[postgis-users] Re: Error while importing data
strk at refractions.net strk at refractions.net
Mon Jun 6 01:24:44 PDT 2005
On Mon, Jun 06, 2005 at 03:49:27AM +0000, Aditya wrote:
> > On Sun, 5 Jun 2005 11:32:15 +0200, strk at refractions.net said:
> > What encoding does your database have ?  Which architecture are you
> > on ?  --strk;
> ah ha! interesting questions that I thought you'd ask when you saw my previous email :-)
> running on FreeBSD-CURRENT on sparc 64bit and encoding is the default, SQL_ASCII
> grot=> select version();
>                                               version
>  PostgreSQL 8.0.3 on sparc64-unknown-freebsd6.0, compiled by GCC gcc (GCC) 3.4.2 [FreeBSD] 20040728
> (1 row)
Mmm.. it might be the 64bit part... does compilation give you
any warning ? Are you able to send a backtrace with gdb ?
--strk;
