[postgis-users] update Geometry_columns
strk at refractions.net
Thu Jun 16 10:59:34 PDT 2005
On Thu, Jun 16, 2005 at 01:07:16PM -0400, Mark Fenbers wrote:
> By "constraints" do you mean that it can be any type constraint, such as
> a foreign-key constraint? Or does it have to be a unique identifier
> constraint? If so, I can ALTER TABLE ADD COLUMN and add such a
> constraint, but I don't know what to use for the naming convention used
> by AddGeometryColumns() and probe_geometry_columns() that you speak
> of... Can you help me out. please?
I mean the constraints that AddGeometryColumn() add on the tables
"santified" as Features Tables.
Suppose your geometry column is is named 'geom3', constraints are:
"enforce_srid_geom3" CHECK (srid(geom3) = -1)
"enforce_dims_geom3" CHECK (ndims(geom3) = 3)
"enforce_geotype_geom3" CHECK (geometrytype(geom3) = 'POINT'::text OR geom3 IS NULL)
You can use \d against one of your "working" Feature Tables to see
this yourself.
It's not a practical path, really. You should avoid to
create new tables bypassing the AddGeometryColumn() step,
generally speaking.
--strk;
> strk at refractions.net wrote:
> >probe_geometry_columns() works by reading constraints, and
> >expects these constraints to have a given naming convention.
> >This is what happen when AddGeometryColumn() is invoked.
> >When you need to move data from a table to another
> >you have to make AddGeometryColumn() part of your flow,
> >or manually add entries in the geometry_columns table,
> >or - finally - set up constraints named as the ones created
> >by AddGeometryColumn() and invoke probe_geometry_column().
> >--strk;
> >_______________________________________________
> >postgis-users mailing list
> >postgis-users at postgis.refractions.net
> >http://postgis.refractions.net/mailman/listinfo/postgis-users
