[postgis-users] Error while importing data
Aditya
aditya at grot.org
Fri Jun 3 17:23:10 PDT 2005
On Sat, Jun 04, 2005 at 02:05:25AM +0200, strk at refractions.net wrote:
> On Sat, Jun 04, 2005 at 12:01:02AM +0000, Aditya wrote:
> > On Sat, Jun 04, 2005 at 01:21:01AM +0200, strk at refractions.net wrote:
> > > It sounds as you upgraded postgis in a wrong manner,
> > > can you show the output of SELECT postgis_full_version() ?
> > Hm, that's odd, I didn't upgrade postgis, I did a fresh install...but in any
> Mmm.. are you sure the shp2pgsql application is the one coming with
> postgis 1.0.1 ? Calling it w/out args should tell you the RCSID.
> /usr/local/pgsql/bin/shp2pgsql
RCSID: $Id: shp2pgsql.c,v 1.88.2.1 2005/04/21 09:07:41 strk Exp $
USAGE: /usr/local/pgsql/bin/shp2pgsql [<options>] <shapefile> [<schema>.]<table>
it's what I compiled out of the postgis-1.0.1.tar.gz tarball I downloaded from
postgis.org
Adi
