[postgis-users] PostGIS/Mapserver Mapfile Question
Stephen Woodbridge woodbri at swoodbridge.com
Tue Jun 28 10:21:54 PDT 2005
OK, it looks like there are no entries in the geometry_columns table.
The zcta table is the only one that currently has a geometry column.
When I did the backup/restore, I did not save the geometry_columns table
it there and easy way to regenerate this?
-Steve
Mark Cave-Ayland wrote:
>  > -----Original Message-----
>>From: postgis-users-bounces at postgis.refractions.net
>>[mailto:postgis-users-bounces at postgis.refractions.net] On
>>Behalf Of Stephen Woodbridge
>>Sent: 28 June 2005 17:52
>>To: PostGIS Users Discussion
>>Subject: Re: [postgis-users] PostGIS/Mapserver Mapfile Question
>>Hi Mark,
>>I created the table from a version 0.9 backup that I restored to the
>>version 1.0 database. This might be the problem. So I guess
>>the question
>>is can it be fixed, or do I need to drop the table and reload it from
>>the shapefile. Also, I think the table was orginially loaded
>>on 0.9 with
>>SRID=-1, but all my tables on 1.0 have a valid SRID set, so
>>maybe this
>>table is hopelessy mangled.
>>And I get the same error if I run the query in psql.
>>-Steve
> Hi Steve,
> Try something like:
> 	BEGIN;
> 	CREATE TABLE old_geometry_columns WITH OIDS AS SELECT * FROM
> geometry_columns;
> 	SELECT probe_geometry_columns();
> 	COMMIT;
> This should look through all your tables for columns of type geometry and
> insert the relevant entries back into geometry_columns.
> Kind regards,
> Mark.
> WebBased Ltd
> 17 Research Way
> Tamar Science Park
> Plymouth
> PL6 8BT
> T: +44 (0)1752 797131
> F: +44 (0)1752 791023
> W: http://www.webbased.co.uk
> postgis-users mailing list
