[postgis-users] Ready for 1.0.0 ?
Fernão Lopes
fernao at gmail.com
Sat Mar 5 09:05:04 PST 2005
Hi!
I've received the following results:
fernao:/usr/local/pgsql/lib# ldd liblwgeom.so
libstdc++.so.5 => /usr/lib/libstdc++.so.5 (0x40059000)
libgeos.so.2 => /usr/lib/libgeos.so.2 (0x40114000)
libproj.so.0 => /usr/lib/libproj.so.0 (0x401f2000)
libgcc_s.so.1 => /lib/libgcc_s.so.1 (0x40227000)
libc.so.6 => /lib/tls/libc.so.6 (0x40230000)
libm.so.6 => /lib/tls/libm.so.6 (0x40364000)
/lib/ld-linux.so.2 => /lib/ld-linux.so.2 (0x80000000)
Fernão
On Fri, 4 Mar 2005 17:17:29 +0100, strk at refractions.net
<strk at refractions.net> wrote:
> Can you verify your liblwgeom.so dynamically links to the
> correct GEOS library ? On a linux system this is done
> with "ldd liblwgeom.so".
> --strk;
> On Fri, Mar 04, 2005 at 12:53:03PM -0300, Fernão Lopes wrote:
> > Ah, and here is the postgis_geos_version.h
> > #ifndef GEOS_FIRST_INTERFACE
> > #define GEOS_FIRST_INTERFACE 2
> > #endif
> > #ifndef GEOS_LAST_INTERFACE
> > #define GEOS_LAST_INTERFACE 3
> > #endif
> > #ifndef GEOS_VERSION
> > #define GEOS_VERSION "2.1.0"
> > #endif
> > #ifndef GEOS_JTS_PORT
> > #define GEOS_JTS_PORT 1.4.1
> > #endif
> > #define POSTGIS_GEOS_VERSION 201
> > Fernão
> > On Fri, 4 Mar 2005 12:49:05 -0300, Fernão Lopes <fernao at gmail.com> wrote:
> > > The GEOS version is 2.1.0
> > > On Fri, 4 Mar 2005 16:40:27 +0100, strk at refractions.net
> > > > On Fri, Mar 04, 2005 at 12:24:29PM -0300, Fernão Lopes wrote:
> > > > > Yes, I've build GEOS at /usr/local, as specified in Makefile.config.
> > > > > I'll try with another geos installation.
> > > > Wait. It is a bug in postgis if it doesn't work.
> > > > Which GEOS version do you have installed ?
> > > > Does it match content of postgis_geos_version.h ?
> > > > --strk;
> > > > > thanks
> > > > > On Fri, 4 Mar 2005 15:55:12 +0100, strk at refractions.net
> > > > > > On Fri, Mar 04, 2005 at 11:51:16AM -0300, Fernão Lopes wrote:
> > > > > > > Hello!
> > > > > > > I have the 0.9.1 installed and working. I'm using Postgresql 8.0.1 in
> > > > > > > a debian with 2.6.8 686 kernel.
> > > > > > > I've tried to install the 1.0 RC3, but experienced some problems.
> > > > > > > I can read old postgis data and publish it with mapserver; but I can't
> > > > > > > enable new databases using the lwpostgis. I received the following
> > > > > > > error:
> > > > > > > DETAIL: Creating a shell type definition.
> > > > > > > psql:lwpostgis.sql:36: ERROR: could not load library
> > > > > > > "/usr/local/pgsql/lib/liblwgeom.so.1.0":
> > > > > > > /usr/local/pgsql/lib/liblwgeom.so.1.0: undefined symbol:
> > > > > > > _ZN4geos11Polygonizer11getPolygonsEv
> > > > > > > The file is there.
> > > > > > > This message is received when I installed it in a system that already
> > > > > > > had postgis 0.91 installed AND in a new one, with a postgresql 8.0.1
> > > > > > > with no data, from the scratch.
> > > > > > > Any ideas?
> > > > > > It seems you're building with GEOS support but w/out GEOS installed.
> > > > > > Can this be the case ? What is USE_GEOS set to in Makefile.config ?
> > > > > > Do you have an USE_GEOS environmental variable set ?
> > > > > > --strk;
> > > > > > > Thanks,
> > > > > > > Fernão Lopes
> > > > > > > On Fri, 04 Mar 2005 12:00:07 +0100, Markus Schaber <schabi at logix-tt.com> wrote:
> > > > > > > > Hi, Mark,
> > > > > > > > Mark Cave-Ayland schrieb:
> > > > > > > > >>BTW, I successfully compiled postgis using JAVAC="jikes-sun
> > > > > > > > >>-target 1.1" for java 1.1 compatibility. :-)
> > > > > > > > > Yes, the PostGIS JDBC driver compiles fine for me with -target 1.1 under the
> > > > > > > > > Sun JDK. I think we should make this the default :)
> > > > > > > > I think this is a good idea.
> > > > > > > > However, I'm afraid not all of the java compilers around do support
> > > > > > > > -target, so I'm hesitating to put it in the makefile as default, as this
> > > > > > > > could annoy Alex Bodnaru :-)
> > > > > > > > >>You can use "make alltests" to run them, they test both
> > > > > > > > >>client and some server functionality, but you will have to
> > > > > > > > >>set up the database connection info via environment or
> > > > > > > > >>makefile. I think this will be the first Windows tests for
> > > > > > > > >>postgis jdbc :-)
> > > > > > > > > The tests appear to run successfully here for me. I just wanted to check
> > > > > > > > > with you as there seem to be multiple entries along the lines of "Finished,
> > > > > > > > > 0 tests failed" as opposed to a single grand total at the end. I'll email
> > > > > > > > > the JDBC results to you separately as they are quite long, but it's looking
> > > > > > > > > promising :)
> > > > > > > > Yes. The reason for this is that two of the test applications are only
> > > > > > > > slightly adopted versions of Pauls original tests, while the others were
> > > > > > > > derived from our in-house work. Another problem was that, originally,
> > > > > > > > some of the test cases were "allowed" to fail against older PostGIS
> > > > > > > > versions, needing manual re-checking of the output. It was not until
> > > > > > > > recently that I added a check for the postgis version so the test
> > > > > > > > programs know which tests to run, and which are allowed to fail.
> > > > > > > > On my todo list for those tests is to have them output only a small
> > > > > > > > summary, and write everything else into a test log file. Another idea
> > > > > > > > may be using junit or another test framework, but I don't like the idea
> > > > > > > > of adding another dependency.
> > > > > > > > Markus
> > > > > > > > Markus Schaber | Dipl. Informatiker | Software Development GIS
> > > > > > > > Fight against software patents in EU! http://ffii.org/
> > > > > > > > http://nosoftwarepatents.org/
> > > > > > > > _______________________________________________
> > > > > > > > postgis-users mailing list
> > > > > > > > postgis-users at postgis.refractions.net
> > > > > > > > http://postgis.refractions.net/mailman/listinfo/postgis-users
