[postgis-users] Return Value of SnapToGrid Function
strk at refractions.net
Thu Jun 9 08:23:30 PDT 2005
On Thu, Jun 09, 2005 at 04:02:09PM +0200, Dam wrote:
> Thanks but, i still have one problem :
> ~/> pgsql2shp -f base -u postgres -h cli57pl -P turing
> -g column_name base_name table_name
> Initializing... Done.
> Dumping: XMalformed WKB
> Does it mean that my function pgsql2shp is not up to
> date ? Or should i add a few flags ?
Run pgsql2shp to find out RCSID, so you're sure you are
using a version compatible with your database.
Also check output of postgis_full_version();
--strk;
