[postgis-users] Finding closest point to a given point
strk at refractions.net
Sun Jun 5 02:35:39 PDT 2005
You can try using a bounding box being an extension of
your input point bbox and growing until it contains
at least another one. Then use distance() on the reduced
set.
With a good amount of fuzzyness you might get a speedup.
Checkout expand and estimated_extent.
--strk;
On Sat, Jun 04, 2005 at 07:31:29PM -0500, Adrian Holovaty wrote:
> Hello,
> I have a point (longitude/latitude), and I want to find the closest point to
> it, from my DB table, that matches given criteria. I tried this (assuming the
> point is (-80, 45)) --
> SELECT the_point
> FROM foo
> WHERE some_criteria='t'
> ORDER BY distance(the_point, GeomFromText('POINT(-80 45)', -1))
> LIMIT 1;
> ...but it's slow, because the database has to calculate the distance to each
> other point in the table and cannot use the index, as pointed out in the
> docs: http://postgis.refractions.net/docs/ch04.html#id3213331
> Following those docs, I added a bounding box to reduce the number of distance
> calculations required.
> SELECT the_point
> FROM foo
> AND the_point && 'BOX3D(-180 -55, 20 145)'::box3d
> LIMIT 1;
> It's faster, but it's still slow because the table has 20,000+ records.
> Note that the point (-80 45) is variable. I can't just create an index on a
> custom function that calculates the distance() to that point.
> Is there a more efficient way to do this, which doesn't involve putting
> distance() in the ORDER BY clause?
> This seems like a FAQ, but I can't find any good solutions in the list
> archives, or on Google. Thanks in advance!
> Adrian
> postgis-users mailing list
