<@????vX@(x
?R_<@o??yX at 8?!a<@???M?X at T????D<@H?P??X at h@?57<@`????X@???B(<@?Q?G?X@??d&<@d????X@QL? <@|W?[?X@ ???!<@$????X at T?T?	?;@ ?a???X@???[?;@h?R@??X@?=??j?;@P
?=??X@??B??;@???@g?X@?????;@?]??y?X at ldWZF?;@?N??:?X at L?g\?;@(c`?X@@?v?;@d?VA?X@??;???;@??w?'?X@?~??@?;@$?6?D?X at T?z??;@???A^?X@|?m?(?;@?H.?!?X@?I????;@<?e?Y?X@|?<??;@??#???X@@N???;@?Hg`??X@??>$x;@?}s??X@|0)>>a;@?'???X at L?E?\;@<??~?X@??r?SR;@h?????X@<? ?@;@8?M?a?X@??v??:;@??? =?X@????B5;@h?2?}?X at T?z?!;@$?6?D?X@?\??k;@??????X@?[<???:@?1 ??X@?k?}??:@???A??X@?=Ab??:@i??X@(????:@o???X@???7m:@|`???X@?????\:@("??X at PX?e?:@P}>??X@(???I/:@<?e?Y?X@??c?!:@|]??t?X at T?X?;:@<}???X@?&M??:@??x?n?X@?????:@?f???X@??*??%:@u???X at PL? 3#:@?{
?q?X at d.? :@|??A??X@???>U:@??????X@|0)>>?9 at P@???X@|-??1?9@?n.???X@??+?z?9 at d?? w?X@,l? ?9@?_"?:?X@??&???9@|??!U?X at 8% &??9 at D????X at L???J?9@??$???X@|?i???9@f????X@?
b??9 at 8en??X@ ?A??9@?f???X@? ????9@??i? ?X@??5??9 at 0kb???X at x??Dg?9 at d?s~??X@???A??9 at L.??:?X@????9@??????X@?{F"4?9 at h?????X@??????9@??????X@?]K?i9@`?? ??X@ ?!??c9@$?`6?X@? ???O9 at 8???z|X@|6?>W79 at h?B,zX@??? 469@|<???xX@??I?9 at d?s~?vX@(??>VD9@?
1^?tX@????:@9@????#tX@???|y59 at d????sX at Ld??+9@?`6?rX at PL? 3#9 at TO?}pX@?Gp#e9@????snX@?ek}?9@????AnX at T?X?;?8 at d??A%oX at T?X?;?8@???lX@?h????8@???jX@$W@??8@????eX@(b??8@????\cX@????k?8 at LF?a?cX@???:T?8 at Tv?A]dX at h|_\??8@N^?cX@??????8 at 8???cX at L??u?8 at h????bX@?>U?z8 at P4`?jX at 8? "5q8@?&??mX@??`8@??_?pX@??gx?B8@$???oX@ ??{G)8@??i? oX@$W@?"8 at 8???(nX at PR`L8@??`?ulX at 8(a??8@????9iX@$??
8@|???abX at t?????7 at d?VAcX@?q?&?7@??|?5eX@?????7 at P4`?hX@???n?7@???~PiX at L?*???7@??A?iX at T??E	?7@<??HlX@(u?8F?7@<}??pX@|?b?:?7@?Ws?`wX@  _B?7 at PX?eyX@???i8@<??@fzX@$[A?8@3m???X@$?`68@`?? ?X at T4???8@??~??X@??sF?8 at 0)>>!?X at x
? 8@?% ???X@$f?y?"8 at h?????X@??G??!8 at d?&??X@?im?8@?r???X@??"h8@??r???X@?8?@d!8@? ?}??X@?8?@d%8@`???X at x0H?(8@{????X@????
 8 at x<-?p?X@????8@ ?> ??X@??8@@?} R?X at 8b->8@?T?~O?X@??}?7@??????X@({K9_?7 at d?	???X@?T????7 at d????X@,?	???7@??4L?X@??????7@??;???X@?4?8E?7@?????X@?)???7@?a??X@?a?? {7 at P??5?X@({K9_|7@(2s???X@?g@?y7@|?????X@(~??kq7@$???X at x??E?i7 at L+?@.?X@|?e??S7 at d??@??X at X????H7@?6?[?X@????l07 at P:?`??X@??N$?7 at T:X???X@???}?7@????X@???L7@?OU???X@??d7@??+???X@?B]"7@??p??X@??!? 7@Z_&?X@??I~??6@??3?I?X@</??6@|K9_??X@?7?a??6@$?w~Q?X@?????6 at TC?
?X@?c???6@?n.???X@?????6@??u???X@??5??6@<??~?X@???$?|6 at PL? 3?X@??6 x6@?sD?K?X@W?}Wt6@???@,?X@?X?;?o6@??I~??X@$???g6@??W??X at T?h?'6@???n?X@??w??6@?ng_y?X at 8(a??6@$?`6?X at T?X?;6@???A??X@?A?6@(2s???X@?????"6@i??X@????6@?_"?:?X@@	]6@$????X at x?0DN6@(??b?X@?>+
6 at d?????X at 8% &?6 at PF\ ?X@??P??6@??F?X@,????6@????b?X@?F???5 at 8?M?a?X@?U????5@(??b?X@(??>V?5 at d?s~??X at x?0DN?5@??:M?X@(?N>=?5@?#????X@?????5 at h?????X@??G?)?5@(??bY@$????5 at d?VA	Y at PU??X?5@???!?Y@??Hh??5@?<c_?Y@?n.???5@????
Y@?/?
v5@(??)
Y@??A_zo5 at d???Y@|'f?z5@???>Y@?D/?X?5 at d?: ?Y@??5??5@?sD?KY@<Y???5@??|?5Y@?????~5@?????Y@??
DOv5@?f??$Y@<&R??s5@<}??(Y@|'f?z5@??;?(.Y@?????5@?-W?63Y@?P3???5@o??3Y@?L?:??5@???~5Y@??
???5@??t!VFY@?O???5@,MJA?GY at T???@?5@??? ?JY@?????5@?E&??JY at La????5 at x?n?|IY@$??E??5@?Ws?`JY@@??P?5@????#HY@??&??}5@?-?sFY@|*?=%w5@?Tka@Y at d???e5@]P?27Y@?S?Q5 at h????5Y@?b??M5@????\4Y at dx?g?L5 at h??>?1Y@??^M5@????.Y@<@???N5@??? -Y@? ?=:5@|Bv??,Y@<#?.5@??? +Y@?/? 5@|Nz??'Y@????5@f???&Y@?T?G?	5@?`6?$Y at P???65 at 8??`?"Y@<%?5 at T%??R!Y@???g??4@?(z?c!Y@????l?4@?z??"Y@Z_&?4@?????$Y@????l?4@?d'Y@$???{?4 at 0w-!)Y@?}8H??4@?;??(Y@???w??4@??"?'Y@??K?'?4@??'??&Y@???|y?4@|H???#Y@????Z?4@<?U??!Y@??9??4 at h???Y@??K?4@????Y@(??=$?4@??\?CY at P^d~?4 at P}>?Y@???f??4@<??A?Y@$?????4 at h??>?Y@??????4@??bg
Y@(~??k?4@???Y@?????4@??>?	Y@$z?r?4 at d?VA	Y@?sD?K}4@??`?
Y@<???f4 at P??5Y@,oG8-`4 at xu??Y@|0)>>Y4 at t?z?fY@??x at Y4@?Q?GY@ ???!b4 at 8??!?X@?.??|j4@??????X@???f?o4@?????X@({K9_t4@<?? ??X@??Hh?m4@`X?|?X@?*?w?g4@??bg?X@(r??9]4@??4?X@|*?=%W4@?-?s?X at L???hT4 at Pg?!??X@?n.??O4@???>?X@?????R4@???A??X@?&M??Y4@??A$?X@?(?7O4@?????X@?8???34@$????X@??K?['4@`???X@|??8G%4 at P??5?X@?B]4@??e???X@<? ?4@??_>?X@?.m8,4 at h?B,?X@<?\?4@(???I?X at T?z?4@??#???X@????4@????Z?X@@?v 4@<q9^??X@????l 4@?????X at x??C54@l\???X@?
1^?
4@|]??t?X@??????3@{????X@T?^
?3 at h??}q?X@$z?r?3@?u?!?X at d????3@?????X@<? ??3@$????X@????g?3@<?u??X@<%??3@<?????X@?V????3@<?i???X@ ?????3@???~P?X at Ljh??3@??$>w?X@ H?9??3@?????X@|???!?3@|fI???X@$???3@??A??X at Lg'???3@?1 ??X@?^}<??3@|6?>W?X@|????3@?:????X@? :v?3 at Tal!??X@ ?={.?3 at 8???(?X at 8.???3@?L???X@??????3 at d?s~??X@???B?3@???M?X@?2Q???3 at P=???}X at T?z??3@??(@zX@,l? ?3@?f??wX at 0?!???3@<???rwX@$?????3@?
j??rX@??Cf3@?h?^`sX at 84e?\3@(??buX@(?N>=J3 at XXp??uX at h o?53@(2s??uX@|?<?*3@|~!<uX@?W?B3@?v?1rX at L??u3@????oX@??I'3@??^?kX@$W@??2 at 8?]?nX@???g??2@????oX@,i?7?2@(?_rX at Ljh??2@?<*??qX@?F??2 at xu??qX@?U????2@<????qX@?????2 at xW=`pX@??:??2@?1 ?iX@?8????2@???hX at PI??&?2@??3?IcX@?c> ??2@?Z? m`X@?a?? 2@?4~??\X at d?g^2@$??WX@,?????2@??3?/WX@??#Ed?2@?
)??VX@?~??@?2@????9VX@EH???2@?q???WX at h?????2@(?
?0YX@??r?S~2 at d???[X at PF\ i2@ra?\X@T?^
d2@|??A?\X@ ??F?^2 at LF?a?\X@? ?=V2@|????_X@?@?9wG2@|~!<aX@ 2D2 at h?2?}bX@????F2@??+?zcX@?t???Q2@?/??eX@??|@?S2@$??gX@?V???P2@????,iX@????G2@$???gX@?O8??@2 at P<??gX at P????92@????iX@???x?,2@`?? ?kX@????? 2@u?pX@?W???1@????oX@l?`q?1@`?_?mX@(?????1 at P???kX@??n?!?1@?t???qX@?d?<
?1@????rX@|*?=%?1@?? vvX@@N???1@??i? {X at 4?z???1@????~X@(n?@?1 at PX?e?X at x???sj1@??#???X at x?q?ZP1@$???{?X at T?z?A1@@?a?'?X@({K9_<1@|]??t?X@?C4??,1@$???{?X at TC?
$1@`?? ??X at T????1@i??X@?Z??
1@???>?X@??&??
1@<?i???X at TC?
1 at T.T???X@ ?A??0@?????X@(u?8F?0 at PL? 3?X@?U????0@\??m?X at h???8?0@\?????X@?X??+?0@]~p?X at P?\?m?0@?C??X at P^d~?0 at T(__?X@??p?u0 at h?????X@$??a0@??d?<?X@@?vH0@o???X@?P3??F0@??=x?X at P?|aZ0@?}s??X at T?T?	g0@|W?[?X at P??{Hp0 at 0M???X at 8? "5e0@?f???X@|?(B?B0@??+???X@??6 $0@?N?`??X@????0 at d?	???X@??eO0@$?@??X at PF\ !0@?ng_y?X@?h;??0@?Z? m?X@????0@|W?[?X at P?*???/@???@-?X@????r/@|ZEh?X@ ????e/@??@??X@??s??R/@?"?~??X@????I/@<?I/?X@???7/@?#????X@(qVDM/@?:????X@2t?/@??B??X@??+?z?. at PI??&?X@@N???.@<?E~??X@????y?.@???@??X@??'???.@|~!<?X@????@?.@??Y??X@???N?.@??t!V?X@??0??.@?P??X@(w?Df?. at L(D?!?X@(?O:??. at xx????X@?f??}?.@|]??t?X@?+???.@??????X at x0)>>q. at PI??&?X@???>t.@?;???X@?????h.@??????X@(w?Df&. at d????X@?t????- at 8?!?X at P?*???-@???!?X@??i3N?- at h?^`V?X@????(?- at P????X@?????-@(????X@ ????-@?4E???X@?y7n-@x'??X@?J %vM-@(/2??X at 8"???E-@???A_?X@?N??9- at T=???X@??6 (-@?E?>?X@?G,?,@?????X at 0Z????,@<?(A?X@???$??,@|6?>W?X@?D???,@???@??X@??K?[o,@?
)???X@????^,@(/2??X@?M?EC,@??x!?X@?????3,@?e??S?X@???P?(,@?NA~6?X@ ????,@?T2 T?X@??;???+@??,AF?X@?????+@?i>"?X@?L??t+ at xx????X@??M?T+@$[A??X at x0H?D+@??m?R?X@?????'+@?"1A
?X@???>U+@|]??t?X@?x#???*@<?Y???X@`?ri??*@ ? >??X@(oG8-x*@h?!?{?X@`???:l*@?!S>?X@?,??;h*@$8????X@??hUe*@??????X@?????[*@|-??1?X@??V?I*@c??K?X@??-x)@xB????X@??M?T)@??B??X@?k?6&)@????r?X at P?\?m?(@?????X@??????(@@?a?'?X@ ?bG??(@??????X@??I
m`(@????X at X?T?	G(@?"1A
?X at p\?M
4(@8????X@(eRC(@?(z?c?X@?j????'@??? =?X@???
??'@?C??X at x*?=%?'@(5???X@????{'@xu???X at pM???B'@(2s???X@ ??G?"'@??e???X@?T?2?&@?qo~??X@ ??F??&@?;???X@??,?sZ&@????H?X@?&M??Q&@|i? ??X@?????2&@P
?=??X@???@?&@`??9?X@???&@|-??1?X@?Yg|_&@P%@?X@??s?&@??i? ?X@???
??%@?-@??X@?;??%@@?@?w?X@?j???%@????9?X at XR?>?W(@?(z?c?X@?v??i(@??4?X at P?*??n(@?`6??X@?,???{(@$????X@?????(@???=#?X@?f??}?(@?P???X at x8?Jw?(@h?????X at X????H(@?9"???X@?T?2S(@????9?X at XR?>?W(@        ?????Y@?4~???5@?d?Y@??Dg??6@          $?`6?Y@?4~???5@???~??Y@?D???5@??,AF?Y@,?????5 at PU??X?Y@?\??k?5@?? l?Y@????a?5@?: ???Y@?Y?$??5@?]??y?Y@?????5 at xB????Y@?/??5@(????Y@$W@??5@?'?>?Y at 4??#??5 at 8?????Y at T???"6@????Y at hy??6@?????Y at t??F?56 at h?????Y@?M?E76@????@?Y at H?p>6@??????Y@K???L6 at 8???Y@$???{S6 at P????Y@?.??|b6@?????Y@????re6@?????Y@({K9_l6@$ &?B?Y@???~?}6@,)w???Y@??????6@$?6?D?Y@???C6?6 at 8?]??Y@?}s??6@?l ]?Y@??Dg??6@?????Y at h?????6@???A^?Y@yv???6 at LLb??Y@|*?=%?6@?d?Y@?g#??6@?d?Y@????)?5@$?`6?Y@?4~???5@     2   ??-?Y at 0t??7(@?d?Y@??????+@   #          ?p!??Y@???$?4)@?.??|?Y@???"J)@d?? w?Y at 8?%?P)@?N??:?Y@??C??^)@h??`o?Y@ :vPy)@(??b?Y@( ?3h?)@?????Y@????i?)@(??)?Y@?/??)@B@???Y at p\?M
?)@??'???Y@????;*@h??I?Y@?????R*@??-?Y@?WXp??*@Hqh?Y@??N@?*@<??A??Y@?w?~??*@?? !??Y@ ???!?*@?????Y@??Po?*@????#?Y@?2Q??%+@(??b?Y@(l? #+@????Y at pP?L?+@?t????Y@?n.??+ at 8????Y@?D??$+@<??~?Y at x0)>>)+@(??>V?Y@@/?:+@<??H?Y@??R?K+@|-??1?Y at h??\?\+@|?Y?H?Y@?A?o+@$?`6?Y@?????+@?d?Y@??????+@?d?Y@??=?
?(@?p!??Y@???$?4)@h?????Y@?D??d(@?d?Y at Pjh??(@?d?Y at 0t??7(@?n???Y@?x?'U(@h?????Y@?D??d(@     ?   ?D???S@??#??@h?yT@`????#@
  ????ArT@?^????@$?`6rT@ ?u7?@????rT@`???@?1 ?qT@ h?
v@h?R@?pT@@?+Z@?? lmT@?S?{F@r???lT@@???@?6?[kT@??^?@?T?~OjT@@
??@??i? gT@????(?@PI??&ZT@??(\?@(/2?TT@@ 7??@???TT@????@|c ?CT@@	]n@????9AT at P????i@????r?T@`?ri?b@D??~?8T@???+??@h?5T@?c> ?)@????2T@???#@h????1T at pI??@?B?/T@??/???@?????,T@?_?|x?@o??%T@??#??@?;??T@`??n??@????ZT@`?vj.?@?cw??T@@?z?@h?R@?T at pC???@??'??T@????#@??RAET@??Z'.w@PR`LT@??#??@d??@?T@`??ky?@???@gT@`??iM@H4?"?S@?dp???@8?]??S@?R??q@?:????S@?????L@L+?@.?S@?%9`W?@??????S@ 2?@???A_?S@???=#@P????S@???#0@`X?|?S@@?vX@f????S@?g??@??,AF?S@?E?S?@0,?-?S@@?????@??i? ?S@???%??@??;???S@?oB!~@@?a?'?S at pVDM??@??A??S@??h?@???A^?S at 0W?6?/@????H?S@?R??q?@??;?(?S@ d?@h?ba??S at 0i?7n@?????S@?????@T@?? ?S@?W?B?@?I+?S@?ek}? @ 2?S@?N???@?cw???S@@???@??m?R?S@?O?c?@x` ??S at ph?N??@|`???S@?E?S?@T=???S@?f??}?@P<???S@`???L?@$???S@?p=
? @??|?5?S@?]?pX @?}s??S@?????( @P:?`??S at P?k?c @<?e?Y?S@????q @????A?S@?l??{ @x{??S@?????? @$)?ah?S at P??{H@ @l\???S@?N??	 @x` ??S@??|@? @?w?~??S@??????@|??A??S@?^????@????\?S@???\??@????@?S at 0{K9_?@???!?S@@???@(????S@ +?w??@?F???S@???N$  @???=#?S at 0H??? @??????S@?b*?? @????S at x-??1 @P"???S@?????} @??????S@@
?!@???>U?S@(z?r!@0b? ??S@?:?v?!@<??H?S@ ??G?B!@?7???S@??/?r!@r????S@ :vPy!@B@???S@ %>w??!@???A??S@
???!@??,AF?S@?&M???!@????r?S@???T?!@?9"??T@?O?e"@??~7T@?Z??
"@???T@??x?n"@?w?~?T@????(\"@d??A%T@?r???e"@$???T at hv?[??"@??$>wT@???P??"@xx???T@?0??"@??,AFT@?7??"@?|AT@??r??"@P
?=?T@ ?????"@8???zT@?/??"@??B?T@????s?"@????NT@???N$ #@P@??	T@?k?}?
#@???@?T@??B?#@o??T@?h???#@h????T@?ek}? #@?7?a?T@??,?s*#@d??ET@???[/#@?-W?6T@???C60#@???@?T@ ????-#@<???;T at 0W?6?#@h????T at pP?L??"@(?N>=T@??
DO?"@?cw??T at xA}???"@?]??y!T@???C6?"@???j"T at X?????"@?*?)#T@???A??"@?B?#T at 0Z????"@?{
?q$T at X??x??"@8?]?'T@??V??"@ ? >?%T@({K9_?"@????\"T@???B?"@h????T at P???6#@?_!sT@?f/#@?3?T at X????#@??A?T at h^?Y-#@???9T@(qVDM#@????#T@????B%#@??i? T@(???+#@|]??t
T@?2Q??E#@E?>?T@?????I#@??I~?T at P???L#@P???
T@??l?I#@h????
T@ ?viC#@??m?RT at pk?K=#@?z2??T@?u?r?:#@d??~?T@ ??C4#@xB???T at P??|z,#@???A?T@?'f?*#@ND??T@?T?23#@$??T@ ? J#@?? @??S@???a#@??6 ?S@????g#@????@?S@?Z??K}#@????@?S@?k?}??#@??(@?S@?????#@r????S@?????#@ A?T at x,?IE?#@?<*??T@(l? ?#@x?ET@ qW?"?#@H.?!?T@?D??f?#@(???T@??P??#@???i
T@(??B?#@??Z`?T@@<K??#@`X?|T@?%??#@??e??T@??U}#@????T@??%:?l#@??>?T@ ?!??c#@PCT??T@???M#@?`6?T at pk?K=#@??m?RT@ ?bG?8#@("?T@?????/#@??=^HT@???n'#@|]??tT@?o`r?p#@?&3?VT@?/????#@?}s?T@?'f??#@??6 T@???
??#@??l?	T at 8?%??#@?;??T@?h????#@xR~R
T@?????#@h?2?}T@`????#@??A$T@??J#f?#@???qT@?^???#@???@?T@??,?s?#@?9?}?T@????y?#@$??T@??????#@?
1^?T@???[_#@?SW>?T@?`?;X#@???@?T@?!????#@r???$T@???B?"@P=???%T at H?2???"@<???	'T@?f??}?"@????#(T at H?s
??"@<}??(T@? ????"@??/??*T at x;????"@?t???-T@??q5??"@??x>1T@?t????"@??~73T@?"R??"@?qo~?4T at P?"??"@????6T at x-??1t"@????\6T@ ???o"@?
)??;T@?1?"@c?~?;T@????y?!@8??!;T@??q5??!@???j:T@?"R??!@????:T@2t??!@????Y;T at X?????!@?!S><T@??>???!@c?~?=T at x5y?j?!@<?E~?=T@? ????!@P<??AT@???>U?!@$W@?JT at x<-?p}!@????ANT@?????S!@h?R@?NT@??#?L!@?N??:PT at 8.??!@h??PT@?qo~?!@PX?eOT@?????!@??!?NT@?????!@??fNT@?7?a?!!@h????MT@?<??$!@|]??tIT@`?1??
!@??t!VHT@?uT5!@<?? ?HT at pD?K?? @????NT at X????? @????HPT@?}s?? @???@,QT@???P?? @(?_RT@({K9_? @?
j??RT@
6u? @?f??RT@`??ky? @<}??TT@??eO
!@??	??VT@????r? @????@WT at H?2??? @h?R@?XT at 0Z???? @??x>YT at x*?=%? @?d[T@?`?dg @??Y?rYT@??e2_ @?E?~YT at x;???L @?d[T@???n/ @?E?>aT@???N$  @(???IgT at 0Lm??L@L.??:lT@?"???@?F??mT@??????@ ? >?mT@?k?}??@????mT@ .?+?@<?E~?kT@`??0_?@(__?kT@??6p?@?Q??BmT@?^
P?@|Q?_nT@ ?J??@`????nT@??Y.?@???>pT@ f?y?r@?? lqT@?????G@<}??pT@?f??}1@???qpT at 04e?@h?qT at 0]?6??@x` ?rT@?`?d?@(V
??sT@ ????@|ZEhtT@@?D?@??^uT@?S?{F?@?????vT@?H? ?@??I~?wT@?}s?h@{???wT@?????]@?p>?xT@`????@?Z? mxT@?????&@<??HxT@??#??@h?yT@?v?
@?;??xT@?ek}? @?9[@hxT@??^?@PU??XvT@??|@?S@?Q??BuT at P???6@<????sT@ ?)?:?@????rT at p8?Jw?@????ArT@?^????@?d?S at P??|z4"@?9?}??S@??<?*"@<?i???S@?N??)"@??(@?S@??C&"@|i? ??S@?/?"@????Z?S at P?&?O
"@?Q?G?S@?G,?!@(?R?o?S@?ek}? "@r????S@??_>)"@?D???S at pP?L?/"@???j?S at p\?M
4"@8????S at pS??4"@?d?S at P??|z4"@     ?   ????9VX@??/???@?d?Y@({K9_t4@   y      %  :  M  X  b  n  ?p!??Y@???$?4)@?d?Y@??=?
?(@?d?Y at Pjh??(@h?????Y@?D??d(@?n???Y@?x?'U(@?d?Y at 0t??7(@?d?Y@ 6??(@?r???Y@?}V?Y(@(c`?Y at x9??ch(@??d ??Y@?????g(@???@g?Y@?,???;(@?&???Y at 0cC7?c(@?Z? m?Y@?h????(@???@??Y at 81$'?(@???M?Y@`???l?(@??I~??Y@?????(@?&???Y@??/???(@?Hg`??Y at 0U0*??(@??@??Y@?A??(@h?>??Y at H?????(@h?????Y@?D???(@???^??Y@??0??(@?w*???Y@?8????(@o???Y@?	????(@|W?[?Y@?o`r??(@??t!V?Y@?/?)@???!??Y@??B?!)@??_>?Y@(?O:? )@xE???|Y@?????)@???>yY@?B???$)@<????wY@?????8)@?#?wY@=???H)@P???sY@?????\)@????ZrY@????c)@P+L?kpY at h??]?h)@(2s??mY at h??]?h)@??M?kY@?????d)@????jY at H???])@(???iY@(r??9M)@??t!VdY@ ?!??C)@???qXY@??u6?7)@?L!uUY@ ???!B)@??;?(TY@??(?AF)@????RY@?4`??I)@?7??PY at X?L??N)@?W??"OY at P???"Q)@?a?FY@ ????Y)@<???	EY@????bY)@8????Y@?"???K)@??%j>Y at hq?0'H)@???>Y@??]g5)@???`?;Y@(f??9)@????6Y@?
O??])@h????5Y@??e2g)@(???5Y at x0)>>y)@???^?7Y@?N???)@x` ?:Y@ ?%??)@h????9Y@?;?$*@?e??S<Y@?Z??Ke*@??M?;Y@????w*@P1???:Y@?Z??K?*@?t?_?;Y@`?zk`?*@??>?=Y at pP?L??*@?^?>Y@????@?*@|0)>>?Y@??????*@???|>Y@??M??*@??;??:Y at X?????*@d??Q6Y@`??jG?*@-???5Y@=b???*@?U???4Y@(x
?R?*@?#???0Y@?c\qq?*@h?%Y@?t???	+@?
??#Y@??^+@?\??Y at 8/N|??*@$???{Y@ ?????*@$???Y at 8P?<??*@Ts??PY at X?T?	?*@???8Y@?x#???*@???A?Y at H?;???*@?????Y@?;??*@?T2 T?X at x><K??*@<???;?X at P<g?*@?/???X at 8?%??*@?'?> Y@?dl*@|W?[Y@`?5?!b*@??A?Y@???yU*@T[? ?Y at P??zL*@??!?Y@?????*@h????Y@(qVDM*@?`?Y@ ??W*@$???{Y@????)@????Y at x0)>>?)@<??~?X at 0Lm??|)@<?i???X@ :vPY)@]~p?X@(eRCH)@0_^?}?X at p#e??E)@|]??t?X@?????=)@$&??[?X@?Y?(@?{
?q Y@
???(@|??!UY at 0U0*?c(@<?I/?X@ ????-(@<??"?X@?????$(@(???I?X@?_?|x(@|?????X at x;???(@??:M?X@      (@d?F ^?X@(x
?R?'@<?I/?X@ s???'@h?2?}?X@ ?????'@T:X???X at X?y??'@Pd????X@`?vj.w'@????0?X at x><K?a'@h?>??X@?O?e'@??????X@????r?&@????Z?X@?N???&@??? ?X@???0??&@????N?X@??g??&@TpxAD?X@?&M??Q&@$???{?X@??G?);&@??i?X@?"1?0&@?z2???X@?7?a?!&@Pd????X@??Q?&@T[? ??X at 8+?&?&@?6?[?X@?Op???%@?: ???X at P??{H?%@?P??X@????a?%@xx????X at P??C?%@d??a??X@?????%@????X@???A?W%@<??A??X@??]0?N%@8?? n?X@?,???%@(???I?X@?x?'?$@8???z?X at P?}??$@|i? ??X at h?TQ??$@??????X@??d?$@????Z?X@?)??f$@P????X at x0)>>A$@i??X@?k?}?*$@?'?>?X@?????#@?????X@?f??}?#@<? ??X@??????#@??j?=?X@ ?K???#@]~p?X@??s??#@P@???X at pJ@L?u#@??3?I?X@@?vH#@h?R@??X at hs????"@$?@??X@??e2?"@PX?e?X at P??C?"@?<*???X@(??;??"@?>;???X@ .???"@?p!??X@?dp???"@?b.?X@?,????"@PI??&?X@??Cv"@?Ko.?X@?IEc?o"@8????X@????g"@$???{?X@ (??b"@??+?z?X@?Xl??f"@PCT???X@?????l"@PF\ ?X@?t????"@?Q?G?X@ ??G??"@ ??>??X@ ??G??"@?Q??B?X@?ek}??"@??~?n?X at 0Ie?9?"@?$???X@??+??"@??6 ?X at h?"???"@8????X@?qo~?t"@?}s??X@???6?A"@?????X@?S???!@$?6?D?X@?WXp??!@????r?X@(f???!@?????X@?b*??K!@<?e?Y?X at Hx$@!@?t????X@?b??5!@<?I/?X@????A&!@h??Y@??Po!@$ &?BY at P?&?O
!@?E?~Y at H????? @4\???Y@???OV? @8qr?C
Y@?T?2? @ZH??Y at P??z? @????{Y@ ???? @??T??	Y at X??y?? @?v? ?Y@?f??}	!@`s?	Y@??Z?{!@??'??
Y@????? @?n??;Y at P???6? @?9[@hY at P?{/? @L1AGY@???[? @4Y??Y@?Z??K? @?#?Y at H?s
?k @??@?Y@???0?H @????Y@(oG8-8 @x*???Y at pO????@?&??Y@`'.?+?@????Y at 0i?7n@ ?B?Y@`??m?3@`??-Y@ ?qS@h?ba?Y@???%??@xrM??Y@`?H?s?@$#gaOY at 0??Ng@Tg??Y at 04e?$@(?B?Y@?g? @????kY@?????@ ???Y at p8?Jww@?_"?: Y@??'??C@??~? Y at P????,@??? ?"Y@???#@L(D?!$Y at 0@i?Q?@? ?}?$Y at pm?k?@N} y$Y@@??0?@xKr??"Y at ps????@?e??Y@?;?$@h?!?{Y@.???@(?N>=Y@ 9{?@`???LY at p{Ic?.@t-Z??Y@????@???? Y@??#?,@??3?I
Y@???B@????
Y at 0???@8???	Y@??/???@$???]	Y@ 0??@??_?	Y at P?????@??H?Y@@??0@??_?Y@@(a??@`???Y@ ?vi?@???^aY@@	]n@Tj?@+Y@????(\@?z??mY@??U?O@@? ?Y at 0???;@???~Y@??^?@4??a0Y at p><K??@$????Y@????b?@?M?t"Y@?b???@?? ?m%Y@?????@xR~R'Y@ h?
?@c??K)Y at pU??@?e??,Y@?	???W@W@?.Y at pJ@L?@????0Y@@???@??Q?1Y at 0Xq???@?? ?m3Y@????@????:Y@?c> ??@$???]=Y@?v?
??@?B???Y@????w@xH1@?AY@????c@\??@CY at P?.??b@????ZDY@????n@P?>?HY@ ?u7o@????KY@ 2t?p@|K9_?VY@`??]??@?F? \UY@??_>?@?????RY@?oB!?@?????UY@`???L?@?????^Y@??V??@???@?aY@??0??n@<?? ?bY@?j???d@??+?zdY at 0:??8N@?=?eY@?.???@????NkY@??|@??@\X7?nY@?Vc	K@d?6??oY at pm?k!@?qo~?pY at 0?74e@P??ZrY@?
/??@$????sY@?S??@L+?@.?Y at 0cC7?#@?s}?Y at P???6@H????Y@_?(??@?SW>??Y@`?n??@?
j???Y@????@'@?-???~Y@?oB!@L?'?|Y@??????@???f|Y@??Z?{?@???!6|Y at pJ@L??@ ???e|Y@ ?qS?@?wak|Y@?X?w@??3??tY@@#??@4P?>sY@?c???@???fqY@????(@`?_??oY@?u?!(@???`?lY at P?X?;@H? OlY at P?L??@t9% &jY@?[?tI@l??3jY at P?T?	g@`????fY@?H? ?@??M~?dY@?G,?@???b`Y@`9{g??@H+???\Y@`??m?s@???SY@??N$?:@8w?^?PY@?=Ab??@L?^INY@?A??@4???#LY@?dp???@?????JY@?_???@????IY@??/???@H?`?CY@?k?}??@?8~??Y at p??}U@??h o?Y@?S^-@4??A?BY@ z?r?@$??~jDY@ ?)r??@??`FY@ ???!?@??l?GY@???,?@ ???FY@??Z?{3@?v?>XFY@ ????y@??%PGY@?????@????+GY@?6??? @?w*??@Y@?i? ?@??	??<Y at 0R????@???^?6Y@ ?????@d?*?36Y@ ?!??#@?P??C6Y@?[?T0@xKr??6Y@???-=J@x0b? 5Y@ h?
?@?Tka0Y at P?P??@d?: ?-Y@?Q???@4?9A?+Y at P???6?@???_*Y@????r?@???Y@@(a??@xrM??Y@?;?$@???ABY@?'???)@???Y at P????,@????sY at 0oG8-X@????)Y@ ??TN{@8n1?7Y at pE????@x*???Y@??|@??@????
Y at 0oG8-?@H?P?
Y@?P??d?@t?~kY@@?+?@????+Y@?Z??K}@?????Y@ ?!??c@L?X?UY@`??iM@xQ???
Y@ ???!?@P%@	Y@?5_%?@`y??"Y@ "nN%?@L?d??Y at pD?K??@L?#~?Y@@	?="@\??a?Y@?z2??@H+??? Y@@??05@?z??m?X@?W:?U@4w??\?X@????r{@????{?X@ ??;??@$??}8?X@@?~?@?D???X at pD?K?K@?Q??B?X@`???ZP@???W?X@?;?d@??I~??X@??????@??$>w?X@?f??}?@??? ??X@???C6 @?z2???X@?ek}?@@???@??X at P????x@??? ?X@??h?@?!S>?X@?{F"4r@???i?X@??????@??,AF?X@?"1??@??x>?X@?B???4@$???X@d???@|~!<?X@?^????@h?????X@?aMeQx@	Q???X@ ?:???@|c ??X@??#??@????Z?X@???[?@$????X@?	????@T(__?X@?-??1?@??#???X at 0???@???`?X@@?DD@?T2 T?X@?G?z?@?E?>?X@????@?@?`6??X@? ??? @|Bv???X@???B?@??bg?X@??w)u	 @???A??X@??Po @d?????X@??/??( @h????X@ ??H.7 @<?????X@?g??_ @$&??[?X at 0O?)?q @?????X at pD?K?? @T?^
?X@?&M??? @??? ??X@@F?7? @x!??X at P??u? @??M??X@???P?? @<??A??X@?+??? @??O???X@?????? @~? ??X@???
?? @|c ??X@??q5?? @????X@?"R?? @?T2 T?X@??(?A? @???f?X@??:??? @(?
?0?X@?w?~?? @?}s??X@??Z?{s @ ?A??X@?????K @??????X@??(?AF @????H?X@???
?j @<?i???X at x;???? @l\???X at X??y?? @P
?=??X at x)u?8!@$)?ah?X@?3Lm?!@h???X@(???+!@????\?X@(f??9!@<???	?X at P???hd!@P
?=??X at H??0?!@??????X@???,?!@<}???X at x?n?|?!@h?????X at X?wg"@@???4?X@?w?~?"@`X?|?X@?u?r?:"@?;???X@??O=j"@(?N>=?X@??,?sz"@T.T???X@?2Q???"@d?: ??X at hF???"@?}s??X at pJ@L??"@( ???X@??C???"@??M??X@2t?#@d?&??X@?X?w#@?????X@??????#@P????X at x><K??#@r????X@???25?#@??6 ?X at H???M$@8?????X@(x
?RW$@|3j?J?X at xE???|$@(????X at H?o	??$@xB????X at x?n?|?$@{????X at x><K??$@|fI???X@?n???$@?Ws?`?X@ %>w??$@$?F??X@?????$@h?????X@@?+
%@8?!?X@?o`r?0%@?&???X@`?9?S>%@??? =?X@?5??Z%@??????X@@#?v%@\F?=??X at 8?????%@@?@?w?X@?j???%@?-@??X@?;??%@??i? ?X@???
??%@P%@?X@??s?&@|-??1?X@?Yg|_&@`??9?X@???&@P
?=??X@???@?&@|i? ??X@?????2&@????H?X@?&M??Q&@?;???X@??,?sZ&@?qo~??X@ ??F??&@??e???X@?T?2?&@(2s???X@ ??G?"'@xu???X at pM???B'@(5???X@????{'@?C??X at x*?=%?'@??? =?X@???
??'@?(z?c?X@?j????'@8????X@(eRC(@?"1A
?X at p\?M
4(@????X at X?T?	G(@??????X@??I
m`(@@?a?'?X@ ?bG??(@?????X@??????(@????r?X at P?\?m?(@??B??X@?k?6&)@xB????X@??M?T)@c??K?X@??-x)@|-??1?X@??V?I*@??????X@?????[*@$8????X@??hUe*@?!S>?X@?,??;h*@h?!?{?X@`???:l*@ ? >??X@(oG8-x*@<?Y???X@`?ri??*@|]??t?X@?x#???*@?"1A
?X@???>U+@??m?R?X@?????'+@$[A??X at x0H?D+ at xx????X@??M?T+@?i>"?X@?L??t+@??,AF?X@?????+@?T2 T?X@??;???+@?NA~6?X@ ????,@?e??S?X@???P?(,@??x!?X@?????3,@(/2??X@?M?EC,@?
)???X@????^,@???@??X@??K?[o,@|6?>W?X@?D???,@<?(A?X@???$??,@?????X at 0Z????,@?E?>?X@?G,?, at T=???X@??6 (-@???A_?X@?N??9-@(/2??X at 8"???E-@x'??X@?J %vM-@?4E???X@?y7n-@(????X@ ????- at P????X@?????- at h?^`V?X@????(?-@???!?X@??i3N?- at 8?!?X at P?*???- at d????X@?t????-@??????X@(w?Df&.@?;???X@?????h. at PI??&?X@???>t.@??????X at x0)>>q.@|]??t?X@?+???. at xx????X@?f??}?. at L(D?!?X@(?O:??.@?P??X@(w?Df?.@??t!V?X@??0??.@??Y??X@???N?.@|~!<?X@????@?.@???@??X@??'???.@<?E~??X@????y?. at PI??&?X@@N???.@??B??X@??+?z?.@?:????X@2t?/@?#????X@(qVDM/@<?I/?X@???7/@?"?~??X@????I/@??@??X@??s??R/@|ZEh?X@ ????e/@???@-?X@????r/@|W?[?X at P?*???/@?Z? m?X@????0@?ng_y?X@?h;??0@$?@??X at PF\ !0 at d?	???X@??eO0@?N?`??X@????0@??+???X@??6 $0@?f???X@|?(B?B0 at 0M???X at 8? "5e0@|W?[?X at P??{Hp0@?}s??X at T?T?	g0@??=x?X at P?|aZ0@o???X@?P3??F0@??d?<?X@@?vH0 at h?????X@$??a0 at T(__?X@??p?u0@?C??X at P^d~?0@]~p?X at P?\?m?0@\?????X@?X??+?0@\??m?X at h???8?0 at PL? 3?X@?U????0@?????X@(u?8F?0 at T.T???X@ ?A??0@<?i???X at TC?
1@???>?X@??&??
1@i??X@?Z??
1@`?? ??X at T????1@$???{?X at TC?
$1@|]??t?X@?C4??,1@@?a?'?X@({K9_<1@$???{?X at T?z?A1@??#???X at x?q?ZP1 at PX?e?X at x???sj1@????~X@(n?@?1@??i? {X at 4?z???1@?? vvX@@N???1@????rX@|*?=%?1@?t???qX@?d?<
?1 at P???kX@??n?!?1@`?_?mX@(?????1@????oX@l?`q?1@u?pX@?W???1@`?? ?kX@????? 2@????iX@???x?,2 at P<??gX at P????92@$???gX@?O8??@2@????,iX@????G2@$??gX@?V???P2@?/??eX@??|@?S2@??+?zcX@?t???Q2 at h?2?}bX@????F2@|~!<aX@ 2D2@|????_X@?@?9wG2 at LF?a?\X@? ?=V2@|??A?\X@ ??F?^2@ra?\X@T?^
d2 at d???[X at PF\ i2@(?
?0YX@??r?S~2@?q???WX at h?????2@????9VX@EH???2@?
)??VX@?~??@?2@??3?/WX@??#Ed?2@$??WX@,?????2@?4~??\X at d?g^2@?Z? m`X@?a?? 2@??3?IcX@?c> ??2@???hX at PI??&?2@?1 ?iX@?8????2 at xW=`pX@??:??2@<????qX@?????2 at xu??qX@?U????2@?<*??qX@?F??2@(?_rX at Ljh??2@????oX@,i?7?2 at 8?]?nX@???g??2@??^?kX@$W@??2@????oX@??I'3@?v?1rX at L??u3@|~!<uX@?W?B3@(2s??uX@|?<?*3 at XXp??uX at h o?53@(??buX@(?N>=J3@?h?^`sX at 84e?\3@?
j??rX@??Cf3@<???rwX@$?????3@?f??wX at 0?!???3@??(@zX@,l? ?3 at P=???}X at T?z??3@???M?X@?2Q???3 at d?s~??X@???B?3@?L???X@??????3 at 8???(?X at 8.???3 at Tal!??X@ ?={.?3@?:????X@? :v?3@|6?>W?X@|????3@?1 ??X@?^}<??3@??A??X at Lg'???3@|fI???X@$???3@?????X@|???!?3@??$>w?X@ H?9??3@???~P?X at Ljh??3@<?i???X@ ?????3@<?????X@?V????3@<?u??X@<%??3@$????X@????g?3@?????X@<? ??3@?u?!?X at d????3 at h??}q?X@$z?r?3@{????X@T?^
?3@|]??t?X@??????3@l\???X@?
1^?
4@?????X at x??C54@<q9^??X@????l 4@????Z?X@@?v 4@??#???X@????4@(???I?X at T?z?4 at h?B,?X@<?\?4@??_>?X@?.m8,4@??e???X@<? ?4 at P??5?X@?B]4@`???X@|??8G%4@$????X@??K?['4@?????X@?8???34@??A$?X@?(?7O4@???A??X@?&M??Y4@???>?X@?????R4 at Pg?!??X@?n.??O4@?-?s?X at L???hT4@??4?X@|*?=%W4@??bg?X@(r??9]4@`X?|?X@?*?w?g4@<?? ??X@??Hh?m4@?????X@({K9_t4@??????X@???f?o4 at 8??!?X@?.??|j4@?Q?GY@ ???!b4 at t?z?fY@??x at Y4@xu??Y@|0)>>Y4@????Y@?
?7O4@<??A?
Y@?\7??J4 at d?s~?Y at x?0DN[4@?<c_?Y@????b4@<??@fY at x?u??d4@?3???Y@????:d4@?=?Y@??*??a4 at P"??Y@ H?9?]4@??FY@?"??JV4@????Y@????N4 at xrM??Y@?;?<4@???MY@?&04 at PU??X!Y at P???T%4@?????$Y@?????)4@?(?A&%Y@?Z?{c(4@?????$Y@?@?9w4@?0??B#Y@3???4@<??@f Y@K????3@???>Y@???B?3@?D??Y@?EC???3@????QY at h?????3@(__?Y@??6??3@?E?~Y@?C??3 at d?	??Y@?O8???3 at d???jY@<?U???3@ A?!Y@?QG???3@T?^
%Y@|???S~3@?,??o%Y at d?u~3@????;'Y@??5??3@?!S>)Y@?}s??3@?7??,Y@???w??3@?%9`W0Y at 8.???3@?????1Y at 8???Z|3@?C?4Y at P??C?3 at d?s~?6Y at L?g\?3@B@??7Y@ ?!???3@?#???8Y@?.m8,?3 at 8?M?a:Y at t?????3@<?e?Y=Y@?A??3@???BY@??f??3@?C?DY@|?<??3@????EY@|?,C?3@?J?hNY@@v()?3@<??A?PY@??j???3@?w?~?QY@?}s??3 at PO??RY at P??C?3@(__?PY at x<-?py3@?s???MY at x?$v3@(??LY at T??y?_3 at LLb?LY@$??E?Z3@?????RY@??G?)3@?cw??SY@?????3@<??VY at L?g\3@?^?UY@?K???3@?dTY@?A??2@]P?2SY at h?"???2@??U?@PY@?????2@?????OY@(?R?o?2@?*?)OY at t??F??2 at PI??&QY@????@?2 at 8?? nOY at T?X?;?2@??l?KY@?Gp#e?2@?? lIY@??7?a?2 at xu??FY@??w???2 at 8}=_?CY@<5?q2@?!???CY@??G?)k2@???`?EY@?9}=c2@???!FY@?,???_2@$8???IY@?H??QX2@????NKY@?????,2@??e??JY@ ? ?S2@ ?,^,IY at T1?~?2@?Q?GGY at 8?!?1 at h????EY@??C?1@???DY@|???!?1@(5??AY@?e?%??1@|6?>W?Y@?B]?1@??^a?>Y@???W?1@? ?> ?Y@B??	?1@$ &?B?Y@`'?ei?1@|Q?_=Y@ ? ?S?1 at d??A%;Y at L?*???1 at d??Q:Y at L??u?1@!Y?;Y@??&???1@??_><Y@????x?1@i?=Y@?/??1@????9?Y@??6??1@??p $BY@@
??1@????DY@??M?1 at h???8JY@?^}<?u1 at 0b? ?NY@??
??1@???A?SY@?8????1@?????VY at PO???1@(?^?_Y@|???S?1@???0eY at 84e??1@???A?cY@W?}W?1@<}??dY@,oG8-?1@?
j??hY@?,????1@??6 lY at T??y??1@??$>woY at H/??1@?`???pY@?c> ?	2@?Z?a/rY@?
?D2 at L
4?svY at x?0DN2@<????xY@ ?z?2@<??HzY at hm?k	2@??M?Y at Lg'?? 2@????Y@????12@?"?~??Y at P???T52@\?????Y@,2: 	72 at 4k) ??Y@?%???52@T?^
?Y@?ZH42@B@???Y@ ?bG?02@|i? ??Y@???i#2@<?(A?Y@?_?|x2 at d??A%?Y@?v?12@?F???Y@???Z`?1@(?N>=?Y@??v?1@?~NA~?Y@?G,?1@$[A??Y at t?y???1@?i????Y at P?|a?1@??~7?Y@??G?)?1@??a?Y@QL? ?1@|o??Y@??B??1@??^a??Y@|????1@?d?Y@?1????1@?d?Y@??????+@$?`6?Y@?????+@|?Y?H?Y@?A?o+@|-??1?Y at h??\?\+@<??H?Y@??R?K+@(??>V?Y@@/?:+@<??~?Y at x0)>>)+ at 8????Y@?D??$+@?t????Y@?n.??+@????Y at pP?L?+@(??b?Y@(l? #+@????#?Y@?2Q??%+@?????Y@??Po?*@?? !??Y@ ???!?*@<??A??Y@?w?~??*@Hqh?Y@??N@?*@??-?Y@?WXp??*@h??I?Y@?????R*@??'???Y@????;*@B@???Y at p\?M
?)@(??)?Y@?/??)@?????Y@????i?)@(??b?Y@( ?3h?)@h??`o?Y@ :vPy)@?N??:?Y@??C??^)@d?? w?Y at 8?%?P)@?.??|?Y@???"J)@?p!??Y@???$?4)@PR`L?X@?G??
S @??????X@ ?!??C @T=???X at H?o	?7 @?}s??X@??<?* @???@??X@?????) @????X@?O@? @????X@??D?e?@?U????X@?Z(???@d?????X@????Z?@o??}?X@`?9?S?@???^??X at P????@L.??:?X at pP?L??@{????X at pE???|@??P???X at 0?74e@<??@f?X@???"M@?I+?X@ *??&@???@g?X@????Z?@TC?
?X@?????] @????k?X@?"R?^ @????s?X@????Y @PR`L?X@?G??
S @??K?Y@      (@??????Y@???B?'@\gC???Y@??
DO?'@t3????Y@??6 ?'@???>?Y at pVDM??'@*?~??Y@?????'@?????Y@??4??B(@?????Y@(h??'M(@??????Y@???M?K(@???N?Y@?????H(@??? =?Y@?0??F(@??x>?Y@?M?EC(@??d ??Y@?????9(@??\?C?Y@??G?)3(@<?????Y@???
?*(@ ?.???Y@?;?$(@?T?~O?Y@?N??	(@?????Y@??9D(@??K?Y@      (@t?~k?X@?????@?????X@?`?d?@??d ??X@??,?sZ@??l??X at ps???+@????Z?X@@?+@h?????X@`???L?@<?????X@?k?}??@<?I/?X at pg??RW@`?_??X@?Xl??f@d??@??X at pO???n@t?~k?X@?????@?'???Y at hwH1@?'@?K?A??Y@?j???d'@??H??Y@??$?R'@?s}?Y@??7?aJ'@`?? ??Y@ ?bG? '@8? U?Y@???""'@????Y@?4~??4'@x'???Y@@
?b'@?	??$?Y@??????'@?'???Y at hwH1@?'@Tv?A]?X at HA???6 @<?E~??X at x9??c( @??/??X@ w?* @d??A%?X at pP?L??@??i? ?X@?7?a??@$????X@??+??@PR`L?X at P?????@(2s???X at p8?Jw?@?????X@?}s?( @h?????X at P?*??. @h????X at x<-?p= @Tv?A]?X at HA???6 @H????Y@?K??$#@ ?q?jY@?????"@?Q?GY@?(z?c?"@|3j?J?X@??????"@??]?9?X@????Z?"@?
)???X@?|A	#@???>?X@??C??&#@(???Y@(r??9-#@??$??Y@????!#@?????Y@???B#@H????Y@?K??$#@     t   ?E?~?X@ ?_??????d?Y at 0oG8-?@   ?          ?   ??????X at p\??J?@??? ??X@ ??;??@?Y???X@?S^?@??? 5?X@?l???@??????X@?Yg|_?@??H??X@`y??U@??????X@???'@8? U?X@?w?~??@?|A?X@?f??}q@P<???X@`?2??z@,kg?X@???-=?@?E?~?X@??????@PF\ ?X@???C6?@??x>?X@??	.V?@|?????X@?T?2?@??????X@????Z?@?w?~??X@??????@??M??X at p><K??@?$???X@?????@??????X at p\??J?@?'?>Y@??1?@4?9A?{Y@??n?|R@8?M?avY@@$C???@x?ErY@????/?@`?? qY@?"1??@????{oY@ 	]??@L??nY@??KX?@???>?lY@??i??@L
,?)cY@@M?p=@????`Y@ ?D?
i@?$??^Y@ ??Q??@???I]Y@`I???@x3?
\Y@`????,@??=xZY@?
1^?j@P
?gYY@?^???@????WY@?-]??@4D?TY@@;?I?@???IRY@`?~l??@`??RY@????@'@W@?RY@`???(\@?
??:TY@ ` ??@????vUY@ ???d?@L???nWY@@:??8?@?????WY@ ??V?C@?|?qWY@?S?{F?@????sVY@@?&?O?@l?`qTY@?|x? 	@`?[>?SY@@???	@?!? ?SY@ K;5??	@8n1?7SY@?N??
@?%!?RY@ ??R?2
@cAOY@ l$	??
@???^aLY@ ?vi?
@t]???FY@ ?O:??@tT5A?EY@?3j?J?@?V??DY@ ??SG@??Q?(DY@@??p@????CY@??????@8b->CY@?E?S?@?SW>?AY@??(?A
@d??~?8Y@`????@uX??7Y@?P?L?@????U6Y@`?"??)@L??4Y@`???T5@???@?3Y@`?~l?_@?$??4Y@`?????@??>6Y@ 5'/2?@x3?
2Y@@R????@??`?u0Y@@M?p?@??`R/Y@`????@9??!.Y@ ??r??@?b??	-Y@ ??Q?@??o^?,Y@?
/?H@????-Y@ $??@??f?\.Y@ )\???@???0Y@ ?????@tT5A?1Y@ ?????@8Vb??7Y at P?2??@H
m 6,Y@?5_%?@tT5A?)Y@@#??@??U??'Y@?Xl???@d???&Y@??V&??@??,%Y@ h?
6@?w*??$Y@????(\@???~P%Y at P?????@d?6??%Y@@?vX@??5??%Y at P???? @??? ?&Y@?f??}1@???? Y@`?zk`?@4????Y@?	????@??Q?Y@??U??@????QY@ ????%@??9 at 0Y@??J#fV@?????Y@ 6??z@$??~jY at p28J^?@?
?.Y@??#??@?????Y@??0??@`?[>?Y@`??jG!@???ajY@?%9`W@`????Y@???-=*@?v?>XY@ ??s?F@$??~jY@?x#??o@uX??Y@?C?b??@?????Y@?=Ab??@4D?Y@ ?mR?H@??]??Y@@)???@$?6?DY at ps????@??? ?Y@ ?t?@x?EY@??w?'?@??A?Y@?R??q@?v?>XY@?????@?"1A
Y@???>U?@oB@Y@?`?d?@H???
Y@??
DO?@?|?qY@ ?J %@???Y@????@x0b? Y@ ????%@??J
Y@???ZDD@?lY?.Y at 0??/??@`y??"Y@ "nN%?@P%@	Y@?5_%?@xQ???
Y@ ???!?@L?X?UY@`??iM@?????Y@ ?!??c@????+Y@?Z??K}@t?~kY@@?+?@H?P?
Y@?P??d?@????
Y at 0oG8-?@x*???Y@??|@??@8n1?7Y at pE????@????)Y@ ??TN{@????sY at 0oG8-X@???Y at P????,@???ABY@?'???)@xrM??Y@?;?$@???Y@@(a??@???_*Y@????r?@4?9A?+Y at P???6?@d?: ?-Y@?Q???@?Tka0Y at P?P??@x0b? 5Y@ h?
?@xKr??6Y@???-=J@?P??C6Y@?[?T0@d?*?36Y@ ?!??#@???^?6Y@ ?????@??	??<Y at 0R????@?w*??@Y@?i? ?@????+GY@?6??? @??%PGY@?????@?v?>XFY@ ????y@ ???FY@??Z?{3@??l?GY@???,?@??`FY@ ???!?@$??~jDY@ ?)r??@4??A?BY@ z?r?@??h o?Y@?S^-@?8~??Y at p??}U@H?`?CY@?k?}??@????IY@??/???@?????JY@?_???@4???#LY@?dp???@L?^INY@?A??@8w?^?PY@?=Ab??@???SY@??N$?:@H+???\Y@`??m?s@???b`Y@`9{g??@??M~?dY@?G,?@`????fY@?H? ?@l??3jY at P?T?	g@t9% &jY@?[?tI@H? OlY at P?L??@???`?lY at P?X?;@`?_??oY@?u?!(@???fqY@????(@4P?>sY@?c???@??3??tY@@#??@?wak|Y@?X?w@ ???e|Y@ ?qS?@???!6|Y at pJ@L??@???f|Y@??Z?{?@L?'?|Y@??????@?-???~Y@?oB!@?
j???Y@????@'@?SW>??Y@`?n??@H????Y@_?(??@?8?~??Y@@;?I?@?k?}??Y at P?pA?@8?A`??Y@??C??@<?I/?Y@ ?????@34??Y@??X??@???A^?Y@`??m??@d??@??Y@ ??TN?@P:?`??Y at pg??Rw@?l ]?Y@?
/?H@Ly ??Y@?G?z@????;?Y@???"M?@?u?!?Y@????@?@@?????Y@??G??i@??? 5?Y@???#P@???@??Y@`????@??????Y@??R%?.@??{?Y?Y@?????
@4?9A??Y@`?zk`?@?d?Y at p???a?@?d?Y@@cB?%????v???Y@ ?_???????X???Y@???*????4Y???Y@????	??4z5 at i?Y@@F??jb @xQ????Y@ ???M? @-????Y@?f??}? @???~3?Y@???|#? @L?????Y@ ????? @??????Y@ ?Y? @???@??Y@??,?sZ@p?_!?Y@??????@ ????Y@?8????@K???Y@@??&@d????Y@?:3P?@?'?>Y@??1?@XO???Y at 0Lk??@???~Y@ h?
?@xQ???Y@?????@?e??SY at p8?JwW@x??^Y@`????@?;?
Y@?W:?@L???Y at 0{K9_,@???Y at pJ@L??@H(}!?Y@????b?@ ?B?Y@?? ???@?
j??Y@?@d?&?@?<??tY@@?~??@?5???Y@??^?@xB???Y@`~nh??@XO???Y at 0Lk??@     ?   ????A7R@??};??????F!?hR@?R??q@   i
            $   )   .   8   =   F   J   N   R   V   Z   ^   e   ????sJR at pU?@????JR@@?z?@ ? >?IR@??N$??@??|?5IR@??U??@??fHR@`?????@???A_JR@ 2t? @????sJR at pU?@l\??VR@??x?n@??RAEWR@@F??jb@??A?WR@??4??B@?h?^`WR@?????@h??}qVR@`???"?@l\??VR@??x?n@?Q??B=R@@)???@|c ?=R at P?T?	?@PL? 3=R@?S^?@???R<R@?UId?@P}>?<R at 0u?8F?@?Q??B=R@@)???@??icR@ R???????$>wcR@@?vj.???<???;cR@@j?? _???: ??bR@??(\?B??PR`LcR@ g?|??????icR@ R???????:MhR@@???@??F!?hR@?M?E?@??+?zhR at P?????@f`XhR@?Z??K?@$[A?gR@?Yg|_?@??:MhR@@???@?-@?[R@ Kr??&??$?w~Q\R@ MN?S???????\R@ ?Q????<q9^?[R@ ?<L???-@?[R@ Kr??&??@?a?'YR@??Z?{?@???>YR@?F????@d?F ^XR@??(?A?@(__?XR@ ???S?@@?a?'YR@??Z?{?@P???_R at 0R????@???A^`R@?j????@????Q`R@?}s??@??{_R@?Z??K?@P???_R at 0R????@<??A?>R@ ??n??@xx???>R@`?ri??@<???	?R@?? ???@<???	?R@?b???@?w?~?>R@ 0??@<??A?>R@???C6?@<??@f>R@@?????@????A>R@?_?|x?@?T2 T>R@?Z??K?@<??A?>R@ ??n??@?'?>FR@
?b?0????+?zFR@ F)!XU???????FR@ ?p?i????i? FR@ ???]M???'?>FR@
?b?0??<?e?YeR@?w?~??
@??>?eR@??4??@?t???eR@ cC7?@xu??eR@????r?
@$??eR@??Y5?
@???A^eR@?,??\?
@??|?5eR@?????
@???9eR@@? O?
@<?e?YeR@?w?~??
@l\??>R@??^?@<????=R@ ?vi?@?-?s>R@?}V??@l\??>R@??^?@????>R@?R??q@?;??>R@?Z??K
@????Y>R@??E;@????>R@?R??q@?B?7R@@)???@?D???7R@@ 7??@????A7R@ K;5??@?B?7R@@)???@d??A%CR@@?D?@?s???BR at 0~??k?@????BR@ ??9x?@d??A%CR@@?D?@<????;R@??I
m?@????;R@??????@8?M?a;R@??????@<????;R@??I
m?@h????eR@?f??}?@(???dR@ f???@??$>weR@??????@h????eR@?f??}?@PU??XFR@ ???I????? GR@ ?p=
???T(__GR@??};???????@?ER@????O??xrM??ER@????)????`6?FR@ u<f????PU??XFR@ ???I??l?? ?`R@ ??Z???()? ?`R@ ???Y???/??`R@ [??????l?? ?`R@ ??Z???     #   Lu??W@?q??????d?Y@?`?d?@   Z      H  d  ?  ?  ?  ?  ?  ?  ?  5  _  t  ?  ?  ?  ?    ,  ??+???Y@ ?Q????x??^?Y@ ?z?G??4??<?Y@ Z??????`|?/?Y@ ?p=
?.?Y@ ?9??q???d?Y@ (?8'???d?Y@?????8??v?1?Y at 0\???(?????Y@@???? ? ?,^,?Y@ ??????????\?Y@`?zk`??(???I?Y@??#Ed??<q9^??Y@????????????Y@?ek}???Q????Y@?z?Ga??&???Y@???(\?(???Y@`?D?A???l??Y@?,?IE???p!??Y@?]????????!??Y@???B|??????Y@???d??????Y@ 0?P?????9?Y@???B|?8?? n?Y@?????x
?$?J %?Y@ ??Q?^
?8???(?Y@????51
?T%??R?Y@ "??
???~7?Y@@?.????o??Y@ ??j????`?wY@@'/2_????!?iY@ ???!"
????@?hY@??Q?
????hY@?|A	?	??a?fY@??Q??	?????r_Y@ ????y????~_Y@ ?K??h?d???^Y@?B???4?????]Y@`????????!?YY@ Ad?&????@?TY@ K;5???<??~TY@??(\???????0SY@?L1A??h????QY@ ??p=???U???PY@??M?t?P???OY@???#bj?Q???LY@ ?C?H@?d????KY@?G?z.??;??HY@??M??? ?.??GY@??I?????@I?GY@?9?!??d???FY@?L1A???]??yEY@ ??j??xu??AY@??G??????~PAY@ ??n???????i at Y@??+?,??()? ?:Y@ W?6???T=??9Y@@?.9??|i? ?5Y@??x?n?T%??R5Y@`U?Y?????N5Y@????h$?|????5Y@?/?x????m?R7Y@@???? ? ?.??7Y@??h;?? ?d???j8Y@`_??`? ????~8Y@??vL] ???`?u8Y@?w?~????8en?8Y@ ??U?o?????`?7Y@ ?C?????<???r7Y@???E}????? !?6Y@?=
??p??,8? "6Y@???C*??8?? n/Y@ ??S????7??,Y@@"???????"1A
,Y@@?????????@+Y@??t??g??(c`*Y@????h$???????)Y@ w?h?????? !?&Y@??e????PR`L%Y@?G?z??? ??_w%Y@ ??Q???????H$Y@@?~l?_??L??~?#Y@??M?4??$????Y@??I???????`?uY@??Vc???h??}qY@?/???????L!uY@ ??-?????
a5Y@ 7?x????|ZEhY@??j?????? !?Y@ U?M??????>?
Y@ ?c??%??T%??RY@?z??K??L
4?s
Y@ ??A????d??QY@?[!?????8?? nY@?b? ?????????Y@ ????`????KY@ t`9B????i???Y@??M??????~7Y@ ?;?2T??h?R@? Y@ m??<+?? 2 Y@ ?4?????xB????X@ I??r???d?s~??X@ ?4?????|?Y?H?X@ Di???o???X@ t?Oq??????#?X@
?b?0??tZ?A??X@ fi??r?????@-?X@ ???????~? ??X@ ??t??L
,?)?X@ 0^?????~? ??X@ (b????f???X@ ??qo??$?w~Q?X@ ?;?y?????????X@ 8????????8?X@ ???'*??P
?=??X@ ????????e???X@ (\?????(2s???X@ di??r??(?R?o?X@ ???????u???X@ l??^??PO???X@ $?]J]????$>w?X@ ????8??h?????X@ ?	????u???X@  A???(5???X@ ???????     ?X@ ???|???*?)?X@ ????`???????X@ ?p=
???l?) ??X@ ??$???? ?}???X@ ?an???????X@ GN?????I????X@ ?.?.??h???X@ ?`S?Q???}:3?X@ ?????T7??X@ ?1????? ????X@ d?M*??,P????X@ ??j?j???????X@?72??A??@???X@ h?
?????F?X@ E???????S ??X@???r?X???y???X@      ???7>[?X@@`W??????????X@@?&?O???,>?x?X@ ` ????D?X?o?X@@)??@??H4?"?X@ ?W?Be???????X@??Yh???????A??X@?U?????f?X@?z?"0??05B?S?X@??X?????	/???X@??(\??????^?X@@?.??????pu ??X@?}????????y?X@@R????????v???X@@??{????pu ??X@?_?|xV???g@??X@@?vj.???p$?`S?X@@?&?O????A|`??X@@???(\??p ???X@ T?^???p>???X@??4?????B@???X@??G?z??(?R?o?X@ ?ZH????<??t?X@@??{????9[@h?X@?????????? 5?X@?p=
????fL??X@ ?kA?????z??m?X@??$?? @(?N>=?X@@?,_?A@??h??X@??F?L@8b->?X@?\?M
t@H????X@???&?@8b->?X@???%??@ ???|X@?,?IE#@`?c@?{X@????@'@8n1?7{X@?,?IE#@ ???zX@?dp??@??M~?yX@ cC7?@~? ?xX@@?&?O?@4bf??wX@ ?Y?@xQ???pX@??I
m @??? pX@?k?}?*@l??3jX@?k?}?*@?????iX@ ?O??<@8??iX@??|@?S@xH1@?iX@@??l@h?2?}iX@`?????@?1=a?iX@@?&?O?@xH1@?iX@?dp??@xH1@?iX@`h?N??@xH1@?iX@ ?O:? @??M~?iX@?????@xrM??hX@?????@??U?ZhX@@?~?@? ?}?gX@`h?N?H@????gX@`????@d???fX@?Z??K?@??? 4fX@ ??U??@d?? weX@?
/?@?P??dX@??,?@??? ?cX@?.2@???@?bX@????b	@????\X@???S@???>?ZX@?Z??m@?|?qXX@???%??@??H?WX@@???@??+??UX@?f??}1@????ZTX@@??l@?8?~?SX@@?74e?@H0?[SX@??0???@L?#~?RX@@???@ ???RX@ ??s?	@d???RX@?P?L?	@d???RX@?w(
?I	@?Z?a/RX@`???Zp	@???!oPX@`?zk`?	@???_?OX@? ??*?	@??'?bMX@?
1^??	@xB???KX@ ???S?	@L?#~?JX@@???>
@ ?A?DX@???y5@??JBX@@'/2?@ ?? ?AX@??(?A@????Z at X@ 5`??I@????U8X@?????k
@4Y??7X@??@?m
@????2X@ ?W?B?
@$??~j2X@`??P??
@????A.X@??4??@-???+X@??4??@d??~?(X@??4??@????'X@???B?
@??Q?%X@ ????
@?D??$X@`?"???
@xN?@?#X@?????
@?????"X@@???
@??? 5!X@?aMeQ?
@???IX@@0G??@???gX@ ?_>YQ@?y??dX@`?6???@???@?X@?k?}??@?$??X@ j?? ?@?3??OX@ ?t[@|0)>>X@ ?_???@xE???X@??$??@??Q?(X@ ?kA??@?? X@?C?H @?k_@/X@?G?z@??,X@?1=a?'@?|?qX@??Z'.w@ ????X@?!???@?+??2X@?Xl???@L??
X@??{*??@?$??	X at 0:??8?@`?>X@@???@?
??:X@???
??@8? UX@ ??TN?@xE??? X at P???h?@???E?W at 0F??j"@??r???W@??|@?S@?????W@??0???@x?n?|?W@`?zk`K@?0??B?W at pC???Z@`??>??W@ ?mR??@?_[???W@????)?@cA?W@`?ri?b@?(?A&?W@?G,y@?? ?W@ ?}?@?
b?k?W@ 0??@?+??2?W@??/??@W@??W@d??!@??:M?W@?{F"4?@????Z?W@`?~l??@????#?W@?'f??@???V?W@ ????@L4H?S?W@?
1^??@?????W@???A?G@`?? ?W@ ??SG@?SW>??W@????Zp@8k??*?W@@?+?@?V????W@??????@ ?> ??W@??.o?@x?E?W@??????@??? ??W@ 1Bx??@??L?D?W at pg??RW@???~P?W@?;?$@?V????W@?T?2@L1AG?W@?A??@$?J %?W@???"M?@P
?g?W@????Z?@?k_@/?W at P???"?@??????W@???A??@L?????W@?r????@?????X@ 6??:@$???X@??/?2@xKr??X@ ?!??#@ ?> ?X@?@d?&@????AX@?UId?@8??X@?R??q?@???@?X@ ??TN?@9???#X@ 2?@??? 5%X@ 2?@T???)X@??V?I?@8qr?C,X@??_>?@`?>.X@???T?@????.X@?+?`p?@L.??:0X@ ??S@d???0X@`?zk`@?SW>?1X@?S?@`?_??3X at 0K;5?@ ?{?4X@?????@tT5A?5X@?????@?????>X@??^@ ??^?BX@?????
@L4H?SFX@??N$??@\?gA(HX at 0i?7?@]?@?HX@ ?????@$??IX@`?H?s?@tT5A?IX@ 0??@??`JX@ ?-s??@??X??JX@?`?d?@xB???KX@?H? ?@??~1LX@?l???@`???MX at pC????@????ANX@????(?@H0?[OX at pP?L??@8????PX@ *???@?|?qXX@??????@?B??[X@??????@????\X@@???@?+??2_X@??]? @??x!`X@????@????`X@??x?n?@?	??$cX@?R??q?@??~1dX@???
??@|0)>>eX@ ?uT5?@???@?fX@?S??@?
??:hX@ 2t?p@h?2?}iX@ ??TN[@?????kX@?aMeQ8@?H???qX@??M??@??A?yX@??,?s?@??h ozX at pD?K??@?b??	{X@??3??|@??? ?|X@`~nh?N@?$??}X@????);@8??}X at P?.??"@L????}X@?G?z@?Y?>?}X@?1=a?@????}X@ ?%??@??J~X@?
/??@t?w~X@?+?`p?@?%r??X@??	.V4@4???#?X@??
DO:@t-Z???X@?;?$@?e???X@????@?$???X@??M??@ND???X@??^?@?#??X@???$??@t?? ??X@@"???e@ ?A??X@??@?m?@~? ??X@??(?A?@8t??P?X@??B??@?D???X@?_?|xV@L=By?X at P???6P@`?>?X@?^???0@l??3?X@????b	@??N?X@@?????@8qr?C?X@?u?!h@?E_A??X@??????@?;??X@??E?x@?<??t?X@@?~?[@?????X@?u?!?
@??e???X@??
@L7?A`?X@??	.V?
@H?>??X@@?74e?
@'???X@ ????y
@?b???X@@??p
@?g???X@?? ??]
@??? ??X@`??n?
@@?]???X@?,??\n@?~NA~?X@`?ri?b@?????X@@ 7?K@@?@?w?X@??$?2@0,?-?X@ Ad?&@?????X@???Dh$
@?d?X@@?&?O?	@?d?X@ ??qo?	@?;???X@?b???	@d?????X@???Q?	@??`?
?X@ <??	@ ?A??X@ d(	@?H????X@?}??@`?>?X@ ` ??@L?#~??X@??F??@??L?D?X@ ?W?Be@??v???X@?p=
??@ ?> ??X@?Wv??z@??v???X@??-$`@t?~k?X@ ?viC@??????X@ ??s?&@???f?X@????	@??? 5?X@?,?IE?@???? ?X@?r????@8? U Y@? ?H?@L1AGY@ ?????@???A{Y@`??n?@8w?^? Y@ W?6?o@?_[???X@??x?n@8???X@`?6???@???@??X@ ?Y?@?n??;?X@ ?ZH?@?????X@??Q??@????kY@?0??@8k??*Y@?6????@`|?/Y@??|?R?@??aQY@????0?@xrM??Y@?dp???@ ?A?Y@??4???@P?>?Y@?i? ?@~? ?Y@?Wv???@ ?? >Y@??U?P?@`??>?Y@ ?u7?@d?*?3Y@`??n??@?????Y@??	.V4@4??@?Y@??p=
7@P4`?Y@?? ??]@????LY@??Y5q@?e??Y@??(?A?@oB@Y@`?"???@8n1?7Y@`????@???IY@ Ad?&@?B??Y@??????@ZH??Y@ ??qo^@?????Y@?????~@H???	Y@ ?X??@?V???
Y@ d?@??E_AY@`?????@`??
Y@@"????@?b? ?Y@? ??*:@???!6Y@@????@H?@1Y@?"??d@?
j??Y@@
??p=@?5???Y@ ???Sv@t!V?Y@`y??@?8?~?Y@@?2???@?????Y@?=Ab??@8t??PY@@+1??@8_???Y@?u?!h@???^aY@ oG8-X@?z??mY@`??m?3@tT5A?Y@ ?W?B?@d?{??Y@?8????@xR~R#Y@??n?|R@xE???$Y@?B???4@?K?A?&Y@`??n?@$?6?D'Y@?3j?J? @??_?'Y@@?2??? @P?>?(Y@???(y? @8k??**Y@`I??@??\??*Y@?Xl??@x` ?C,Y@@??? @xrM??,Y@???$?? @??? ?4Y@???*?7 @L???n6Y@@`W?????|Q?_7Y@ ?O??????????7Y@@???Q???D??8Y@ >x????$???8Y@???????`???9Y@@?[='}???$??9Y@@?z?G????? 59Y@ ?X?????oa?9Y@ h?
????????:Y@?UIdd???t"?T;Y@?????A??????Q<Y@??G? ??xrM??<Y@@?:??????5x_?<Y@ ???M?? ?? >9Y@ ????+ @??E`?8Y@@???Q @9???7Y@`??P?p @8t??P7Y@`???"? @?D??4Y@ oG8-? @8en?4Y@ ????? @xR~R3Y@ ?u7/@?s}3Y@ 0?P@d?{??2Y@ ?K??h@???>?2Y@ l?<?@|Q?_3Y@`?vj.?@?+??23Y@ ?????@0>?^?3Y@????0?@?5???4Y@@"???%@tT5A?5Y@`?&?>@??)7Y@ T^M@?D??8Y@??p=
W@ ?> ?;Y@???)?c@ ???CY@`I??D@`?[>?CY@?u?!(@oB at CY@??E??@?B??CY@?u?!?@?e??DY@@)???@?????DY@@???@4}v?uLY@ $?? @|?Y?HPY@?"1?? @PqNQY@?????? @PqNSY@ K;5?[ @4D?TY@????); @????ZTY@ \???( @?
j??TY@ ??p=
 @????UY@??Yh?????%r?UY@?fffff???????TY@?~nh???d???TY@???Q????%r?UY@????0u?????~PUY@@ 7?K?????IWY@???C6???`?_??WY@?3j?J~??P4`?XY@?N??	??H???YY@?p=
????x?EZY@@????y?????[Y@ ??"M<???[?~l\Y@??F=D#????JbY@??Q????`?"??bY@????0u??d???dY@?UIdd??`??>?eY@?fffff?????@?fY@?{??vw??tHj?dgY@??Q??????chY@@0G?????????sjY@ ?ZH??????lY@?D?K????8t??PmY@?3?Ib???4w??\nY@???Q???d?	??pY@@?[='}??P%@qY@??"??i??L(D?!rY@ ??"M<???e??xY@ {?G???d?{??~Y@@??Yef????? 5?Y@??	????x?E?Y@?D?K????H0?[?Y@ ` ????????k?Y@?6???`????A^?Y@ ???M??8?????Y@ H,??????^??Y@??????????>??Y@@:??8???x` ?C?Y@?w?~????? ?}??Y@?=Ab????? ?}??Y@??4??????e???Y@ 0?P???|?q?Y@@7?????P?>??Y@@?.??????H?}?Y@@
??p=??t9% &?Y@?n???????H??Y@???9L?????=?Y@??Q????|Bv???Y@? n/???????{?Y@?
???????????Y@ ?p=
???L1AG?Y@??Yh???????>??Y@ ??l??? ?}??Y@ 0?P??d????Y@???9L????? ??Y@ ??l??H?>??Y@ :??8???8???Y@??Yh?????d?Y@??G??????d?Y@ ????4??L(D?!?Y@ ??&???8_????Y@ J????x<-?p?Y@ ?.?.????M~??Y@ ??(\???$?:?v?Y@ ?m??P@???Y@ ?z?G??L1AG?Y@ j1x???8?Q???Y@ &???????????Y@ ^G????oB@?Y@ ???(\????????Y@ ?<L???H?}?Y@ b??m???4?????Y@ F)!XU??4_%??Y@ ??2??E?>??Y@ H?z?????+???Y@ ?Q????$[A??X@ /??????????H?X@ ???i??|o??X@ ` ????$????X@ <
??p??l\???X@ @?rJ??????@?X@ ?????}?(c`?X@ ???E}r????~??X@ ?? Z+z???D???X@ ?%9`Ws??? ???X@  ?G?zT?L:??l?X@ ?an??<}???X@ ???c??????>U?X@ X(????? ? >??X@ \???(???t????X@ ????7????(@?X@ ?zO????x` ??X@ ,??A??$?6?D?X@ ~???-???cw???X@ $??P??l?J>v?X@ ?Q?U????? l?X@ fffff??????A?X@ ????$[A??X@ j?? ?????i?X@ r75???P=????X@ ?#?????o???X@  a????<???	?X@ ?U?0???$[A??X@ /??????|c ?qY@ ?X32???????nY@@\???(??8?Q??nY@?w?~???? ?|nY@?R]??????w*??nY@ ????r????? ?nY@???(y5???V???nY@?0~?????E_A?nY@@??????`?c@?mY@ ?sCSv????>jY@ 7?x???? ?s`9iY@@??$??????U?ZhY@?,??\n??PqNgY@??ajK]?????@?fY@@??r?X???P??dY@@??r?X??`?[>?cY@?6???`??W@?bY@ ??l??????{_Y@ 7?x?????e??^Y@ &p?n????ng_y]Y@@?B?_????@?\Y@@?S;?T?????8\Y@ ?_?????t<f?2YY@@???????,YY@?cz????Lu?YY@??-$???d?: ?YY@?,?IE# @$??}8ZY@?????A @??X?+[Y@?'f?j @t?? ?\Y@     ? @??,]Y@?*???? @?z??mgY@ ?Y? @4?EaiY@ l$	?? @8?]?jY@??Y5? @??? ?jY@ ?Y? @??^?kY@?6???? @xQ???lY@???"M? @x<-?pqY@ ??$????x!?qY@ ?|?R???d????qY@??????|c ?qY@ ?X32????A$?X@ ?S?D???@? ??X@??]gE????Q?(?X@?+??A????????X@??]gE??(/2??X@?p=
??????$>w?X@ S?K????Y?>??X@ ????8????a?X@ ?Q?U???o???X@ r:?V??????^a?X@ Ct	??T:X???X@ .?????P<???X@ ???*???????X@ ???????qo~??X@ ?U?0????qo~??X@ ??p=
????A$?X@ ?S?D???@?????Y@?"2?????????U?Y@@?~l?_??$?	??Y@???*????$????Y@ ?c??%?????^??Y@?fffff???????Y@@:??8????d?Y@@r??9????d?Y@?Dio????@?????Y@?"2?????d?s~??X@ L(D?!??0e????X@ ?)? ???0DN_??X@ `?4?????y8???X@ 4-?2??4P?>?X@ ??8d????????X@ ?an????????X@ fc%?Y??X??!??X@ r:?V???D??,?X@ l??^??U???X@ ?Nw?x??*A*?X@ ????????z???X@ ?f+/??????@?X@ ?[??b????5!??X@ X"P?????>??X@ mr?????[?~l?X@ p:?V???D????X@ ??n?o??d?s~??X@ L(D?!?? 2?Y@?q?????LLb??Y@ ??Q????{
?q?Y@?R?Z???(z?c?Y@?t??.W?T%??R?Y@`?D?AF???:M?Y@`}<???8?? n?Y at p1?q? ?,^,?Y at P?P??B????A_?Y@?+?`p}??F???Y at p7????????^??Y at p$?`S??h?????Y@???????????Y@?5[y??? 2?Y@?q???????5??Y@@&??H?8???zY@@????<???;Y@`?"?&?d???
Y@ ??lu9?<?e?Y	Y@????K?h??	Y@@"???e?xu??Y@@?v|??<?E~?Y@???"M??r??Y@ m?OT??h??>? Y@ a?N"????m?R?X@`d~??h?????X@`BZc?i?u???X@?i? ???T2 T?X@?b????QL? ?X@??t><??d?6???X@ ????????_ Y@ ??????$?`6
Y@??Q????Q?(Y@?_?|xV???
a5
Y@?N?????]??y
Y@?1?q??h????
Y@?]??????I~?
Y@ ?????5??Y@@&??H???>??Y@ ?$"?K??P?>??Y@ ?X???t?w?Y@?A??U????5x_??Y@@"?????? ????Y@ h?
???~? ??Y@ ????r????M~??Y@@?B?_??PCT???Y@ #?G???`???Y@?]k?SU?????`??Y@ 0????????r?Y@?????????D???Y@ ??????9????Y@??????????d?<?Y@?:U?g$????+???Y@@??N?? ?A??Y@??E?x???V???Y@??U???8t??P?Y@?????8?? ????Y@? n/??? ?A??Y@ ?sCSv??P?>??Y@ 7?x????P%@?Y@@)??@??Lu??Y@????0u????? ??Y@ j? ????4_%??Y@@0G?????P4`??Y@@OI???x!??Y@? n/???`???~?Y@     ???xR~R?Y@????
S???<??t?Y@?N??	????>?Y@?:3P???H?_{?Y@ ?8??????????Y@@???TU????>??Y@ ?$"?K??Ly ??Y@@!u;?????????Y@ d?????F?Y@ ??"M???????Z?Y@?"M?|??????#?Y@ ???C??????{?Y@???A?'?????`??Y@??$?2????????Y@ E,b?a??`?? ?Y@ qt?????t?? ??Y@ ?~??????f?Y@??.?.??xR~R?Y@ ?sCSv??`?_???Y@@?2???????????Y@?Y????????????Y@@?????xQ????Y@??	????$?????Y@@???????PCT???Y@@?????????? ??Y@@?t"???????Y@?mQf????<??t?Y@???????xrM???Y@??<?;+??`?[>??Y@???9L??L???n?Y@?\?M
t??d?6???Y@@?v???0>?^??Y@?D?????tWv???Y@@???Q????.???Y@??(\????(???Y@@??n????p>??Y@ 0?P???????Y@????0u???w*??Y@ h?
????E_A??Y@?
1^????4w??\?Y@ H,???uX???Y@@??{????p>??Y@@"????????,?Y@?R]?????Z?!??Y@?3j?J~??Hqh?Y@?t??g??L???n?Y@ ???????t$????Y@??G? ???B???Y@      ???
? x?Y@ ?W?B????0??B?Y@ {?G?????@??Y@?b??????????Y@?=
??p???|?q?Y@@?~l?_??8? U?Y@@HO?CD????oa??Y@?Z??-????????Y@?N??	???????Y@?0~????PqN?Y@@&?v??????????Y@?j.7*??Ly ??Y@@!u;???????U?Y@ :??8???|Q?_?Y@ :??8???L?????Y@?=
??p??x??^?Y@?t?Oq??H?`??Y@??il???xQ????Y@???Q???t!V??Y@??J????? ????Y@????>????"1A
?Y@????`???????Y@ r75?????M~??Y@????Q??$??~j?Y@?m?k????_[???Y@??????????A?Y@?fffff??????Y@ x_????t0? ??Y@ 4?Ib???`?? ?Y@???????tT5A??Y@?t?Oq???"1A
?Y@ ??&???<??~?Y@?E?x???L?d???Y@????I~???z??m?Y@??M?????v?>X?Y@@x_??????????Y@??????????oa??Y@?_?|xV????U???Y@?
/????`?>?Y@???Q?????J?Y@@??"j??????^(?Y@ ???M??h?ba??Y@?A??U4?????g?Y@?A??U4??????s?Y@?,?IE#??t!V??Y@ ????????????Y@@Y??????6?[?Y@ ??#c????~?^??Y@?t?3E???
1^??Y@ ??L?????9[@h?Y@?b*???????n???Y@@?6??8???d?Y@@[#?q0???d?Y@?	?8???????U?Y@ :??8?????U??UX@ '0??m @??,UX@????I @$???TX@`?&?> @?!? ?SX@?
1^?j @????RX@ ?_??? @*?~?RX@?P?L?? @?????QX@ ?ZH? @L?'?NX@?Kr??&@?0??BMX@??-$`@????LX@?Q??k@H???IX@?D????@?z??mGX@ ???!?@?????FX@??	.V?@d?{??FX@?Xl???@8Vb??JX@ ??qo?@???!6RX@?,??\?@Q???TX@ ????M@????UX@`rjg?:@??>VX@??U?P? @?_[??UX@ ????r @??U??UX@ '0??m @???@gY@ ?????
???d?<Y@@???v?
??h?^`Y@???B|
?????Y@`a?9?	??L!uY@?? Z+?	?i?Y@@??p	??t???Y@`??U	??/??Y@?B??????qo~?Y@@s????P??5Y@?Q????h???Y@?V??d?LLb?Y@@?????p>?Y@@?*????$???Y@???y??<??"Y@@'0?v???l?Y@??-$`?d??~?Y@????K?P<??
Y@`???=?x` ?Y@??G?:?d????Y@`I??D???t!VY@??p=
W???=xY@?1?q?|o?Y@?%??H?P<??Y@ ??Q??????Y@??M??0???,AFY@??Y?E?`X?|Y@`p???x9??cY@???????$???Y@@???	?P%@Y@ ?C?H 	?????Y@??A?V	?d??QY@@'0?6	??~NA~Y@?*????	?xx???Y@?? ???	???l?Y@?}??
?|K9_?Y@`???)
?<?I/Y@`?f?b
?????Y@?s`9B?
?PU??XY@?
????@gY@ ?????
?8? U?W@,??Y@x??^?W@ ??s?F@????U?W@?@?t9@xQ????W@??_>@`????W at P???h$@??_??W at P????,@??U???W@??0??@8S!??W@??$??@Lu??W@??w?'?@?e???W@?`?d?@uX???W@?i? ??@?
? x?W@?M?Ec@8? U?W@,??Y@P????X@ ??#??l???X@`~nh???xu???X@???'*???w?~??X@???????|3j?J?X@?}????h?????X@`??????d?X@??l<????=??X@`I??D?h?????X@???C*?P}>??X@?#?w~q ?()? ??X@ ??o6 ??Q??B?X@?Z??- ?????X@?????  ??#??X@`k??? ??.???X@ 8??_, ?P????X@?????? ??9[@h?X@ ?K??? ?h?R@??X@@????? ??E?>?X@@????? ? ??_w?X@????h$??1 ??X@@
??p=?$???{?X@?%9`W??h?2?}?X@`a?9??????k?X@ ????+????@-?X@?%??H?d?VA?X@ Mh?Xr?<?I/?X@ W?6???h?>??X@??X???P????X@ ??#?9???sX@ ?|?R?????X??lX@ B	3m????^?kX@ ?@ C????alX@??ypw????_[??iX@?"?4????????gX@ :??8????
?.gX@ ;U?g$???6?[eX@?
??????%r?YX@???(y5??$?:?vWX@????E??L??VX@????@????!? ?SX@??(\?????Q*?	PX@???C*??d?{??JX@ O?z1T?????VGX@@ 7?K???|~JX@? n/????3??ONX@?
/??????x!PX@???A??????~1TX@@????y????FUX@@?????$???]YX@?/?x???tWv??^X@??Q?????G?aX@???????8k??*bX@ ?t[?????@?bX@?}????L%<??kX@?f??}?????H?oX@?p=
?????J?hrX@ &p?n^???+??2zX@?6??????`?"??{X@ ??&
????~?zX@?m?????T???yX@?w?~????PqNyX@?_??`??x$^??xX@???W???Q???xX@ n???W??Q???xX@ ??????xN?@?xX@??
???????_?wX@??.?????$??~jtX@?F^????9???sX@ ?|?R????????X@@?S;?????????X@???(\???d?????X@@)??@??h??}q?X@??A?V????
j???X@????h$??PI??&?X@???&???????@?X@??G? ???z2???X@ h?
?????l??X@?6???`???b.?X@@#/k???<?????X@@6?????????r?X@@:??8????T?~O?X@?fffff??????X@@?S;?????:????X@ ?ZH????F???X@ ??lu9???6?[?X@ ?t[???????X@???r?????? ?X@?cz????|<????X@ qt??n???p>??X@?/?x???8???z?X@@???????<??A??X@@Y??????a??X@@??pZ???PL? 3?X@?
1^?j???-W?6?X@?G??????X@?T????????F!??X@??X????|<????X@???{?????(@?X@?%9`W????=x?X@ =??tZ??<??@f?X@??v???|?Y?H?X@?p=
?????Q?G?X@ ??lu???Pd????X@?&?v?)????$>w?X@ w?h?h???Ws?`?X@ ?O???????i?X@?z?"0???d?????X@??*?3R???????X@@A?>???????Y?X@@\???h??T?^
?X@?????S???t????X@?
1^????N^??X@?_?|xV???T?~O?X@??Vc????????X@@?S;????`?? ??X@@=E????^a???X@@???????h o??X@@7?????????N?X@????E?????>??X@ ???????xN?@??X@@??{s??xR~R?X@@????????z??m?X@?ffff???fL??X@?????????? ?X@????E??xN?@??X@ ????J???`6??X@ ?????????>?X@@?????????"??X@?
/???N??;?X@@7?????`?? ??X@@=E?????? ?X@??	??@ ?k^?X@?
1^??@L??X@@'/2?@ ?> ?X@??????@?????X@???*??@P0?AX@??$??@fL?X@ ?K???@H?>?X@?Wv???@cAX@??	.V4@??T??X@??-$`@H?>?X@??????@??`?
X@@M?p?@????kX@??]g?@`??-?W@`?"?&@L
,?)?W@`???Z0@?9[@h?W@ ?O??<@?\???W@@?.??"@???@??W@?????>@0???D?W@?'f?j@?E_A??W@?n??@8h?>?W@`?"??@8Vb???W@?w?~?~@ZH???W@@F??jb@$????W@?;?y?Y@???I?W@`h?N?H@?|~?W@?'f?*@???@??W@?*???@ ????W@`???(\@`?_???W@???%?8@????? X@@?.??"@???~?X@? ??*@?	??$X@`U?@P%@X@??M?@t?wX@??Q?@$?6?DX@??M??@ZH??X@`?~l??@$??~j
X@ ???Sv@?i???
X@`?zk`@??? ?X@????/?@$??}8X@@?*??N@??r??X@ ????%@4?9A?X@ ??s?@$???]X@ ??r??@???gX@???B|@?(?A&X@`?vj.7@??? ?X@??	??@      x   TC?
?K at pT?d(?(?
?0?K at 0!?1?4?          |?m?(?K at pT?d(?|?,C?K@? ???%??\??k?K@?!??????}?K@ m?OT??TC?
?K@??=?$??,?	???K@?X5s;? ?A|`?K at 0!?1?4?,????K@??k&?<???`??K@???W???(?
?0?K@``?eM????????K@ T?^
?|?m?(?K at pT?d(?
d   ???0?K@$z?r9@<??bF?O@??H.?YB@   ?      6   E   T:X??$L@\.?;1?:@PX?eL at x<-?p?:@??:ML@?B]?:@Ld??L@?,????:@T4???L@???}??:@????L@?Ry;??:@|*?=%L@??*???:@|o?L@$?????:@????\?K@??
DO?:@xE????K@(?????:@?!<??K@?????:@?g@??K at x?q?Z?:@T
????K at x?4E??:@T?t<f?K@(?R?o?:@? ????K at L?g\?:@??B??K@?????:@?-?s?K@??:??:@T??;M?K at T@?? ?:@PL? 3?K@?I????:@|?m?(?K@??v?:@T1?~??K@??????:@x9??c?K@|$%=?:@|????K@(??>V?:@?H?}?K at x?u???:@P?|a?K@?????:@$?@??K@(????:@P^d~?K@??????:@ ?a???K@(k?C4?:@????B?K at X?????:@|`???K@?H?F??:@????K@???A??:@P}>??K@?V&?R?:@(??=$?K@?d?:@??????K@|?<??:@?Yg|_?K@(x
?R?:@P?|a?K@?Fu:??:@??????K at x?u???:@????H?K at PX?e?:@$A?
?K at P?????:@PU??X?K@??w?'?:@l?6??K@?=Ab??:@??????K at t?????:@?????K@???B?:@?_"?:?K at P?|a?:@?>??s?K@,i?7?:@(?o|??K@????:@?????L@|?b?:?:@?z2??L@?????:@L.??:L@(??=$ ;@P????L@?a?? ?:@|?<?"L@$?????:@|-??1$L at x9??c?:@(h??'%L@?I????:@T:X??$L@\.?;1?:@<??a?K@<?????:@ ? >??K at P?&?O?:@L.??:?K@?.m8,?:@|?(B??K@|??A??:@(&o???K@?]K??:@x~Q???K@$z?r?:@???@-?K at P??C?:@P?????K at PR`L?:@??d ??K@?q?&?:@x?0DN?K@(x
?R?:@??'???K at x?u???:@??(@?K at La????:@|i? ??K@|?m?(?:@t?V?K@?C4???:@<??a?K@<?????:@???0?K@??~7?:@???0?K@??H.?YB@??q5?%N@??H.?YB at T?t<f*N at L.??:TB@?)??.N@$W@?RB@,*?Z at N@|l???RB@??
?RN@(5??RB@???A^UN@(?.??RB@??[?eN@???SB@??#??wN@?K ?)SB@???~P?N@$?6?DSB@$????N@?~??@SB@???>U?N@ ?A?PB at 8?a?A?N at d?b?HB@<? ??N@??p?5B@??#???N at P
?=?$B@????C?N at xx???B at t?V?N@??B?B@??I~??N@?b??
B at P<???N@?!<?B@(????N@|!????A@?[<???N@?M?=??A at PU??X?N@|'f??A at T8???N@??????A at 4??#??N at d?????A at xu???N@<? ??A at T||Bv?N at x~Q???A@<??@f?N@<P?<??A@?!<??N@???}?A at PX?e?N@?!?A?A@?A?<??N@??????A at T8???N@??X??A at d??Q?N@? ?=?A@??????N@|fI???A at xx????N@?L????A@???i?N@?[<???A@?!<??N at P????A at P}>??N@????*?A@??B??N@??B?pA at La????N@|$%=eA@????}N at PR`LSA@??\5mN@??!?HA@????jN at d????GA@?,???cN at L+?@.GA@????^N@???@?EA@??d ?\N@<????CA@<??bFbN@?b.=A@???@-fN at 8??"N;A at PF\ qN@???|y-A@??>pN@?|?|?(A at d?ckN at PR`L)A@?`"bN@?E?>)A@$W@?^N@?l??(A at d???jVN@|-??1(A@?b??EN@$G:#A@|6?>WCN@ ? >?A@,kgAN at d??a?A@?ek}?@N at T
???A@?????@N@?,???A@????,AN at 0s??A@?????BN at T?3?YA@?,???CN@????@@?%?"?FN@?;l"3?@@????FN@?p $?@@(?
?0EN at T???r?@@p?r?AN at P=????@@P????AN@$P??H?@@??BN at hv?[??@@?j?#?CN@??B??@@?b??EN at P"???@@????IN@???8?@@P[#?qLN at P??|z?@@????BUN@ ?????@@\p?ZN@??????@@?????dN@?Hg`??@@T8??mN@? ????@@(?R?orN@|*?=%?@@???0uN@?`"?@@??-xN@?\?].?@@h o?wN@???;??@@?#??SpN@????@@|*?=%mN@????@@$[A?fN@??
??@@????`N@|?m?(?@@??d ?\N@? ????@@?????PN at P??B??@@P??C?JN@|*?=%?@@?T?~OJN@|6?>W?@@P??B?JN@??`?u?@@(n?@KN@?b???@@??\?CLN@??W??@@P[#?qTN@?/?h@@(????\N@?X?;?O@@Ty=?jN at z??C5)@@????mN@:?}?k!@@|????mN at d	kc?@@?I?pmN at z9??c@@x???kN@|c ?@@PO??hN@??}@@(???IgN@|*?=%??@?*?]giN@?U?????@ ?=~iN at x???A??@?X?;?gN@ ?bG???@?9"??lN@?a?? ?@???>U?N at La???v?@x?$?N@??I~?s?@?)???N@?@-k?@???W?N@ ???!b?@?v|??N at x???sZ?@|l????N at P^d~Q?@?8+?&?N@,?MF?A?@T:X???N@?*?w?7?@???A??N@?:q9^-?@<? ??N@??d?@?E~??N at P?&?O?>@T
????N@?^??a>@??q???N@|??A?H>@?,????N at H/?9>@??N@?N@??E}?/>@???A^?N at P?c*>@xE???tN at PO???=@?2d?oN@ ?????=@?:???nN@?|~?=@?+?P?N@??C???=@|?m?(?N@|*?=%o=@PO???N at P???Te=@??_>?N at d??a?J=@?H?}?N at TC?
D=@P}>??N@<#?&=@??????N@(k?C4=@?????N at p?Z|
?<@Ty=??N@??????<@???B??N@(?R?o?<@ ?A|`?N@?]K??<@x??C5?N at P??{H?<@?z2???N@,i?7?<@T?t<f?N@@
??<@P%@?N@(??=$?<@|l???O@(????u<@$???(O at 8???Zp<@?b.3O@???Z`k<@|fI??>O at T?T?	[<@x{?CO@?b*??K<@P???KO@?6?x?;<@8?!QO@???=<@(?o|?WO@??@<@h??dO@?b*??C<@?????dO@???f6<@TpxADdO@???B,<@?>??sbO@$???{<@???@,aO@ ??F??;@?<?|?aO at H/??;@(?.??bO at T?z??;@????fO@?Ry;??;@x9??chO at L??u?;@x??C5iO@??r???;@(??biO@?S^?;@$???{kO@????ty;@|'f?jO at x?n?|r;@?_?|xfO@?=??jb;@d*??cO@$qVDMD;@???"MhO at 8???(<;@?B?_?wO@?????6;@???A?O@|?<?:;@|??B?O at t??F?=;@xu???O@3???D;@?? v?O@???%?8;@<??bF?O@??C&;@$D???O at h??\? ;@PX?e?O@?w?~?;@h?^`V?O@?????;@?d?O@(h??'
;@??^?O@?????:@??ZC??O@$??E??:@?M?=??O@?????:@$;6??O@(~??k?:@?????O@??gx??:@??
??O@?qo~??:@?????|O@?2Q???:@?`"jO@?)???:@??bO@,i?7?:@h??}q_O@(?R?o?:@|'f?ZO@?>+?:@T:X??LO at X?????:@????EO@|?e???:@PF\ AO@????:@T?^
8O@?]K??:@?'??Z(O at P?&?O?:@P?>?"O@????k:@$;6?$O@?n??a:@|{??/#O@??9#J[:@??hUO@?v?1\:@PX?eO at T@?? _:@???O@<\r?)a:@PR`L
O@$}ZEP:@??7?a
O@????lP:@Lp??O@?NG?O:@$???{?N@(??9x>:@8?}?k?N at d?c;:@?d?<
?N at T?{/6:@Ty=??N@ ????-:@?ek}??N@????:@|i? ??N at P???T?9@$D???N@?????9 at P????N@ ?z??9@??l??N at xrM???9@?z2???N at 8+?&??9@???B?N@????(?9 at x?U?0?N@ ?={.?9 at P[#?q?N@?&M???9@????r?N@?z2??c9@(????N at PF\ Y9@??7?a?N@?Yg|_L9@???C6?N@'i??29@??7?a?N@,l? 39@?'??Z?N@????*9@(?o|??N@?1??89@??>?N@$z?r9@?????N@$?^F?9 at P"???N at x?4E?9 at d?? w?N at hv?[?(9@??;???N@l?`q,9@$?2?N@|???S69@??ZC?{N@?*?w?79@??ZC?cN@?????9@??'??[N@|???B9@???SN@???WC9@?<c_?ON@??-YE9@$??MN at L???hT9@<b??BMN@???X?Z9@@?Q?yMN@?O8??`9@?Q??BMN@?2Q??e9 at x{?KN@(u?8Fj9@?E?>IN@|*?=%o9@????FN at d	kc?p9@?>??sBN at P^d~q9@??0Bx>N@?/?p9@(?N>=:N at L?*??n9 at P?D?6N at x???sj9@?????4N@?2Q??e9@?p!?2N@??l?]9@$P??H4N@(r??9U9 at L?8??7N at 8? UT9@|o?;N@??#?D9@??U??8N at L???hD9@,??'N@?Z
H?S9 at h?{??%N@???#X9 at x??C5N@???]9@??I~?N@??`9@$W@??M at P?\?m_9@?-?s?M@??Pi9 at d*???M@??l?i9@(??{??M@??vh9@????9?M@ ? ?Sf9@?#?G?M@@??d9 at 8??cx?M@?4~??d9 at T
????M@Z_&f9@$8????M@????aj9@??ZC??M@???is9 at P}>??M@(r??9y9@???}??M@??
DOz9@?x#??M@?W??y9@??m?R?M@??Cv9@?????M@???m9@?T?~O?M@$????e9@?x??[?M@?
?Dd9@?J????M@?qo~?d9@??????M@???f9@?d?M@?t???i9@?B?_?yM@???}?y9 at d*??wM@ ?%??9@?????tM@??????9@(/2?hM at L?g\?9@???}eM@?ek}??9@??l?aM@?/??9@???C6\M@?_?|x?9@|?i???M@ ? ?S?9@$W@?2M@?U????9 at L+?@./M@?K????9@??l?+M@?C4???9@?}s)M at P7P???9@??3??M@??????9@<k?]hM@???X??9@??d#	M@?n.???9@$W@?M@????s?9@Q?|M at p'?_?9@?x?'M@??I?9@,??<??L@??5[y?9@?K????L@?Qew?9@???C??L@?m??2?9@|*?=%?L at PI??&?9 at Lm????L@?>+?9@??ZC??L@??G?)?9@<???L@???i?9@?E&???L@(?????9 at P^d~?L at P?\?m?9 at x~Q???L at t???	?9@??w?'?L@????r?9@(????L@??????9@(5???L@?M?#~?9@|`???L at T?????9@ ? ?S?L@?????9@?Q??B?L@$???9 at Lm????L@ ?A|`?9 at P?????L at 8>Z?1?9@??$???L@???~??9@??Y??L@H?]??9@c??K?L@??:?:@h???L@??)?:@|`???L at x??E?i:@?h????L@?T???t:@??E}??L@?B]~:@?z2???L at P?&?O?:@?M?=??L@$w?Df?:@??I?L@? ?=?:@??`?u?L@????B?:@??~7?L@??3???:@?qo~??L@(h??'?:@$?s}?L@??:??:@QL? ?L@?}s??:@(h??'?L@?A??:@?????nL@?&M??;@x??lL@H?]?;@$A?
oL@?
?7;@P???mL@$???{;@? ???gL@$???;@x9??cXL@??9?%;@Ty=?RL@$???';@|*?=%OL@???A?';@???^?NL at D????';@$?s}DL@?G,);@??
??-L at 4=((E3;@$>w??)L at T?X?;3;@x~Q??L@?]K?);@?_?|xL@(??9x&;@Ls+???K@?_x%?;@|ZEh?K at P???6;@??>$?K at d{-??;@??[??K at P???;@$?w~Q?K@?a?? ?:@P??|z?K@(?????:@|'f??K@<?? ??:@???@??K at t?????:@????K@??1ZG?:@??i? ?K@?U????:@$?s}?K@|?(B??:@?#??K@?J??q?:@|i? ??K@,?????:@?P???K@?^???:@?;O<g?K at x??C5?:@??VBw?K@???eN?:@??????K@??????:@<\r?)?K at L??u?:@?)???K at L?g\?:@xrM???K at xB????:@???0?K@??~7?:@
Name: Country Boundaries 2.shx
Type: application/octet-stream
Desc: not available
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20050602/c2bd4f6d/attachment.obj>
GEOGCS["GCS_WGS_1984",DATUM["D_WGS_1984",SPHEROID["WGS_1984",6378137.0,298.257223563]],PRIMEM["Greenwich",0.0],UNIT["Degree",0.0174532925199433]]
i   !Y                    AREA       N                  PERIMETER  N                  CNTRY_     N    &	              CNTRY_ID   N    &	              FIPS_CNTRY C                   GMI_CNTRY  C                   CNTRY_NAME C    (               SOVEREIGN  C    (               POP_CNTRY  N                  CURR_TYPE  C                   CURR_CODE  C                   LANDLOCKED C                   COLOR_MAP  C                   SOVEREIGN_ C    (               AREA       N    &	              LEN        N    &
          57.861         44.801                          52.000000000                          52.000000000TXTKMTurkmenistan                            Turkmenistan                               3714642.0000Manat           tum Y1Turkmenistan                                                      57.860564329                          44.801161214          14.716         33.878                          55.000000000                          55.000000000TITJKTajikistan                              Tajikistan                                 5382232.0000Ruble           tsr Y6Tajikistan                                                        14.715852826                          33.877518274          62.567         50.803                          61.000000000                          61.000000000AFAFGAfghanistan                             Afghanistan                               17250390.0000Afghani         AFA Y3Afghanistan                                                       62.566714340                          50.803211884          82.063         71.730                          77.000000000                          77.000000000PKPAKPakistan                                Pakistan                                 126693000.0000Rupee           PKR N4Pakistan                                                          82.062509295                          71.729721108          13.534         23.533                          79.000000000                          79.000000000NPNPLNepal                                   Nepal                                     19927280.0000Rupee           NPR Y1Nepal                                                             13.533725770                          23.533247540           3.636          9.206                          80.000000000                          80.000000000BTBTNBhutan                                  Bhutan                                     1586631.0000Ngultrum        BTN Y7Bhutan                                                             3.635557415                           9.205519077           6.235         16.395                          84.000000000                          84.000000000TCAREUnited Arab Emirates                    United Arab Emirates                       2061800.0000Dirham          AED N8United Arab Emirates                                               6.234608833                          16.394998837          12.222         42.012                          85.000000000                          85.000000000BGBGDBangladesh                              Bangladesh                               120732200.0000Taka            BDT N6Bangladesh                                                        12.222448558                          42.011911539          26.761         32.335                          89.000000000                          89.000000000MUOMNOman                                    Oman                                       2090308.0000Rial            OMR N7Oman                                                              26.760912109                          32.335191894         950.606        302.750                          90.000000000                          90.000000000CHCHNChina                                   China                                   1281396894.0000Renminbi Yuan   CNY N2China                                                            950.605830743                         302.749570946         173.820         69.765                          93.000000000                          93.000000000SASAUSaudi Arabia                            Saudi Arabia                              18099990.0000Riyal           SAR N3Saudi Arabia                                                     173.820025014                          69.765275912          19.680         37.558                          94.000000000                          94.000000000LALAOLaos                                    Laos                                       4722773.0000Kip             LAK Y1Laos                                                              19.680370041                          37.558287651         278.686        176.490                         127.000000000                         127.000000000ININDIndia                                   India                                    894608700.0000Rupee           INR N5India                                                            278.686050299                         176.489641579          58.120         87.347                         135.000000000                         135.000000000BMMMRMyanmar (Burma)                         Myanmar (Burma)                           43099620.0000Kyat            MMK N8Myanmar (Burma)                                                   58.120111881                          87.347230867          27.552         66.828                         137.000000000                         137.000000000VMVNMVietnam                                 Vietnam                                   71215210.0000Dong            VND N3Vietnam                                                           27.552036659                          66.827655226          15.129         21.994                         138.000000000                         138.000000000CBKHMCambodia                                Cambodia                                   9129576.0000Riel            KHR N5Cambodia                                                          15.128533102                          21.993997927           5.412         13.998                         158.000000000                         158.000000000CELKASri Lanka                               Sri Lanka                                 18321920.0000Rupee           LKR N7Sri Lanka                                                          5.412086188                          13.998372819          43.140         65.463                         159.000000000                         159.000000000THTHAThailand                                Thailand                                  57323780.0000Baht            THB N4Thailand                                                          43.140136149                          65.462497506          26.753         60.767                         162.000000000                         162.000000000MYMYSMalaysia                                Malaysia                                  19626380.0000Ringgit         MYR N6Malaysia                                                          26.753193554                          60.766751223           0.003          1.129                         169.000000000                         169.000000000MVMDVMaldives                                Maldives                                     11511.0000Rufiyaa         MVR N4        0.002738598                           1.128667344         153.002        416.254                         183.000000000                         183.000000000IDIDNIndonesia                               Indonesia                                188474200.0000Rupiah          IDR N1Indonesia                                                        153.001568484                         416.253867104           0.031          1.357                         196.000000000                         196.000000000SESYCSeychelles                              Seychelles                                   73000.0000Rupee           SCR N6        0.030891742                           1.356746799         161.770         75.773                         246.000000000                         246.000000000IRIRNIran                                    Iran                                      64193450.0000Rial            IRR N6Iran                                                             161.769889975                          75.773239289
BEGIN;
CREATE TABLE "geoserver"."country" (gid serial PRIMARY KEY, "area" float8, "perimeter" float8, "cntry_" numeric, "cntry_id" numeric, "fips_cntry" varchar, "gmi_cntry" varchar, "cntry_name" varchar, "sovereign" varchar, "pop_cntry" float8, "curr_type" varchar, "curr_code" varchar, "landlocked" varchar, "color_map" varchar, "sovereign_" varchar, "area__14" numeric, "len" numeric);
SELECT AddGeometryColumn('geoserver','country','the_geom','-1','MULTIPOLYGON',2);
INSERT INTO "geoserver"."country" ("area","perimeter","cntry_","cntry_id","fips_cntry","gmi_cntry","cntry_name","sovereign","pop_cntry","curr_type","curr_code","landlocked","color_map","sovereign_","area__14","len","the_geom") VALUES ('57.861','44.801','52.000000000','52.000000000','TX','TKM','Turkmenistan','Turkmenistan','3714642.0000','Manat','tum','Y','1','Turkmenistan','57.860564329','44.801161214','00000000060000000100000000030000000100000070404E25B23571D1D4404259FF2E48E8A84050296B3354C122404259FF2E48E8A8405028CA600B0292404258319C5A3E3840502811DFFC547A404254F9FCB0C0284050277BBF93FF2640425174FF865D7C40502707BFE7E1FC40424CCCA2DB61BC40502755219A847C4042489F1F14983C405028586013660E4042441B21C475E840502883BE6601BC40423E41C3EFAE784050280FA15DB33A40423A0FA15DB33840502760807357E640423638C111ADA84050267CFE586014404232CEFED63454405025353F7CED9240422F49BE8FF328405021873FFAC1D240422653E2D6238C4050203AFFB04EE8404223E8FF327AA840501DD91EEAA6D24042202D6238DA3C40501B562174C4CE40421F7E02645E504050169CBEE807BC40421D8B827FA1A040500A886162F1664042151561911490405006144028E4FC40420FC903EA704C404FFD27A20578E44042050342AA9F7C404FF6AEE2003AB8404204E7FF583A54404FF1C9FF92F2B84042040C4156E264404FE693C03BC4D44041FE6AC215B9A4404FE26AC215B9A44041FD4762952090404FD959817B95A44041FC43FE5C91D0404FD3E8FF327AA84041FC0D3CFF64D0404FD110FD7E45804041FC1682F94424404FCE787CE95FAC4041FBD6BEBE1650404FCB84C271FFF84041FAA821F29910404FC66AC215B9A44041F57E02645E50404FC2EA209AAA3C4041F3927D45A5FC404FABD6BEBE16504041EDB940FECDD0404FA89A8049667C4041ED15831F03D0404FA5DDC1E7967C4041ED0342AA9F7C404FA2E9FF0CBAF84041ED27C3936828404F9EC144028E504041EDA7008A697C404F9A2AFDDA8BD44041EE4ADFF822BC404F8FC200C0F0204041EE7000431BE0404F8D6BE37DE9384041EA7CE0FC2EBC404F9443FE5C91D04041E1CFFEB074A8404F97A4BDBA0A544041D638C111ADA8404F919042D8C2A44041D38DDE7A743C404F8D7BBF93FF244041D11E5C0B9990404F8CB5DCC63F144041C7377E1B8ED0404F8FED634549B84041C515831F03D0404F8DBDBE3C10504041BA7D028A1DFC404F8B1C219EB6384041B752C16DF3F8404F86784230FCF84041B70A02B84124404F82F32378AB0C4041B6C122749F10404F7E38C111ADA84041B539C0EBEDFC404F76144028E4FC4041B12C40D0AAA8404F739FFD60E9504041AFE481F53824404F710C3D25247C4041ADC243DCCEA4404F6B20C069E7FC4041A97E3D1CC100404F5D10C2C5E2CC4041A0FA1E3EAF68404F50A38327674C40419CE7BC3C5BD0404F465881A1555040419E4ADFF822BC404F43927D45A5FC4041A11A005C4650404F41AB9F559B3C4041A30A02B84124404F3C19C17225B84041A4CEC41DD1A4404F36AF038E29F84041A1EB7CBB3C80404F348CBD1244A84041A011FD5885D4404F319042D8C2A440419D1540032550404F2E38C111ADA84041996BC1EFF9F8404F2B64E054690C404195C243DCCEA4404F27F383F0BAE8404192AFBC1ACDE0404F230C3D25247C404199C8E25C810C404F228F217093104041A0CCA2DB61BC404F14F102363B244041AAFC3F811F50404F10F7C243DCD04041AF1C7DE5082C404F105ABC0E38A84041AFF67F4DBDF8404F094784230FD04041B5C243DCCEA4404F05774256BCA44041B87A7C9DE050404EFEEEBF65DBFC4041BABC9CD3E0BC404EFB9BA1B196104041BAC5C13FD0D0404EE8A3BDDFCA004041B59DFDAC68A8404EE62F837B4A244041B4B11C6D1E10404ECC43FE5C91D04041B8DA0168B5CC404EC9CFFEB074A84041B9B4C3C18B50404EC3A4BDBA0A544041BDEB2074EA8C404EC06CFC829CFC4041C13543AEAB78404EB9309C7FFDE84041C69CC319C5A4404EB6F4BE835DEC4041C702BC72E274404EB001DE2691644041D16BC1EFF9F8404EA5EFE0CE0B904041D073BC903EA8404EA36640A6B93C4041CDBA3CA7503C404EA076427C7C544041D0FE82517E78404E9DD9018E75784041D4D12018A43C404E9D8023A6CE344041D89CA18BD664404EA18BBD3804544041E883C297BFA4404E9E5881A155504041F218BD66277C404E9CE7BC3C5BD04041F3B23DD54DA4404E9B17BD8BE7284041F7FFBCE4217C404E99BDBE3C1050404208DA3C211880404E9BC47E49B1FC40420DE6BC621B80404E9C5604189374404211EB4202D9D0404E9C43DCCEA290404216E581CF7878404E979B8023A6D0404224B13DFB0D50404E94D12018A43C404235B91F70DE90404E9841A261BF38404248D362E90364404E95553EF6B5D4404250EC41DD1A20404E93ADC0980B2440425340A2877EE4404E89507E9D94D040425344FE36D224404E779B8023A6D040425329FE004B80404E65F0025BFAD44042530E7FF583A4404E555E41D4B6A8404252E0FC2EBA28404E5206C00DA1A8404252D801B43528404E405AFF2A172C404252B380CB6C7C404E2EAF038E29F8404252A140570824404E2A663C74FB544042543AC0C62E4C404E25B23571D1D4404259FF2E48E8A8');
INSERT INTO "geoserver"."country" ("area","perimeter","cntry_","cntry_id","fips_cntry","gmi_cntry","cntry_name","sovereign","pop_cntry","curr_type","curr_code","landlocked","color_map","sovereign_","area__14","len","the_geom") VALUES ('14.716','33.878','55.000000000','55.000000000','TI','TJK','Tajikistan','Tajikistan','5382232.0000','Ruble','tsr','Y','6','Tajikistan','14.715852826','33.877518274','0000000006000000010000000003000000010000000A4051E6FC71D60630404259FF2E48E8A84051F7018E757928404259FF2E48E8A84051F5EFBF401C5040425896C3FC43B44051F47F4128BF3C404257A1016CE7884051F206C00DA1A8404256CFBFC6540C4051F095FEDA661440425662C343B7104051EC7EFE0CE0B8404255FEFBF401C44051EB573EAB367C404256877EE4E26C4051E760FE47991C40425952E2FBE33C4051E6FC71D60630404259FF2E48E8A8');
INSERT INTO "geoserver"."country" ("area","perimeter","cntry_","cntry_id","fips_cntry","gmi_cntry","cntry_name","sovereign","pop_cntry","curr_type","curr_code","landlocked","color_map","sovereign_","area__14","len","the_geom") VALUES ('62.567','50.803','61.000000000','61.000000000','AF','AFG','Afghanistan','Afghanistan','17250390.0000','Afghani','AFA','Y','3','Afghanistan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
INSERT INTO "geoserver"."country" ("area","perimeter","cntry_","cntry_id","fips_cntry","gmi_cntry","cntry_name","sovereign","pop_cntry","curr_type","curr_code","landlocked","color_map","sovereign_","area__14","len","the_geom") VALUES ('82.063','71.730','77.000000000','77.000000000','PK','PAK','Pakistan','Pakistan','126693000.0000','Rupee','PKR','N','4','Pakistan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
INSERT INTO "geoserver"."country" ("area","perimeter","cntry_","cntry_id","fips_cntry","gmi_cntry","cntry_name","sovereign","pop_cntry","curr_type","curr_code","landlocked","color_map","sovereign_","area__14","len","the_geom") VALUES ('13.534','23.533','79.000000000','79.000000000','NP','NPL','Nepal','Nepal','19927280.0000','Rupee','NPR','Y','1','Nepal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
INSERT INTO "geoserver"."country" ("area","perimeter","cntry_","cntry_id","fips_cntry","gmi_cntry","cntry_name","sovereign","pop_cntry","curr_type","curr_code","landlocked","color_map","sovereign_","area__14","len","the_geom") VALUES ('3.636','9.206','80.000000000','80.000000000','BT','BTN','Bhutan','Bhutan','1586631.0000','Ngultrum','BTN','Y','7','Bhutan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
INSERT INTO "geoserver"."country" ("area","perimeter","cntry_","cntry_id","fips_cntry","gmi_cntry","cntry_name","sovereign","pop_cntry","curr_type","curr_code","landlocked","color_map","sovereign_","area__14","len","the_geom") VALUES ('6.235','16.395','84.000000000','84.000000000','TC','ARE','United Arab Emirates','United Arab Emirates','2061800.0000','Dirham','AED','N','8','United Arab Emirates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
INSERT INTO "geoserver"."country" ("area","perimeter","cntry_","cntry_id","fips_cntry","gmi_cntry","cntry_name","sovereign","pop_cntry","curr_type","curr_code","landlocked","color_map","sovereign_","area__14","len","the_geom") VALUES ('12.222','42.012','85.000000000','85.000000000','BG','BGD','Bangladesh','Bangladesh','120732200.0000','Taka','BDT','N','6','Bangladesh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
INSERT INTO "geoserver"."country" ("area","perimeter","cntry_","cntry_id","fips_cntry","gmi_cntry","cntry_name","sovereign","pop_cntry","curr_type","curr_code","landlocked","color_map","sovereign_","area__14","len","the_geom") VALUES ('26.761','32.335','89.000000000','89.000000000','MU','OMN','Oman','Oman','2090308.0000','Rial','OMR','N','7','Oman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
INSERT INTO "geoserver"."country" ("area","perimeter","cntry_","cntry_id","fips_cntry","gmi_cntry","cntry_name","sovereign","pop_cntry","curr_type","curr_code","landlocked","color_map","sovereign_","area__14","len","the_geom") VALUES ('950.606','302.750','90.000000000','90.000000000','CH','CHN','China','China','1281396894.0000','Renminbi Yuan','CNY','N','2','China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
INSERT INTO "geoserver"."country" ("area","perimeter","cntry_","cntry_id","fips_cntry","gmi_cntry","cntry_name","sovereign","pop_cntry","curr_type","curr_code","landlocked","color_map","sovereign_","area__14","len","the_geom") VALUES ('173.820','69.765','93.000000000','93.000000000','SA','SAU','Saudi Arabia','Saudi Arabia','18099990.0000','Riyal','SAR','N','3','Saudi Arabia','173.820025014','69.765275912','00000000060000000100000000030000000100000007404B8030D306A2B040340125247CB70C404B8030D306A2B04036A66AFCCE1C58404B9221E1D217904036A221D96E9BC0404B997E3D1CC1004036B320B8066C2C404BD542FE8251804035FFEDC7EF177C404BB60ABF76A2F44035447B45F17BD8404B8030D306A2B040340125247CB70C');
INSERT INTO "geoserver"."country" ("area","perimeter","cntry_","cntry_id","fips_cntry","gmi_cntry","cntry_name","sovereign","pop_cntry","curr_type","curr_code","landlocked","color_map","sovereign_","area__14","len","the_geom") VALUES ('19.680','37.558','94.000000000','94.000000000','LA','LAO','Laos','Laos','4722773.0000','Kip','LAK','Y','1','Laos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
INSERT INTO "geoserver"."country" ("area","perimeter","cntry_","cntry_id","fips_cntry","gmi_cntry","cntry_name","sovereign","pop_cntry","curr_type","curr_code","landlocked","color_map","sovereign_","area__14","len","the_geom") VALUES ('278.686','176.490','127.000000000','127.000000000','IN','IND','India','India','894608700.0000','Rupee','INR','N','5','India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
INSERT INTO "geoserver"."country" ("area","perimeter","cntry_","cntry_id","fips_cntry","gmi_cntry","cntry_name","sovereign","pop_cntry","curr_type","curr_code","landlocked","color_map","sovereign_","area__14","len","the_geom") VALUES ('58.120','87.347','135.000000000','135.000000000','BM','MMR','Myanmar (Burma)','Myanmar (Burma)','43099620.0000','Kyat','MMK','N','8','Myanmar (Burma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
INSERT INTO "geoserver"."country" ("area","perimeter","cntry_","cntry_id","fips_cntry","gmi_cntry","cntry_name","sovereign","pop_cntry","curr_type","curr_code","landlocked","color_map","sovereign_","area__14","len","the_geom") VALUES ('27.552','66.828','137.000000000','137.000000000','VM','VNM','Vietnam','Vietnam','71215210.0000','Dong','VND','N','3','Vietnam','27.552036659','66.827655226','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');
INSERT INTO "geoserver"."country" ("area","perimeter","cntry_","cntry_id","fips_cntry","gmi_cntry","cntry_name","sovereign","pop_cntry","curr_type","curr_code","landlocked","color_map","sovereign_","area__14","len","the_geom") VALUES ('15.129','21.994','138.000000000','138.000000000','CB','KHM','Cambodia','Cambodia','9129576.0000','Riel','KHR','N','5','Cambodia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
INSERT INTO "geoserver"."country" ("area","perimeter","cntry_","cntry_id","fips_cntry","gmi_cntry","cntry_name","sovereign","pop_cntry","curr_type","curr_code","landlocked","color_map","sovereign_","area__14","len","the_geom") VALUES ('5.412','13.998','158.000000000','158.000000000','CE','LKA','Sri Lanka','Sri Lanka','18321920.0000','Rupee','LKR','N','7','Sri Lanka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
INSERT INTO "geoserver"."country" ("area","perimeter","cntry_","cntry_id","fips_cntry","gmi_cntry","cntry_name","sovereign","pop_cntry","curr_type","curr_code","landlocked","color_map","sovereign_","area__14","len","the_geom") VALUES ('43.140','65.463','159.000000000','159.000000000','TH','THA','Thailand','Thailand','57323780.0000','Baht','THB','N','4','Thailand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
INSERT INTO "geoserver"."country" ("area","perimeter","cntry_","cntry_id","fips_cntry","gmi_cntry","cntry_name","sovereign","pop_cntry","curr_type","curr_code","landlocked","color_map","sovereign_","area__14","len","the_geom") VALUES ('26.753','60.767','162.000000000','162.000000000','MY','MYS','Malaysia','Malaysia','19626380.0000','Ringgit','MYR','N','6','Malaysia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
INSERT INTO "geoserver"."country" ("area","perimeter","cntry_","cntry_id","fips_cntry","gmi_cntry","cntry_name","sovereign","pop_cntry","curr_type","curr_code","landlocked","color_map","sovereign_","area__14","len","the_geom") VALUES ('0.003','1.129','169.000000000','169.000000000','MV','MDV','Maldives','Maldives','11511.0000','Rufiyaa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
INSERT INTO "geoserver"."country" ("area","perimeter","cntry_","cntry_id","fips_cntry","gmi_cntry","cntry_name","sovereign","pop_cntry","curr_type","curr_code","landlocked","color_map","sovereign_","area__14","len","the_geom") VALUES ('153.002','416.254','183.000000000','183.000000000','ID','IDN','Indonesia','Indonesia','188474200.0000','Rupiah','IDR','N','1','Indonesia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
INSERT INTO "geoserver"."country" ("area","perimeter","cntry_","cntry_id","fips_cntry","gmi_cntry","cntry_name","sovereign","pop_cntry","curr_type","curr_code","landlocked","color_map","sovereign_","area__14","len","the_geom") VALUES ('0.031','1.357','196.000000000','196.000000000','SE','SYC','Seychelles','Seychelles','73000.0000','Rupee','SCR','N','6',NULL,'0.030891742','1.356746799','0000000006000000010000000003000000010000000C404BC428C36DA87CC013281B64E05470404BC31C432CA57CC01325D4E8FB00C0404BC16BFCA85CACC0131ABD1AA821F0404BBD1E7D9988D4C012F6544FE36D20404BB00D801B4354C0128024B33DAF90404BB8FEBD09E12CC0123B73083558A0404BBB607C419A00C01234E831AD2130404BBCCCBC05D52CC0123CDF266BA490404BC4E3608D0890C012A7AE5796BFD0404BC530BE0DED28C012BC4D65E46060404BC483C297BFA4C0130D5E8D541100404BC428C36DA87CC013281B64E05470');
INSERT INTO "geoserver"."country" ("area","perimeter","cntry_","cntry_id","fips_cntry","gmi_cntry","cntry_name","sovereign","pop_cntry","curr_type","curr_code","landlocked","color_map","sovereign_","area__14","len","the_geom") VALUES ('161.770','75.773','246.000000000','246.000000000','IR','IRN','Iran','Iran','64193450.0000','Rial','IRR','N','6','Iran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
END;
