[postgis-users] Intersection errors
Carl Anderson
carl.anderson at vadose.org
Wed Jun 8 18:30:22 PDT 2005
Markus Schaber wrote:
>Hi, Ethan,
>Ethan Alpert wrote:
>>While we're on the topic of multipolygons. I've noticed that the
>>shapefile specification doesn't have any convention for communicating
>>outer and inner rings. That said how do apps like shp2pgsql and ogr2ogr
>>determine whether the next polygon in a list is an inner or a new outer?
>If you need a really stable algorithm, current JTS releases contain a
>polygonize function that converts arbitrary linework into polygons. This
>should work without any dependencies on ring order or clockwise
>ordinates, but I suspect this to be rather inefficient.
>Markus
Alternatively, the treatment of shapefile polygons the same as the
accumulated symdifference of each ring.
look at ESRI's handling of polygons which have parts that cross each
other for how that works.
If you can cast each ring to a PostGIS polygon you can use the
symdifference function to assemble all the parts.
It's still relatively expensive, but not as expensive as the polgonize
function.
(expressed in no particular language)
mp = part[1]
i = 2
while ( i < nparts) loop
mp = symdifference(mp, part[i]);
end loop
C.
>_______________________________________________
>postgis-users mailing list
>postgis-users at postgis.refractions.net
>http://postgis.refractions.net/mailman/listinfo/postgis-users
