[postgis-users] Error while importing data
strk at refractions.net
Sun Jun 5 02:32:15 PDT 2005
What encoding does your database have ?
Which architecture are you on ?
--strk;
On Sat, Jun 04, 2005 at 02:48:09AM +0000, Aditya wrote:
> On Sat, Jun 04, 2005 at 02:36:57AM +0200, strk at refractions.net wrote:
> > I downloaded your .sql file and it loads fine here:
> > Postgis version is 1.0.1 installed from official package.
> > Another question: can you send description of your geometry_columns table ?
> Let me know if you want more than this:
> grot=> \d geometry_columns
> Table "public.geometry_columns"
> Column | Type | Modifiers
> f_table_catalog | character varying(256) | not null
> f_table_schema | character varying(256) | not null
> f_table_name | character varying(256) | not null
> f_geometry_column | character varying(256) | not null
> coord_dimension | integer | not null
> srid | integer | not null
> type | character varying(30) | not null
> Indexes:
> "geometry_columns_pk" PRIMARY KEY, btree (f_table_catalog, f_table_schema,
> f_table_name, f_geometry_column)
> grot=> \d geometry_columns_pk
> Index "public.geometry_columns_pk"
> Column | Type
> primary key, btree, for table "public.geometry_columns"
> grot=> select * from geometry_columns ;
> f_table_catalog | f_table_schema | f_table_name | f_geometry_column |
> coord_dimension | srid | type
> (0 rows)
> postgis-users mailing list
