[postgis-users] runtime problems on Solaris
strk at refractions.net
Tue Jun 14 15:01:01 PDT 2005
On Tue, Jun 14, 2005 at 10:37:20AM -0700, James Marca wrote:
> At approximately Tue, Jun 14, 2005 at 11:04:05AM +0200, strk at refractions.net wrote:
> > mmm... does the trace stop there ?
> > Can you try a backtrace from gdb ?
> We will try. My sysadmin was having trouble getting gdb to connect to
> the postgresql process to trace the session. Is there anyway to
> run the postgis code *without* using postgresql?
No way, you need postgres.
What I do is:
# pg_ctl stop
# gdb postgres
gdb> run test.sql
--strk;
