AW: [postgis-users] compiling-problem under linux
Uwe Seher
uwe.seher at arteng.de
Fri Jun 17 07:55:52 PDT 2005
Thank you all! Great group here!
It works now!
CU Uwe
> -----Ursprüngliche Nachricht-----
> Von: postgis-users-bounces at postgis.refractions.net
> [mailto:postgis-users-bounces at postgis.refractions.net]Im Auftrag von R.
> Müller
> Gesendet: Freitag, 17. Juni 2005 15:41
> An: PostGIS Users Discussion
> Betreff: Re: [postgis-users] compiling-problem under linux
> hallo Uwe,
> you have to run the ./configure skript from sources of your postgres
> installation. this skript creates the missing file 'makefile.global' .
> if you have only a binary-installation of postgres, then download the
> sources and run configure manually.
> in the makefile.config of postgis you have to point to root path of your
> postgres-source dir.
> ronald
> Uwe Seher wrote:
> > Hello!
> > i am triing to setup a geodatabase with postgis on a
> linuxserver (suse 9.2).
> > I am using postgresql 8.0.1. from a rpm.
> > When i try to compile postgis appear these messages in the shell:
> xxxxxx:/usr/src/packages/SOURCES/postgresql-8.0.1/contrib/postgis-1.0.1 #
> > make
> > make -C lwgeom
> > make[1]: Entering directory
> `/usr/src/packages/SOURCES/postgresql-8.0.1/contrib/postgis-1.0.1/lwgeom'
> > ../Makefile.config:98:
> /usr/src/packages/SOURCES/postgresql/postgresql-8.0.1/src/Makefile.global:
> > No such file or directory
> > Makefile:110: /src/Makefile.shlib: No such file or directory
> > make[1]: *** No rule to make target `/src/Makefile.shlib'. Stop.
> > make[1]: Leaving directory
> > make: *** [liblwgeom] Error 2
> > the requested file makefile.global doesnt exist.
> > Can someone help with this?
> > Thank you
> > Uwe Seher
> > ____________
> > Virus checked by G DATA AntiVirusKit
> > postgis-users mailing list
> > postgis-users at postgis.refractions.net
> > http://postgis.refractions.net/mailman/listinfo/postgis-users
____________
