[postgis-users] update Geometry_columns
strk at refractions.net
Thu Jun 16 01:31:59 PDT 2005
probe_geometry_columns() works by reading constraints, and
expects these constraints to have a given naming convention.
This is what happen when AddGeometryColumn() is invoked.
When you need to move data from a table to another
you have to make AddGeometryColumn() part of your flow,
or manually add entries in the geometry_columns table,
or - finally - set up constraints named as the ones created
by AddGeometryColumn() and invoke probe_geometry_column().
--strk;
