[postgis-users] Odd explain analyze estimates?
Ron Mayer
rm_postgis at cheapcomplexdevices.com
Fri Mar 4 03:46:49 PST 2005
I have a query that runs quite quickly using a hash join when run
standalone. When I use this query as a subquery the planner always
seems to pick a differnt plan with an order of magnitude worse
performance.
This bad plan is chosen even when the outer sql statement is
a trivial expression like this:
select * from (query) as a;
which I believe should be a no-op.
If I'm reading the "explain analyze" output correctly; it seems that
depending on the context; in one case the optimizer thinks the
comparison on GEOMETRIES will be extremely selective (returning 1 row)
while in the other case it think it will be quite unselective (returning
15000+ rows). I'm pretty sure that the two expressions are identical,
though, and can't guess why the estimates vary so drastically. Am I
reading that explain analyze output correctly? Or am I doing something
else wrong? Thanks.
Explain analyze output follows.
Thanks,
Ron
fli=# explain analyze SELECT * from (select * from userfeatures.points join icons using (iconid) where the_geom && setSRID('BOX3D(-123.40 25.66,-97.87 43.17)'::BOX3D, -1 )) as upf ;
QUERY PLAN
Nested Loop (cost=0.00..446.42 rows=1 width=120) (actual time=-0.096..7928.546 rows=15743 loops=1)
Join Filter: ("outer".iconid = "inner".iconid)
-> Seq Scan on points (cost=0.00..444.43 rows=1 width=82) (actual time=0.096..132.255 rows=15743 loops=1)
Filter: (the_geom && '010300000001000000050000009A99999999D95EC0295C8FC2F5A839409A99999999D95EC0F6285C8FC295454048E17A14AE7758C0F6285C8FC295454048E17A14AE7758C0295C8FC2F5A839409A99999999D95EC0295C8FC2F5A83940'::geometry)
-> Seq Scan on icons (cost=0.00..1.44 rows=44 width=42) (actual time=0.006..0.242 rows=44 loops=15743)
Total runtime: 8005.766 ms
(6 rows)
fli=# explain analyze select * from userfeatures.points join icons using (iconid) where the_geom && setSRID('BOX3D(-123.40 25.66,-97.87 43.17)'::BOX3D, -1 );
QUERY PLAN
Hash Join (cost=1.55..682.84 rows=15789 width=120) (actual time=0.641..320.002 rows=15743 loops=1)
Hash Cond: ("outer".iconid = "inner".iconid)
-> Seq Scan on points (cost=0.00..444.43 rows=15794 width=82) (actual time=0.067..94.307 rows=15743 loops=1)
-> Hash (cost=1.44..1.44 rows=44 width=42) (actual time=0.530..0.530 rows=0 loops=1)
-> Seq Scan on icons (cost=0.00..1.44 rows=44 width=42) (actual time=0.026..0.287 rows=44 loops=1)
Total runtime: 397.003 ms
(7 rows)
