RES: [postgis-users] changing SRID?
Gustavo Henrique Sberze Ribas gribas at cpqd.com.br
Tue Jun 28 06:08:29 PDT 2005
Hallo,
  If the SRID 31497 from 0.8 is equivalent to SRID 31467 in 1.0
then you could just replace the old SRID in the dump file with
the new one.
  If it's a new system, you could restore your data to a
temporary table and use something like
   INSERT INTO new_table(id,...,geom)
     SELECT
        id,
        transform(geom,31467)
     FROM temp_table;
Gruß,
Gustavo
> -----Mensagem original-----
> De: postgis-users-bounces at postgis.refractions.net
> [mailto:postgis-users-bounces at postgis.refractions.net]Em nome de Achim
> Weßling
> Enviada em: terça-feira, 28 de junho de 2005 10:42
> Para: PostGIS Users Discussion
> Assunto: [postgis-users] changing SRID?
> Hallo,
> I have one older postgis install with version 0.8 (Postgre 7.4) and a
> newer one with version 1.0 (Postgre 8.0).
> Under postgis 0.8 I used SRID 31497, on postgis 1.0 I use SRID 31467.
> Now I have to migrate the data from the older installation to
> the newer
> one. Can someone give any hints? Espacially for the migration of the
> SRID?
> Thanks!
> Achim Weßling
> INFOKOM Gütersloh AöR
> Fachbereich II - Technische Anwendungen
> Herzebrocker Str. 140
> 33334 Gütersloh
> Tel.: 05241/85-2926
> Achim.Wessling at gt-net.de
> http://www.infokom-gt.de
> postgis-users mailing list
