[postgis-users] query on polygon type column
Stephen Woodbridge
woodbri at swoodbridge.com
Thu Jun 23 08:24:05 PDT 2005
strk at refractions.net wrote:
> On Thu, Jun 23, 2005 at 05:13:15PM +0300, orkun wrote:
>>hello
>>say I have geodatabase which has been created in postgresql and in
>>following
>>structure:
>>(cat int, pol polygon)
>>cat | pol
>> 1 | ((35.50456,37.59156),(35.84032,37.91965),(35.78211,37.8825))
>> 2 | ((45.50456,47.59156),(45.84032,47.91965),(45.78211,47.8825))
>>how can I query this table on pol column something like
>>select * from table where pol_val contains '45.50456,47.59156'
>>How is using regular exp possible on pol ?
> This has nothing to do with postgis.
> Polygon is a core postgresql object.
> Using Geometry, which is a postgis type, you can use
> the contains() function for your kind of test.
> --strk;
Can a Polygon be cast or converted into a Geometry? If so then
contains() would work.
-Steve
