[postgis-users] Problem file.map to Postgis
Levert Donovan dono78fr at yahoo.fr
Thu Jun 16 01:05:55 PDT 2005
Hello
Problem Resolved.
> Try just changing to lowercase and see if it works.
I changed "FROM" to "from", and this works fine !!!!
Thank you, I lost much time for a so simple promblem
Best Regards,
Donovan LEVERT
--- Andre Cruvinel Resende
<andrecruvinel at yahoo.com.br> a écrit :
> Hello Levert,
> I have problems when was using the word "FROM" in
> uppercase.
> You can see something about here:
http://mapserver.gis.umn.edu/cgi-bin/wiki.pl?QueryError
> By..
> André Cruvinel
> --- Levert Donovan <dono78fr at yahoo.fr> escreveu:
> > Hello,
> > I am newbie with Postgis, I use the tutorial
> example
> > Gmap-demo  from FGS(Maptools) and I would like to
> link
> > a .map file with the Postgis database, but I have
> many
> > problems.
> > This is a part of file gmap75.map to a Postgis
> > connection :
> > LAYER
> >   NAME popplace
> >   METADATA
> >     "DESCRIPTION"   "Cities"
> >     "RESULT_FIELDS" "NAME"
> >   END
> >   TYPE POINT
> >   STATUS ON
> >   DATA "the_geom FROM popplace"
> >   CONNECTIONTYPE POSTGIS
> >   CONNECTION "user=x password=x dbname=mapcanada
> > host=192.168.20.200 port=5432"
> >   LabelItem "Name"
> >   CLASSITEM "Capital"
> >   CLASS
> >     EXPRESSION "1"
> >     TEMPLATE "ttt_query.html"
> >     SYMBOL 2
> >     SIZE 8 .....
> > The connection to database doesn't works, I
> activated
> > verbose logs, and I see a bad format for the text,
> > this is the error log :
> > DEBUG:  StartTransactionCommand
> > LOG:  statement: DECLARE mycursor BINARY CURSOR
> FOR
> > SELECT
Capital::text,Name::text,asbinary(force_collection(force_2d(ä¶J@ä¶J@)),'NDR'),OID::text
> > from ì¶J@ì¶J@ WHERE ä¶J@ä¶J@ &&
> > setSRID('BOX3D(-2598687.33333333
> > -712631,3471487.33333333 3840000)'::BOX3D,
> > find_srid('','ì¶J@ì¶J@','ä¶J@ä¶J@') )
> > ERROR:  syntax error at or near "@" at character
> 139
> > Do you know
> > Best Regards,
> > LEVERT Donovan
___________________________________________________________________________
> > Appel audio GRATUIT partout dans le monde avec le
> nouveau
> > Yahoo! Messenger
> > Téléchargez cette version sur
> > http://fr.messenger.yahoo.com
> > postgis-users mailing list
> > postgis-users at postgis.refractions.net
http://postgis.refractions.net/mailman/listinfo/postgis-users
> Yahoo! Acesso Grátis - Internet rápida e grátis.
> Instale o discador agora!
> http://br.acesso.yahoo.com/
Appel audio GRATUIT partout dans le monde avec le nouveau Yahoo! Messenger
Téléchargez cette version sur http://fr.messenger.yahoo.com
