[postgis-users] R-TREE
strk at refractions.net
Tue Jun 28 04:14:43 PDT 2005
On Tue, Jun 28, 2005 at 12:00:38PM +0100, Luksana Sridawong wrote:
> hello all,
> Can I create index by using rtree?
> now I create index by using gist and run vacuum analyze but map stil slow ,Well I thing if I create index by using rtree maybe it make my map fast more.I am not sure PostGIS support rtree or not?
> thank you forword.
Index used by postgis IS an rtree implemented using GiST.
Check 'explain analyze' output to see whether the index
is used or not.
--strk;
