[postgis-users] envelope
Mark Cave-Ayland m.cave-ayland at webbased.co.uk
Mon Jun 20 08:42:20 PDT 2005
What version of PostgreSQL are you using? Also can you show us the complete
function including the CREATE FUNCTION line?
Kind regards,
Mark.
WebBased Ltd
17 Research Way
Tamar Science Park
Plymouth
PL6 8BT
T: +44 (0)1752 797131
F: +44 (0)1752 791023
W: http://www.webbased.co.uk <http://www.webbased.co.uk/>
-----Original Message-----
From: postgis-users-bounces at postgis.refractions.net
[mailto:postgis-users-bounces at postgis.refractions.net] On Behalf Of
rsosnowski at cableone.net
Sent: 17 June 2005 22:54
To: postgis-users at postgis.refractions.net
Cc: rsosnowski at cableone.net
Subject: [postgis-users] envelope
Hello all,
Trying to write a stored procedure that returns the envelope.
Code follows:
  sSQLExp:= 'SELECT the_geom FROM ' || quote_ident(stable) || ' WHERE ' ||
quote_ident(sfield) || ' = ' || quote_literal(svalue);
  RAISE NOTICE 'sSQLExp = %', sSQLExp;
  OPEN pTempCursor FOR EXECUTE sSQLExp;
  LOOP
  FETCH pTempCursor INTO pFeatureGeometry;
  EXIT WHEN NOT FOUND;
      sSQL:= 'SELECT envelope(' || sSQLExp || ') FROM ' ||
quote_ident(stable);
      RAISE NOTICE 'sSQL = %', sSQL;
    OPEN pCursor FOR EXECUTE sSQL;
    LOOP
      FETCH pCursor INTO pBoundBox;
   END LOOP;
 END LOOP;
 CLOSE pCursor;
 CLOSE pTempCursor;
THE SECOND NOTICE STATEMENT SHOWS:
sSQL = SELECT envelope(SELECT the_geom FROM subdiv WHERE subdivname =
'HIGHLANDER ESTATES') FROM subdiv
GET THE FOLLOWING ERROR:
SYNTAX ERROR AT OR NEAR "SELECT" AT CHARACTER 17; POINTS TO THE 'S' IN THE
SECOND SELECT STATEMENT.
    SELECT ENVELOPE(SELECT.....
ANY IDEAS????
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20050620/3bf06716/attachment.html>
