[postgis-users] Help needed installing Postgis 1.0 RC3
strk at refractions.net strk at refractions.net
Tue Mar 1 09:48:37 PST 2005
Brent, should be fixed in CVS.
Problems is that postgresql source is defining YACC to the empty
string.
(Did you configure youre postgresql source tree ?)
--strk;
On Tue, Mar 01, 2005 at 09:36:32AM -0800, Brent Wood wrote:
> > Hi, Brent,
> > I'm shure that this list is a good place for discussing such, but maybe
> > postgis-devel at postgis.refractions.net is an alternative.
> To save me subscribing to (yet) another list.... here we go...
> make output...
> <snip>
> Plwg_parse_yy -i -f -o'lex.yy.c' wktparse.lex
> make[1]: Plwg_parse_yy: Command not found
> make[1]: [lex.yy.c] Error 127 (ignored)
> gcc -O2 -Wall -Wmissing-prototypes -Wpointer-arith -Wendif-labels
> -fno-strict-aliasing -g -fexceptions -fPIC -DUSE_VERSION=80
> -DPOSTGIS_LIB_VERSION='"1.0.0RC3"' -DPOSTGIS_SCRIPTS_VERSION='"0.2.0"'
> -DPOSTGIS_BUILD_DATE='"2005-03-01 17:43:49"' -I/usr/local/include
> -DAUTOCACHE_BBOX=1  -DUSE_STATS -fpic
> -I/home/baw/postgresql-8.0.1/contrib/postgis-1.0.0-rc3/../../src/include
> -D_GNU_SOURCE   -c -o lex.yy.o lex.yy.c
> gcc: lex.yy.c: No such file or directory
> gcc: no input files
> make[1]: *** [lex.yy.o] Error 1
> make[1]: Leaving directory
> `/home/baw/postgresql-8.0.1/contrib/postgis-1.0.0-rc3/lwgeom'
> make: *** [liblwgeom] Error 2
> The lex.yy.c(&o)  files are not there after I untar the Postgis file. They are
> present in the 0.9.1 file. The contents of the 1.0RC3/lwgeom directory are:
> BBOXCACHE_BEHAVIOURS         lwgeom.h            Makefile
> box2d.c                      lwgeom_inout.c      measures.c
> box2d.o                      lwgeom.o            measures.o
> compat.h                     lwgeom_ogc.c        MISSING_OBJECTS
> liblwgeom.c                  lwgeom_pg.c         pgsql_compat.h
> liblwgeom.h                  lwgeom_pg.h         profile.h
> lwcollection.c               lwgeom_spheroid.c   ptarray.c
> lwcollection.o               lwgeom_svg.c        ptarray.o
> lwgeom_api.c                 lwgeom_transform.c  README
> lwgeom_api.o                 lwgeom_triggers.c   stringBuffer.c
> lwgeom_box2dfloat4.c         lwgparse.c          stringBuffer.h
> lwgeom_box3d.c               lwgparse.o          test.c
> lwgeom_box.c                 lwline.c            TODO
> lwgeom_btree.c               lwline.o            vsprintf.c
> lwgeom.c                     lwmline.c           wktparse.h
> lwgeom_chip.c                lwmline.o           wktparse.lex
> lwgeom_debug.c               lwmpoint.c          wktparse.tab.c
> lwgeom_dump.c                lwmpoint.o          wktparse.tab.h
> lwgeom_estimate.c            lwmpoly.c           wktparse.tab.o
> lwgeom_functions_analytic.c  lwmpoly.o           wktparse.y
> lwgeom_functions_basic.c     lwpoint.c           wktunparse.c
> lwgeom_geos.c                lwpoint.o           wktunparse.o
> lwgeom_geos_wrapper.cpp      lwpoly.c            y.output
> lwgeom_gist.c                lwpoly.o
> lwgeom_gml.c                 lwpostgis.sql.in
> Thanks,
> Brent Wood
> postgis-users mailing list
