[postgis-users] Possible bug in postgis RC3 / proj4 with large data sets
Bryce Watkins
bwatkins.lists at ihug.co.nz
Wed Mar 9 02:17:35 PST 2005
Hi folks,
We have a problem when running pgsql2shp on a large dataset via the
following query (as a view):
SELECT crs_street_address.house_number AS house_no,
crs_street_address.status, crs_road_name."type", crs_road_name.name,
crs_road_name."location", transform(translate(crs_street_address.shape,
160::double precision, 0::double precision, 0::double precision), 27200) AS
point
FROM crs_street_address
JOIN crs_road_name ON crs_street_address.rna_id = crs_road_name.id;
QUERY PLAN
Merge Join (cost=0.00..83997.59 rows=1506893 width=86)
Merge Cond: ("outer".id = "inner".rna_id)
-> Index Scan using crs_road_name_id_idx on crs_road_name
(cost=0.00..1854.48 rows=68168 width=51)
-> Index Scan using crs_street_address_rna_id_idx on crs_street_address
(cost=0.00..55602.24 rows=1506893 width=43)
The job runs for quite some time, but eventually will output the following:
Initializing... GeometryType: ERROR: out of memory
DETAIL: Failed on request of size 63.
CONTEXT: SQL function "get_proj4_from_srid" statement 1
PL/pgSQL function "transform" line 2 at return
This is running on FreeBSD 5.3 with 2Gb ram and as I watch memory
utilisation, it is not using any swap at all. So it doesn't appear to be a
traditional memory leak. Also we have other querys that work find on a
smaller number of rows.
Any suggestions appreciated.
Bryce.
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20050309/b35bac31/attachment.html>
