[postgis-users] Intersection errors
Paul Ramsey
pramsey at refractions.net
Tue Jun 7 11:07:39 PDT 2005
Just because you can scanline fill a geometry does not make it valid :)
Check my previous email. You have all the information in AV3, you just
need to write it out correctly and everything will be pluperfect.
P
Sean M. Montague wrote:
> I take it back. It does work. When I export to SVG, I set
> fill-rule="evenodd", and the hole appears.
> -----Original Message-----
> From: postgis-users-bounces at postgis.refractions.net
> [mailto:postgis-users-bounces at postgis.refractions.net] On Behalf Of Sean
> M. Montague
> Sent: Tuesday, June 07, 2005 11:46 AM
> To: PostGIS Users Discussion
> Subject: RE: [postgis-users] Intersection errors
> I just tested it, it does not work. Very interesting. This explains a
> lot. Is there not a way to cut holes in polygons?
> M. Montague
> Sent: Tuesday, June 07, 2005 11:41 AM
> It's a hole. It should be valid...I think. What about islands in a
> lake? The only time I have a problem with them is when I intersect one.
> [mailto:postgis-users-bounces at postgis.refractions.net] On Behalf Of Paul
> Ramsey
> Sent: Tuesday, June 07, 2005 11:35 AM
> Subject: Re: [postgis-users] Intersection errors
> It's not valid, because legal multipolygons do not have parts that
> interact. Your multipolygon has two parts and one is completely
> contained in the other. No cookie for you!
> Paul
> postgis-users mailing list
