[postgis-users] PostGIS/Mapserver Mapfile Question
Stephen Woodbridge
woodbri at swoodbridge.com
Tue Jun 28 11:03:06 PDT 2005
Mark,
Awesome, that worked great.
So, what is the "correct" procedure if you want to move a table with
geometry from database to another. Obviously, backup/restore does not do
the "whole" thing.
-Steve
Mark Cave-Ayland wrote:
>>-----Original Message-----
>>From: postgis-users-bounces at postgis.refractions.net
>>[mailto:postgis-users-bounces at postgis.refractions.net] On
>>Behalf Of Stephen Woodbridge
>>Sent: 28 June 2005 18:22
>>To: PostGIS Users Discussion
>>Subject: Re: [postgis-users] PostGIS/Mapserver Mapfile Question
>>OK, it looks like there are no entries in the geometry_columns table.
>>The zcta table is the only one that currently has a geometry column.
>>When I did the backup/restore, I did not save the
>>it there and easy way to regenerate this?
>>-Steve
> Hi Steve,
> Sorry if it wasn't clear; the SQL given before should do that job for you.
> The corrected version is:
> BEGIN;
> CREATE TABLE old_geometry_columns WITH OIDS AS SELECT * FROM
> geometry_columns;
> DELETE FROM geometry_columns;
> SELECT probe_geometry_columns();
> COMMIT;
> You can probably delete the old_geometry_columns table once you're done,
> especially as in your case it was empty to begin with :)
> Kind regards,
> Mark.
> WebBased Ltd
> 17 Research Way
> Tamar Science Park
> Plymouth
> PL6 8BT
> T: +44 (0)1752 797131
> F: +44 (0)1752 791023
> W: http://www.webbased.co.uk
> postgis-users mailing list
