[postgis-users] PostGIS/Mapserver Mapfile Question
Mark Cave-Ayland
m.cave-ayland at webbased.co.uk
Tue Jun 28 10:02:57 PDT 2005
> -----Original Message-----
> From: postgis-users-bounces at postgis.refractions.net
> [mailto:postgis-users-bounces at postgis.refractions.net] On
> Behalf Of Stephen Woodbridge
> Sent: 28 June 2005 17:52
> To: PostGIS Users Discussion
> Subject: Re: [postgis-users] PostGIS/Mapserver Mapfile Question
> Hi Mark,
> I created the table from a version 0.9 backup that I restored to the
> version 1.0 database. This might be the problem. So I guess
> the question
> is can it be fixed, or do I need to drop the table and reload it from
> the shapefile. Also, I think the table was orginially loaded
> on 0.9 with
> SRID=-1, but all my tables on 1.0 have a valid SRID set, so
> maybe this
> table is hopelessy mangled.
> And I get the same error if I run the query in psql.
> -Steve
Hi Steve,
Try something like:
BEGIN;
CREATE TABLE old_geometry_columns WITH OIDS AS SELECT * FROM
geometry_columns;
SELECT probe_geometry_columns();
COMMIT;
This should look through all your tables for columns of type geometry and
insert the relevant entries back into geometry_columns.
Kind regards,
Mark.
WebBased Ltd
17 Research Way
Tamar Science Park
Plymouth
PL6 8BT
T: +44 (0)1752 797131
F: +44 (0)1752 791023
W: http://www.webbased.co.uk
