[postgis-users] collect(geom) in rc3?
Mark Cave-Ayland
m.cave-ayland at webbased.co.uk
Fri Mar 4 02:23:14 PST 2005
> -----Original Message-----
> From: postgis-users-bounces at postgis.refractions.net
> [mailto:postgis-users-bounces at postgis.refractions.net] On
> Behalf Of Mark Cave-Ayland
> Sent: 04 March 2005 09:14
> To: strk at refractions.net; 'PostGIS Users Discussion'
> Subject: RE: [postgis-users] collect(geom) in rc3?
(cut)
> Yes, I can reproduce the crash by doing a simple 'select
> collect(the_geom) from geom_table' under Win32 while the same
> query works fine under Linux with RC3. Will try and get a
> backtrace from gdb....
Hi strk,
Here is the backtrace from the crashing 'select collect(the_geom) from
geom_table'. Is this your segfault fix in geom_accum()?
Program received signal SIGSEGV, Segmentation fault.
[Switching to thread 700.0x238]
0x0060623c in pfree (pointer=0x191b9d8) at mcxt.c:583
583 (*header->context->methods->free_p) (header->context,
pointer);
(gdb) bt
#0 0x0060623c in pfree (pointer=0x191b9d8) at mcxt.c:583
#1 0x6082b474 in LWGEOM_accum (fcinfo=0x105eec0)
at lwgeom_functions_basic.c:1769
#2 0x004f437e in advance_transition_function (aggstate=0x1919d38,
peraggstate=0x191b540, pergroupstate=0x191b5c8, newVal=26327512,
isNull=0 '\0') at nodeAgg.c:377
#3 0x004f44e6 in advance_aggregates (aggstate=0x1919d38,
pergroup=0x191b5c8)
at nodeAgg.c:439
#4 0x004f4ac7 in agg_retrieve_direct (aggstate=0x1919d38) at nodeAgg.c:778
#5 0x004ec06b in ExecProcNode (node=0x1919d38) at execProcnode.c:353
#6 0x004ea88e in ExecutePlan (estate=0x1919c10, planstate=0x1919d38,
operation=CMD_SELECT, numberTuples=0, direction=ForwardScanDirection,
dest=0x18b87c0) at execMain.c:1060
#7 0x004e9c89 in ExecutorRun (queryDesc=0x1910c30,
direction=ForwardScanDirection, count=0) at execMain.c:226
#8 0x00572ae6 in PortalRunSelect (portal=0x19115c8, forward=1,
count=2147483647, dest=0x18b87c0) at pquery.c:746
#9 0x0057280b in PortalRun (portal=0x19115c8, count=2147483647,
dest=0x18b87c0, altdest=0x18b87c0, completionTag=0x105f240 "")
at pquery.c:561
#10 0x0056da93 in exec_simple_query (
query_string=0x18b80a8 "select collect(the_geom) from tgr12133lka;")
at postgres.c:933
#11 0x0057144a in PostgresMain (argc=4, argv=0x2241f0,
username=0x224118 "postgres") at postgres.c:3007
#12 0x00541a79 in BackendRun (port=0x105fc30) at postmaster.c:2816
#13 0x005428bf in SubPostmasterMain (argc=3, argv=0x222548)
at postmaster.c:3214
#14 0x0050754d in main (argc=3, argv=0x222548) at main.c:278
(gdb)
Kind regards,
Mark.
WebBased Ltd
South West Technology Centre
Tamar Science Park
Plymouth
PL6 8BT
T: +44 (0)1752 791021
F: +44 (0)1752 791023
W: http://www.webbased.co.uk
