AW: [postgis-users] PostGis to ArcCatalog
Uwe Seher
useher at web.de
Fri Jun 10 04:03:04 PDT 2005
So this means, i have to install 1.0 ;)
If i right understad, i can do asbinary() twice to get a binary output of
the geometry?
uwe
> -----Ursprungliche Nachricht-----
> Von: postgis-users-bounces at postgis.refractions.net
> [mailto:postgis-users-bounces at postgis.refractions.net]Im Auftrag von
> strk at refractions.net
> Gesendet: Freitag, 10. Juni 2005 11:22
> An: PostGIS Users Discussion
> Betreff: Re: [postgis-users] PostGis to ArcCatalog
> Postgis 0.x did no have a binary output function defined
> for the geometry type, but the asbinary() function returned
> a WKB type which had a binary output function (when compiled
> against postgresql > 7.3).
> --strk;
> On Fri, Jun 10, 2005 at 10:16:19AM +0200, Uwe Seher wrote:
> > Hello!
> > The output is:
> > SELECT version();
> > PostgreSQL 8.0.2 on i686-pc-mingw32, compiled by GCC gcc.exe (GCC) 3.4.2
> > (mingw-special)
> > SELECT postgis_full_version();
> > POSTGIS="0.9.1" GEOS="2.1.1" PROJ="Rel. 4.4.9, 29 Oct 2004" USE_STATS
> > DBPROC="0.0.1" RELPROC="0.0.1"
> > uwe
> > > Gesendet: Donnerstag, 9. Juni 2005 17:56
> > > On Thu, Jun 09, 2005 at 05:41:18PM +0200, Uwe Seher wrote:
> > > > Hello!
> > > > Yes i am using PostGIS 1.0 with the last postgres on Win2000.
> > > > The asbinary()function delivers this error from PgOleDb-driver,
> > > also with no
> > > > conversion.
> > > > PgOleDb: Error: no binary output function available for
> type geometry
> > > Can you send output of:
> > > SELECT version();
> > > --strk;
> > > _______________________________________________
> > > postgis-users mailing list
> > > postgis-users at postgis.refractions.net
> > > http://postgis.refractions.net/mailman/listinfo/postgis-users
> > ____________
> > Virus checked by G DATA AntiVirusKit
____________
